09-29-2018, 10:59 | #61 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
There some guys spread rumors around my method is just "cosmetic" and "not working" , but it is not main moment. Main moment deal with locked devices, security completely fail, if use repair on locked device. | |
09-29-2018, 17:26 | #64 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | There is lot of sw over net, but if you need some exact format - mention it, give example. DAT ( Nokia MTK restorable format ) will be in near version. As well as convert - you can import/edit/export contacts on Nokia MTK phones. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
09-29-2018, 20:07 | #65 (permalink) | |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | Quote:
locked, unlocked, clean - nvram will NOT change. so come on - put OST account in work and issue "imei set" in best2 nk free for best2 users, of course, otherwise it is cheat | |
The Following User Says Thank You to the_laser For This Useful Post: |
10-01-2018, 09:06 | #67 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Hmd Gloabal TA-1017 Format Error Please Add reset usercode option Operation : Reset Settings [ v1.06 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM64) MODE : NOKIA USB SERIAL PORT : 64 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 2D82D652E2DC5EDA4731EA3FB2B4F610 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : KESA61A.10.00.11.p2 AGENT : Look for suitable BootChain in DA ... AGENT : Device AutoID failed! Error : Fail to init protocol! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
10-01-2018, 15:25 | #68 (permalink) | |
Yes, have idea about "deviceinfo" and rest. Sure need change more, as BEST does. I will, thanks for worry about it. | |
10-01-2018, 15:26 | #69 (permalink) | |
10-01-2018, 15:29 | #70 (permalink) | |
You can get combined vcf file from your old nokia, rename it to restorable file for MTK and put to sd card and try restore from device menu, have no ide huw much good will be result. | |
10-03-2018, 04:56 | #72 (permalink) | |
Junior Member Join Date: Apr 2014
Member: 2176644 Status: Offline Thanks Meter: 0 | Quote:
10-04-2018, 18:50 | #74 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | New software version released - https://www.infinity-box.com/support/?r=100046 |
