Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 10-03-2018, 19:56   #1 (permalink)
Member: 2006990
Thanks Meter: 540
Infinity-Box [BEST] NK2 v1.07 - Nokia 130 (2017) support and new features!
- Nokia 130 (2017) line support activated !
Next revision of Nokia 130 (2017) are supported:
Nokia 130 (2017): KESA : TA-1017/TA-1019
For now the next features are supported:
> Firmware flashing ( Factory/BEST firmware packages )
> Firmware reading
> Format FS / Reset Settings
> Identify ( read complete device info & check/verify security area )
- Changes/Fixes
> MTK FP line
Fix/Change: Flash engine revised : Automatic Repair Mode enable, if device semi-dead
Fix/Change: AutoID in case of semi-dead device state may fail, fixed
- Support
Hundreds of firmwares for 130 (2017) have been uploaded to support area
> Check out for required region packages or language packages in support area first! Also you can read from any good working device that you have.
Link http://dl1.infinity-best.com/47/pub....BEST2_v1.07.7z
The Following 10 Users Say Thank You to Surtax For This Useful Post:
Old 10-03-2018, 20:29   #2 (permalink)
farukpdm's Avatar
Member: 1417131
Sonork: Uninstalled
Thanks Meter: 1,090
Really nice update
Thx team
Sent from my Redmi 4X using Tapatalk
Old 10-03-2018, 22:05   #3 (permalink)
Member: 911021
Thanks Meter: 81
thanks for inifinity best team waiting for support flash nokia 105 ta 1034
Old 10-04-2018, 08:58   #4 (permalink)
skynumber's Avatar
Member: 872681
Sonork: 1680923
Thanks Meter: 51
Thanks for starting regular updats
thanks
keep it up team
Old 10-04-2018, 12:49   #5 (permalink)
yousaf.awan's Avatar
Member: 2332177
Thanks Meter: 55
Thanks Infinity Box BEST2 Team I M Waiting Nokia 105 2017 Update.................
Old 10-04-2018, 12:52   #6 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,776
excellent update respect you.
Old 10-04-2018, 14:34   #7 (permalink)
Shani3's Avatar
Member: 1582572
Sonork: 100.1609641
Thanks Meter: 573
i have nokia 3310 ta-1022 security code , How to resat
Old 10-04-2018, 14:41   #8 (permalink)
Member: 1677653
Thanks Meter: 2,769
install driver and connect under NOKIA MTK [FP]
Old 10-04-2018, 16:48   #9 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,117
3310 only 2g supported 3310 3g not supported
Old 10-04-2018, 17:17   #10 (permalink)
Member: 1613469
Thanks Meter: 192
excellent update .....
Old 10-05-2018, 18:12   #11 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Will be supported in next version.
Operation : Read FirmWare [ v1.08 ]
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : Care Suite USB Serial Port (COM19)
MODE : NOKIA USB SERIAL
PORT : 19
BROM : Init BROM
BROM init passed!
     CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001
BROM : SECCFG : 0x00000007
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : D14D86E190B053934168DF4D6D930A41
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : N103.10.02.11.p1
BOOT : BDDS : 30
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
SWVer : N103.10.02.11.p1
FLASH : 00C2 : 0025 : 0036 : 0000
CODE  : 0x00370000
Reading Flash ...
TDSN : TA-1010
PRDC : 059Z174
PPM  : EI
LANG :
[1] : Georgian (Georgia)
[2] : Armenian (Armenia)
[3] : Romanian (Romania)
[4] : Ukrainian (Ukraine)
[5] : Belarusian (Belarus)
[6] : Russian (Russia)
[7] : Kazakh (Kazakhstan)
[8] : Azeri (Azerbaijan)
[9] : English (United Kingdom)
BUILD : TA-1010_ROM_eMP_10.02.11
BUILD : TA-1010_LANG_PACK_ROM_EI_eMP_10.02.11_001
BUILD : TA-1010_CUSTPACK_ROM_EI_eMP_10.02.11_001
BUILD : TA-1010_JUMP_TABLE_EI_eMP_10.02.11_001
BUILD : TA-1010_VIVA_eMP_10.02.11
Make VPL definition
Save Path : D:\Nokia\TA-1010\
Save Name : TA-1010_059Z174_10.02.11.vpl
Build Finished!
Done!
Elapsed: 00:03:53
Reconnect Power/Cable!
Open VPLfile : TA-1010_059Z174_10.02.11.vpl
Description  : TA-1010 EI
DeviceType   : TA-1010
ProductCode  : 059Z174
SoftwareVer  : 10.02.11
Load Ok!
Operation : Write FirmWare [ v1.08 ]
Setting   : UserData erase : True
Setting   : LangPack Only : False
PORT : 19
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
AGENT : Look for suitable BootChain in DA ...
AGENT : DEFAULT AUTO
AGENT : Found MT6261
AGENT : N103.10.02.11.p1
     BOOT : Sending 1st DA ...
BOOT : DA sent
BOOT : Transfer control to DA ...
DA : Agent : v03.02 on BBID : 0x8E
        NOR: 00EF : 0070 : 0016 : 0000
        NOR: [Winbond] SF_W25Q32JV
        NOR:
              TSIZE  : 0x00400000 [ 4,00 MB ]
              PSIZE  : 0x00400000 [ 4,00 MB ]
              STYPE  : 0x00000000
              FLOTP  : DA_NOR_OTP_EXIST
 STATUS : OK
 BSTYLE : SF_FLASH_BOOT
Boot done!
Load FlashSet :
MROM : TA-1010_ROM_eMP_10.02.11
LANG : TA-1010_LANG_PACK_ROM_EI_eMP_10.02.11_001
CUST : TA-1010_CUSTPACK_ROM_EI_eMP_10.02.11_001
JUMP : TA-1010_JUMP_TABLE_EI_eMP_10.02.11_001
VIVA : TA-1010_VIVA_eMP_10.02.11
Prepare FlashSet :
DCR : TA-1010_ROM_eMP_10.02.11
DCR : TA-1010_LANG_PACK_ROM_EI_eMP_10.02.11_001
DCR : TA-1010_CUSTPACK_ROM_EI_eMP_10.02.11_001
DCR : TA-1010_JUMP_TABLE_EI_eMP_10.02.11_001
DCR : TA-1010_VIVA_eMP_10.02.11
Prepare Target
SDS : OK : 0x003F8000 : 0x00008000
FFS Format Ok!
Erase Target Flash
Erase done!
Write Target Flash
Write : TA-1010_ROM_eMP_10.02.11
Write : TA-1010_LANG_PACK_ROM_EI_eMP_10.02.11_001
Write : TA-1010_CUSTPACK_ROM_EI_eMP_10.02.11_001
Write : TA-1010_JUMP_TABLE_EI_eMP_10.02.11_001
Write : TA-1010_VIVA_eMP_10.02.11
Write done, waiting target response ...
Write flash done!
Verify Target FlashContent
Verify : TA-1010_ROM_eMP_10.02.11
Verify : TA-1010_LANG_PACK_ROM_EI_eMP_10.02.11_001
Verify : TA-1010_CUSTPACK_ROM_EI_eMP_10.02.11_001
Verify : TA-1010_JUMP_TABLE_EI_eMP_10.02.11_001
Verify : TA-1010_VIVA_eMP_10.02.11
Done!
Elapsed: 00:01:04
The Following 9 Users Say Thank You to JayDi For This Useful Post:
Old 10-08-2018, 18:45   #12 (permalink)
tgsm's Avatar
Member: 13827
Thanks Meter: 16
please add navi manager new files in software
Old 10-09-2018, 16:05   #13 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Hello,
Here is ur answer http://forum.gsmhosting.com/vbb/13352250-post47.html
U can download all Files from IOS for more info check here https://www.infinity-box.com/support/?s=4
Page generated in 0.22638 seconds with 8 queries
