Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 03-17-2019, 22:21   #1 (permalink)
Member: 148515
Thanks Meter: 19,534
Infinity-Box [BEST] NK2 v1.10 - Nokia 3310 3G support and new features
- Nokia SPRD tab activated
Nokia 3G SS [TA-1006] supported
Nokia 3G SS [TA-1022] supported
Nokia 3G DS [TA-1036] supported
- Identify
- Reset Settings / Format FS
- Firmware Flashing ( cross, nvm update, lang change )
Info: Device security paired, store all NV backups to emergency case !
Info: Crossflashing can be done and not touch security ( require enable NV update )
- Nokia SP tab changes
Identify now read BOTH part info for A/B devices
Flash Engine updated
"UserData preserve" mode updated
Format FS / Reset FRP revised
Nokia 5.1+ ( Nokia X5 ) supported ( TA-1102, TA-1105, TA-1108, TA-1109, TA-1112, TA-1120 )
Nokia 3.1+ supported ( TA-1104, TA-1113, TA-1115, TA-1117, TA-1118, TA-1125 )
- Identify
- Reset Settings / Format FS / Reset FRP
- Firmware Flashing
- Nokia FP tab changes
PhoneBook extraction engine updated
Extract "from file" revised
Download link
How to upload files to support
Infinity-Box 14 years (2005 - 2019) updates and support as nobody else !
The Following 82 Users Say Thank You to InfinityHelp For This Useful Post:
Old 03-17-2019, 22:40   #2 (permalink)
kundicom's Avatar
Member: 2650777
Sonork: 100.650600
Thanks Meter: 161
Thank you so much team please please focus of new security of oppo with infinity cm2
The Following 7 Users Say Thank You to kundicom For This Useful Post:
Old 03-18-2019, 04:06   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Some firmwares can be found on support for every TA-xxxx from supported list, more to come.
The Following 21 Users Say Thank You to JayDi For This Useful Post:
Old 03-18-2019, 06:12   #4 (permalink)
ahmer5050's Avatar
Member: 2385819
Sonork: No More Used
Thanks Meter: 827
Thankz Boss.
U R The Best.
Plz Fixd Quallcomm Tab.
Deactivated .
The Following 7 Users Say Thank You to ahmer5050 For This Useful Post:
Old 03-18-2019, 06:13   #5 (permalink)
yousaf.awan's Avatar
Member: 2332177
Thanks Meter: 55
Thanks infinity Team Good Update.
The Following 2 Users Say Thank You to yousaf.awan For This Useful Post:
Old 03-18-2019, 06:15   #6 (permalink)
rahihimkhan's Avatar
Member: 613449
Sonork: 100.1614074
Thanks Meter: 634
Thanks
nokia 106 TA-1114 ?
Plz Fixd Quallcomm Tab is Deactivated
The Following 4 Users Say Thank You to rahihimkhan For This Useful Post:
Old 03-18-2019, 06:20   #7 (permalink)
Member: 613449
Sonork: 100.1614074
Thanks Meter: 634
Nokia Ta1114
Operation : Identify [ v1.10 ]
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : Nokia USB Serial Port (COM4)
MODE : NOKIA USB SERIAL
PORT : 4
BROM : Init BROM
BROM init passed!
CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001
BROM : SECCFG : 0x00000005
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : B46EB663D588BB973A9D304821E10912
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : NEMO61D.10.00.11.p2
BOOT : SWR : 10.00.11
BOOT : BDDS : 30
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
SWVer : NEMO61D.10.00.11.p2
FLASH : 00C2 : 0025 : 0036 : 0000
BBSN [RPL] : 6614C72B8E36B4A8CE54D9B3F7C83464
BBSN [DEV] : B46EB663D588BB973A9D304821E10912
-> Info : Device security area damaged!
-> Info : Write RPL backup, if it exists!
Done!
Elapsed: 00:00:34
Reconnect Power/Cable!
The Following 5 Users Say Thank You to rahihimkhan For This Useful Post:
Old 03-18-2019, 06:52   #8 (permalink)
Member: 2332177
Thanks Meter: 55
Nokia QLM [LM] Tab is Deactivated, QLM [ED] Show. [ED] who is this Please Explain.
Old 03-18-2019, 06:58   #9 (permalink)
sajidi1984's Avatar
Member: 2778467
Sonork: only Telegram
Thanks Meter: 265
Thanks Team
finaly nokia spd update released
The Following User Says Thank You to sajidi1984 For This Useful Post:
Old 03-18-2019, 07:04   #10 (permalink)
Member: 2274431
Thanks Meter: 6
Thanks infinity Team for Good Update
The Following User Says Thank You to kirancl For This Useful Post:
Old 03-18-2019, 07:09   #11 (permalink)
Nishan_Raja's Avatar
Member: 2554807
Thanks Meter: 612
InfinityBox BEST working Fine but InfinityBox BEST2 not working in my Pc
HLP ME Infinity Teams
The Following User Says Thank You to Nishan_Raja For This Useful Post:
Old 03-18-2019, 08:44   #12 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Hello,
copy "Licence files" from Best to BEST2 Folder.
Results ?
The Following User Says Thank You to Kirumira For This Useful Post:
Old 03-18-2019, 08:45   #13 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,067
Thanks for Update and specialy for SPD phones.
The Following User Says Thank You to asad_nomy7 For This Useful Post:
Old 03-18-2019, 08:55   #14 (permalink)
>>Gsmmilon>>'s Avatar
Member: 2142580
Thanks Meter: 1,214
Please Support Nokia QLM / FRP / Flash / Network Unlock / Security Repair /
The Following 2 Users Say Thank You to >>Gsmmilon>> For This Useful Post:
Old 03-18-2019, 08:56   #15 (permalink)
Member: 1302942
Thanks Meter: 171
Because you can't read and can't see
The Following 2 Users Say Thank You to fedja85 For This Useful Post:
Page generated in 0.21490 seconds with 8 queries
