03-25-2019, 06:32 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity-Box [BEST] NK2 v1.11 - More MTK and SPRD features activated - Nokia SPRD tab Activated Flash Dump feature Support another signed base driver ( can be found on support for both x86 and x64 systems ) FlashEngine updated - Nokia MTK SP tab changes Flash Engine updated MT6755 line has been broken in previous release, fixed - Nokia MTK FP tab changes PhoneBook extraction engine updated Flash Engine updated Backup security feature released, allow store device security Restore security feature released, allow restore device security backups Backup now also made during "Identify" During backup security RPL will be cleaned and prepared ( all counters reset and default mtk settings/options set ) - Other Minor bugfixes and changes - Additional info SPRD flash backups can be sent for processing via IOS FileUploader for adding new LangPacks on support. ETA of processing - 48 hours, then files can be found on support. All other ways will be ignored. NEW SPRD DRIVERS should be installed ! Download link - How to upload files to support Infinity-Box 14 years (2005 - 2019) updates and support as nobody else ! Last edited by YellowBoss; 03-25-2019 at 06:51. |
The Following 66 Users Say Thank You to YellowBoss For This Useful Post: |
03-25-2019, 07:05 | #5 (permalink) |
Freak Poster Join Date: Feb 2014 Location: Peshawar Age: 35
Member: 2123463 Status: Offline Sonork: 100.1652545 Thanks Meter: 29 | Mention nokia spd based models plz Mention nokia spd based models plz it will be really appreciated |
The Following User Says Thank You to adduangel For This Useful Post: |
03-25-2019, 07:23 | #7 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | good update good team But Nokia 106 ta1114 SUPOORT ? Please Add Data package Directory path |
The Following User Says Thank You to rahihimkhan For This Useful Post: |
03-25-2019, 07:43 | #12 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | nokia ta1114 info done but Read firmware Option Not work in nokia mtk(FP) Tab Operation : Identify [ v1.11 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM15) MODE : NOKIA USB SERIAL PORT : 15 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 134C54AB1563B819E7CF9E49A0DC3474 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.10.00.11.p2 BOOT : SWR : 10.00.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : NEMO61D.10.00.11.p2 FLASH : 00C2 : 0025 : 0036 : 0000 PRDC : 059Z0X8 IMEI[1] : 354176103540993 IMEI[2] : 354176104540992 NCK : 20 digits PROV : 24407000 Saved as : 35xxxxxxxxxxxxxxxxx.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ nokia ta1114 info done but Read firmware Option Not work in nokia mtk(FP) Tab |
03-25-2019, 08:13 | #15 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | After may try Read firmware Option work Operation : Read FirmWare [ v1.11 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM15) MODE : NOKIA USB SERIAL PORT : 15 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 134C54AB1563B819E7CF9E49A0DC3474 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.10.00.11.p2 BOOT : SWR : 10.00.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : NEMO61D.10.00.11.p2 FLASH : 00C2 : 0025 : 0036 : 0000 CODE : 0x00370000 Reading Flash ... TDSN : TA-1114 PRDC : 059Z0X8 PPM : IB LANG : [1] : Portuguese (Portugal) [2] : French (France) [3] : Spanish (Castilian/Spain) [4] : English (United Kingdom) BUILD : TA-1114_ROM_eMP_10.00.11 BUILD : TA-1114_LANG_PACK_ROM_IB_eMP_10.00.11_001 BUILD : TA-1114_CUSTPACK_ROM_IB_eMP_10.00.11_001 BUILD : TA-1114_JUMP_TABLE_IB_eMP_10.00.11_001 BUILD : TA-1114_VIVA_eMP_10.00.11 Make VPL definition Save Path : F:\Infinity-Box\InfinityBox BEST\TA-1114\ Save Name : TA-1114_059Z0X8_10.00.11.vpl Build Finished! Done! Elapsed: 00:02:27 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to rahihimkhan For This Useful Post: |
