04-10-2019, 07:48 | #32 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
04-10-2019, 16:55 | #35 (permalink) |
No Life Poster Join Date: Aug 2011
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | why it is not reading any TA series phone? 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM32) MODE : NOKIA USB SERIAL PORT : 32 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 7B8B6AFDD136CDAA6ADFD46BB97289BE BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.10.02.11.p1 BOOT : SWR : 10.02.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! Error : Failed to read initial info! Erased/Damaged device??? Make sure device HW is in normal condition, check battery and cable! Reconnect Power/Cable! |
04-10-2019, 17:21 | #36 (permalink) | |
I got just few reports about problem ( 3 eaxctly for now ) And not see reason to rebuild anything for now. Try change USB port and use good original USB cable, insert direct in back side port, not to host ones. Try update drivers and reboot PC. As last chance - try on another PC. | |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
04-11-2019, 20:56 | #40 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Earth
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | Instead of tabs like MTK , SPS,Qualcomm. You should use TA like TA-1032 As user know TA and can read TA on back sticker and software should Auto pick CPU and All operations. Sent from my SM-G935F using Tapatalk |
