07-05-2020, 16:38 | #121 (permalink) |
Insane Poster Join Date: Oct 2011 Location: iran.behbahan
Member: 1679748 Status: Offline Thanks Meter: 12 | 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL Info : Device is not supported yet! Reconnect Power/Cable! |
07-10-2020, 13:01 | #122 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Enable Best2 to access other firmware apart from nb0 & wzip In next update. Make it universal.. |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
07-27-2020, 16:00 | #128 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | If possible to add META MODE to MTK SP tab for imei edit/repair and SP unlock in next update .. |
07-30-2020, 15:40 | #130 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Colombia Age: 42
Member: 452143 Status: Offline Thanks Meter: 198 | Please how reset Nokia TA-1214 ...... Operation : Identify [FTM] [ v1.20 ] -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Reset Settings [FTM] [ v1.20 ] -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Not work..... please help me |
08-21-2020, 14:34 | #131 (permalink) |
Freak Poster Join Date: Jan 2006 Location: colombia Age: 45
Member: 220008 Status: Offline Thanks Meter: 95 | nokia 2.3 I can not read or firmware and less restoration Reconnect Power/Cable! Operation : Flash Firmware [FTM] [ v1.20 ] Setting : UserData preserve : False Setting : FRP Reset : True Setting : Change SKUID : False Setting : Keep SVC : True -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Flash Firmware [FTM] [ v1.20 ] Setting : UserData preserve : False Setting : FRP Reset : True Setting : Change SKUID : False Setting : Keep SVC : True -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Flash Firmware [FTM] [ v1.20 ] Setting : UserData preserve : False Setting : FRP Reset : True Setting : Change SKUID : False Setting : Keep SVC : True -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Card found : A3F5C4AC , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM20) MODE : BOOTROM PORT : 20 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL Info : Device is not supported yet! Reconnect Power/Cable! Card found : A3F5C4AC , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... Card found : A3F5C4AC , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Reset Settings [FTM] [ v1.20 ] -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM20) MODE : BOOTROM PORT : 20 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL Info : Device is not supported yet! Reconnect Power/Cable! Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... |
08-21-2020, 14:35 | #132 (permalink) |
Member: 220008 Status: Offline Thanks Meter: 95 | nokia 4.2 firmware Card found : A3F5C4AC , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Load : C:\Users\TECNOSHOP_2403\Downloads\Compressed\N4.2_ HMDSW_Panther-2290-0-00WW-B01_user\HMDSW_Panther-2290-0-00WW-B01_user-images.zip Bad file selected! Select correct wZip file! Load : C:\Users\TECNOSHOP_2403\Downloads\Compressed\N4.2_ HMDSW_Panther-2290-0-00WW-B01_user_2\HMDSW_Panther-2290-0-00WW-B01_user-images.zip Bad file selected! Select correct wZip file! Load : C:\Users\TECNOSHOP_2403\Downloads\Compressed\N4.2_ HMDSW_Panther-2290-0-00WW-B01_user_2\HMDSW_Panther-2290-0-00WW-B01_user-images\HMDSW_Panther-2290-0-00WW-B01_user-update.zip Bad file selected! Select correct wZip file! Load : C:\Users\TECNOSHOP_2403\Downloads\Compressed\HMDSW _Panther-117I-0-00WW-B01_user.zip Device : Panther Android: 9.0 SKU ID : Generic ROM Ver: HMDSW_Panther-117I-0-00WW-B01_user Load Ok! Operation : Flash Firmware [FTM] [ v1.20 ] Setting : UserData preserve : False Setting : FRP Reset : True Setting : Change SKUID : False Setting : Keep SVC : True -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Dev Model : Panther HW version : 0.15 HW variant : QRD eMMC HW RF_BAND : GSM_850_900_1800_1900^W1_2_4_5_8^L_1_2_3_4_5_7_8_1 2_17_28_38_66 SW version : V2.29C_B01 SW CurrSlot : B SW serialnm : 8T89571MA19A1901570 SW secured : YES Bootloader type : WT2 Security Version : 0003 Prepare base package, please, wait ... Prepare data package, please, wait ... Prepare update package, please, wait ... Device : Panther ( Panther ) BLType : WT2 SecVer : 03 ERROR : Unsupported SecurityVersion! Info : Device is not supported yet! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
08-24-2020, 14:50 | #133 (permalink) |
Freak Poster Join Date: Sep 2014 Location: islamabad pakistan Age: 39
Member: 2266425 Status: Offline Thanks Meter: 58 | how to download full flash files from Navi manager only download vpl file SSChannel : Create SC SSChannel : SC Created! ProductID HWCode : RM-1013 SSChannel : DC Ok with code 0x01 Switch to IDM now ... IDM initializing, wait... Checking access to Products folder... Folder for RM-1013 not exist. Attempt to create Prepare done, collect info [Query] : RM1013_059V782_2.1.0.13_149.vpl , 20.86 KiB Files to download : 1 Total size to download : 20.86 KiB Downloading now, please, wait... [Download] : RM1013_059V782_2.1.0.13_149.vpl Verify files now ... All done, all files were downloaded! |
08-25-2020, 13:31 | #134 (permalink) |
Member: 2266425 Status: Offline Thanks Meter: 58 | nokia 6 Ta 1021 flashing error Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Dev Model : PAD HW version : 5.1 HW variant : FIH eMMC HW RF_BAND : G_850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28_38 _40 SW version : PLE-619D-0-00WW-B01 SW serialnm : PLEGAR47B1312193 SW secured : YES Bootloader type : RETAIL Security Version : 0004 OP : Activate SVC Device : PAD ( PLE1 ) BLType : RETAIL SecVer : 04 Device authentification ... Processing server operation ... Connecting to server... Connected Authenticating... Authentication error:Connection Closed Gracefully. Disconnected Disconnected Finished Error : Device auth failed! Server reported error! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
08-25-2020, 13:34 | #135 (permalink) |
Member: 2266425 Status: Offline Thanks Meter: 58 | read info Operation : Identify [FTM] [ v1.20 ] -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Dev Model : PAD HW version : 5.1 HW variant : FIH eMMC HW RF_BAND : G_850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28_38 _40 SW version : PLE-619D-0-00WW-B01 SW serialnm : PLEGAR47B1312193 SW secured : YES Project DevCode : PLE1 Bootloader type : RETAIL Security Version : 0004 Done! Elapsed: 00:00:08 |
