01-13-2020, 19:08 | #46 (permalink) |
Junior Member Join Date: Jun 2018 Location: Honduras
Member: 2843104 Status: Offline Thanks Meter: 0 | Targeta inteligente no encontrada Conecte la tarjeta inteligente ¿que sera ayuda para despejar mi duda? |
01-14-2020, 18:31 | #47 (permalink) | |
Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
01-15-2020, 17:34 | #48 (permalink) |
Junior Member Join Date: Jun 2018 Location: Bhilai Chhattisgrah
Member: 2843834 Status: Offline Sonork: 100.1684009 Thanks Meter: 6 | Nokia 3 TA 1032 Identyfing error Help sir please but Phone Ok Infinity-Box BEST Nokia [HMD] Module [NK2] v1.19 Operation : Identify [ v1.19 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM15) MODE : PRELOADER PORT PORT : 15 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : BEST_Nokia_DA_v19_1711_06 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 13014E51324A393652100525737FDFEB DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 13014E51324A393652100525737F34EB EMMC: VEN : MICRON | OEM : 4E01 | DEV : Q2J96R EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 7FD36112312C7A699CEEA3F0430C62B3 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Error : Failed to read initial info! Erased/Damaged device??? Make sure device HW is in normal condition, check battery and cable! Reconnect Power/Cable! Operation : Identify [ v1.19 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM15) MODE : PRELOADER PORT PORT : 15 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : BEST_Nokia_DA_v19_1711_06 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 13014E51324A393652100525737FDFEB DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 13014E51324A393652100525737F34EB EMMC: VEN : MICRON | OEM : 4E01 | DEV : Q2J96R EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 7FD36112312C7A699CEEA3F0430C62B3 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Error : Failed to read initial info! Erased/Damaged device??? Make sure device HW is in normal condition, check battery and cable! Reconnect Power/Cable! Operation : Identify [ v1.19 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM15) MODE : PRELOADER PORT PORT : 15 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : BEST_Nokia_DA_v19_1711_06 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 13014E51324A393652100525737FDFEB DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 13014E51324A393652100525737F34EB EMMC: VEN : MICRON | OEM : 4E01 | DEV : Q2J96R EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 7FD36112312C7A699CEEA3F0430C62B3 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Error : Failed to read initial info! Erased/Damaged device??? Make sure device HW is in normal condition, check battery and cable! Reconnect Power/Cable! i used 1.20 version also. but same problem i try remove battery i try new cable and other usb port reinstall and restart pc |
01-19-2020, 15:06 | #52 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
We will try find such device in near time to make some test. | |
01-19-2020, 23:44 | #54 (permalink) |
Freak Poster Join Date: Dec 2015 Age: 46
Member: 2496790 Status: Offline Thanks Meter: 11 | in HMD software .. in the best spd file flash for nokia 3310 can you pls add a tool to turn it to iso file like in the best 1 pls as it relay on the series 30+ OS or else that are free and open source like firefox or kaiok ? |
01-20-2020, 00:26 | #55 (permalink) | |
Member: 2496790 Status: Offline Thanks Meter: 11 | Quote:
and is it easer for you ? | |
01-20-2020, 07:24 | #56 (permalink) | ||
Rest you can find in google. I not see any reason copypast it here. FireFox/KaiOs infact same. Modify it and change some stuff possible. We will add some tools for 2720/8810/800/33104G | ||
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
01-20-2020, 08:25 | #57 (permalink) | |
you mean the old 2720 fold? (it will be grait) and about 33104g it has the YunOS SC9820A emmc chip (right) i just copy paste it from another web. i asuume it will usefull yap ofcourse we will do with it a lor of use but if you can to the 3g 3310 it will graiter for me and others in my erea so i much more comon the TA-1036 version and it said there that it based on java in the article. | |
01-20-2020, 21:47 | #58 (permalink) |
Junior Member Join Date: Dec 2018 Location: pasuruan - indonesia
Member: 2881448 Status: Offline Thanks Meter: 1 | Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM48) MODE : NOKIA USB SERIAL PORT : 48 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 6E532F7DEE119917675CC314504ED2A1 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.12.00.11.p1 BOOT : SWR : 12.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.12.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4,00 MB ] PSIZE : 0x00400000 [ 4,00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 30.04.11 [TA-1034] DEV SoftwareVersion : 12.00.11 SWInfo compare result : DEVICE SW ( Major version ) is LOWER, than in VPL! Load FlashSet : MROM : TA-1034_ROM_eMP_30.04.11 LANG : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 CUST : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 JUMP : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 VIVA : TA-1034_VIVA_eMP_30.04.11 Prepare FlashSet : DCR : TA-1034_ROM_eMP_30.04.11 DCR : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 DCR : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 DCR : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 DCR : TA-1034_VIVA_eMP_30.04.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 FFS Format ERROR : DA_NOR_BLOCK_DATA_UNSTABLE Open_SFStorage ERROR : DA_NOR_BLOCK_IS_LOCKED Unknow Error! Make sure device HW is in normal condition, check battery and cable! Reconnect Power/Cable! |
The Following User Says Thank You to tomadcell For This Useful Post: |
