03-07-2012, 22:24 | #75 (permalink) |
No Life Poster Join Date: Jul 2004 Location: IN MY SERVER
Member: 71189 Status: Offline Sonork: 100.1617065 Thanks Meter: 90 | is server sx4 auth is off Processing Server SX4 Auth Checking SDD key... Check SD : Key is Ok Operating mode is OK, no need change... Connecting to server... Connection error #1 Server not found... SX4 Auth error No any file found for this RM-identifier, break operation Processing Server SX4 Auth Checking SDD key... Check SD : Key is Ok Operating mode is OK, no need change... Connecting to server... Connection error #1 Server not found... SX4 Auth error Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! WMDRM key found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 22D0011638640344E0E38381F8D6B1D38882AD1B ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.48.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.48.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6 ADL: Preparing for write certificates... Erase NPC... Ok Writing NPC... Ok Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Wait, reconneting... Writing SimLock Key... Ok! Writing SimLock Data... Ok! SDD Key status : SD Data is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! WMDRM_PD key sent... Ok Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 22D0011638640344E0E38381F8D6B1D38882AD1B ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.48.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.48.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:03 Seek file for this phone.... ----------------------------- - > RPL file found for this phone! - > NPC Found in : 358238031749975.rpl Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! WMDRM key found! ----------------------------- Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6 ADL: Preparing for write certificates... Erase NPC... Ok Writing NPC... Ok Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Wait, reconneting... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Writing SimLock Key... Ok! Writing SimLock Data... Ok! SDD Key status : SDData is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL3 phone detected , SP_CODE_LEN : 15 WMDRM_PD key sent... Ok Done! Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Local SX4 procedure started... Phone Imei: 358238031749975 Use custom key... Step 1... Step 2... SX4 Auth fail... - > Try Check "Custom Keys" checkbox and repeat - > If SDD original - "Use Server Sx4" Local SX4 procedure started... Phone Imei: 358238031749975 Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > Try Check "Custom Keys" checkbox and repeat - > If SDD original - "Use Server Sx4" Processing Server SX4 Auth Checking SDD key... Check SD : Key is Ok Operating mode is OK, no need change... Connecting to server... Connection error #1 Server not found... SX4 Auth error Processing Server SX4 Auth Checking SDD key... Check SD : Key is Ok Operating mode is OK, no need change... Connecting to server... Connection error #1 Server not found... SX4 Auth error i cant repair security test failed |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
