08-01-2011, 12:07 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: from the dark past
Member: 744064 Status: Offline Thanks Meter: 99 | n73 phone startup failed contact retailer done. first check via ufs hwk.. logs, MCU SW : V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. APE Core: APE Var : A+ Product : Nokia N73 Prd.Code: 0529607 Bpr.Code: 0527006 Prod.Sn : SBH144666 HW Vers : 6000 APE HW : APE Adsp: EM VILMA: 15 EM BETTY: 21 RFIC Ver: 17191719 DSP Vers: scarfe_mc.05wk46v50p2 IMEI : 359738-00-164719-9 SL Serv : SIMLOCK SERVER VERSION 63 SL Conf : 000-00-00000000000 SL Prof : 0144196900000000 SL Count: 00 00 SL Data Corrupted Provider: Not Found now i use best donle to repair this error.. first tick repair SL second tick repair SDD card found: S/N ***** registered to: kulazgsm Connect phone on selected interface... UFS S/N 45600 boot - Ok Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Read and Check phone data... SimLock status : SimLock Damaged!!!!! Security status : Security is Ok SDD Key status : SD Data is Ok PA_SimLock Version : PA_SL phone detected Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 7D86B8B2BCF08F9FEB0B74563EBF2773158D8918 APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B21 CMT PUB ID : 15F00119BEB3005465E27DDEC2853F09C652D051 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 22E800EC , CMT , NOR CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 02 FLASHID : 00A100EC , APE , APE Flash ID : 00A100EC < SAMSUNG [SEC] => K5E1G12ACM [NAND] FLCNT : 010100FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Sending ALGO.... Use : h3_sam_nand_xsr.fg , Rev : 0.0 Ver : 1.47.0 APE Algo sent APE PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBC Transmission mode : Dual (Ddr, TX2) Boot Done! PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Init Service mode... Wait... Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Read Uniq key data started... Phone Imei: 359738001647199 Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 7D86B8B2BCF08F9FEB0B74563EBF2773158D8918 APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B21 CMT PUB ID : 15F00119BEB3005465E27DDEC2853F09C652D051 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... CMT Loader sent, Boot Ok rap= 15F00119BEB3005465E27DDEC2853F09C652D051 hash= BAF3A9C3DBFA8454937DB77F2B8852B1 key= D18BE50B93212715B645BEFDF4EB709C750CBFF7 Init Service mode... Wait... Key file updated... Done! Repair SL procedure started... Phone Imei: 359738001647199 Key file exists, no need to read... Operating mode is OK, no need change... Writing SimLock Data... Ok Writing SimLock Key... Ok Done! Reading Phone Info.... Connected phone - Nokia N73 Software ver : V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. IMEI : 359738001647199 Ape Ver : APE Var : APE ADSP: DSP Ver : scarfe_mc.05wk46v50p2 APE Test: PPM : CNT : Product SN : SBH144666 Product code : 0529607 Base Prd.code: 0527006 Module code : 0202855 Long Prod.SN : Hardware info======= HWID : 6000 Retu : 15 Tahvo : 21 Batery: 4256 mV Camera: CMT BT: APE BT: APE HW: LCDVer: RF ic : 17191719 Lock info =========== IMEI : 359738001647199 IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User Code : 12345 UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Read and Check phone data... SimLock status : SimLock is Ok Security status : Security is Ok SDD Key status : SDData Damaged!!!!! PA_SimLock Version : PA_SL phone detected Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 7D86B8B2BCF08F9FEB0B74563EBF2773158D8918 APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B21 CMT PUB ID : 15F00119BEB3005465E27DDEC2853F09C652D051 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 22E800EC , CMT , NOR CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 02 FLASHID : 00A100EC , APE , APE Flash ID : 00A100EC < SAMSUNG [SEC] => K5E1G12ACM [NAND] FLCNT : 010100FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Sending ALGO.... Use : h3_sam_nand_xsr.fg , Rev : 0.0 Ver : 1.47.0 APE Algo sent APE PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBC Transmission mode : Dual (Ddr, TX2) Boot Done! PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Init Service mode... Wait... Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Repair SD procedure started... Phone Imei: 359738001647199 Key file exists, no need to read... Accepted SdRepReq (on alive SD) by user Operating mode is OK, no need change... Writing Super Dongle Key... Ok Done! Read and Check phone data... SimLock status : SimLock is Ok Security status : Security is Ok SDD Key status : SD Data is Ok PA_SimLock Version : PA_SL phone detected Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 7D86B8B2BCF08F9FEB0B74563EBF2773158D8918 APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B21 CMT PUB ID : 15F00119BEB3005465E27DDEC2853F09C652D051 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 22E800EC , CMT , NOR CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 02 FLASHID : 00A100EC , APE , APE Flash ID : 00A100EC < SAMSUNG [SEC] => K5E1G12ACM [NAND] FLCNT : 010100FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Sending ALGO.... Use : h3_sam_nand_xsr.fg , Rev : 0.0 Ver : 1.47.0 APE Algo sent APE PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBC Transmission mode : Dual (Ddr, TX2) Boot Done! PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Init Service mode... Wait... Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... now phone is ok..... br,kulasgsm |
The Following User Says Thank You to stacey-ann For This Useful Post: |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
