03-07-2015, 16:15 | #17 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2136362 Status: Offline Thanks Meter: 31 | Always good news from infinity team. Please answer me some questions.... What is "MTKx : Forensic Mode supported for more models"? what is secwim images and what does this line mean "also now possible get SECWIM directly from BEST"? How to do that, give me the procedure |
03-07-2015, 16:38 | #18 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
First - Extract UserData from MTK Nokia. Second - Service WP8.1 phones. | |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
03-07-2015, 18:33 | #19 (permalink) | |
Member: 2136362 Status: Offline Thanks Meter: 31 | Quote:
Thanks for ur kind reply jaydi. Ur co operation is really appreciated. Will take care of mtk phone. Bye | |
03-07-2015, 19:45 | #20 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,827 | Nokia Asha 205 USB Flashing Successfully Done By Infinity Best Code: Connect phone on selected interface... Core : v2.04 , BB5XG FlashEngine : v9.9 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm862__04.51.mcusw PPM : rm862__04.51.ppm_mh2 CNT : rm862__04.51.image_mh2_059Q0B9_059R1C1_205_01 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.55_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 35369XXXXXXXXXX IMEI 2 : 35369XXXXXXXXXX PCcode : 059R1C1 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\35369XXXXXXXXXX_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm862__04.51.mcusw Image : rm862__04.51.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x017C0000 Erasing, wait ... Erase done, time : 00:02:12 Write , Start : 0x40280000 , Len : 0x017C0000 Flashing , wait ... Region flash done, time : 00:00:33 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip [Minor Error] : CRC returned by phone is wrong! [CHK] : 01003014 ===Flashing [PPM]=== File : rm862__04.51.ppm_mh2 Image : package_mh2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A40000 , Len : 0x00640000 Erasing, wait ... Erase done, time : 00:00:25 Write , Start : 0x41A40000 , Len : 0x004F24C4 Flashing , wait ... Region flash done, time : 00:00:05 CRC check passed , 0x33D5 ===Flashing [CNT]=== File : rm862__04.51.image_mh2_059Q0B9_059R1C1_205_01 Image : rm862__04.51.image_mh2_059Q0B9_059R1C1_205_01.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42080000 , Len : 0x01DA0000 Erasing, wait ... Erase done, time : 00:04:13 Write , Start : 0x42080000 , Len : 0x01180000 Flashing , wait ... Region flash done, time : 00:00:29 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip CRC check passed , 0x6B42 Flashing done! Total flash time : 00:08:18 Reboot phone now... Reading Phone Info.... Connected phone - 205 Software Info: V 04.51 31-05-13 RM-862 (c) Nokia IMEI: 35369XXXXXXXXXX PPM version : V 04.51 31-05-13 RM-862 (c) Nokia MH2 Product code: 059R1C1 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:09:42 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
03-10-2015, 12:02 | #27 (permalink) | |
Hard reset or flash - sure. If you talk about user password. | |
03-10-2015, 20:19 | #28 (permalink) |
No Life Poster Join Date: Oct 2007 Location: EGYPT
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | i have nokia x v2 after flash phone not power on and phone show emergency connectivity driver and not flash again i repaire it on riff and also atf jtag but phone not power on |
03-10-2015, 20:37 | #29 (permalink) | |
Solution - use something other for revive phone to flashable state and after use BEST to revive it to working condition. | |
