03-12-2018, 11:25 | #1 (permalink) |
No Life Poster Join Date: Jul 2013 Location: Kamber, Sindh, Pakistan Age: 36
Member: 1983780 Status: Offline Thanks Meter: 353 | nokia 206 rm-872 detected wrong image! stop killing phone Files Set for Flashing : MCU : rm872__04.52.mcusw PPM : rm872__04.52.ppm_m2 CNT : rm872__04.52.image_m2_059Q4J7 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Detected wrong image! Stop killing phone!!!! Connect phone on selected interface... here is readed rpl info Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF EBL Loader : Custom EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL EBL : Custom EBL sent Ok EBL : Quantum_Bootloader_2.5_M1S1 Boot done! Reading Done! Saved to : 359999050907740_X213.bin ===== USER CODE ===== Executing Code extraction... - > Phone Lock Code : 12345 ===== USER CODE ===== MMC password not found (not set) ===== RPL DATA ===== Executing RPL Data extraction... SL3 Simlock found (XGOLD) ... WMDRM Key found ... CMLA Key found ... IMEI 1 : 359999050907740 IMEI 2 : 359999050907757 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\359999050907740_2n d_XG213.rpl if some one know about this solution plz share , thanx |
03-12-2018, 14:42 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | There is option in settings - skip sw version check. Use it and flash. According device info it Nokia 206, someone flashed it with ANOTHER rm-identifier. |
