02-06-2011, 11:24 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | << Infinity's B.E.S.T. working perfect on win 7 64bit >> BR Faisal_Computer |
The Following 10 Users Say Thank You to Faisal_Computer For This Useful Post: |
02-06-2011, 13:48 | #3 (permalink) |
Freak Poster Join Date: Jan 2008 Location: Pakistan Age: 39
Member: 693282 Status: Offline Sonork: 100.1602586 Thanks Meter: 41 | only BEST is working but with UFSx interface ? i mean if you have Ufsx Driver for windows 7 64Bit please share a link here i ll be thank full BR MrGSM |
02-07-2011, 07:38 | #5 (permalink) | |
Member: 151871 Status: Offline Thanks Meter: 71,421 | Quote:
i got the way how to install ufs drivers on windows 7 64bit i am just preparing it , just tested with nokia 5800 on infinity's best on ufs interface in few mins i will upload all detail so stay with us Br Faisal_Computer | |
The Following User Says Thank You to Faisal_Computer For This Useful Post: |
02-07-2011, 08:17 | #6 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,421 | How to Work On Infinity's B.E.S.T. with Ufs interface on Windows 7 64bit 1.uninstall Ufs drivers if already installed 2. Go to the Start menu and type cmd.exe in the Search Bar. Right click on cmd.exe and choose Run as Administrator 3. If you have the UAC turned on, choose Yes to proceed. Otherwise, you should see the command windows opened already. In the shell window 4. Now in command prompt type these two commands one by one and press enter ( type 1st command then press enter and You’ll get a confirmation that the operation completed successfully then again enter 2nd command You’ll again get a confirmation that the operation completed successfully ) Commands are Code: bcdedit.exe -set loadoptions DDISABLE_INTEGRITY_CHECKS Code: bcdedit.exe -set TESTSIGNING ON 5.Restart Computer ( it is very important ) 6.Install HWK_Support_Suite_Setup_v02.10.000 ( during installing it will ask you to do you want to install new drivers press yes ) 7.Plug Ufs with your pc or laptop ( i have laptop ) it will install drivers without any error 8.Open Best -> settings -> connect settings -> select ufs Now you are ready to use !! just tested on one Nokia 5800 to test , this one my own mobile so i just test it with boot only i do not want to flash my own mobile Code: card found: S/N 1E6E:0116 registered to: Faisal_Computer Connect phone on selected interface... UFS S/N 134427 boot - Ok Connect phone on selected interface... Read and Check phone data... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101031103 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 13000216C97A0052BF22F1B03BC1935A547D241D CMT MODE ID : 00 CMT R_HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE CMT ROM ID : 4B9B75103E691FF8 CMT : Sending 2nd loader... Use : RAPIDOv11_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 004000EC , CMT , NAND CMT Flash ID : 004000EC < SAMSUNG [SEC] => KAT00F00RA [NAND] FLCNT : 00030000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAPIDOv11_algo.fg CMT Algo sent CMT PAPUB : A20187051C30162EE91C77AE5E6011F5F1BA619000 Transmission mode : Dual (Ddr, TX2) Boot Done! i hope you'll enjoy Infinity's B.E.S.T. with Ufs on Windows Seven 64Bit Br Faisal_Computer |
The Following 9 Users Say Thank You to Faisal_Computer For This Useful Post: |
02-07-2011, 22:59 | #11 (permalink) |
No Life Poster Join Date: Nov 2009 Location: portugal Age: 46
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | hello that´s good new´s for the beast....buut y kent update ur install models fones pack´s..... example:wen whee install InfinityUpdate_MModule_v3.73 v3.73: .Fly-MC105 model supported .Fly-MC175 model under test .Fly-MC220 model supported .Fly-Q200 model supported .Fly-E160 operations improved .Spice-M4242 model supported .Coral-280 model under test .Maxx-MQ340 model included in list .Maxx-MQ430 model included in list .UTStarcom-GPFE1238ENR model under test .BMobile-X131 model under test .Zonda-ZMTN610 unlock operations improved (new firmware types supported) .Lanix-X10 model under test .Doro-PhoneEasy-410s operations improved .Zonda-TF425 model under test .Fly-E130 model supported .Zonda-ZMCK870 model under test .Viettel-V6202 operations improved .Alcatel-255 operations improved .Alcatel-565 model supported .firmware database updated THIS WHANT APEAR ON SHELL UR BOX....dont now whay???????? |
02-09-2011, 06:34 | #13 (permalink) | |
did not understand please explain it what you want to say Br Faisal_Computer | |
02-18-2011, 13:19 | #14 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | This drivers work on windows 7 64bit without any modification in windows all that is needed JUST SELECT correct directory and that all. All work great and without any problems. http://forum.gsmhosting.com/vbb/f311...-here-1210050/ |
02-19-2011, 12:19 | #15 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,421 | Test mode disable again commands are Code: bcdedit.exe -set loadoptions ENABLE_INTEGRITY_CHECKS Code: bcdedit.exe -set TESTSIGNING OFF Faisal_Computer |
