Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 05-06-2014, 22:54   #1 (permalink)
Member: 382783
Thanks Meter: 124
No fear to flash this Nokia 503 SS ???
Hello,
i want flash a Nokia Asha 503 SS, ( store ,apps & rings are removed).
when read info:
operator : unknown
Locks : Damaged
SDD key status : Error read info
is there problem after flashing ??????
Old 05-06-2014, 23:55   #2 (permalink)
Member: 2128325
Thanks Meter: 3
after flash check imei
Old 05-07-2014, 02:55   #3 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Hello, read PM and send me, plese, interest to check.
About flash - sure you can without any fear.
Old 05-07-2014, 20:32   #4 (permalink)
Member: 382783
Thanks Meter: 124
Ok this PM file link,
rm-920 503_358996052948525_0_400 - Download - 4shared
Old 05-08-2014, 03:41   #5 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Ok, thanks for link. It is Ok, I will check ini for fix that. You can flash it or do anything with it as well now.
Old 05-08-2014, 11:29   #6 (permalink)
Member: 382783
Thanks Meter: 124
Thanks Mr Dzirt,
i flashed it & flash successfully Dooooooooooone.
Good team,Good work,Good experience,...Best surely is The Beeeeeeeeeeeeeest.
Old 05-30-2014, 07:35   #7 (permalink)
stylius's Avatar
Member: 51989
Sonork: 1575109
Thanks Meter: 145
Can not read sim lock info.
Reading Phone Info....
Connected phone - 503s
Software ver : V 12.1.9 17-12-13 RM-920 (c) Nokia
IMEI : 358996052265722
XappVer : 0000076C
APE Var : 0000000000000000000000000000000000000000
PPM : 7a8cf92204d28c0deafae28ba06f5c847498bace
CNT :
Product SN : 48576D2BH
Product code : 059V6Z6
Base Prd.code: 059S205
Module code : 0205680
Long Prod.SN : 0
Hardware info=======
HWID : 1000
Tahvo : RM-920-12.1.9-059V6Z6-12.1.4-12.1.4
Batery: 4070 mV
CMT BT: 19e2-4702H10
LCDVer: TPO
Lock info ===========
IMEI spNet : 3A 85 99 06 25 62 75 02
IMEI svNet : 33 85 99 06 25 62 75 32 F0
Conf key : 8181000803000000
Provider key : 0020000001FFFFFF
Country : Unknown
Operator : Unknown
Counters : Key 0 [3] , Fbus 0 [10]
Blocks : 0
LOCKS : Damaged!
CRT308 Backup Created
SDD key status : Error Read Info
CMLA Key status : Ok
SimLock status : Ok
Security status : Ok
PA_SimLock Version :
PA_SL30 (20 digit) phone detected...
User Code : not set
MMC pwd : no any record found
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
Old 05-30-2014, 08:53   #8 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
My fault , open BEST.ini , find string : RM-920=007200 , change it to RM-920=007100
Restart SW and all should be ok.
Old 05-30-2014, 09:47   #9 (permalink)
stylius's Avatar
Member: 51989
Sonork: 1575109
Thanks Meter: 145
Now working good.
Sl Conf : 234-33-00190233141
Sl Prof : 800000000004000-B
Sl Aux : 000B0000
Hw Sig : 77AD726D82BEBF69
Country : United Kingdom
Operator : Orange
Lock info:
Block 1
L1:Close;
Block 2
L1:Close;
Block 3
L1:Close;
SimLock status : Ok
User Code : not set
Old 06-01-2014, 12:01   #10 (permalink)
Member: 382783
Thanks Meter: 124
Thanks for info Mr.Dzirt
Best is always the Beeeeest
Old 03-08-2016, 06:44   #11 (permalink)
sachu2002's Avatar
Member: 2362867
Sonork: ththtuu
Thanks Meter: 659
need Nokia 503 SS tested firmware
Old 03-08-2016, 06:54   #12 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
All TESTED firmwares inside BEST NaviManager.
Page generated in 0.23337 seconds with 9 queries
