07-10-2014, 11:11 | #1 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Mars Age: 40
Member: 38084 Status: Offline Thanks Meter: 115 | Lumia 800 date recovery How read back brf? Read Key is disabled I have to select partition or sector? |
07-10-2014, 13:00 | #3 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. Wp7x tab. Extended - Unlock BL After follow instructions inside log. Extended - ReadBack - USER. Read it. Next tab after - extract info. |
The Following User Says Thank You to Dzirt For This Useful Post: |
07-10-2014, 13:12 | #4 (permalink) |
Member: 38084 Status: Offline Thanks Meter: 115 | Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... --- Press and hold 'Volume Up' button and insert cable! --- Connection opened successfully Establish connection with device... Kick ... - > Error on Preparing stage, Check Cable/Battery Error occured on QCSBL installing Connect phone on selected interface... |
07-10-2014, 15:06 | #7 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hm. That meant inside data is smashed and normal mode not help. Only forensic. I still work on it and not sure, when finish it and can I finish it or not. |
07-10-2014, 15:26 | #8 (permalink) | |
Member: 38084 Status: Offline Thanks Meter: 115 | Quote:
forensic will work with this readed brf? Can i write firmware without write userdata? -------------------------- after about 1 hour memory error | |
07-10-2014, 15:37 | #9 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | No , you can't revive that phone by any way within keep data. Try use R-studio to extract some content, I heard it can eat my readout files. You can extract some data in successful case, but not phonebook. |
07-10-2014, 18:15 | #11 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Other OS.nb "id" will kill user data. You will have empty phone. Don't waste time, because your FS is dead , even if you change all - it just erase UDA by itself , if some system UID changes. You can extract stock , by opening WP file ( bugger one) in winrar - big file is plain OS. |
