11-04-2012, 19:15 | #1 (permalink) |
Freak Poster Join Date: Apr 2009 Location: Setif
Member: 1020097 Status: Offline Sonork: 100.1612690 Thanks Meter: 83 | [RM-352] Writing SimLock Data... Error 1..../ BEFOR FLASH Code: Connect phone on selected interface... UFS S/N 27627 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 3600 slide Software ver : V 04.11 24-06-08 RM-352 (c) Nokia IMEI : 355706026404825 DSP Ver : ICPR72_08w24 PPM : V 04.11 24-06-08 RM-352 (c) Nokia C CNT : Product SN : DKJ515029 Product code : 0561174 Base Prd.code: 0551468 Module code : 0203624 Long Prod.SN : 0 Hardware info======= HWID : 1001 Retu : 15 Tahvo : 22 Batery: 4819 mV CMT BT: Error APE BT: Error APE HW: Error LCDVer: SEIKO RF ic : 064c0601 Lock info =========== IMEI : 355706026404825 IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! 2..../ FLASH Code: Phone found! Series 40 Device detected! read info... - Ok Core : v1.53 , FlashEngine : v1.9 Selected FlashSettings : Files Set for Flashing : MCU : rm352__57.23.mcusw PPM : rm352__57.23.ppm_c CNT : rm352__57.23.image_c_fr_charcoal_sl2 Check FlashFiles, Please, wait... -> Check SW version... FlashFile version : 57.23 Phone version : 04.11 24-06-08 RM-352 (c) Nokia -> Check SW version : Upgrade Backup enabled, Will read Certificates now... SLx Simlock Data read ... Ok SL2 Simlock read ... Ok WMDRM read ... Ok CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 0900020BF0160354DAC52D0CA3C9DBFD531B8BB5 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 220C00EC , CMT , NOR CMT Flash ID : 220C00EC < SAMSUNG [SEC] => K5G1257ATM FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : E4BA39EE248FC5E165E280B6AD60C5C0B1A1DA6DF9 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 355706026404825 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\355706026404825.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 0900020BF0160354DAC52D0CA3C9DBFD531B8BB5 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 220C00EC , CMT , NOR CMT Flash ID : 220C00EC < SAMSUNG [SEC] => K5G1257ATM FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : E4BA39EE248FC5E165E280B6AD60C5C0B1A1DA6DF9 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm352__57.23.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x014DFFFF CMT , NOR , Area : 0x014E0000 - 0x0167FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:00 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm352__57.23.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1367 blocks TIME : Write time : 00:02:26 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm352__57.23.ppm_c Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01680000 - 0x01F1FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:20 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm352__57.23.ppm_c Total writen 458 blocks TIME : Write time : 00:00:49 PrReq : NOR , 00 ConvertImage: Processing rm352__57.23.image_c_fr_charcoal_sl2 ConvertImage: Page Size is 128K, no need convert Transmission mode : Dual (Ddr, TX2) Erase : Processing rm352__57.23.image_c_fr_charcoal_sl2 Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01F20000 - 0x022BFFFF CMT , NOR , Area : 0x022C0000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:31 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm352__57.23.image_c_fr_charcoal_sl2 Total writen 584 blocks TIME : Write time : 00:01:02 PrReq : NOR , 00 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 3600 slide Software Info: V 57.23 17-07-09 RM-352 (c) Nokia IMEI: 12345610654321? Product code: 0561174 Checking... SimLock status : SimLock is Ok Security status : Security Damaged!!!!! :( Read Info Done! Checking User Certificates... Total - 0 certs Uploading certificates... Repair user cert failed :( AfterFlash operations done ;D Connect phone on selected interface... Connect phone on selected interface... Phone found! Code: Phone found! Series 40 Device detected! read info... - Ok Checking StartUp data ... ----------------------- IMEI Validation : IMEI Damaged!!!! - > SIMLOCK , SECURITY Info can be wrong! - > Need restore NPC backup or RPL SDD Key status : SDData is Ok CMLA Key status : CMLA key is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! :( - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL2 phone detected Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 3600 slide Software ver : V 57.23 17-07-09 RM-352 (c) Nokia IMEI : 12345610654321? DSP Ver : ICPR72_09w17 PPM : V 57.23 17-07-09 RM-352 (c) Nokia C CNT : Content: c_fr_charcoal_sl2 V 57.23 17-07-09 RM-352 (c) Nokia Product SN : DKJ515029 Product code : 0561174 Base Prd.code: 0551468 Module code : 0203624 Long Prod.SN : 0 Hardware info======= HWID : 1001 Retu : 15 Tahvo : 22 Batery: 4811 mV CMT BT: 2222-143C LCDVer: SEIKO RF ic : 064c0601 Lock info =========== IMEI : 12345610654321? IMEI spNet : IMEI svNet : Unable to read Lock table... :( User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Restor Rpl Backup Code: Phone found! Series 40 Device detected! read info... - Ok Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! WMDRM key found! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 0900020BF0160354DAC52D0CA3C9DBFD531B8BB5 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 220C00EC , CMT , NOR CMT Flash ID : 220C00EC < SAMSUNG [SEC] => K5G1257ATM FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) Boot Done! Preparing for write certificates... Switching to CMT... CMT : NPC erase Ok Writing NPC... Ok CMT : CCC erase Ok Writing CCC... Ok CMT : HWC erase Ok Writing HWC... Ok Init Service mode... Wait... Writing SimLock Data... Error Writing SimLock Key... Error |
