12-05-2012, 12:15 | #1 (permalink) |
Freak Poster Join Date: Oct 2012 Location: sadar cantt lahore
Member: 1821487 Status: Offline Thanks Meter: 18 | nokia 6303c rm 443 contact service when on set show start up phone without sim card? when accept this its show contact service and off after flash same condition help plz |
12-05-2012, 13:04 | #3 (permalink) |
Member: 1821487 Status: Offline Thanks Meter: 18 | Connect phone on selected interface... Core : v1.56 , FlashEngine : v3.3 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm443__10.10.mcusw PPM : rm443__10.10.ppm_mb CNT : rm443__10.10.image_mb_matt_black Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Backup enabled, Will read Certificates now... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 0BB000049E397F5630C2629BB96FB7E8BE1607B4 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 353411042984783 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Init Service mode... Wait... Init Service Mode Failed! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\353411042984783_CR T.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 0BB000049E397F5630C2629BB96FB7E8BE1607B4 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm443__10.10.mcusw Found 8 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x0005FFFF CMT , NOR , Area : 0x00060000 - 0x0007FFFF CMT , NOR , Area : 0x00080000 - 0x0015FFFF CMT , NOR , Area : 0x00160000 - 0x0023FFFF CMT , NOR , Area : 0x01740000 - 0x0191FFFF CMT , NOR , Area : 0x00240000 - 0x0173FFFF CMT , NOR , Area : 0x022E0000 - 0x0261FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:02:26 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm443__10.10.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 1587 blocks TIME : Write time : 00:03:33 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm443__10.10.ppm_mb Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01920000 - 0x022DFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:37 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm443__10.10.ppm_mb Total writen 367 blocks TIME : Write time : 00:00:49 PrReq : NOR , 00 ConvertImage: Processing rm443__10.10.image_mb_matt_black ConvertImage: Page Size is 128K, no need convert Transmission mode : Dual (Ddr, TX2) Erase : Processing rm443__10.10.image_mb_matt_black Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x02620000 - 0x029BFFFF CMT , NOR , Area : 0x029C0000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:23 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm443__10.10.image_mb_matt_black Total writen 560 blocks TIME : Write time : 00:01:10 PrReq : NOR , 00 Init Service mode... Wait... Init Service mode Failed! Skip AfterFlash Connect phone on selected interface... |
12-05-2012, 13:23 | #4 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Green Forest
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | flash not complete. check cable better to do usb flash check bsi line. read full flash and extract simlock data. PAPUBkeys blank (erased or HW failure) if your cable ok then dig it in HW BR |
12-05-2012, 17:55 | #6 (permalink) |
Insane Poster Join Date: Sep 2012 Location: indonesia
Member: 1813079 Status: Offline Sonork: tholibul ilmi Thanks Meter: 19 | D bro you problem two 1.no local mode 2.pasubkey step one you cek bsi line so that LOCal mode after local mode,,,,,,post you log.......... BR.ALVIAN V2 |
