navimanager not working hello im newuser navimanager not working ican download file show this SSChannel : Create SC SSChannel : Failed to get info! ErroInfo : Unable connect to SRV |
Hello. Open best.ini file ( located in C:\InfinityBox\BEST\ ) with NotePad. Find [server] section. Change SChan=1 to SChan=0 Save file. Download via NaviManager again. |
navimanager not working again SSChannel : Create SC SSChannel : Failed to get info! ErroInfo : Unable connect to SRV |
i need flash file nokia 603 rm-779 navimanager for same model is not working for other evry think is fine |
Try read sometimes. For example - sticky threads, or try check some buttons in NaviManager. |
thnk sir for reply i change channel in best.in to 0 i do evrey thnik but i cant download same flash file |
Then problem in your OS or Firewall. |
SSChannel : Create SC SSChannel : Failed to get info! ErroInfo : Unable connect to SR SSChannel : Create SC SSChannel : Failed to get info! ErroInfo : Unable connect to SRV whare is best.in |
Thanxxx My problem is infinty navifirm manager |
correct answer 100% ok Hello. Open best.ini file ( located in C:\InfinityBox\BEST\ ) with NotePad. Find [server] section. Change SChan=1 to SChan=0 Save file. Download via NaviManager again. |
i have same problem ...i changed the value but still same problem |
Hello. Then it mean you have one option left - " Copy Links ". Tick it and SW will generate links for files. |
WHERE IS THE "SChan=1 to SChan=0" [server] API=http://service.infinity-box.com/dcapi.php OnlineService=http://user.infinity-box.com # Set NaviFFLs option to 1 , if want download COMPLETE firmware package with all garbage NaviFFls=0 [Download] server-1=http://server1.infinity-best.com/download server-2=http://server2.infinity-best.com/download [Update] URL= [Configurator] Version=1 |
