09-18-2012, 08:46 | #1 (permalink) | |||
Freak Poster Join Date: Mar 2010 Location: Earth Age: 39
Member: 1265640 Status: Offline Sonork: 100.1622602 Thanks Meter: 51 | problem with repair SECURITY c6-01 i tried downgrade c6-01 rm-718 but after (erase-flash) restore pm&rpl i cannot repair security area . i do sx4 , repair sdd via usb but problem unresolved!! back up Quote:
Local SX4 procedure started... Quote:
09-18-2012, 08:55 | #3 (permalink) |
Member: 1265640 Status: Offline Sonork: 100.1622602 Thanks Meter: 51 | Code: PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 353759045459736 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Done! Operating mode is OK, no need change... Field 1 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 4 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 13 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 22 write - Ok Record 26 write - Ok Record 27 write - Ok Record 28 write - Ok Record 29 write - Ok Record 30 write - Ok Record 31 write - Ok Record 32 write - Ok Record 33 write - Ok Record 35 write - Ok Record 36 write - Ok Record 38 write - Ok Record 39 write - Ok Record 40 write - Ok Record 41 write - Ok Record 43 write - Ok Record 44 write - Ok Record 45 write - Ok Field 2 Record 0 write - Ok Field 4 Record 1 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 9 write - Ok Record 28 write - Ok Field 6 Record 0 write - Ok Field 8 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Field 11 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Field 12 Record 0 write - Ok Field 26 Record 0 write - Ok Record 1 write - Ok Field 31 Record 4 write - Ok Field 44 Record 0 write - Ok Field 50 Record 0 write - Ok Field 54 Record 0 write - Ok Record 2 write - Ok Field 96 Record 0 write - Ok Record 1 write - Ok Field 117 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 5 write - Ok Record 6 write - Ok Record 8 write - Ok Record 13 write - Ok Record 14 write - Ok Record 16 write - Ok Field 120 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Field 122 Record 0 write - Ok Field 153 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Field 193 Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 9 write - Ok Field 217 Record 0 write - Ok Field 239 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Field 291 Record 0 write - Ok Field 308 Record 0 write - Error Record 1 write - Error Record 3 write - Error Record 4 write - Error Record 6 write - Error Record 7 write - Error Record 9 write - Error Field 309 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 7 write - Ok Record 17 write - Ok Field 313 Record 0 write - Ok Field 322 Record 0 write - Ok Field 327 Record 0 write - Ok Field 329 Record 0 write - Ok Field 334 Record 0 write - Ok Field 341 Record 0 write - Ok Record 3 write - Ok Record 4 write - Ok Record 10 write - Ok Record 11 write - Ok Field 354 Record 0 write - Ok Field 356 Record 0 write - Ok Record 1 write - Ok Field 360 Record 0 write - Ok Record 1 write - Ok Field 369 Record 0 write - Ok Field 382 Record 1 write - Ok Field 388 Record 0 write - Ok Done! Elapsed: 00:00:00 Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok CMLA Key status : CMLA key Not exist SimLock status : SimLock is Ok Security status : Security Damaged!!!!! :( - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! |
