01-27-2022, 17:06 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | need Help ... nokia RM-1175 Contact Service.. Info log... Code: Operation : Identify [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM69) MODE : NOKIA USB SERIAL PORT : 69 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : B5707C8B3B00015B916359BDB7E2320A BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DOHA.10.01.11.p1 BOOT : SWR : 10.01.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : DOHA.10.01.11.p1 FLASH : 00EF : 0060 : 0018 : 0000 BBSN : B5707C8B3B00015B916359BDB7E2320A PRDC : 059X4M2 IMEI[1] : 356893073458109 IMEI[2] : 356893073458117 NCK : 20 digits PROV : 24407000 Saved as : 356893073458109.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:00:28 Format log... Code: Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 69 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : B5707C8B3B00015B916359BDB7E2320A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DOHA.10.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Doha.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 Executing FFS FORMAT now... FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:14 Flashing log.... Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1172_DOHA_ROM_eMP_80.00.11 VIVA : RM-1172_DOHA_VIVA_eMP_80.00.11 LANG : RM-1172_DOHA_LANG_PACK_ROM_ER_eMP_80.00.11 CUST : RM-1172_DOHA_CUSTPACK_ROM_ER_eMP_80.00.11 JMPT : RM-1172_DOHA_JUMP_TABLE_ER_eMP_80.00.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 69 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : B5707C8B3B00015B916359BDB7E2320A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DOHA.10.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Doha.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 SecureDecrypt : RM-1172_DOHA_ROM_eMP_80.00.11 SecureDecrypt : RM-1172_DOHA_VIVA_eMP_80.00.11 SecureDecrypt : RM-1172_DOHA_LANG_PACK_ROM_ER_eMP_80.00.11 SecureDecrypt : RM-1172_DOHA_CUSTPACK_ROM_ER_eMP_80.00.11 SecureDecrypt : RM-1172_DOHA_JUMP_TABLE_ER_eMP_80.00.11 OVRLP : 000069B900000001 PHPID : DOHA.10.01.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1172_DOHA_ROM_eMP_80.00.11 Write : RM-1172_DOHA_LANG_PACK_ROM_ER_eMP_80.00.11 Write : RM-1172_DOHA_CUSTPACK_ROM_ER_eMP_80.00.11 Write : RM-1172_DOHA_JUMP_TABLE_ER_eMP_80.00.11 Write : RM-1172_DOHA_VIVA_eMP_80.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1172_DOHA_ROM_eMP_80.00.11 [VERIFY] DONE : RM-1172_DOHA_LANG_PACK_ROM_ER_eMP_80.00.11 [VERIFY] DONE : RM-1172_DOHA_CUSTPACK_ROM_ER_eMP_80.00.11 [VERIFY] DONE : RM-1172_DOHA_JUMP_TABLE_ER_eMP_80.00.11 [VERIFY] DONE : RM-1172_DOHA_VIVA_eMP_80.00.11 CODE_VERIFY : Ok Flashing done! Total flash time : 00:02:33 Reboot phone Ok ReadInfo can't be done! Re-insert battery and power up phone manually 2nd BEST V2 flash log Code: Open VPLfile : RM-1172_059Z0X8_80.00.11.vpl Description : RM-1172 059Z0X8 ER 80.00.11 DeviceType : RM-1172 ProductCode : 059Z0X8 SoftwareVer : 80.00.11 PPM LangPack : [1] : Arabic (Saudi Arabia) [2] : Russian (Russia) [3] : Hebrew (Israel) [4] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM69) MODE : NOKIA USB SERIAL PORT : 69 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : B5707C8B3B00015B916359BDB7E2320A BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DOHA.80.00.11.p1 BOOT : SWR : 80.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : DOHA.80.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 80.00.11 [RM-1172] DEV SoftwareVersion : 80.00.11 SWInfo compare result : SAME Load FlashSet : MROM : RM-1172_DOHA_ROM_eMP_80.00.11 LANG : RM-1172_DOHA_LANG_PACK_ROM_ER_eMP_80.00.11 CUST : RM-1172_DOHA_CUSTPACK_ROM_ER_eMP_80.00.11 JUMP : RM-1172_DOHA_JUMP_TABLE_ER_eMP_80.00.11 VIVA : RM-1172_DOHA_VIVA_eMP_80.00.11 Prepare FlashSet : DCR : RM-1172_DOHA_ROM_eMP_80.00.11 DCR : RM-1172_DOHA_LANG_PACK_ROM_ER_eMP_80.00.11 DCR : RM-1172_DOHA_CUSTPACK_ROM_ER_eMP_80.00.11 DCR : RM-1172_DOHA_JUMP_TABLE_ER_eMP_80.00.11 DCR : RM-1172_DOHA_VIVA_eMP_80.00.11 Prepare Target SDS : OK : 0x00FF4000 : 0x0000C000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : RM-1172_DOHA_ROM_eMP_80.00.11 Write : RM-1172_DOHA_LANG_PACK_ROM_ER_eMP_80.00.11 Write : RM-1172_DOHA_CUSTPACK_ROM_ER_eMP_80.00.11 Write : RM-1172_DOHA_JUMP_TABLE_ER_eMP_80.00.11 Write : RM-1172_DOHA_VIVA_eMP_80.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1172_DOHA_ROM_eMP_80.00.11 Verify : RM-1172_DOHA_LANG_PACK_ROM_ER_eMP_80.00.11 Verify : RM-1172_DOHA_CUSTPACK_ROM_ER_eMP_80.00.11 Verify : RM-1172_DOHA_JUMP_TABLE_ER_eMP_80.00.11 Verify : RM-1172_DOHA_VIVA_eMP_80.00.11 Done! Elapsed: 00:02:39 Reconnect Power/Cable! |
01-28-2022, 10:14 | #4 (permalink) |
Member: 1146038 Status: Offline Thanks Meter: 196 | flash with this file so set is working but not india language ... https://drive.google.com/file/d/10qY..._sxgg5mr7/view |
