01-14-2019, 12:21 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Need Serbian Langue Flash for Nokia 105 TA-1034 I Need ED or EB langue pack v10.00.11 After update full firmware from v10.00.11 to v30.04.11 phone not power only keypad blinks ---------------------------- Card found : 07XXXXXX , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.09 Operation : Identify [ v1.09 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM750) MODE : NOKIA USB SERIAL PORT : 750 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCA02 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : B31CB5EEA6650F999A10F3FD50D55154 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.10.02.11.p1 BOOT : SWR : 10.02.11 BOOT : BDDS : 20 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : N103.10.02.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 BBSN : B31CB5EEA6650F999A10F3FD50D55154 PRDC : 059Z0W1 IMEI[1] : 355820091908626 IMEI[2] : 355820093908624 Done! Elapsed: 00:01:28 Reconnect Power/Cable! Operation : Read FirmWare [ v1.09 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM750) MODE : NOKIA USB SERIAL PORT : 750 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCA02 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : B31CB5EEA6650F999A10F3FD50D55154 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.10.02.11.p1 BOOT : SWR : 10.02.11 BOOT : BDDS : 20 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : N103.10.02.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 CODE : 0x00370000 Reading Flash ... TDSN : TA-1034 PRDC : 059Z0W1 PPM : EC LANG : [1] : Slovak (Slovakia) [2] : Hungarian (Hungary) [3] : Czech (Czech Republic) [4] : English (United Kingdom) BUILD : TA-1034_ROM_eMP_10.02.11 BUILD : TA-1034_LANG_PACK_ROM_EC_eMP_10.02.11_001 BUILD : TA-1034_CUSTPACK_ROM_EC_eMP_10.02.11_001 BUILD : TA-1034_JUMP_TABLE_EC_eMP_10.02.11_001 BUILD : TA-1034_VIVA_eMP_10.02.11 Make VPL definition Save Path : D:\D DISK\Program Files\Nokia\Phoenix\Products\TA-1034\ Save Name : TA-1034_059Z0W1_10.02.11.vpl Build Finished! Done! Elapsed: 00:09:16 Reconnect Power/Cable! Open VPLfile : TA-1034_059Z0W3_30.04.11.vpl Description : TA-1034 ED DeviceType : TA-1034 ProductCode : 059Z0W3 SoftwareVer : 30.04.11 PPM LangPack : [1] : Slovenian (Slovenia) [2] : Croatian (Croatia) [3] : Hungarian (Hungary) [4] : Bosnian (Bosnia and Herzegovina) [5] : German (Germany) [6] : FYRO Macedonian (Former Yugoslav Republic of Macedonia) [7] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.09 ] Setting : UserData erase : False Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM750) MODE : NOKIA USB SERIAL PORT : 750 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCA02 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : B31CB5EEA6650F999A10F3FD50D55154 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.10.02.11.p1 BOOT : SWR : 10.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.10.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8E NOR: 00C2 : 0020 : 0016 : 0000 NOR: [MXIC] MX25L3291FWJI_09 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 30.04.11 [TA-1034] DEV SoftwareVersion : 10.02.11 SWInfo compare result : DEVICE SW ( Major version ) is LOWER, than in VPL! Load FlashSet : MROM : TA-1034_ROM_eMP_30.04.11 LANG : TA-1034_LANG_PACK_ROM_ED_eMP_30.04.11_001 CUST : TA-1034_CUSTPACK_ROM_ED_eMP_30.04.11_001 JUMP : TA-1034_JUMP_TABLE_ED_eMP_30.04.11_001 VIVA : TA-1034_VIVA_eMP_30.04.11 Prepare FlashSet : DCR : TA-1034_ROM_eMP_30.04.11 DCR : TA-1034_LANG_PACK_ROM_ED_eMP_30.04.11_001 DCR : TA-1034_CUSTPACK_ROM_ED_eMP_30.04.11_001 DCR : TA-1034_JUMP_TABLE_ED_eMP_30.04.11_001 DCR : TA-1034_VIVA_eMP_30.04.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 Erase Target Flash Erase done! Write Target Flash Write : TA-1034_ROM_eMP_30.04.11 Write : TA-1034_LANG_PACK_ROM_ED_eMP_30.04.11_001 Write : TA-1034_CUSTPACK_ROM_ED_eMP_30.04.11_001 Write : TA-1034_JUMP_TABLE_ED_eMP_30.04.11_001 Write : TA-1034_VIVA_eMP_30.04.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1034_ROM_eMP_30.04.11 Verify : TA-1034_LANG_PACK_ROM_ED_eMP_30.04.11_001 Verify : TA-1034_CUSTPACK_ROM_ED_eMP_30.04.11_001 Verify : TA-1034_JUMP_TABLE_ED_eMP_30.04.11_001 Verify : TA-1034_VIVA_eMP_30.04.11 Done! Elapsed: 00:02:01 Reconnect Power/Cable! |
01-14-2019, 15:44 | #2 (permalink) |
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Solved thanks to a great guy from Greece (A.........) Solved thanks to a great guy from Greece (A.........) ----------------------------- Card found : 07XXXXXX , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.09 Open VPLfile : TA-1034_059Z0W3_10.02.11.vpl Description : TA-1034 ED DeviceType : TA-1034 ProductCode : 059Z0W3 SoftwareVer : 10.02.11 PPM LangPack : [1] : Slovenian (Slovenia) [2] : Croatian (Croatia) [3] : Hungarian (Hungary) [4] : Bosnian (Bosnia and Herzegovina) [5] : German (Germany) [6] : FYRO Macedonian (Former Yugoslav Republic of Macedonia) [7] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.09 ] Setting : UserData erase : False Setting : LangPack Only : True 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM750) MODE : NOKIA USB SERIAL PORT : 750 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCA02 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : B31CB5EEA6650F999A10F3FD50D55154 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.10.02.11.p1 BOOT : SWR : 10.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.10.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8E NOR: 00C2 : 0020 : 0016 : 0000 NOR: [MXIC] MX25L3291FWJI_09 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 10.02.11 [TA-1034] DEV SoftwareVersion : 10.02.11 SWInfo compare result : SAME Load FlashSet : LANG : TA-1034_LANG_PACK_ROM_ED_eMP_10.02.11_001 CUST : TA-1034_CUSTPACK_ROM_ED_eMP_10.02.11_001 JUMP : TA-1034_JUMP_TABLE_ED_eMP_10.02.11_001 Prepare FlashSet : DCR : TA-1034_LANG_PACK_ROM_ED_eMP_10.02.11_001 DCR : TA-1034_CUSTPACK_ROM_ED_eMP_10.02.11_001 DCR : TA-1034_JUMP_TABLE_ED_eMP_10.02.11_001 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 Erase Target Flash Erase done! Write Target Flash Write : TA-1034_LANG_PACK_ROM_ED_eMP_10.02.11_001 Write : TA-1034_CUSTPACK_ROM_ED_eMP_10.02.11_001 Write : TA-1034_JUMP_TABLE_ED_eMP_10.02.11_001 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1034_LANG_PACK_ROM_ED_eMP_10.02.11_001 Verify : TA-1034_CUSTPACK_ROM_ED_eMP_10.02.11_001 Verify : TA-1034_JUMP_TABLE_ED_eMP_10.02.11_001 Done! Elapsed: 00:00:42 Reconnect Power/Cable! |
10-03-2019, 10:24 | #5 (permalink) | |
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Quote:
https://www.4shared.com/rar/aq_ZwHjw...00211_ED.html? PPM LangPack : [1] : Slovenian (Slovenia) [2] : Croatian (Croatia) [3] : Hungarian (Hungary) [4] : Bosnian (Bosnia and Herzegovina) [5] : German (Germany) [6] : FYRO Macedonian (Former Yugoslav Republic of Macedonia) [7] : English (United Kingdom) | |
11-20-2019, 14:37 | #6 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Hungary, Pécs Age: 48
Member: 6142 Status: Offline Sonork: i dont use it Thanks Meter: 47 | Hi! Can you upload this TA-1034_059Z0W3_10.02.11_ED.rar file again? I have same problem, phone not turn on with newer flashfile! Thanks for help! |
07-25-2020, 12:58 | #7 (permalink) | |
Junior Member Join Date: Jan 2007 Location: Romania,Saint George Age: 34
Member: 432624 Status: Offline Thanks Meter: 3 | Quote:
can you upload the fw again? | |
