04-28-2020, 14:49 | #1 (permalink) |
No Life Poster Join Date: Mar 2018 Location: Future.... ✌️
Member: 2825953 Status: Offline Thanks Meter: 246 | Nokia 1 Plus TA-1111 DM Verification Failed Issue !! How To Fix it ? Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Load : C:\Users\Toshiba\ANT-0360-0-00WW-B02.nb0 Load Ok! Operation : Write FW [ v1.20 ] Setting : UserData preserve : False Setting : Flash Pre-Erase : True Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... Device not found ! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Write FW [ v1.20 ] Setting : UserData preserve : False Setting : Flash Pre-Erase : False Setting : Bootloader update : False 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY BROM : PRELOADER PORT BROM : SOCID : 3004D43882476769C4719C84128273AD61893475A127783945 1AC213E25AF484 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6739 AGENT : BEST_Nokia_DA_v19_1711_06 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 150100464E36324D42030C27D35666AF EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 46A881FEA8E8B28CADBF2B28C72FA2A1 DA : USB : HIGH-SPEED Boot done! DL_INFO : PMT present SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : HW verification passed! Prepare : Flash Pre-Erase disabled PMT Update : OK Flashing now ... PROCESS : PRELOADER Unpack : ANT-0-0360-00WW-1-1-preloader_ANT.bin Flash : ANT-0-0360-00WW-1-1-preloader_ANT.bin Update bootloader backup copy ... Update bootloader backup copy Ok! PROCESS : RECOVERY Unpack : ANT-0-0360-00WW-1-1-recovery.img Flash : ANT-0-0360-00WW-1-1-recovery.img PROCESS : MD1IMG Unpack : ANT-0-0360-00WW-1-1-md1img.img Flash : ANT-0-0360-00WW-1-1-md1img.img PROCESS : MD1DSP Unpack : ANT-0-0360-00WW-1-1-md1dsp.img Flash : ANT-0-0360-00WW-1-1-md1dsp.img PROCESS : SPMFW Unpack : ANT-0-0360-00WW-1-1-spmfw.img Flash : ANT-0-0360-00WW-1-1-spmfw.img PROCESS : MCUPMFW Unpack : ANT-0-0360-00WW-1-1-mcupmfw.img Flash : ANT-0-0360-00WW-1-1-mcupmfw.img PROCESS : LK Unpack : ANT-0-0360-00WW-1-1-lk.img Flash : ANT-0-0360-00WW-1-1-lk.img PROCESS : LK2 Unpack : ANT-0-0360-00WW-1-1-lk.img Flash : ANT-0-0360-00WW-1-1-lk.img PROCESS : LOADER_EXT1 Unpack : ANT-0-0360-00WW-1-1-loader_ext.img Flash : ANT-0-0360-00WW-1-1-loader_ext.img PROCESS : LOADER_EXT2 Unpack : ANT-0-0360-00WW-1-1-loader_ext.img Flash : ANT-0-0360-00WW-1-1-loader_ext.img PROCESS : BOOT Unpack : ANT-0-0360-00WW-1-1-boot.img Flash : ANT-0-0360-00WW-1-1-boot.img PROCESS : LOGO Unpack : ANT-0-0360-00WW-1-1-logo.bin Flash : ANT-0-0360-00WW-1-1-logo.bin PROCESS : DTBO Unpack : ANT-0-0360-00WW-1-1-dtbo.img Flash : ANT-0-0360-00WW-1-1-dtbo.img PROCESS : TEE1 Unpack : ANT-0-0360-00WW-1-1-tee.img Flash : ANT-0-0360-00WW-1-1-tee.img PROCESS : TEE2 Unpack : ANT-0-0360-00WW-1-1-tee.img Flash : ANT-0-0360-00WW-1-1-tee.img PROCESS : VENDOR Unpack : ANT-0-0360-00WW-1-1-vendor.img Flash : ANT-0-0360-00WW-1-1-vendor.img PROCESS : SYSTEM Unpack : ANT-0-0360-00WW-1-1-system.img Flash : ANT-0-0360-00WW-1-1-system.img PROCESS : CACHE Unpack : ANT-0-0360-00WW-1-1-cache.img Flash : ANT-0-0360-00WW-1-1-cache.img PROCESS : USERDATA Unpack : ANT-0-0360-00WW-1-1-userdata.img Flash : ANT-0-0360-00WW-1-1-userdata.img PMT Update : OK SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 Flashing finished! Done! Elapsed: 00:02:29 Reconnect Power/Cable! |
