07-13-2015, 08:37 | #63 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | From BEST v2.09 possible reset user code on following phones without ANY byte of UserData Lost : Nokia 105 SS [RM-1133] Nokia 105 DS [RM-1134] Nokia 105 SS [RM-1135] |
07-13-2015, 10:22 | #65 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,974 | [BEST] v2.09 released - http://forum.gsmhosting.com/vbb/f641...-more-1968671/ |
07-24-2015, 11:41 | #66 (permalink) |
No Life Poster Join Date: May 2013 Location: TkinterPy,Hex Cal,Ext2,Ext4,
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Nokia 130 security code reset without data lose done. Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 468 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 85AEAC6D73B41D3209B4CBF1657C44B5 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
The Following User Says Thank You to ij_cell For This Useful Post: |
07-28-2015, 21:41 | #67 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Code: Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 16 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : EABB74F587812ED2027FE99F2FE9F3FD BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... | |
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
08-18-2015, 11:34 | #71 (permalink) |
Freak Poster Join Date: Nov 2007
Member: 629558 Status: Offline Thanks Meter: 53 | RM-969 - Nokia 220 DS Hang Logo Done Operation : Check / Read Info [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 95 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 1C1FB29CAEAA7DDF37F53AC5227DBAD4 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Nk1.fg DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Format FileSystem [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 95 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 1C1FB29CAEAA7DDF37F53AC5227DBAD4 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Nk1.fg DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 Executing FFS FORMAT now... FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:01:04 Reconnect Power/Cable! |
The Following User Says Thank You to nans1981 For This Useful Post: |
08-23-2015, 12:49 | #72 (permalink) |
Junior Member Join Date: Aug 2015
Member: 2448515 Status: Offline Thanks Meter: 1 | yes i agreed that fault is cable i tested 3 time error the reset and finally i changed the cable then my problem is solved dont use uart combo cable only use usb fbuss cable sorry for my bad english |
