10-18-2020, 16:05 | #1 (permalink) |
Insane Poster Join Date: Sep 2017
Member: 2763156 Status: Offline Thanks Meter: 28 | Any plan of fixing Nokia C3 identification? Code: Card found : xxxxxxxx , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Identify [FTM] [ v1.20 ] -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Executing fastboot oem getsecurityversion will return 3 FYI. Also from what I have acknowledged, this device utilized a special build of PackageDownload that requires online authorization for flashing - either generic Infinity CM2SP2 or ResearchDownload won't flash it properly. And of course, I've already got the stock firmware (both CN and Global). |
10-18-2020, 17:31 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, You know about "online authorization for flashing" - it's good. There is no alternative solution for it at the moment. And yes, more work regarding [BEST] improvements is in progress. please upload flash files for investigation via IOS File Uploader Tool |
10-19-2020, 02:10 | #3 (permalink) | |
Member: 2763156 Status: Offline Thanks Meter: 28 | Quote:
I believe @JayDi will have access of these files. | |
10-19-2020, 02:16 | #4 (permalink) |
Member: 2763156 Status: Offline Thanks Meter: 28 | Output of "fastboot oem getversions": Code: (bootloader) model=Nokia C3 (bootloader) sub_model=nokia_cn (bootloader) software version=00CN_1_040 (bootloader) SW model=00CN (bootloader) build number=A01 (bootloader) hardware version=V01 (bootloader) RF band id=RF_BAND_ID OKAY [ 0.030s] Finished. Total time: 0.039s |
