08-12-2021, 09:25 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | Nokia 150 TA-1235 Read firmware log for support Identify: Code: Operation : Identify [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM283) MODE : NOKIA USB SERIAL PORT : 283 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 7605486901C647F5F15F9F370BDDE1EF BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : GEMINIVAL.10.01.11.p1 BOOT : SWR : 10.01.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : GEMINIVAL.10.01.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 PRDC : 059Z0X8 IMEI[1] : 35316311021xxxx IMEI[2] : 35316311121xxxx NCK : 20 digits PROV : 24407000 Saved as : 35316311021xxxx.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:00:29 Reconnect Power/Cable! Code: Operation : Read FirmWare [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM283) MODE : NOKIA USB SERIAL PORT : 283 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 7605486901C647F5F15F9F370BDDE1EF BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : GEMINIVAL.10.01.11.p1 BOOT : SWR : 10.01.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : GEMINIVAL.10.01.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 CODE : 0x00398000 Error : Device NOT supported for SAFE READ! Send log and report.log to support! Include device info also! Reconnect Power/Cable! mtsec - attached. |
The Following 2 Users Say Thank You to Dr_Wolodya For This Useful Post: |
10-25-2021, 13:40 | #2 (permalink) |
Banned Join Date: Aug 2017 Location: kerala Age: 26
Member: 2751649 Status: Offline Thanks Meter: 6 | writing not done. infinity best error 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM15) MODE : NOKIA USB SERIAL PORT : 15 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 2C32259E8A06492C1667E15B52A80FB2 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : GEMINIVAL.10.01.11.p1 BOOT : SWR : 10.01.11 AGENT : Look for suitable BootChain in DA ... AGENT : Device AutoID failed! Error : Fail to init protocol! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
The Following User Says Thank You to alwinbenny For This Useful Post: |
