06-15-2014, 13:33 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | nokia c2-03 rm702 contact service Code: Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Checking StartUp data ... ----------------------- CMLA Key status : CMLA key Not exist SimLock status : SimLock Damaged!!!!! :( - > Do REPAIR SL if it SL2/SL phone, if SL3 - Help Only Backup Or RPL Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL phone detected Done! here the pm and RPL bakup Rahim - Download - 4shared |
06-15-2014, 14:43 | #3 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Code: card found: S/N 900A:0122 registered to: Rahim khan Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created Check communication with phone.... Communication verify done... Preparing... SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok Reboot.... Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF EBL Loader : Custom Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL : Custom EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Boot done! Read CRT block... Read EEPROM block... WMDRM Key found ... ===== USER CODE ===== Executing Code extraction... - > Phone Lock Code : 12345 ===== USER CODE ===== MMC password not found (not set) NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\359735041153865_2nd_XG213.rpl Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok already post rpl and pm bakup |
