12-20-2019, 21:08 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Romania,Buc
Member: 694535 Status: Offline Thanks Meter: 70 | rm-1190 read rpl/ flash failed Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 266 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 9A28F3B4171AC5AF0FD0A28A17CC2379 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DUBAI61D.30.00.11.p1 BROM/BL stage done Configure RAMINIT Ok Reading flash now ... Done! Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive Mobile Info IMEI : 355808090588309 BBUID : 9A28F3B4171AC5AF0FD0A28A17CC2379 PCCode: 059X8T7 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 355808090588xxx_MTKx_2nd.mtsec Read Done! Connect phone on selected interface... Flashing log Core : v2.24 , MTKx FlashEngine : v10.2 Verify files ... MAUI : RM-1190_DUBAI_ROM_eMP_40.00.11 VIVA : RM-1190_DUBAI_VIVA_eMP_40.00.11 LANG : RM-1190_DUBAI_LANG_PACK_ROM_EI_eMP_40.00.11 CUST : RM-1190_DUBAI_CUSTPACK_ROM_EI_eMP_40.00.11 JMPT : RM-1190_DUBAI_JUMP_TABLE_EI_eMP_40.00.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 266 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 9A28F3B4171AC5AF0FD0A28A17CC2379 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DUBAI61D.30.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW NOT Found Connect phone on selected interface... Boot Error Flashing failed! Connect phone on selected interface... What is the problem ? |
