Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 09-11-2012, 10:18   #1 (permalink)
kasner's Avatar
Member: 56469
Thanks Meter: 136
How to fix CMLA Key status : read data error
How to fix CMLA Key status : read data error on Nokia X2-02.
WBr Kasner
Old 09-11-2012, 12:32   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Hello.
Seems, problem in phone SW.
Try reflash, make factory sets.
Old 09-11-2012, 13:17   #3 (permalink)
xseven's Avatar
Member: 649553
Thanks Meter: 45
rm-607 after flash n factory setting
Phone found!
Series 40 Device detected!
read info... - Ok
Checking StartUp data ...
INFINEON : SDData is not present (It is Ok)
SimLock status : SimLock is Ok
Security status : Security is Ok
PA_SimLock Version :
PA_SL3 phone , SP_CODE_LEN : 15
Done!
Old 09-11-2012, 13:28   #4 (permalink)
xseven's Avatar
Member: 649553
Thanks Meter: 45
and i flash again
-> If Windows say "Unrecognized device" - just reinsert battery
-> If flashing freeze - reinsert cable and try again
--- Press phone's power button or insert charger! ---
Connection opened successfully
DBG : F00A1FB300020303010100FF
CPUID : XGOLD 213
2nd boot Ok, 01
2nd ready, AA
Sending Algo
Algo sent Ok
BL : Quantum_Bootloader_2.5_M1S1
Speed accepted, use 6.500.000
FLASHID : EC001230
FLIC conf set, RST set
Boot done!
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI : 357009045832946
PCcode : 059F0V3
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : D:\hwk\infi\InfinityBox_FREE_BEST_v1.51_2\Backup\C ert\357009045832946_2nd_XG213_CRT.rpl
===Flashing [MCU]===
File : rm607__06.15.mcusw
Image : rm607__06.15.mcusw_ebl_psi.fls
Cert block found, sending....
Cert sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00040000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00040000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40080000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40080000 , Len : 0x00020000
Flashing , wait ...
Processing Region 4/5
Erase , Start : 0x400A0000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:02
Write , Start : 0x400A0000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 5/5
Erase , Start : 0x40400000 , Len : 0x01800000
Erasing, wait ...
Erase done, time : 00:00:48
Write , Start : 0x40400000 , Len : 0x01780000
Flashing , wait ...
Region flash done, time : 00:00:29
===Flashing [PPM]===
File : rm607__06.15.ppm_x
Image : package_x.ppm_ebl_psi.fls
Cert sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41C00000 , Len : 0x00600000
Erasing, wait ...
Erase done, time : 00:00:08
Write , Start : 0x41C00000 , Len : 0x0041A488
Flashing , wait ...
Region flash done, time : 00:00:04
===Flashing [CNT]===
File : rm607__06.15.image_x_0596685
Image : package_x_0596685.image.fls
Cert sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x42200000 , Len : 0x01C60000
Erasing, wait ...
Erase done, time : 00:01:05
Write , Start : 0x42200000 , Len : 0x00DC0000
Flashing , wait ...
Region flash done, time : 00:00:16
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
No write data, skip
Flashing done!
Total flash time : 00:03:00
Reboot phone now...
Reading Phone Info....
Connected phone - C1-01
Software Info: V 06.15 25-11-11 RM-607 (c) Nokia
IMEI: 357009045832946
PPM version : V 06.15 25-11-11 RM-607 (c) Nokia X
Product code: 0596685
Checking...
Read Info Done!
Settings After Flash Defaults...
ProductTuneSet...OK!
SwUpgradeSet...OK!
Product code update...
Resetting LifeTimer
Reset Done!
Checking User Certificates...
Total - 39 certs
Data exist, skip certificate repair...
Battery voltage is enough for start
AfterFlash operations done ;D
Done!
Connect phone on selected interface...
Elapsed: 00:03:34
Phone found!
read info... - Ok
Read and Check phone data...
RAP_BOOT: 0000000000000000
RAP_PUB: 0000000000000000000000000000000000000000
CMT_ROOT: 00000000000000000000000000000000
RAP_PAPUB: 0000000000000000000000000000000000000000
Live Test Ok!
CNT sector : 128 kb
Old 09-11-2012, 13:41   #5 (permalink)
xseven's Avatar
Member: 649553
Thanks Meter: 45
rm-702 after flash
Live Test Ok!
CNT sector : 128 kb
Old 09-11-2012, 13:43   #6 (permalink)
xseven's Avatar
Member: 649553
Thanks Meter: 45
rm-702 can't read full flash via usb
Dead Mode is Selected
Waiting for USB device...
--- Insert cable and charger or press phone's power button! ---
Waiting for communication response...
BootRom : Verify Error
Try again...
-> Error answer from BootRom
Boot error #1, break
Phone disconected!
Old 09-11-2012, 15:49   #7 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Sure, and will not read it.
It is XG213 phone.
About Old Models - C1-01 and same - they not have CMLA at all, so, no anything can be inside.
The Following 3 Users Say Thank You to Dzirt For This Useful Post:
Old 09-15-2012, 14:19   #8 (permalink)
xseven's Avatar
Member: 649553
Thanks Meter: 45
ok thank bos, that answer my question
Old 11-22-2015, 06:04   #9 (permalink)
Member: 879723
Thanks Meter: 6
x2-05, CMLA Key status : Not Present . Plz hlep
Phone found!
read info... - Ok
Connected phone - X2-05
Software ver : V 08.60a 27-12-11 RM-772 (c) Nokia
IMEI : 35740604941xxxx
XappVer : 00000848
PPM : V 08.60a 27-12-11 RM-772 (c) Nokia D
CNT : Content: tele2 HR V 08.60a 27-12-11 RM-772 (c) Nokia
Product SN : 84F1AADAH
Product code : 059N8G1
Base Prd.code: 059F6M7
Module code : 0204959
Long Prod.SN : 0
Hardware info=======
HWID : 1001
Battery: 3750 mV
CMT BT: 19b5-22012
LCDVer: TPO
Lock info ===========
IMEI : 357406049415001
IMEI spNet : 3A 75 04 06 94 14 05 00
IMEI svNet : 33 75 04 06 94 14 05 00 F7
Sl Conf : 001-01-00000000000
Sl Prof : 800000000003000-B
Sl Aux : 000B0000
Hw Sig : 8E65C761940F4ED4
Country : Test SIM (Open)
Operator : NOKIA (Open)
Lock info:
Block 1
L1:Open; L2:Open; L3:Open; L4:Open; L5:Open;
Block 2
Block 3
Block 4
Block 5
Block 6
Block 7
Error collect lock info, try again
CRT308 Backup Created
SimLock status : Ok
Security status : Ok
User Code : 12345
MMC pwd : no any record found
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
Old 11-22-2015, 13:56   #10 (permalink)
Member: 879723
Thanks Meter: 6
Nokia X2-05 RM-772 after flash n factory setting
SimLock status : Ok
how to solve CMLA Key status : Not Present
Old 11-22-2015, 16:58   #11 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Seems as you have NO idea, what it and for why. If it really disturb you - close your eyes next time.
Old 11-22-2015, 17:22   #12 (permalink)
Member: 1900449
Sonork: 100.1613676
Thanks Meter: 26
Bro Use atfbox and repair CMLA key 1click
Sent from my iPhone using Tapatalk
Old 11-22-2015, 17:39   #13 (permalink)
JayDi's Avatar
Member: 462970
and from where you come, oversmarted "friend"? Increase your pity "post" counter in trash section.
Old 11-24-2015, 10:01   #14 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
CMLA Key not needed for X2, it will work fine
Page generated in 0.20402 seconds with 8 queries
