02-06-2022, 14:11 | #1 (permalink) |
Freak Poster Join Date: Oct 2010 Location: Transylvania
Member: 1423806 Status: Offline Sonork: 100.1685119 Thanks Meter: 44 | Nokia E71 - cannot read SL3 BF Phone Imei: 352924026****** Checking locks... Conf key : 8000000000000000 Provider key : 2420100000000000 Country : Norway Operator : TELENOR Counters : Key 0 [3] , Fbus 1 [10] Blocks : 4 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Close Lock3:Close BLK : 2 Lock1:Open Lock2:Close Lock3:Open BLK : 3 Lock1:Close Lock2:Close BLK : 4 Lock1:Open Lock2:Close Lock3:Close ============================= LOCKS : Closed ============================= PA_SL2 phone detected... Use "Unlock" button... Error...! If I press just "Unlock", it tells me this: Phone Imei: 352924026****** Checking locks... Conf key : 8000000000000000 Provider key : 2420100000000000 Country : Norway Operator : TELENOR Counters : Key 0 [3] , Fbus 1 [10] Blocks : 4 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Close Lock3:Close BLK : 2 Lock1:Open Lock2:Close Lock3:Open BLK : 3 Lock1:Close Lock2:Close BLK : 4 Lock1:Open Lock2:Close Lock3:Close ============================= LOCKS : Closed ============================= PA_SL2 phone detected... Setting FlashMode FlashMode set Ok No answer from phone... - > 1. Check cable/connection, try again - > 2. Maybe HW fault or bad cable Error fetching data... Can't read Unique data! NCK unlock failed, will try direct RPL Phone disconected! Connect phone on selected interface... Direct RPL Unlock Error! [SL3 phone?] Here is the "Read info" log: Reading Phone Info.... Connected phone - Nokia E71 Software ver : V ICPR71_09w47.5 24-05-10 RM-346 (c) Nokia IMEI : 352924026****** XappVer : 000008F2 Ape Ver : 500.21.009 APE Var : 500.21.009500.21.009_v18 APE ADSP: 256 DSP Ver : ICPR71_09w40 APE Test: RM346ENO74110842.a36 PPM : CNT : Product SN : MMJ****** Product code : 0568829 Base Prd.code: 0552256 Long Prod.SN : 0 Hardware info======= HWID : 0910 Retu : 15 Tahvo : 22 Battery: 4394 mV APE HW: 256 RF ic : 17141715 Lock info =========== IMEI : 352924026****** IMEI spNet : IMEI svNet : Conf key : 8000000000000000 Provider key : 2420100000000000 Country : Norway Operator : TELENOR Counters : Key 0 [3] , Fbus 1 [10] Blocks : 4 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Close Lock3:Close BLK : 2 Lock1:Open Lock2:Close Lock3:Open BLK : 3 Lock1:Close Lock2:Close BLK : 4 Lock1:Open Lock2:Close Lock3:Close ============================= LOCKS : Closed ============================= Error collect lock info, try again User Code : Not Set UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! What I'm missing here? |
02-06-2022, 15:04 | #2 (permalink) |
No Life Poster Join Date: Sep 2008 Location: FMI OF Age: 52
Member: 866455 Status: Offline Sonork: SAMSUNG CPID ONLINE Thanks Meter: 577 | use hwk or jaff as interface and box cabel dont use usb rj45 https://multi-com.eu/,details,id_pr,...touch-4pc.html |
02-13-2022, 17:53 | #3 (permalink) | |
Member: 1423806 Status: Offline Sonork: 100.1685119 Thanks Meter: 44 | Quote:
02-13-2022, 21:33 | #4 (permalink) | |
Member: 866455 Status: Offline Sonork: SAMSUNG CPID ONLINE Thanks Meter: 577 | Quote:
02-14-2022, 13:51 | #5 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: John Kemeny1926-1992 Age: 57
Member: 136220 Status: Offline Thanks Meter: 403 | Quote:
PA_SL2 phone detected.. FREE unlock ufs cable rj 45 | |
