12-30-2023, 11:33 | #1 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | Nokia ta-1452 mtk cpu can't boot HELLO TEAM PLEASE GIVE ME SOLUTION Card found : ADCE8487 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Identify [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1633 (Android) (COM21) MODE : PRELOADER PORT PORT : 21 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT BROM : SOCID : F65A2EA8E600BF80CB3750BC4F1929A95A040405B83A7DEF58 A0091405404AA1 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6739 AGENT : BEST_Nokia_DA_v19_1711_06 BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT MODE! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1633 (Android) (COM21) MODE : PRELOADER PORT PORT : 21 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT BROM : SOCID : F65A2EA8E600BF80CB3750BC4F1929A95A040405B83A7DEF58 A0091405404AA1 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6739 AGENT : BEST_Nokia_DA_v19_1711_06 BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT MODE! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
The Following User Says Thank You to pintu_das For This Useful Post: |
