08-17-2013, 10:42 | #1 (permalink) |
Freak Poster Join Date: Mar 2009
Member: 985391 Status: Offline Thanks Meter: 12 | nokia 2055 rm 863 flashed with nokia best service tool Code: Connect phone on selected interface... Core : v1.68 , BB5XG FlashEngine : v5.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm863__03.20.mcusw PPM : rm863__03.20.ppm_meg CNT : rm863__03.20.image_meg_059Q0M0_059S5G2_259_03 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.55_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! ===Flashing [MCU]=== File : rm863__03.20.mcusw Image : rm863__03.20.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01780000 Erasing, wait ... Erase done, time : 00:02:20 Write , Start : 0x40280000 , Len : 0x01780000 Flashing , wait ... Region flash done, time : 00:00:32 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip ===Flashing [PPM]=== File : rm863__03.20.ppm_meg Image : package_meg.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A00000 , Len : 0x00640000 Erasing, wait ... Erase done, time : 00:00:24 Write , Start : 0x41A00000 , Len : 0x00401E58 Flashing , wait ... Region flash done, time : 00:00:04 ===Flashing [CNT]=== File : rm863__03.20.image_meg_059Q0M0_059S5G2_259_03 Image : rm863__03.20.image_meg_059Q0M0_059S5G2_259_03.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42040000 , Len : 0x01DE0000 Erasing, wait ... Erase done, time : 00:03:28 Write , Start : 0x42040000 , Len : 0x00E60000 Flashing , wait ... Region flash done, time : 00:00:18 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:05 No write data, skip Flashing done! Total flash time : 00:07:23 Reboot phone now... Reading Phone Info.... Connected phone - 2055 Software Info: V 03.20 25-02-13 RM-863 (c) Nokia IMEI: 353700056946369 PPM version : V 03.20 25-02-13 RM-863 (c) Nokia MEG Product code: 059S5H7 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:08:21 Connect phone on selected interface... |
The Following User Says Thank You to markgmark For This Useful Post: |
