07-31-2020, 07:53 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Update Firmware done v13 to v20 nokia 3310 3G TA-1022 ------------------------------------ Card found : 07EXXXXXX , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Identify [ v1.20 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! SW_VERS : 13.0.0.17.01 PC_EXTR : AX 059Z3D9 IMEI[1] : 357305083761744 IMEI[2] : 352751019523267 BT_ADDR : 9F88F528F104 Security saved : NKSPDv2_357305083761744.scnv Done! Elapsed: 00:00:38 Reconnect Power/Cable! -------------------------------------------- Operation : Read Flash Dump [ v1.20 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! SW_VERS : 13.0.0.17.01 PC_EXTR : AX 059Z3D9 IMEI[1] : 357305083761744 IMEI[2] : 352751019523267 BT_ADDR : 9F88F528F104 Dumping Flash Content ... Read Ok! Saved as : NKSPDv2_357305083761744.bin Saved to : C:\InfinityBox\BEST2\phdata\ Done! Elapsed: 00:10:34 Reconnect Power/Cable! ------------------------------------------------------ File : TA-1022_20.0.0.17.00_AW_059Z3B7.sprd SWVersion : TA-1022_PL_SW20 Operation : Write FirmWare [ v1.20 ] Setting : False : Full Factory Reset Setting : True : NVRAM Update/Swap 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! [NVM] : Initialize SRC [NVM] : Initialize DST [NVM] : Prepare [NVM] : SWP : 0x000B : 0x000A [NVM] : Update [NVM] : Update Ok! Flash : KERNELIMG Flash : BOOTLOADER Flash : USERIMG Flash : MMIRES Flash : DSPCODE Flash : DSPCODE2 Erase : ERASE AUTOSMS Erase : ERASE PRELOAD Flash : PRELOAD Erase : FLASH Flashing finished! Done! Elapsed: 00:01:26 Reconnect Power/Cable! |
The Following User Says Thank You to gile@gile For This Useful Post: |
