after flash 205 restart on camera solution. Just Downgrade 3.18 problem Solved. Code:
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len : 0x0A
IF xCPUID : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data : 1FB300020303010100FF
Sending EBL Loader ...
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.55_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
Check keys...
Check done. Image can be flashed
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 355903058008927
IMEI 2 : 355903058008935
PCcode : 059R4V4
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\355903058008927_2nd_XG213_CRT.rpl
Settings : EDM [0x8] , Block Mode , Fast CRC , Verify
===Flashing [MCU]===
File : rm862__03.18.mcusw
Image : rm862__03.18.mcusw_ebl_psi.fls
Sec-pack found, sending ...
Sec-pack sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:01
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:06
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x017C0000
Erasing, wait ...
Erase done, time : 00:02:18
Write , Start : 0x40280000 , Len : 0x017C0000
Flashing , wait ...
Region flash done, time : 00:00:33
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
CRC check passed , 0x107F
===Flashing [PPM]===
File : rm862__03.18.ppm_ma3
Image : package_ma3.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41A40000 , Len : 0x00640000
Erasing, wait ...
Erase done, time : 00:00:23
Write , Start : 0x41A40000 , Len : 0x003EF9A4
Flashing , wait ...
Region flash done, time : 00:00:04
CRC check passed , 0xEC56
===Flashing [CNT]===
File : rm862__03.18.image_ma3_059Q046
Image : package_ma3_059Q046.image.fls
Sec-pack sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x42080000 , Len : 0x01DA0000
Erasing, wait ...
Erase done, time : 00:03:34
Write , Start : 0x42080000 , Len : 0x00FC0000
Flashing , wait ...
Region flash done, time : 00:00:20
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
No write data, skip
CRC check passed , 0x1FE7
Flashing done!
Total flash time : 00:07:31
Reboot phone now...
Reading Phone Info....
Connected phone - 205
Software Info: V 03.18 02-12-12 RM-862 (c) Nokia
IMEI: 355903058008927
PPM version : V 03.18 02-12-12 RM-862 (c) Nokia MA3
Product code: 059R4V4
Wait, when phone will be ready ...
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Check and Upload User Certificates ...
Total - 42 certs
Certificates found, skip upload ...
Set phone to Normal mode...
AfterFlash operations done ;D
Done!
Connect phone on selected interface...
Elapsed: 00:08:22
Connect phone on selected interface... |
