10-22-2012, 13:51 | #1 (permalink) |
No Life Poster Join Date: Apr 2012 Location: -->Certs+ Sboot
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | Nokia C5-00 Dead After Flashing Files Set for Flashing : MCU : rm645_071.005_prd.core.fpsx PPM : rm645_071.005_21.01_India_prd.rofs2.fpsx PPM2 : rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx CNT : rm645_071.005_U000.000_prd.uda.fpsx APE : RM645_ENO_10wk48v0.001.fpsx Now How Can I Recover Please Help Team Regards, |
10-24-2012, 12:36 | #5 (permalink) | |
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | Check This Quote:
I Think I M In Mistaken So Check My LOgs Sir...................... User ACCEPTED FULL ERASE Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 12B00005DA9403445031142F2886A87FC4D4D8D6 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Seek file for this phone.... - > RPL backup found, but not full (NPC/SimLock absent) !!! - > Make RPL read from Alive/Dead , Make FlashRead - > Or check "Skip Bak.Chk." Stopping operation... Please Guide For Next.................. Regards, | |
10-24-2012, 19:22 | #6 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Pakistan Lower Dir kpk
Member: 651892 Status: Offline Thanks Meter: 205 | With out Full Backup U Erased Your Phone??? Did u Read Full Flash Backup From your phone Before Erasing?? If Not, Then Answer is Simple u Need to Buy Rpl For Your Phone. |
10-29-2012, 05:23 | #7 (permalink) | |
Member: 651892 Status: Offline Thanks Meter: 205 | Quote:
As u see in the log Best tool can't Erase your phone because BestTool can auto check your rpl file before Erase,if u don't have full backup then besttool denied Erasing and give u one more chance for full backup before u mistakenly erase your phone.. Now Go to User Data Tool and Read full flash from your phone Then Go to Misc and Check your readed Flash file for restor SL Data If u have Alive SL data,Best Tool can execute it From it. Now you have full backup Erase your phone again if best tool give the same error again then Check Marked the Skip backup chek. (it will skip the auto check full backup) Now erase your phone...Flash it.. restore your phone etc... Best is Really Best, I Love This Tool | |
The Following User Says Thank You to danishalnoor For This Useful Post: |
06-20-2013, 15:26 | #8 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Pakistan,Toba Tek Singh
Member: 531289 Status: Offline Sonork: 100.1603200 Thanks Meter: 292 | same problem here phone just vibrate try to restore SL show this error Spr read failed on #2 step [Absent data] ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Error on SPR reading Connect phone on selected interface... what to do ? Br ask4moon |
06-20-2013, 15:58 | #9 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 237256 Status: Offline Thanks Meter: 91 | CHAIN, it very easy and simple, i guess the file type of your Nokia C5 is rm-645, if yes your problem is as a result of your using the normal system of configuring other Nokia phone files to flash. Just interchange the position of the two files then reflash your phone again: CNT : rm645_071.005_U000.000_prd.uda.fpsx APE : RM645_ENO_10wk48v0.001.fpsx What i mean is in the place of image file or cnt file select ENO file and on the next line to that place/selet UDA which is the image file. You phone will revive authomatically after flash. |
06-21-2013, 13:37 | #10 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
01-03-2014, 21:35 | #12 (permalink) |
Insane Poster Join Date: Jul 2012 Location: apple mobile durbar main gate
Member: 1790945 Status: Offline Thanks Meter: 6 | Big news c5 only vibrate only not start after flash...... Done 1000000% sure step by step 1-flsh with same product code...2-remove headfone ic....3-back up simlock and rpl erase flashfile and flash it again and write rpl and simlock trust me ....ur handset will be ok garented....first folow 1 ...if not then jump on 2nd solution....if not then do 3rd .....enjoy and if u done press thanx button....INFINITY BEST IS BEST TOOL FOR THIS KIND OF HANDSET... |
