Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 09-24-2013, 11:00   #1 (permalink)
Crazy Poster
Member: 7909
SL3 Unlock Jobs Failed
Out of the last 6 SL3 unlock jobs I have created 5 have returned as failed
I cannot see what I might be doing wrong but it is very frustrating as once a job has failed then I cannot find any way to resubmit it
Any help or advice would be very appreciated and welcomed
Old 09-24-2013, 11:11   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,185
Hello.
More info. Phones? Logs?
Old 09-24-2013, 13:24   #3 (permalink)
Crazy Poster
Member: 7909
Phone found!
Series 60 Device detected!
read info... - Ok
Phone Imei: 356237046222822
Checking locks...
Conf key : 8000000000000000
Provider key : 2340000100000000
Country : United Kingdom
Operator : Unknown
Counters : Key 0 [3] , Fbus 0 [10]
Blocks : 1
LOCK STATUS :
BLK : 1
Lock1:Close Lock2:Close
LOCKS : Closed
PA_SL3 (15 digit) phone detected...
- > Power Off phone, dissconnect it and connect
Dead Mode is Selected
Waiting for USB device...
--- Insert cable and charger or press phone's power button! ---
Connection opened successfully
Waiting for communication response...
ASIC ID: 000000030000022600010007600C192102031104
CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB
PUBLIC ID: 2910010D77D40344EA9DC16C80CDE4411953A959
ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
Fetching data, wait...
- > Reinsert cable and battery, press powerOn button again
- > For X7, E7 - just waiting, near 1 minute
- > When BEST start Search Phone - Press PowerOn if needed
-> Phone not found..
Minor error, phone reboot not done #2 (Phone was not BootUp)
rap= 16C00114BC037F56E2B3DD001DA7084CA3733DBE
hash= BAF3A9C3DBFA8454937DB77F2B8852B1
key= 3865CD10930A1D149983E9B0258CE894256A8511
- > Keys was readed sucefully!
- > You can ignore it, power up phone manually
- > Or repeat procedure again
Phone found!
read info... - Ok
Upload Job procedure started...
Phone Imei: 357398043239927
Checking locks...
Provider key : 2343000000000000
Operator : T-Mobile UK
Blocks : 1
LOCK STATUS :
BLK : 1
Lock1:Close
LOCKS : Closed
PUBLIC ID: 0DC0021859D50344FF0EA65245260AA4E9F2A8F7
Key file updated...
Check RSA procedure disabled by user setting...
Done!
Phone disconected!
Phone found!
read info... - Ok
Phone Imei: 355379046164504
Checking locks...
Conf key : 0000000000000000
Provider key : 2341000000000000
Operator : O2 - UK
Blocks : 2
LOCK STATUS :
BLK : 1
Lock1:Close
BLK : 2
Lock1:Close
LOCKS : Closed
PUBLIC ID: 0E70010B4CA70344D9B20C807395BD966EE27C64
Phone disconected!
Connect phone on selected interface...
Key file updated...
Phone found!
Series 40 Device detected!
read info... - Ok
Phone Imei: 351698055924316
Checking locks...
Provider key : 2343300190233141
Operator : Orange
Blocks : 6
LOCK STATUS :
BLK : 1
Lock1:Close
BLK : 2
Lock1:Close
BLK : 3
Lock1:Close
BLK : 4
Lock1:Close
BLK : 5
Lock1:Close
BLK : 6
Lock1:Close
LOCKS : Closed
ASIC ID: 000000030000022600010007400C192103022107
CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB
PUBLIC ID: 400E00C0FFFB3C40BF3148C2963E0B5C74EB3145
ROOT KEY HASH: 8E309B54DA1ADDE27C2A035D63AACACD
Key file updated...
Phone found!
read info... - Ok
Phone Imei: 352696043936920
Checking locks...
Provider key : 2343300000000000
Operator : Orange
Blocks : 2
LOCK STATUS :
BLK : 1
Lock1:Close
BLK : 2
Lock1:Close
LOCKS : Closed
ASIC ID: 000000030000022600010007600C192102011104
PUBLIC ID: 2390001424770E49880801E90D2B56499805283E
ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695
Key file updated...
Old 09-24-2013, 17:29   #4 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,185
You not complete "after" boot procedure - mean when BEST ask re-connect phone - you not do it. Why?
Seems as error in it.
Send in pm Imei's which should be removed from "queue".
And also - try follow procedure, explained in logs.
Anyway - I will do something for remove that reason of error.
Old 09-24-2013, 19:08   #5 (permalink)
Member: 755916
Thanks Meter: 28
Hi Team,
Me too the same problem one Nokia X6 for unlock SL3 status : "Faild" what is wrong?
Thanks
Old 09-24-2013, 21:38   #6 (permalink)
Member: 128745
Thanks Meter: 16,905
send a mail with your job file and imei to [email protected]
Old 09-25-2013, 08:30   #7 (permalink)
Crazy Poster
Member: 7909
It does the same everytime..... and surely if the "phone not boot, minor error" was the problem then all of them would fail ?
Also I send 2 of the .bcl log files created to somebody else for processing and they come back to me with the codes
Old 09-25-2013, 09:22   #8 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,185
I just want understand where is problem, because in log I see different result, than must be, and this strange at all.
BEST require reboot phone (re-insert battery and connect again in dead state), when sw asks.
It is for verify all data and be sure all is fully correct.
The Following User Says Thank You to Dzirt For This Useful Post:
Old 09-25-2013, 10:40   #9 (permalink)
Crazy Poster
Member: 7909
Next one I do I will take more notice about what you say. You help and advice is appreciated, Thank you
Old 09-27-2013, 20:25   #10 (permalink)
gile@gile's Avatar
Member: 1473716
Thanks Meter: 965
Read .BCL File from Nokia to calculation unlock code by BRUTE FORCE - YouTube
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.17840 seconds with 7 queries
