12-15-2017, 16:03 | #1 (permalink) |
Freak Poster Join Date: Oct 2016 Location: india
Member: 2636476 Status: Offline Thanks Meter: 61 | Nokia RM-697 dead after flash strange from my side i got the set in user code condition then i try to flash after flash set dead its strange Code: Connect phone on selected interface... Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-697_23.0.015_prd.core.C00 PPM : RM-697_23.0.015_prd.rofs2.V21 PPM2 : RM-697_23.0.015_C01_prd.rofs3.fpsx CNT : RM697_719_015_U002.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001060 PUBLIC ID: 09A000030A0D5940867A0466DCB5B31F609933EC ASIC MODE ID: 00 ROOT KEY HASH: DA550B5BAAB517409088A3E4F3EB53AC ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 42331BE20CA122EF82A3028902F3E2692DDAE2FE ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 358300042083479 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358300042083479_CRT.rpl === SW Version Check === - > Can not collect initial info, continue flashing... - > Hope, this version will be ok === SW Version Check === ===Flashing [MCU]=== Erase : Processing RM-697_23.0.015_prd.core.C00 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-697_23.0.015_prd.core.C00 Total writen 429 blocks TIME : Write time : 00:00:18 MCU Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-697_23.0.015_prd.rofs2.V21 Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-697_23.0.015_prd.rofs2.V21 Total writen 52 blocks TIME : Write time : 00:00:02 PPM Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-697_23.0.015_C01_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-697_23.0.015_C01_prd.rofs3.fpsx Total writen 5 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ===Flashing [CNT]=== Erase : Processing RM697_719_015_U002.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM697_719_015_U002.uda.fpsx Total writen 25 blocks TIME : Write time : 00:00:01 CNT Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ADL: Close_Session Content: 000300000000060000000600000000 ADL: Reboot Flashing done! Total flash time : 00:00:25 Reboot phone now... - > AfterFlash Failed! :( Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! |
12-15-2017, 18:02 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Make sure about last version has been used. since : Code: === SW Version Check === - > Can not collect initial info, continue flashing... - > Hope, this version will be ok === SW Version Check === |
12-16-2017, 08:55 | #3 (permalink) | |
Member: 2636476 Status: Offline Thanks Meter: 61 | Quote:
sir i use last version is there any solution or it may be dead permanent | |
12-16-2017, 17:20 | #5 (permalink) |
Member: 2636476 Status: Offline Thanks Meter: 61 | i checked bsi on battery ok i also try with other battery but still not on Now when i click on restore simlock option plz check log sir Code: Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001060 PUBLIC ID: 09A000030A0D5940867A0466DCB5B31F609933EC ASIC MODE ID: 00 ROOT KEY HASH: DA550B5BAAB517409088A3E4F3EB53AC ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : blank (Erased or HW failure) ADL: phone is in flash mode Reading NPC certificate... IMEI : 358300042083479 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358300042083479_CRT_2nd.rpl Trying read spr block , wait ... Get phone data... Get flash data... SPR Read Ok! Spr saved to : 358300042083479.spr ADL: Close_Session Content: 000300000000060000000600000000 ADL: Reboot Processing SimLock extraction.... Checking readed data, wait few seconds ID_INFO : ICPR82_11w25.8/29-12-11/RM-815 #1st block Ok [SLT] #2nd block Ok [SHA] #3rd block Ok [SIG] Initial data found, start fun... SimLock RPL saved : c:\InfinityBox\BEST\Backup\Cert\358300042083479_SIM.rpl SimLock PM saved : c:\InfinityBox\BEST\Backup\Cert\358300042083479_SIM.pm Done! Elapsed: 00:00:27 then i erase flash stopped operation Code: User ACCEPTED FULL ERASE Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001060 PUBLIC ID: 09A000030A0D5940867A0466DCB5B31F609933EC ASIC MODE ID: 00 ROOT KEY HASH: DA550B5BAAB517409088A3E4F3EB53AC ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Seek file for this phone.... - > RPL backup found, but not full (NPC/SimLock absent) !!! - > Make RPL read from Alive/Dead , Make FlashRead - > Or check "Skip Bak.Chk." Stopping operation... |
