Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 02-25-2017, 09:21   #16 (permalink)
ishant's Avatar
Member: 1763238
Thanks Meter: 370
Arrow
Karboon Titanium K9 Smart Privacy Protection Remove Done
Operation : Reset Privacy Lock [ v1.58 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 700100563130303038500CA8566FC253
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , 80001
[eMMC] : FLASH_CID : 700100563130303038500CA8566FC253
[eMMC] : FLASH_LEN : 0x00000001C3000000
[eMMC] : FLASH_UCP : 7216 MiB [eMMC 8 GiB]
DEV RID    : 0xE8130045AD7E7A24BA8D96AB09050757
INT RAM    : 0x00020000
EXT RAM    : 0x20000000 [512 MiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Checking data ...
Process block #1
Process block #2
Privacy Lock reset Ok!
Done!
Elapsed: 00:00:33
Reconnect Power/Cable!
The Following 2 Users Say Thank You to ishant For This Useful Post:
Old 02-28-2017, 14:42   #17 (permalink)
Nasir Mobiles's Avatar
Member: 355782
Thanks Meter: 1,265
Nokia 225 (RM-1011) Flashing Done
Core : v2.24 , MTKx FlashEngine : v10.2
Verify files ...
MAUI : RM-1011_ROM_eMP_30.06.11
VIVA : RM-1011_VIVA_eMP_30.06.11
LANG : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001
CUST : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001
JMPT : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001
 - > MODE : FullFlash
Dead Mode is Selected
Waiting for USB device...
1. Phone should be Off!
2. Battery must be charged and inserted! ( if not used external power )
 - > If phone can't switch to BL - use battery or flash from Local mode!
--- Insert USB cable now! ---
Wait for phone...
Phone found! [ 8 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0001
BB_CPU_SN : 83ECA11C11FCACDD5124005E689F48AF
BROM Protocol Version : 05
BROM Status : 0000
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x8000
Project ID : PEARL.20.10.11.p1
BROM/BL stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_eMP_Pearl.fg
DA_VERIFY : 00
DA_JUMP   : 00040000
DA_AUTH   : Passed!
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8B
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW
[0] : FLASH_DIE : 00EF 0060 0018 0000
[0] : FLASH_LEN : 0x01000000
FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000
SecureDecrypt : RM-1011_ROM_eMP_30.06.11
SecureDecrypt : RM-1011_VIVA_eMP_30.06.11
SecureDecrypt : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001
SecureDecrypt : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001
SecureDecrypt : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001
OVRLP : 000069B900000001
PHPID : PEARL.20.10.11.p1
OVRLP : 00004DF900000001
DA : FORMAT_BIN
Processing Flash Pre-format
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
WRITE_STYLE : DEF : 0x01 (SEQ)
Write : RM-1011_ROM_eMP_30.06.11
Write : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001
Write : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001
Write : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001
Write : RM-1011_VIVA_eMP_30.06.11
CODE_DNLOAD : Ok
[VERIFY] DONE : RM-1011_ROM_eMP_30.06.11
[VERIFY] DONE : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001
[VERIFY] DONE : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001
[VERIFY] DONE : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001
[VERIFY] DONE : RM-1011_VIVA_eMP_30.06.11
CODE_VERIFY : Ok
Executing FFS FORMAT now...
DA_RET   : DA_IN_PROGRESS
DA_RET   : FORMAT_DONE
Rebooting phone now
Flashing done!
Total flash time : 00:03:02
Reboot phone Ok
Connect phone on selected interface...
The Following User Says Thank You to Nasir Mobiles For This Useful Post:
Old 03-01-2017, 11:24   #18 (permalink)
Member: 355782
Thanks Meter: 1,265
Nokia 112 ( RM-837 ) Flash Succeed
Core : v2.24 , BB5XG FlashEngine : v10.3
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm837__03.51.mcusw
PPM : rm837__03.51.ppm_m2
CNT : rm837__03.51.image_m2_059P7C1
Flashing phone now...
[Gen] Rules accepted for : XGOLD Generation
Check files done...
-> SWversion check skipped : Dead mode selected
-> If Windows say "Unrecognized device" / Operation not start
-> Or if Phone start charge - just reinsert battery
-> If flashing freeze - reinsert cable/battery and try again
--- Press phone's power button or insert usb cable! ---
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
IF xCPUID    : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data  :  1FB300020303010100FF
Sending EBL Loader ...
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.50_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
Check keys...
Check done. Image can be flashed
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 356331053660584
IMEI 2 : 356331053660592
PCcode : 059P7C1
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\356331053660584_XG213_CRT.rpl
Settings : EDM [0x8] , Block Mode , Fast CRC , Verify
   ===Flashing [MCU]===
File : rm837__03.51.mcusw
Image : rm837__03.51.mcusw_ebl_psi.fls
Sec-pack found, sending ...
Sec-pack sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:05
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01940000
Erasing, wait ...
Erase done, time : 00:02:12
Write , Start : 0x40280000 , Len : 0x018C0000
Flashing , wait ...
Region flash done, time : 00:00:29
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
CRC check passed , 0x87F4
   ===Flashing [PPM]===
File : rm837__03.51.ppm_m2
Image : package_m2.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41BC0000 , Len : 0x00600000
Erasing, wait ...
Erase done, time : 00:00:17
Write , Start : 0x41BC0000 , Len : 0x0030F7C0
Flashing , wait ...
Region flash done, time : 00:00:03
CRC check passed , 0x46E6
   ===Flashing [CNT]===
File : rm837__03.51.image_m2_059P7C1
Image : package_m2_059P7C1.image.fls
Sec-pack sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x421C0000 , Len : 0x01C60000
Erasing, wait ...
Erase done, time : 00:04:14
Write , Start : 0x421C0000 , Len : 0x00EE0000
Flashing , wait ...
Region flash done, time : 00:00:19
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
Erase done, time : 00:00:08
No write data, skip
CRC check passed , 0x2559
Flashing done!
Total flash time : 00:07:53
Reboot phone now...
Old 03-01-2017, 13:28   #19 (permalink)
ishant's Avatar
Member: 1763238
Thanks Meter: 370
Intex Cloud 4+ Usercode Remove Done
Operation : Format File System
Settings : SmartFormat is On
Waiting phone ...
Connect battery, press and hold 'VolUP' + 'PowerOn' buttons
Connect USB cable and keep hold buttons, until phone will be detected
Device found!
Handshake Ok!
Processing UBOT init ...
UBOOT FCS Init Ok!
Processing FL init ...
Handshake with FL Ok!
Factory Defaults : Will reset UserData and Settings!
Format USERDATA partition ...
Format USER Ok
Reboot Phone
Elapsed: 00:00:20
Old 03-01-2017, 14:12   #20 (permalink)
Member: 355782
Thanks Meter: 1,265
Nokia 108 (RM-944) MTK Flash succeed
Verify files ...
MAUI : RM-944_ROM_eMP_20.06.11
VIVA : RM-944_VIVA_eMP_20.06.11
LANG : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11
CUST : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11
JMPT : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11
Wait for phone...
Phone found! [ 7 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0001
BB_CPU_SN : C3C7E3072475988385339ECAF21B7A18
BROM Status : 1012
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
Project ID : Bree.20.06.11.p4
BROM/BL stage done
DA_eMP_Bree.fg
DA_VERIFY : 00
DA_JUMP   : 00040000
DA_AUTH   : Passed!
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x88
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E
[0] : FLASH_DIE : 00C2 0025 0036 0000
[0] : FLASH_LEN : 0x00400000
FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000
SecureDecrypt : RM-944_ROM_eMP_20.06.11
SecureDecrypt : RM-944_VIVA_eMP_20.06.11
SecureDecrypt : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11
SecureDecrypt : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11
SecureDecrypt : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11
PHPID : Bree.20.06.11.p4
DA : FORMAT_BIN
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
Write : RM-944_ROM_eMP_20.06.11
Write : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11
Write : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11
Write : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11
Write : RM-944_VIVA_eMP_20.06.11
CODE_DNLOAD : Ok
[VERIFY] DONE : RM-944_ROM_eMP_20.06.11
[VERIFY] DONE : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11
[VERIFY] DONE : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11
[VERIFY] DONE : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11
[VERIFY] DONE : RM-944_VIVA_eMP_20.06.11
CODE_VERIFY : Ok
Rebooting phone now
Flashing done!
Total flash time : 00:00:56
Reboot phone Ok
The Following 2 Users Say Thank You to Nasir Mobiles For This Useful Post:
Old 03-02-2017, 07:24   #21 (permalink)
dey mobiles's Avatar
Member: 799558
Thanks Meter: 430
Micromax Q346 FRP Remove Done
Operation : Format File System / Reset Settings [ v1.24 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
 ====  Wait for phone...
Phone found! [ 34 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:36
The Following User Says Thank You to dey mobiles For This Useful Post:
Old 03-03-2017, 16:09   #22 (permalink)
anjanbonik's Avatar
Member: 571956
Thanks Meter: 496
Arrow Nokia X2 Hung On Logo Done
Core : v2.24 , NXP FlashEngine : v5.2
Flash Mode : Full Update (System, User, Boot)
Check and select files according selected FlashMode
Ok, Set : rm1013_2.1.0.11_059W0F3_001_rawprogram_unsparse_ui.xml
Ok, Set : rm1013_2.1.0.11_user_prog_emmc_firehose_8x10.mbn
2. Press and hold 'Volume Down' button
3. Insert USB cable and hold button, until phone will be detected
Get Phone Initial Info
Product : MSM8610
Version : 0.5
Serial  : 3A1CEC6
Handshake Ok
Init[0] : 0x01000000
Init[1] : 0x30000000
Sending Loader ...
Init Loader ...
FireHose Initialized
Device Init Ok
Target VER : 1
Target CPU : 8x10
Target FLN : eMMC
Target CNF : 1000/C000/1000
Target DBG : logbuf@0xF8021118 fh@0xF801DF80
Files in Chain : 67
Flashing now
Flashing : rm1013_2.1.0.11_user_NON-HLOS.bin
ProgInit : start 16384, num 75203
ProgDone : Finished sector address 91587
Flash Ok
Flashing : rm1013_2.1.0.11_user_sbl1.mbn
ProgInit : start 147456, num 492
ProgDone : Finished sector address 147948
Flash Ok
ProgInit : start 148480, num 492
ProgDone : Finished sector address 148972
Flash Ok
Flashing : rm1013_2.1.0.11_user_sdi.mbn
ProgInit : start 149504, num 45
ProgDone : Finished sector address 149549
Flash Ok
Flashing : rm1013_2.1.0.11_user_emmc_appsboot.mbn
ProgInit : start 180224, num 938
ProgDone : Finished sector address 181162
Flash Ok
ProgInit : start 181248, num 938
ProgDone : Finished sector address 182186
Flash Ok
Flashing : rm1013_2.1.0.11_user_rpm.mbn
ProgInit : start 182272, num 296
ProgDone : Finished sector address 182568
Flash Ok
ProgInit : start 183272, num 296
ProgDone : Finished sector address 183568
Flash Ok
Flashing : rm1013_2.1.0.11_user_boot.img
ProgInit : start 196608, num 14549
ProgDone : Finished sector address 211157
Flash Ok
Flashing : rm1013_2.1.0.11_user_tz.mbn
ProgInit : start 229376, num 663
ProgDone : Finished sector address 230039
Flash Ok
ProgInit : start 230376, num 663
ProgDone : Finished sector address 231039
Flash Ok
Flashing : rm1013_2.1.0.11_user_system_1.img
ProgInit : start 344064, num 262160
ProgDone : Finished sector address 606224
Flash Ok
Flashing : rm1013_2.1.0.11_user_system_2.img
ProgInit : start 606600, num 16
ProgDone : Finished sector address 606616
Flash Ok
Flashing : rm1013_2.1.0.11_user_system_3.img
ProgInit : start 610352, num 257992
ProgDone : Finished sector address 868344
Flash Ok
Flashing : rm1013_2.1.0.11_user_system_4.img
ProgInit : start 868352, num 16
ProgDone : Finished sector address 868368
Flash Ok
Flashing : rm1013_2.1.0.11_user_system_5.img
ProgInit : start 872104, num 258384
ProgDone : Finished sector address 1130488
Flash Ok
Flashing : rm1013_2.1.0.11_user_system_6.img
ProgInit : start 1130496, num 16
ProgDone : Finished sector address 1130512
Flash Ok
Flashing : rm1013_2.1.0.11_user_system_7.img
ProgInit : start 1130888, num 16
ProgDone : Finished sector address 1130904
Flash Ok
Flashing : rm1013_2.1.0.11_user_system_8.img
ProgInit : start 1134640, num 95712
ProgDone : Finished sector address 1230352
Flash Ok
Flashing : rm1013_2.1.0.11_user_system_9.img
ProgInit : start 1392640, num 16
ProgDone : Finished sector address 1392656
Flash Ok
Flashing : rm1013_2.1.0.11_user_system_10.img
ProgInit : start 1654784, num 16
ProgDone : Finished sector address 1654800
Flash Ok
Flashing : rm1013_2.1.0.11_user_system_11.img
ProgInit : start 1655176, num 16
ProgDone : Finished sector address 1655192
Flash Ok
Flashing : rm1013_2.1.0.11_user_cache_1.img
ProgInit : start 1777664, num 11376
ProgDone : Finished sector address 1789040
Flash Ok
Flashing : rm1013_2.1.0.11_user_recovery.img
ProgInit : start 1974272, num 15529
ProgDone : Finished sector address 1989801
Flash Ok
Flashing : rm1013_2.1.0.11_user_misc_erase.img
ProgInit : start 1998848, num 1
ProgDone : Finished sector address 1998849
Flash Ok
Flashing : rm1013_2.1.0.11_059W0F3_001.custom_1.img
ProgInit : start 2015232, num 262136
ProgDone : Finished sector address 2277368
Flash Ok
Flashing : rm1013_2.1.0.11_059W0F3_001.custom_2.img
ProgInit : start 2277376, num 16
ProgDone : Finished sector address 2277392
Flash Ok
Flashing : rm1013_2.1.0.11_059W0F3_001.custom_3.img
ProgInit : start 2277640, num 16
ProgDone : Finished sector address 2277656
Flash Ok
Flashing : rm1013_2.1.0.11_059W0F3_001.custom_4.img
ProgInit : start 2280856, num 258656
ProgDone : Finished sector address 2539512
Flash Ok
Flashing : rm1013_2.1.0.11_059W0F3_001.custom_5.img
ProgInit : start 2539520, num 16
ProgDone : Finished sector address 2539536
Flash Ok
Flashing : rm1013_2.1.0.11_059W0F3_001.custom_6.img
ProgInit : start 2542736, num 227528
ProgDone : Finished sector address 2770264
Flash Ok
Flashing : rm1013_2.1.0.11_059W0F3_001.custom_7.img
ProgInit : start 2801664, num 16
ProgDone : Finished sector address 2801680
Flash Ok
Flashing : rm1013_2.1.0.11_059W0F3_001.custom_8.img
ProgInit : start 2801928, num 16
ProgDone : Finished sector address 2801944
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_1.img
ProgInit : start 2834432, num 80272
ProgDone : Finished sector address 2914704
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_2.img
ProgInit : start 3096576, num 16
ProgDone : Finished sector address 3096592
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_3.img
ProgInit : start 3097800, num 16
ProgDone : Finished sector address 3097816
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_4.img
ProgInit : start 3358720, num 16
ProgDone : Finished sector address 3358736
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_5.img
ProgInit : start 3620864, num 16
ProgDone : Finished sector address 3620880
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_6.img
ProgInit : start 3622088, num 16
ProgDone : Finished sector address 3622104
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_7.img
ProgInit : start 3883008, num 16
ProgDone : Finished sector address 3883024
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_8.img
ProgInit : start 4145152, num 16
ProgDone : Finished sector address 4145168
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_9.img
ProgInit : start 4146376, num 16
ProgDone : Finished sector address 4146392
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_10.img
ProgInit : start 4407296, num 16
ProgDone : Finished sector address 4407312
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_11.img
ProgInit : start 4669440, num 16
ProgDone : Finished sector address 4669456
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_12.img
ProgInit : start 4670664, num 16
ProgDone : Finished sector address 4670680
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_13.img
ProgInit : start 4931584, num 16
ProgDone : Finished sector address 4931600
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_14.img
ProgInit : start 5193728, num 16
ProgDone : Finished sector address 5193744
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_15.img
ProgInit : start 5194952, num 16
ProgDone : Finished sector address 5194968
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_16.img
ProgInit : start 5455872, num 16
ProgDone : Finished sector address 5455888
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_17.img
ProgInit : start 5718016, num 16
ProgDone : Finished sector address 5718032
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_18.img
ProgInit : start 5980160, num 16
ProgDone : Finished sector address 5980176
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_19.img
ProgInit : start 6242304, num 16
ProgDone : Finished sector address 6242320
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_20.img
ProgInit : start 6504448, num 16
ProgDone : Finished sector address 6504464
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_21.img
ProgInit : start 6766592, num 16
ProgDone : Finished sector address 6766608
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_22.img
ProgInit : start 7028736, num 16
ProgDone : Finished sector address 7028752
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_23.img
ProgInit : start 7290880, num 16
ProgDone : Finished sector address 7290896
Flash Ok
Flashing : rm1013_2.1.0.11_user_userdata_24.img
ProgInit : start 7553024, num 16
ProgDone : Finished sector address 7553040
Flash Ok
Chain finished, All files flashed!
Rebooting phone now
Flashing done!
Total flash time : 00:01:44
Phone found!
Nokia X Platform Phone detected
Read info... Ok
Phone disconected!
The Following 2 Users Say Thank You to anjanbonik For This Useful Post:
Old 03-04-2017, 06:42   #23 (permalink)
Member: 2573542
Thanks Meter: 12
nokia 301 dead recover done
flash
Core : v2.25 , BB5XG FlashEngine : v10.3
MCU : rm839__09.04.mcusw
PPM : rm839__09.04.ppm_mh2
CNT : rm839__09.04.image_mh2_059R2H1_059T029_229_04
Check files done...
IF Boot Init : 0xF0
IF Resp Len  : 0x16
IF xCPUID    : XGOLD 618 [XMM6180 QUARK]
IF uCHIPID    :  50A9070100030101E0002409301C055149EC0935FFFF
IF Resp Data  :  50A9070100030101
Wait for user action : Insert battery
EBL Loader Ok
EBL Loader ready
Sending EBL ...
EBL sent Ok
EBL : QUARK_1337.500_M1S1
QUARK EEP config Ok
FLASHID : EC004000 , [ MuxOneNAND ]
Boot conf set, Target Ready
Boot done!
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 357885051711987
IMEI 2 : 357885051711995
Phone Product Code : 059T029
RPL saved : C:\InfinityBox\BEST\Backup\Cert\357885051711987_XG618_CRT.rpl
Processing file : rm839__09.04.mcusw
Region count : 8
00 : [ PSI ]   : psi_flash_unsigned.fls
01 : [ BCore ] : slb_signed.fls
02 : [ Code ]  : main_toc_signed.fls
03 : [ Code ]  : rm839__09.04.mcusw_signed_mcusw.fls
04 : [ Code ]  : swap_signed.fls
05 : [ Cust ]  : dynsw.fls
06 : [ Code ]  : aeneas_signed.fls
07 : [ Code ]  : fota_signed.fls
Parse done , flashing now
Flash : 00 : psi_flash_unsigned.fls
Sending Sec-Pack
SecInfo Area : 0x0000 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x00090000 , Len : 0x00020000
Erase now...
Erase done
Region Start : 0x00090000 , Data Len : 0x00010FB0
Region Load done
Write done
psi_flash_unsigned.fls image flash done
Flash : 01 : slb_signed.fls
Sending Sec-Pack
SecInfo Area : 0x0001 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x60000000 , Len : 0x00040000
Erase now...
Erase done
Region Start : 0x60000000 , Data Len : 0x00040000
Region Load done
Write done
slb_signed.fls image flash done
Flash : 02 : main_toc_signed.fls
Sending Sec-Pack
SecInfo Area : 0x0002 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x60040000 , Len : 0x00000400
Erase now...
Erase done
Region Start : 0x60040000 , Data Len : 0x00000400
Region Load done
Write done
main_toc_signed.fls image flash done
Flash : 03 : rm839__09.04.mcusw_signed_mcusw.fls
Sending Sec-Pack
SecInfo Area : 0x0003 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x62E00000 , Len : 0x01100000
Erase now...
Erase done
Erase area 0x01 , Start 0xFFF00000 , Len : 0x00080000
Erase now...
Erase done
Region Start : 0x62E00000 , Data Len : 0x00F0D4CC
Region Load done
Write done
rm839__09.04.mcusw_signed_mcusw.fls image flash done
Flash : 04 : swap_signed.fls
Sending Sec-Pack
SecInfo Area : 0x0004 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x80000000 , Len : 0x00F00000
Erase now...
Erase done
Region Start : 0x80000000 , Data Len : 0x00C2BCD0
Region Load done
Write done
swap_signed.fls image flash done
Flash : 05 : dynsw.fls
Sending Sec-Pack
SecInfo Area : 0x0005 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x62080000 , Len : 0x00100000
Erase now...
Erase done
Region Start : 0x62080000 , Data Len : 0x00044000
Region Load done
Write done
dynsw.fls image flash done
Flash : 06 : aeneas_signed.fls
Sending Sec-Pack
SecInfo Area : 0x0006 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x63F79C00 , Len : 0x00080000
Erase now...
Erase done
Region Start : 0x63F79C00 , Data Len : 0x00046870
Region Load done
Write done
aeneas_signed.fls image flash done
Flash : 07 : fota_signed.fls
Sending Sec-Pack
SecInfo Area : 0x0007 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x61F00004 , Len : 0x0017FFFC
Erase now...
Erase done
Region Start : 0x61F00004 , Data Len : 0x00149890
Region Load done
Write done
fota_signed.fls image flash done
Processing file : rm839__09.04.ppm_mh2
Region count : 1
00 : [ Cust ]  : package_mh2.ppm_ebl_psi.fls
Flash : 00 : package_mh2.ppm_ebl_psi.fls
Sending Sec-Pack
Erase area 0x00 , Start 0x80F00000 , Len : 0x00B00000
Erase now...
Erase done
Region Start : 0x80F00000 , Data Len : 0x0068BEAC
Region Load done
Write done
package_mh2.ppm_ebl_psi.fls image flash done
Processing file : rm839__09.04.image_mh2_059R2H1_059T029_229_04
Region count : 1
00 : [ Cust ]  : rm839__09.04.image_mh2_059R2H1_059T029_229_04.fls
Flash : 00 : rm839__09.04.image_mh2_059R2H1_059T029_229_04.fls
Sending Sec-Pack
Erase area 0x00 , Start 0xA1000000 , Len : 0x0C580000
Erase now...
Erase done
Erase area 0x01 , Start 0xAE000000 , Len : 0x00300000
Erase now...
Erase done
Region Start : 0xA1000000 , Data Len : 0x01DB4000
Region Load done
Write done
rm839__09.04.image_mh2_059R2H1_059T029_229_04.fls image flash done
Flashing done!
Total flash time : 00:00:14
Reboot phone now...
Reading Phone Info....
Connected phone -   Nokia 301 Dual SIM
Software Info:     V 09.04 03-12-13 RM-839 (c) Nokia
IMEI:  3578*********
PPM version :   V 09.04 03-12-13 RM-839 (c) Nokia             MH2
Product code:  059T029
Wait, when phone will be ready ...
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Check and Upload User Certificates ...
Total - 58 certs
Certificates found, skip upload ...
Battery voltage is enough for start
AfterFlash operations done ;D
Done!
Elapsed: 00:01:08
Phone found!
Series 40 Device detected!
read info...  - Ok
Phone disconected!
The Following User Says Thank You to Sonu For This Useful Post:
Old 03-04-2017, 11:03   #24 (permalink)
>>Gsmmilon>>'s Avatar
Member: 2142580
Thanks Meter: 1,214
Nokia 105 Dual MT6261 Phone Lock Remove Done Without Flash
The Following User Says Thank You to >>Gsmmilon>> For This Useful Post:
Old 03-06-2017, 04:44   #25 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile X25 MT6572 Stuck Logo Revocer Done By Flashing With Infinity CM2
Flash Done...
:: NO FAKE ADVERTISEMENT ::
:: NO FAKE UPDATES ::
:: NO FAKE WORLD'S FIRST ::
:: NO FAKE BLA BLA BLA ::
Stay Tune!
More Developing!!
More coming!!!
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 03-06-2017, 04:45   #26 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile X800 MT6592 Pettran Lock Read Done Save All Data With Great Infinity CM2
Read Pettran Done...
Stay Tune!
More Developing!!
More coming!!!
Old 03-08-2017, 11:27   #27 (permalink)
Member: 2560333
Thanks Meter: 25
NOKIA X2.02 RM 694 FULL FLAS DONE in bast dongle
Selected FlashSettings : FullFlash
MCU : CC2F4A5A_rm694__11.79.mcusw
PPM : CB29780C_rm694__11.79.ppm_bg
CNT : 53D201F3_rm694__11.79.image_bg_059H3C5
Check files done...
-> If Windows say "Unrecognized device" - just reinsert battery
-> If flashing freeze - reinsert cable and try again
--- Press phone's power button or insert charger! ---
DBG : F00A1FB300020303010100FF
CPUID : XGOLD 213
2nd boot Ok, 01
2nd ready, AA
Sending Algo
Algo sent Ok
BL : Quantum_Bootloader_10.46_M1S1
FLASHID : EC001230
Boot done!
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 358103053859583
IMEI 2 : 358103053859591
PCcode :  њ
RPL saved : C:\Program Files\Nokia_Best\Backup\Cert\358103053859583_35810 3053859591_XG213_CRT.rpl
File : CC2F4A5A_rm694__11.79.mcusw
Image : rm694__11.79.mcusw_ebl_psi.fls
Cert block found, sending....
Cert sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:00:02
Flashing , wait ...
Erase , Start : 0x40280000 , Len : 0x01980000
Erasing, wait ...
Erase done, time : 00:00:50
Write , Start : 0x40280000 , Len : 0x01900000
Flashing , wait ...
Region flash done, time : 00:00:32
Erasing, wait ...
No write data, skip
File : CB29780C_rm694__11.79.ppm_bg
Image : package_bg.ppm_ebl_psi.fls
Cert sent
Found 1 region(s)
Erase , Start : 0x41C00000 , Len : 0x00700000
Erasing, wait ...
Erase done, time : 00:00:10
Write , Start : 0x41C00000 , Len : 0x0051758C
Flashing , wait ...
Region flash done, time : 00:00:05
File : 53D201F3_rm694__11.79.image_bg_059H3C5
Image : package_bg_059H3C5.image.fls
Cert sent
Found 2 region(s)
Erase , Start : 0x42300000 , Len : 0x01B20000
Erasing, wait ...
Erase done, time : 00:00:58
Write , Start : 0x42300000 , Len : 0x00D60000
Flashing , wait ...
Region flash done, time : 00:00:16
Erasing, wait ...
No write data, skip
Flashing done!
Total flash time : 00:03:01
Reboot phone now...
Connected phone - X2-02
Software Info: V 11.79 15-08-12 RM-694 (c) Nokia
IMEI: 358103053859583
PPM version : V 11.79 15-08-12 RM-694 (c) Nokia BG
Product code: 059N1T6
Checking...
Read Info Done!
Settings After Flash Defaults...
SwUpgradeSet...OK!
Checking User Certificates...
Total - 43 certs
Data exist, skip certificate repair...
Set phone to Normal mode...
The Following User Says Thank You to bhanumobiles For This Useful Post:
Old 03-08-2017, 16:34   #28 (permalink)
iOS_Shakil's Avatar
Member: 2441719
Sonork: uninstall
Thanks Meter: 2,073
Nokia 130 / RM-1035 Hang On Logo Solve By Nokia BEST Dnngle
Registered to: iOS_Shakil
Core : v2.25 , MTKx FlashEngine : v10.5
Verify files ...
MAUI : RM-1035_ROM_eMP_10.01.11
VIVA : RM-1035_VIVA_eMP_10.01.11
LANG : RM-1035_LANG_PACK_ROM_MS_eMP_10.01.11_001
CUST : RM-1035_CUSTPACK_ROM_MS_MEA_BD_eMP_10.01.11_001
JMPT : RM-1035_JUMP_TABLE_MS_MEA_BD_eMP_10.01.11_001
Wait for phone...
Phone found! [ 25 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : 27DC4CE511E5FB3DF5E2AB373713973B
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
Project ID : CRYSTAL.10.01.11.p2
BROM/BL stage done
DA_eMP_Crystal.fg
DA_VERIFY : 00
DA_JUMP   : 00040000
DA_AUTH   : Passed!
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV
[0] : FLASH_DIE : 00EF 0040 0016 0000
FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000
SecureDecrypt : RM-1035_ROM_eMP_10.01.11
SecureDecrypt : RM-1035_VIVA_eMP_10.01.11
SecureDecrypt : RM-1035_LANG_PACK_ROM_MS_eMP_10.01.11_001
SecureDecrypt : RM-1035_CUSTPACK_ROM_MS_MEA_BD_eMP_10.01.11_001
SecureDecrypt : RM-1035_JUMP_TABLE_MS_MEA_BD_eMP_10.01.11_001
PHPID : CRYSTAL.10.01.11.p2
DA : FORMAT_BIN
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
Write : RM-1035_ROM_eMP_10.01.11
Write : RM-1035_LANG_PACK_ROM_MS_eMP_10.01.11_001
Write : RM-1035_CUSTPACK_ROM_MS_MEA_BD_eMP_10.01.11_001
Write : RM-1035_JUMP_TABLE_MS_MEA_BD_eMP_10.01.11_001
Write : RM-1035_VIVA_eMP_10.01.11
CODE_DNLOAD : Ok
[VERIFY] DONE : RM-1035_ROM_eMP_10.01.11
[VERIFY] DONE : RM-1035_LANG_PACK_ROM_MS_eMP_10.01.11_001
[VERIFY] DONE : RM-1035_CUSTPACK_ROM_MS_MEA_BD_eMP_10.01.11_001
[VERIFY] DONE : RM-1035_JUMP_TABLE_MS_MEA_BD_eMP_10.01.11_001
[VERIFY] DONE : RM-1035_VIVA_eMP_10.01.11
CODE_VERIFY : Ok
Rebooting phone now
Flashing done!
Total flash time : 00:01:04
Reboot phone Ok
The Following User Says Thank You to iOS_Shakil For This Useful Post:
Old 03-10-2017, 10:27   #29 (permalink)
Member: 291133
Thanks Meter: 4
HISENSE U601s FRP LOCK DONE BY CM2 DONGLE
FRP LOCK HISENSE U601s DONE BY CM2 DONGLE
3. Insert cable
Phone found! [ 446 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Reset Ok!
Done!
Report Post
The Following 2 Users Say Thank You to malik_luv For This Useful Post:
Old 03-13-2017, 11:39   #30 (permalink)
Member: 1763380
Thanks Meter: 86
Lumia rm-914 flight mode done
Core : v2.25 , WP10x FlashEngine : v2.5
FFU : RM914_3058.50000.1425.0004_RETAIL_apac_indonesia_4 92_04_448124_prd_signed.ffu
Checking FFU file, wait...
FFU Revision ID : 2.0
FFU Model ID : Nokia.MSM8227.P6036
FFU RootKeyHash : F771E62AF89994064F77CD3BC16829503BDF9A3D
FFU Languages : Albanian , Arabic , Azerbaijan(Latin) , Belorusian , Bulgarian , Catalan , Croatian , Czech , Danish (Denmark) , Dutch (Netherlands) , English (UK) , English , Estonian , Filipino (Philippines) , Finnish , French , German , Greek , Hwbre (Israel) , Hindi (India) , Hungarian , Indonesian , Italian , Japanese , Kazakh , Korean , Latvian , Lithuanian , Macedonian , Malay (Malaysia) , Norwegian (Bokmal , Norway) , Persian (Iran) , Polish , Portuguese(Brazil) , Portuguese(Portugal) , Romanian , Russian , sr-latn-rs , Chinese , Slovak , Slovenian , Spanish(Mexico) , Spanish , Swedish , Thai , Chinese(Taiwan) , Turkish , Ukrainian , Uzbekistan(Latin) , Vietnamese ,
FFU ChipSectors : 15155200
FFU Header : 0x000E0000
FFU Payload : 0x65660000
FFU FastVerify : Ok
Waiting for phone...
Dead mode is selected , no phone in normal mode found
1. Press and hold "Volume Down"
2. Insert USB cable
3. Hold button until phone will be detected
Device catched in BOOT mode!
Boot Mode confirmed!
Setting Preloder
Collect Info...
Setting Application
Setting Secure
Collect Info...
=== Nokia Flash App info :
Protocol Version : 1.15
Protocol Implementation : 1.28
=== Phone Initial info :
Phone RMxxx ID : RM-914
Phone Model ID : Nokia.MSM8227.P6036.1.2
Phone Model PC : 059S3Q0
Phone IMEI : 358106058406565
=== eMMC info :
eMMC Vendor : Samsung
eMMC CID : 0015
eMMC Size : 7456 MiB
=== Security Initial info :
Security Status : 010100000101
Secure Boot : Enabled
Secure eFUSE : Enabled
JTAG : Disabled
RDC Key : Not Present (Retail)
UEFI SBoot : Enabled
SecHW Key : Exists
Device RootKey : F771E62AF89994064F77CD3BC16829503BDF9A3D
=== Other info :
SD present : True , 00203B00
Full Check skipped , will be checked by ImageSignature
Battery Level : 48%
RPMB Provision Status Code : 0x0101
Device RAM size : 512 MiB
Device not have ATRP
Backup to RAM Ok!
Flashing FFU
Sending FFU Header CertData
Header sent , accepted
Perform Data Partition Erase
Erase done
Sending FFU Payload Data...
Finishing flashing
Flashing done!
Green Light
Image Sent, processing PostFlash
FinalConfig : abnormal status, error code : 0xFFFF0000
Make Factory Set : Ok
Restore RAMBkp : Ok
Update NVI from Image
Ok , NVI will be updated on first boot!
PostFlash Finished
Total flash time : 00:02:36
Rebooting
Phone found!
WP10/WP8x Lumia Phone detected
Read info... Ok
Phone disconected!
The Following User Says Thank You to den fatih For This Useful Post:
Page generated in 0.41361 seconds with 10 queries
