05-07-2019, 06:13 | #826 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 105 full flash by best Registered to: A.G.Shahid Connect phone on selected interface... UFS S/N 14332 boot - Ok Connect phone on selected interface... Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm908_02.700 PPM : rm908_02.70ij CNT : rm908_nai02.70ij Infineon flashing... -> Infineon XG110 : IMEI Backup Created Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 PBL : Dynamic Boot Ok , 01AB SBL : Dynamic Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH VEN : 0000002C FLASH DIE : 0000CB17 FLASH ID : SPI , 25W064A Boot Done! ===Flashing [MCU]=== File : rm908_02.700 Image : hw_b1_rm908_02.700.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00800000 , Len : 0x00210000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x00210000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00C60000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00C60000 , Len : 0x00221240 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00FFC000 , Len : 0x00004000 Erasing, wait ... Erase done Write , Start : 0x00FFC000 , Len : 0x00000040 Flashing , wait ... Region flash done Check : A59F ===Flashing [PPM]=== File : rm908_02.70ij Image : hw_b1_rm908_02.70ij.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00210000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00210000 , Len : 0x0018A340 Flashing , wait ... Region flash done Check : 96E9 ===Flashing [CNT]=== File : rm908_nai02.70ij Image : hw_b1_rm908_nai02.70ij.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00EB0000 , Len : 0x000D0000 Erasing, wait ... Erase done Write , Start : 0x00EB0000 , Len : 0x000661C0 Flashing , wait ... Region flash done Check : A3FD Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Afterflash settings... SW ver : IMEI : PCode : Settings After Flash Defaults... Error When resetting FullFactory ... Error When resetting Product Tune ... Error When resetting SW upgrade Default ... All done! Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:14 Phone disconected! |
The Following User Says Thank You to A.G.Shahid For This Useful Post: |
05-07-2019, 13:53 | #827 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 130 hang on logo done by best2 Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.16 Operation : Identify [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM29) MODE : NOKIA USB SERIAL PORT : 29 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 01989AB4315977B36A0CF0B3EE847D20 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : CRYSTAL.14.00.11.p1 BOOT : SWR : 14.00.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : CRYSTAL.14.00.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 BBSN : 01989AB4315977B36A0CF0B3EE847D20 PRDC : 059W037 IMEI[1] : IMEI[2] : NCK : 20 digits PROV : 24407000 Saved as : 35729xxxxxxxxxx.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:01:03 Reconnect Power/Cable! Open VPLfile : RM-1035_059W2D7_14.00.11.vpl Description : RM-1035 059W2D7 IJ 14.00.11 DeviceType : RM-1035 ProductCode : 059W2D7 SoftwareVer : 14.00.11 PPM LangPack : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.16 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM29) MODE : NOKIA USB SERIAL PORT : 29 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 01989AB4315977B36A0CF0B3EE847D20 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : CRYSTAL.14.00.11.p1 BOOT : SWR : 14.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : CRYSTAL.14.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0040 : 0016 : 0000 NOR: [WINBOND] W25Q32BV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 14.00.11 [RM-1035] DEV SoftwareVersion : 14.00.11 SWInfo compare result : SAME Load FlashSet : MROM : RM-1035_CRYSTAL_ROM_eMP_14.00.11 LANG : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11 CUST : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11 JUMP : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11 VIVA : RM-1035_CRYSTAL_VIVA_eMP_14.00.11 Prepare FlashSet : DCR : RM-1035_CRYSTAL_ROM_eMP_14.00.11 DCR : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11 DCR : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11 DCR : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11 DCR : RM-1035_CRYSTAL_VIVA_eMP_14.00.11 Prepare Target SDS : OK : 0x003F4000 : 0x0000C000 FFS Format Ok! CBR : 0x0000001A:0x00000001:0x00000000:0x00000000:0x0000 0010:0x00000002:0x00000000 Erase Target Flash Erase done! Write Target Flash Write : RM-1035_CRYSTAL_ROM_eMP_14.00.11 Write : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11 Write : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11 Write : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11 Write : RM-1035_CRYSTAL_VIVA_eMP_14.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1035_CRYSTAL_ROM_eMP_14.00.11 Verify : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11 Verify : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11 Verify : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11 Verify : RM-1035_CRYSTAL_VIVA_eMP_14.00.11 Done! Elapsed: 00:01:22 Reconnect Power/Cable! |
05-09-2019, 12:11 | #828 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 216 Format Done Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 44 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : B71833E3B4C17E2007144D3C7A8B1065 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : SUEZ.40.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Suez.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00CE0000-0x00FF3FFF , LEN : 0x00314000 Executing FFS FORMAT now... FAT_RANGE : 0x00CE0000-0x00FF3FFF , LEN : 0x00314000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:36 Connect phone on selected interface... |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
05-09-2019, 20:38 | #829 (permalink) |
Freak Poster Join Date: Sep 2007 Age: 36
Member: 579725 Status: Offline Sonork: 100.1675677 Thanks Meter: 96 | Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 141EE8EC ID_BLOCK_I : 009600E1 ID_BLOCK_L : C0CE2B1F0987C34C6D9A3B55DB9A5FB5 ID_BLOCK_L : AE92F5777D9E5A15174A807BD622F3FC Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Flash Chain : 49 Flashing now Flashing : gpt_main0.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : sysinfo.cfg Flashing : splash.img Flashing : hidden.img Flashing : cda.img Flashing : recovery.img Flashing : sec.dat Flashing : boot.img Flashing : NON-HLOS.bin Flashing : system.img Flashing : misc.img Flashing : cache.img Flashing : persist.img Flashing : cmnlib.mbn Flashing : cmnlib.mbn Flashing : keymaster.mbn Flashing : keymaster.mbn Flashing : userdata.img Flashing : gpt_backup0.bin Wipe data ... BootConfig set to 0x00 Flashing done! When you will see ANDROID on screen make next steps : 1. Press and Hold both 'Vol_UP' and 'Power_On' keys 2. Hold them until device will reboot and show again ANDROID logo 3. Release 'Power_On' button, wait when color circle appear on screen! Done! Elapsed: 00:03:46 Reconnect Power/Cable! |
The Following User Says Thank You to MIRZAvicko For This Useful Post: |
05-10-2019, 05:31 | #830 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 105 rm-1133 reset password done by best2 Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.16 Operation : Identify [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM29) MODE : NOKIA USB SERIAL PORT : 29 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 174FCD67395B8EEF5A627CA16219F59F BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : LAGOS61D.13.00.11.p1 BOOT : SWR : 13.00.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : LAGOS61D.13.00.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 BBSN : 174FCD67395B8EEF5A627CA16219F59F PRDC : 059W9Z8 IMEI[1] : IMEI[2] : NCK : 20 digits PROV : 24407000 Saved as : 354877xxxxxxxxxx.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:01:01 Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM29) MODE : NOKIA USB SERIAL PORT : 29 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 174FCD67395B8EEF5A627CA16219F59F BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : LAGOS61D.13.00.11.p1 BOOT : SWR : 13.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : LAGOS61D.13.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00368000 : 0x00090000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
05-13-2019, 10:35 | #831 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 130 Format Done Operation : Reset Settings [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM20) MODE : NOKIA USB SERIAL PORT : 20 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : FDE9342C98CC3EFF6DAF529717348379 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : CRYSTAL.10.01.11.p2 BOOT : SWR : 10.01.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : CRYSTAL.10.01.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00C2 : 0025 : 0036 : 0000 NOR: [MX] MX25U3235E NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x003A4000 : 0x00050000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:01:23 Reconnect Power/Cable! |
05-13-2019, 16:01 | #832 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 3310 3g reset password done by best2 Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.12 Operation : Reset Settings ( Format FS ) [ v1.12 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! Erase BLK #0 Erase BLK #1 Erase BLK #2 Erase BLK #3 Format Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
05-17-2019, 13:29 | #833 (permalink) |
Freak Poster Join Date: Jun 2009
Member: 1051138 Status: Offline Sonork: 123456 Thanks Meter: 382 | nokia 5.1 plus frp+formate done Operation : Reset Settings [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM15) MODE : BOOTROM PORT : 15 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6771 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100474436424D420128226B665CF EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GD6BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A9C28950AFA24F7BA77149CE3D9E10F7 DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : RESET PROTECTION Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
The Following User Says Thank You to akeel2000 For This Useful Post: |
05-17-2019, 15:52 | #834 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 215 reset password done by cm2 Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.16 Operation : Reset Settings [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM29) MODE : NOKIA USB SERIAL PORT : 29 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 5DA39B80632FD72C3DFD9511C5C22E78 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : JET.10.01.11.p1 BOOT : SWR : 10.01.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : JET.10.01.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00C2 : 0025 : 0038 : 0000 NOR: [MXIC] MX25U12835FZNI_10G NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00E80000 : 0x00174000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
05-19-2019, 10:43 | #835 (permalink) |
No Life Poster Join Date: Feb 2011 Location: ( United States Of Islam ) Age: 35
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | NOKIA 1LITER TA-1047 FRP RESET DON Code: Card found : 8C73AEBC , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.16 Operation : Reset Settings [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM19) MODE : PRELOADER PORT PORT : 19 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 150100464E36324D42034DF1D09725A7 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464E36324D42034DF1D09715A7 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 24AEAEB6C5CC487C755D6112F60C7A97 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
The Following User Says Thank You to niaz muhammad For This Useful Post: |
05-20-2019, 08:03 | #836 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 105 reset password done by best Card found: S/N : 30C22462 , v0122 Registered to: A.G.Shahid Connect phone on selected interface... UFS S/N 14332 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... SW ver : V 03.40 08-08-13 RM-908 (c) Nokia IMEI : 359193052364494 PPM : V 02.70 22-02-13 RM-908 (c) Nokia IA PCode : 059R452 BPCode : 059T865 HWID : 2000 LCDVer : CMI:BEIHAIv01 ILI9163C IMEI : 359193052364494 Sl Conf : 001-01-00000000000 Sl Prof : 000000000004000-2 Sl Aux : 000B0000 Hw Sig : A3E2A5F0DFC9458E Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:14 |
05-22-2019, 14:00 | #837 (permalink) | |
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | Nokia 5.1. TA1105 V 9.0 FRP reset done Nokia 5.1. TA1105 V 9.0 FRP Reset Done Quote:
The Following User Says Thank You to .::EXTREME::. For This Useful Post: |
05-23-2019, 06:42 | #838 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 206 reset password done by best Card found: S/N : 30C22462 , v0122 Registered to: A.G.Shahid Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - 206 Software ver : V 03.58 05-12-12 RM-872 (c) Nokia IMEI 1 : IMEI 2 : XappVer : 000008F2 PPM : V 03.58 05-12-12 RM-872 (c) Nokia M2 CNT : Content: m2_059R6D9 V 03.58 05-12-12 RM-872 (c) Nokia Product SN : 218A2EEBH Product code : 059S8K7 Base Prd.code: 059P6H3 Module code : 0205283 Long Prod.SN : 0 Hardware info======= HWID : 1601 Battery: 5110 mV CMT BT: 19b5-22012 LCDVer: AUO Lock info =========== IMEI : IMEI spNet : 3A 85 73 01 65 55 25 06 IMEI svNet : 33 85 73 01 65 55 25 06 F5 Sl Conf : 001-01-00000000000 Sl Prof : 800000000004000-B Sl Aux : 000B0000 Hw Sig : 5D35574E4BF75307 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Error collect lock info, try again CRT308 Backup Created CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL30 (20 digit) phone detected... User Code : 25524 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:12 Phone disconected! |
05-25-2019, 09:44 | #839 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Bangladesh
Member: 1076772 Status: Offline Sonork: 100.1601881 Thanks Meter: 2,847 | TA-1102} PHONE LOCK FRP DONE Operation : Reset Settings [ v1.15 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MTK USB Port (COM20) MODE : BOOTROM PORT : 20 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6771 AGENT : Nokia_All_InOne_DA_v04.2019.0804 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A68423861503E016647EEC6755D EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 546D3848553355001BBFF48C3BB0C00D DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : RESET PROTECTION Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
05-27-2019, 07:41 | #840 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 230 Format /Reset Settings Done Operation : Reset Settings [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM23) MODE : NOKIA USB SERIAL PORT : 23 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : ACFA02DE26017715DFEAA58130C789AC BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DOHA.13.00.11.p1 BOOT : SWR : 13.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : DOHA.13.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00DC0000 : 0x00234000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:45 Reconnect Power/Cable! |
