Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 01-04-2020, 17:59   #991 (permalink)
Member: 2312129
Thanks Meter: 139
Nokia E61i network unlock done
Card found: S/N : INFINITY BEST BOX , v0138
Registered to: ESEOGHENE
UFS S/N DOLPHIN CLIP boot - Ok
Connect phone on selected interface...
Read and Check phone data...
BB5 bus checking...
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
APE part info :
APE ASICID : 17100708
APE MODE ID : 00
APE PUB ID : FF971D2DBD16240E641D9FF6039C25B6896DE866
APE R_HASH : 49A97E826B93BA20B7ED0B082475C005
APE ROM ID : 1DFD66132C872FD4
CMT part info :
CMT ASICID : 000000010000022600010006010C192101003000
CMT EM0 ID : 00000295
CMT EM1 ID : 00000B22
CMT PUB ID : 1E40020AD1A94F5003A86999906E97A9C1FFD8DC
CMT MODE ID : 00
CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
CMT ROM ID : 273F6D55DFAAF68F
[1ST BOOT] : Boot Ok , A6
CMT : Sending 2nd loader...
Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0
CMT Loader sent, Boot Ok
MCU Configuration
MCU Cfg Ok , 03
FLASHID : 22E800EC , CMT , NOR
CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC
FLCNT : 00000000000000000000000000000000000000
FLASHID : 0000FFFF , CMT , MMC , EXT
CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok
[2ND BOOT] : CMT : Boot Ok
Sending ALGO....
Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0
CMT Algo sent
CMT PAPUB : F6AB1F68D2E4D7D0487762E37D74EA7D923C341FBD
[ALGO BOOT] : CMT : Boot Ok
Transmission mode : Dual (Ddr, TX2)
APE : Sending 2nd loader...
Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0
Payload message : 72
Payload message : D9
APE Loader sent, Boot Ok
MCU Configuration
ready [09100000]
ready [00000000]
MCU cfg fail!!! Error : 000000
[2ND BOOT] : APE : Error , boot not accepted
UFS S/N 79119 boot - Ok
Phone found!
Series 60 Device detected!
read info... - Ok
Read Uniq key data started...
Phone Imei: 351879013203999
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
APE part info :
APE MODE ID : 00
CMT part info :
CMT MODE ID : 00
rap= 1E40020AD1A94F5003A86999906E97A9C1FFD8DC
hash= BAF3A9C3DBFA8454937DB77F2B8852B1
key= 6CDD6456A64D154FFCDBCB33BFCAAB6B9968D0FE
Init Service mode... Wait...
Key file updated...
Done!
Phone found!
read info... - Ok
Unlock procedure started...
Checking locks...
Conf key : 0100000000000000
Provider key : 2140700000000000
Country : Spain
Operator : movistar
Counters : Key 0 [3] , Fbus 0 [10]
Blocks : 4
LOCK STATUS :
BLK : 1
Lock1:Close
BLK : 2
Lock1:Close
BLK : 3
Lock1:Close
BLK : 4
Lock1:Close
LOCKS : Closed
NCK unlock failed, will try direct RPL
Key file exists, no need to read...
Check phone mode...
Phone in Local mode
Seting Test mode... wait...
Test mode set
Writing SimLock Data... Ok
Writing SimLock Key... Ok
Unlock Done!
Phone disconected!
Phone found!
read info... - Ok
Phone disconected!
The Following 2 Users Say Thank You to Elasunuas For This Useful Post:
Old 01-07-2020, 12:40   #992 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 680
Nokia 130 format done
Operation : Reset Settings [ v1.19 ]
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : Nokia USB Serial Port (COM342)
MODE : NOKIA USB SERIAL
PORT : 342
BROM : Init BROM
BROM init passed!
CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000
BROM : SECCFG : 0x00000007
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : C073DDFA861EDD632DD216F38F09BCAD
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : CRYSTAL.10.01.11.p2
BOOT : SWR : 10.01.11
AGENT : Look for suitable BootChain in DA ...
AGENT : DEFAULT AUTO
AGENT : Found MT6260
AGENT : CRYSTAL.10.01.11.p2
BOOT : Sending 1st DA ...
BOOT : DA sent
BOOT : Transfer control to DA ...
DA : Sync Passed!
DA : Authentification pass!
DA : Agent : v03.02 on BBID : 0x8B
NOR: 00EF : 0040 : 0016 : 0000
NOR: [WINBOND] W25Q32BV
NOR:
TSIZE : 0x00400000 [ 4.00 MB ]
PSIZE : 0x00400000 [ 4.00 MB ]
STYPE : 0x00000000
FLOTP : DA_NOR_OTP_EXIST
STATUS : OK
BSTYLE : SF_FLASH_BOOT
Boot done!
FFS Info exists in MAUI : 0x003A4000 : 0x00050000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:29
Reconnect Power/Cable!
The Following User Says Thank You to Luckey1 For This Useful Post:
Old 01-08-2020, 08:48   #993 (permalink)
wong edan's Avatar
Member: 775581
Thanks Meter: 186
Nokia 1 plus TA-1130 FRP done
very easy, just identify & reset settings :
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
- > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage!
PTFN : Android Gadget VCOM Driver (COM41)
MODE : PRELOADER PORT
PORT : 41
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002
TYPE : MODERN RAPHAEL
BROM : DSLevel : DEV_KEY
BROM : PRELOADER PORT
BROM : SOCID : 25027F1C7875BF9660DACC4C38464FE4D48760DCCF062B9465 5AAE766AC9D9E6
AGENT : Found MT6739
AGENT : BEST_Nokia_DA_v19_1711_06
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x40000000 [ 1.00 GB ]
EMMC: 150100464E36324D4203F3AB68B4A511
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00080000 [ 512.00 KB ]
USER : 0x1D2000000 [ 7.28 GB ]
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 9A45F0E49F1C981B3B64822ECA8D89E
DA : USB : HIGH-SPEED
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:29
The Following User Says Thank You to wong edan For This Useful Post:
Old 01-09-2020, 10:52   #994 (permalink)
shabirahmad22's Avatar
Member: 2293727
Sonork: 100.1660528
Thanks Meter: 450
Nokia 2.2 frp reset done by nokia best
NOKIA 2.2 FRP RESET DONE BY NOKIA BEST TOOL
The Following 3 Users Say Thank You to shabirahmad22 For This Useful Post:
Old 01-09-2020, 16:10   #995 (permalink)
Member: 1677653
Thanks Meter: 2,769
Nokia 2.2 format all done
Operation : Identify [ v1.20 ]
PTFN : MediaTek USB Port (COM5)
MODE : BOOTROM
PORT : 5
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200
BROM : DSLevel : DEV_KEY+DEV_ARB
BROM : BOOTROM
BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001]
BROM : SOCID : CC6D3659963A22B1C20075B9634BB2C4E32BC6727D06BE814C 606734C805B250
AGENT : Found MT6761
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : EXT_RAM CFG Passed!
SRAM: 0x00038000 [ 224.00 KB ]
DRAM: 0x80000000 [ 2.00 GB ]
EMMC: 700100544232383136201E1811E85619
EMMC: VEN : KINGSTON | OEM : 01 | DEV : TB2816
EMMC:
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x3A8000000 [ 14.63 GB ]
CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
RNID : E1A7C59436546899EDCBAB815C0DE6B
Boot done!
--- SysInfoSub [PART A]:
Patch Level : PPR1.180610.011
Display ID : 00WW_1_280_SP02
Ver. CodeName : REL
Ver. Release : 9
Sec. Patch : 2019-07-05
Build Time : 1561563965
Product Model : Nokia 2.2
Product Brand : Nokia
Product Name : Wasp_00WW
Product Device : WSP_sprout
Product Manfct : HMD Global
Product Info : WSP_sprout
Product Model : 00WW
Product Board : MT6761
Board Platform : mt6761
--- SysInfoSub [PART B]:
Display ID : 00WW_1_280_SP01
Ver. CodeName : REL
Ver. Release : 9
Sec. Patch : 2019-06-05
Build Time : 1559735086
--- SecuritySub :
NVRAM check : Passed!
Backup sensetive data [ 11 ]
Backup path : Backup\MT6761__E1A7C594365468990EDCBAB815C0DE6B\
[16] Read : PROINFO
[17] Read : NVRAM
[15] Read : SEC1
Backup done!
Done!
Elapsed: 00:00:25
Operation : Reset Settings [ v1.20 ]
MODE : BOOTROM
PORT : 5
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMMC:
Boot done!
Done!
Elapsed: 00:00:38
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 01-10-2020, 04:39   #996 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
Nokia rm-1034 hang on logo done by flashing
Operation : Write FirmWare [ v1.19 ]
Setting   : UserData erase : False
Setting   : LangPack Only : False
PTFN : MediaTek DA USB VCOM Port (COM39)
PORT : 39
BROM : Init BROM
BROM init passed!
     CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001
BROM : MEID : 6D85F20D97C897FD149CE30F505A81F7
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : N103.30.04.11.p1
BOOT : SWR : 30.04.11
AGENT : Found MT6261
AGENT : N103.30.04.11.p1
BOOT : DA sent
DA : Sync Passed!
DA : Agent : v03.02 on BBID : 0x8E
        NOR: 00C8 : 0060 : 0016 : 0000
        NOR: [GigaDevice] GD25LQ32
        NOR:
              STYPE  : 0x00000000
 STATUS : OK
Boot done!
VPL SoftwareVersion   : 10.02.11 [TA-1034]
DEV SoftwareVersion   : 30.04.11
SWInfo compare result : VPL SW ( Major version ) is LOWER, than in DEVICE!
Load FlashSet :
MROM : TA-1034_ROM_eMP_10.02.11
LANG : TA-1034_LANG_PACK_ROM_MS_eMP_10.02.11_001
CUST : TA-1034_CUSTPACK_ROM_MS_eMP_10.02.11_001
JUMP : TA-1034_JUMP_TABLE_MS_eMP_10.02.11_001
VIVA : TA-1034_VIVA_eMP_10.02.11
Prepare FlashSet :
DCR : TA-1034_ROM_eMP_10.02.11
DCR : TA-1034_LANG_PACK_ROM_MS_eMP_10.02.11_001
DCR : TA-1034_CUSTPACK_ROM_MS_eMP_10.02.11_001
DCR : TA-1034_JUMP_TABLE_MS_eMP_10.02.11_001
DCR : TA-1034_VIVA_eMP_10.02.11
Prepare Target
SDS : OK : 0x003F8000 : 0x00008000
Erase Target Flash
Erase done!
Write Target Flash
Write : TA-1034_ROM_eMP_10.02.11
Write : TA-1034_LANG_PACK_ROM_MS_eMP_10.02.11_001
Write : TA-1034_CUSTPACK_ROM_MS_eMP_10.02.11_001
Write : TA-1034_JUMP_TABLE_MS_eMP_10.02.11_001
Write : TA-1034_VIVA_eMP_10.02.11
Write done, waiting target response ...
Write flash done!
Verify Target FlashContent
Verify : TA-1034_ROM_eMP_10.02.11
Verify : TA-1034_LANG_PACK_ROM_MS_eMP_10.02.11_001
Verify : TA-1034_CUSTPACK_ROM_MS_eMP_10.02.11_001
Verify : TA-1034_JUMP_TABLE_MS_eMP_10.02.11_001
Verify : TA-1034_VIVA_eMP_10.02.11
Done!
Elapsed: 00:01:18
The Following User Says Thank You to kothamamun For This Useful Post:
Old 01-10-2020, 07:48   #997 (permalink)
YMS-RYK's Avatar
Member: 1489718
Sonork: 100.1652829 QQ 3237590752
Thanks Meter: 1,495
nokia 110 Hmd ta-1192 6531efm read password done
big thanks best2 team
Operation : Read UserCode [ v1.20 ]
1. Power off device, remove battery
2. Not hold any key on device!
3. Insert battery in device!
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
SVC : DiagChannel opened!
Boot Done!
SW_VER  : 21.00.17.02
LP_VER  : IJ 23NKL74PK00
UserCode : 45678
Done!
Elapsed: 00:00:16
The Following 3 Users Say Thank You to YMS-RYK For This Useful Post:
Old 01-10-2020, 10:07   #998 (permalink)
Registered User
Member: 731353
Thanks Meter: 254
VODAFONE smart kicka 5 NETWORK DONE
Operation : Identify [ v2.06 ]
PTFN : PreLoader USB VCOM (Android) (COM235)
PORT : 235
BROM : Init BROM
BROM init passed!
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
MODE : 0_base : BASE_v1712 | Manual : Enabled
AGENT : blacksheep.bin
AGENT : Found MT6580
AGENT : MTK_DOWNLOAD_AGENT
BROM : DA sent
DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 4500017041493848711F01347B46EBEB
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC: 700100454838494134011F71EBEB467B
EMMC: VEN : KINGSTON | OEM : 01 | DEV : EH8IA4
EMMC:
USER : 0x1C8000000 [ 7.13 GB ]
DRAM: 0x20000000 [ 512.00 MB ]
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 308609D826B69118D0ECA755AFD97322
STATUS : BLANK FLASH
BSTYLE : EMMC FLASH BOOT
Boot done!
Patch Level : O11019
Display ID : O11019 release-keys
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2019-08-05
Build Time : 1568171595
Product Model : Kicka 5
Product Brand : MobiWire
Product Name : Kicka_5
Product Device : Kicka_5
Product Manfct : MobiWire
Product Info : k80hd_bsp_fwv_512m
Board Platform : mt6580
Product Board : VP506_Mobiwire_Kicka5
USERDATA : ENCRYPTED
Card found : 6EF5F8E0 , v0138
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06
Load IDBase v124106 Ok!
Update configuration ...
Error connecting with SSL.
EOF was observed that violates the protocol
Update failed! Check settings and/or internet connection!
Operation : SP Unlock [ v2.06 ]
PORT : 235
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC:
Boot done!
ID0 : Lock : Locked! | MNC : 512 | CNT : 214 | CODE : 12345678
ID1 : Lock : Not Locked!
ID2 : Lock : Not Locked!
ID3 : Lock : Not Locked!
ID4 : Lock : Not Locked!
ID5 : Lock : Not Locked!
ID6 : Lock : Not Locked!
Direct unlock done!
Done!
Elapsed: 00:00:55
The Following 2 Users Say Thank You to bigjef1 For This Useful Post:
Old 01-10-2020, 10:41   #999 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 680
Nokia 210 read user code done
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
Boot Done!
UserCode : 963214
Done!
Elapsed: 00:00:18
The Following 2 Users Say Thank You to Luckey1 For This Useful Post:
Old 01-11-2020, 12:18   #1000 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Nokia 105 rm-1133 reset password done by best2
Card found : 30C22462 , v0122
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20
PTFN : Nokia USB Serial Port (COM7)
PORT : 7
BROM : Init BROM
BROM init passed!
BROM : MEID : BCD567AE8615D104DFB4ED28B388D6EB
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : LAGOS61D.15.00.11.p1
BOOT : SWR : 15.00.11
BOOT : BDDS : 30
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
SWVer : LAGOS61D.15.00.11.p1
FLASH : 00C2 : 0025 : 0036 : 0000
BBSN : BCD567AE8615D104DFB4ED28B388D6EB
PRDC : 059W9Z8
IMEI[1] : 3572990xxxxxxxx
IMEI[2] : 3572990xxxxxxxx
NCK : 20 digits
PROV : 24407000
Saved as : 3572990xxxxxxxx.mtsec
Saved to : C:\InfinityBox\BEST2\Backup\
Done!
Elapsed: 00:00:59
PORT : 7
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
AGENT : LAGOS61D.15.00.11.p1
BOOT : DA sent
DA : Sync Passed!
NOR: 00EF : 0070 : 0016 : 0000
NOR: [Winbond] SF_W25Q32JV
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Info exists in MAUI : 0x00368000 : 0x00090000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:23
The Following 2 Users Say Thank You to A.G.Shahid For This Useful Post:
Old 01-11-2020, 12:22   #1001 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Nokia 150 hang on logo done by best2
PORT : 7
BROM : Init BROM
BROM init passed!
BROM : MEID : 45BF3AAB276B63A9C9E0FE82CE17E970
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : DUBAI61D.30.00.11.p1
BOOT : SWR : 30.00.11
BOOT : BDDS : 30
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
SWVer : DUBAI61D.30.00.11.p1
BBSN : 45BF3AAB276B63A9C9E0FE82CE17E970
PRDC : 059X8W6
IMEI[1] : 357345081xxxxxx
IMEI[2] : 357325086xxxxxx
NCK : 20 digits
PROV : 24407000
Saved as : 357345081xxxxxx.mtsec
Done!
Elapsed: 00:00:59
Open VPLfile : RM1190_059X8W6_30.00.11.vpl
Description : RM-1190 NDT MEA IJ BLACK URDU PK
DeviceType : RM-1190
ProductCode : 059X8W6
SoftwareVer : 30.00.11
PPM LangPack :
[1] : Urdu (Islamic Republic of Pakistan)
[2] : English (United Kingdom)
Load Ok!
Operation : Write FirmWare [ v1.20 ]
PORT : 7
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
AGENT : DUBAI61D.30.00.11.p1
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
VPL SoftwareVersion : 30.00.11 [RM-1190]
DEV SoftwareVersion : 30.00.11
SWInfo compare result : SAME
Load FlashSet :
MROM : RM-1190_ROM_eMP_30.00.11
LANG : RM-1190_LANG_PACK_ROM_IJ_eMP_30.00.11_001
CUST : RM-1190_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.00.11_001
JUMP : RM-1190_JUMP_TABLE_IJ_MEA_PK_eMP_30.00.11_001
VIVA : RM-1190_VIVA_eMP_30.00.11
Prepare FlashSet :
DCR : RM-1190_ROM_eMP_30.00.11
DCR : RM-1190_LANG_PACK_ROM_IJ_eMP_30.00.11_001
DCR : RM-1190_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.00.11_001
DCR : RM-1190_JUMP_TABLE_IJ_MEA_PK_eMP_30.00.11_001
DCR : RM-1190_VIVA_eMP_30.00.11
Prepare Target
Erase Target Flash
Erase done!
Write Target Flash
Write : RM-1190_ROM_eMP_30.00.11
Write : RM-1190_LANG_PACK_ROM_IJ_eMP_30.00.11_001
Write : RM-1190_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.00.11_001
Write : RM-1190_JUMP_TABLE_IJ_MEA_PK_eMP_30.00.11_001
Write : RM-1190_VIVA_eMP_30.00.11
Write flash done!
Verify : RM-1190_ROM_eMP_30.00.11
Verify : RM-1190_LANG_PACK_ROM_IJ_eMP_30.00.11_001
Verify : RM-1190_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.00.11_001
Verify : RM-1190_JUMP_TABLE_IJ_MEA_PK_eMP_30.00.11_001
Verify : RM-1190_VIVA_eMP_30.00.11
Done!
Elapsed: 00:01:07
Old 01-14-2020, 10:35   #1002 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
Nokia ta-1139 identify,password remove and firmware backup done
PORT : 39
BROM : Init BROM
BROM init passed!
BROM : SECCFG : 0x00000005
BROM : MEID : 0D2C69BB3CE3E5DD4BB2E261A06A6840
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : OUTRUN.10.01.11.p1
BOOT : BDDS : 30
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
SWVer : OUTRUN.10.01.11.p1
FLASH : 00EF : 0060 : 0018 : 0000
PRDC : 059Z0X8
IMEI[1] : 357704109543435
IMEI[2] : 357704109983433
NCK  : 20 digits
PROV : 24407000
Saved as  : 357704109543435.mtsec
Done!
Elapsed: 00:00:28
PORT : 39
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
AGENT : OUTRUN.10.01.11.p1
BOOT : DA sent
DA : Sync Passed!
        NOR: 00C8 : 0060 : 0018 : 0000
        NOR: [GigaDevice] GD25LQ128
        NOR:
              TSIZE  : 0x01000000 [ 16.00 MB ]
              PSIZE  : 0x01000000 [ 16.00 MB ]
              STYPE  : 0x00000000
              FLOTP  : DA_NOR_OTP_NOT_SUPPORT
 STATUS : OK
Boot done!
FFS Info exists in MAUI : 0x00C40000  :  0x003B4000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:32
Operation : Read FirmWare [ v1.20 ]
PORT : 39
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : BDDS : 30
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
CODE  : 0x00C40000
Reading Flash ...
TDSN : TA-1139
PRDC : 059Z0X8
PPM  : MD
LANG :
[1] : Malay (Malaysia)
[2] : Indonesian (Indonesia)
[3] : Chinese (S)
[4] : English (United Kingdom)
BUILD : TA-1139_ROM_eMP_10.01.11
BUILD : TA-1139_LANG_PACK_ROM_MD_eMP_10.01.11_001
BUILD : TA-1139_CUSTPACK_ROM_MD_eMP_10.01.11_001
BUILD : TA-1139_JUMP_TABLE_MD_eMP_10.01.11_001
BUILD : TA-1139_VIVA_eMP_10.01.11
Make VPL definition
Save Path : D:\Nokia Flash file\TA-1139\
Save Name : TA-1139_059Z0X8_10.01.11.vpl
Build Finished!
Done!
Elapsed: 00:05:58
Old 01-16-2020, 07:53   #1003 (permalink)
Member: 2935044
Thanks Meter: 75
Nokia 106 TA-1114 Pin Code Reset Done Infinity-Box [BEST] NK2
Here are Logs
Youtube Link
https://www.youtube.com/watch?v=EPsIOuMygNo
The Following User Says Thank You to AAdnan Mobile For This Useful Post:
Old 01-16-2020, 07:55   #1004 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,424
Smile Nokia 210 HMD Global Read User Code Done
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
Boot Done!
UserCode : 26795
Done!
Elapsed: 00:00:16
Old 01-16-2020, 11:28   #1005 (permalink)
naveed ali's Avatar
Member: 720264
Sonork: 100.1649278
Thanks Meter: 192
Nokia 220 [ TA-1155 ] Format Done
Operation : Reset Settings ( Format FS ) [ v1.20 ]
Extra : FTM mode
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
Boot Done!
Erase BLK #0
Format Ok!
Done!
Elapsed: 00:00:19
GSMdunya!
The Following User Says Thank You to naveed ali For This Useful Post:
Page generated in 0.41632 seconds with 10 queries
