GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   BB5 Easy Service Tool (BEST) Nokia Dongle (https://forum.gsmhosting.com/vbb/f641/)
-   -   Success Test Reports (https://forum.gsmhosting.com/vbb/f641/success-test-reports-2192308/)
Akhtar Ali Jatt 02-26-2019 06:16
Nokia 225 Format Done
Operation : Reset Settings [ v1.08 ]
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM Port (COM44)
MODE : NOKIA USB SERIAL
PORT : 44
BROM : Init BROM
BROM init passed!
CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000
BROM : SECCFG : 0x00000007
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : 0ED4CB4E4F27AFDEA91E9158E007BDCD
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : PEARL.10.01.11.p2
AGENT : Look for suitable BootChain in DA ...
AGENT : DEFAULT AUTO
AGENT : Found MT6260
AGENT : PEARL.10.01.11.p2
BOOT : Sending 1st DA ...
BOOT : DA sent
BOOT : Transfer control to DA ...
DA : Agent : v03.02 on BBID : 0x8B
NOR: 00C2 : 0025 : 0038 : 0000
NOR: [MXIC] MX25U12835FZNI_10G
NOR:
TSIZE : 0x01000000 [ 16.00 MB ]
PSIZE : 0x01000000 [ 16.00 MB ]
STYPE : 0x00000000
FLOTP : DA_NOR_OTP_EXIST
STATUS : OK
BSTYLE : SF_FLASH_BOOT
Boot done!
FFS Info exists in MAUI : 0x00C80000 : 0x00374000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:28
Reconnect Power/Cable!
gsaara 02-27-2019 09:32
lumia Unlock Done
Connecting to server...
Credits: 56
WP8 Unlock Started
Connected
Authenticating...
Authenticated
Checking Client version...
Client version is valid
Processing Step #1
Processing Step #2
Processing Step #3
Processing Step #4
Disconnected
Need SDAuth to finish ...
Started
Connecting to SX4 server...
Connected
SX4 enter ..
SDAuth Ok!
SX4 Disconnected
Unlock Done!
Wait for phone reboot ...
Reboot Ok!
Phone disconected!
Connect phone on selected interface...
mbiborna 02-27-2019 12:47
Operation : Reset Settings [ v1.09 ]
PTFN : Care Suite USB Serial Port (COM7)
PORT : 7
BROM : Init BROM
BROM init passed!
CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001
BROM : MEID : CD5A8F5195B552FA3F696A31D8DBA428
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : DUBAI61D.11.00.11.p1
BOOT : SWR : 11.00.11
AGENT : Found MT6261
AGENT : DUBAI61D.11.00.11.p1
BOOT : DA sent
DA : Agent : v03.02 on BBID : 0x8E
NOR: 00EF : 0070 : 0016 : 0000
NOR: [Winbond] SF_W25Q32JV
NOR:
TSIZE : 0x00400000 [ 4.00 MB ]
PSIZE : 0x00400000 [ 4.00 MB ]
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Info exists in MAUI : 0x003A0000 : 0x00058000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:24
Akhtar Ali Jatt 02-27-2019 14:42
Nokia 200
Core : v2.29 , BB5XG FlashEngine : v10.5
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm761__11.95.mcusw
PPM : rm761__11.95.ppm_ma2
CNT : rm761__11.95.image_ma2_059J4K9
Flashing phone now...
[Gen] Rules accepted for : XGOLD Generation
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" / Operation not start
-> Or if Phone start charge - just reinsert battery
-> If flashing freeze - reinsert cable/battery and try again
--- Press phone's power button or insert usb cable! ---
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len : 0x0A
IF xCPUID : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data : 1FB300020303010100FF
Sending EBL Loader ...
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.46_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
Check keys...
Check done. Image can be flashed
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 353256050842484
IMEI 2 : 353256050842492
PCcode : 059N752
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\353256050842484_XG 213_CRT.rpl
Settings : EDM [0x8] , Block Mode , Fast CRC , Verify
===Flashing [MCU]===
File : rm761__11.95.mcusw
Image : rm761__11.95.mcusw_ebl_psi.fls
Sec-pack found, sending ...
Sec-pack sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:07
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01800000
Erasing, wait ...
Erase done, time : 00:02:50
Write , Start : 0x40280000 , Len : 0x01800000
Flashing , wait ...
Region flash done, time : 00:00:44
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
CRC check passed , 0x495E
===Flashing [PPM]===
File : rm761__11.95.ppm_ma2
Image : package_ma2.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41A80000 , Len : 0x00740000
Erasing, wait ...
Erase done, time : 00:00:33
Write , Start : 0x41A80000 , Len : 0x0051B9FC
Flashing , wait ...
Region flash done, time : 00:00:08
CRC check passed , 0xA3D2
===Flashing [CNT]===
File : rm761__11.95.image_ma2_059J4K9
Image : package_ma2_059J4K9.image.fls
Sec-pack sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x421C0000 , Len : 0x01C60000
Erasing, wait ...
Erase done, time : 00:02:55
Write , Start : 0x421C0000 , Len : 0x00FA0000
Flashing , wait ...
Region flash done, time : 00:00:19
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
Erase done, time : 00:00:06
No write data, skip
CRC check passed , 0xFF7A
Flashing done!
Total flash time : 00:07:49
syed tuqeer 02-27-2019 15:48
Nokia 6120c Write Firmware Done :)
Backup Certificates now...
--- Insert cable and charger or press phone's power button! ---
Waiting for communication response...
[BootRom] : 1st boot Ok!
ASIC ID:      000000010000022600010006400C192101051103
CPU ID :      RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB
EM0 ID:        00000296
EM1 ID:        00000B22
PUBLIC ID:    0FB0010908AA00524410F011170D3FFD59876EC2
ASIC MODE ID:  00
ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
ROM ID:        4B9B75103E691FF8
Use URAPIDOv11_2nd.fg  ,  Rev : 2.0  Ver : 12.8.0
Processing RAWLOADER...
FLIC : 003000EC
Req : XSR 1.5
Use URAPIDOv11_XSR15_alg.fg  ,  Rev : 2.0  Ver : 12.8.0
Processing PASUBTOC ...
Processing ALG ...
Boot Done! :)
TIME : Boot time : 00:00:03
CFL: Wait for Loader take control  ...
CFL: Check mode
Phone ready, boot Ok
TransReq set Ok
PAPUBkeys : 0FE1BA92D924A658E4800780FA6F4868100AC947
CFL : Reading flash certs....
CFL : Reading NPC
IMEI : 355938045116078
CFL : Reading CCC
CFL : Reading HWC
CFL: Close_Session
Content: 000300000000010000000100000000
CFL: Reboot
Wait, reconneting...
SLx Simlock Data read ... Ok
SL2 Simlock read ... Ok
CRT308 Backup Created
SimLock Data saved...
SimLock Key saved...
RPL saved : F:\1+Flashing Software\1+Infinity Box\BEST\Backup\Cert\355938045116078.rpl
All done, Disconnecting
Elapsed: 00:00:53
Phone found!
Series 60 Device detected!
read info...  - Ok
MCU : rm243_07.20_prd_core.fpsx
PPM : rm243_07.20_prd_vB15_01_apac2.fpsx
CNT : rm243_ENO_A_2009wk15v0.100.fpsx
APE : rm243_07.20_prd_UDA_Nokia_Noir.fpsx
[Gen] Rules accepted for : RAPIDO Generation
Check files done...
->  Check SW version...
FlashFile version : 07.20
Phone version : 07.20
->  Check SW version : Reflash
Backup CRT308 data...
RPL saved : F:\1+Flashing Software\1+Infinity Box\BEST\Backup\Cert\355938045116078_SIM.rpl
Check communication with phone....
ADL req restart
Communication verify done... Preparing...
Gathering phone info...
Reboot....
BootRom : 1st boot ok
EM0 ID:        00000296
EM1 ID:        00000B22
ASIC MODE ID:  00
PatchRAWLoader: Patched OK
Processing UPDAPP ...
Boot Done! :)
TIME : Boot time : 00:00:30
Reopening the connection...
Waiting for response: 30
Waiting for response: 29
ADL Server confirm flashmode!
Get req info : empty
ADL : ASIC CMT select Ok
Erase : Processing rm243_07.20_prd_core.fpsx
Found 3 areas to erase
Erasing area 0x00040000 - 0x00082FFF, NAND, CMT
Result: 0000
Erasing area 0x00083400 - 0x0087FFFF, NAND, CMT
Result: 0000
Erasing area 0x00B80000 - 0x04DFFFFF, NAND, CMT
Result: 0000
Partition erase not allowed by loader
Partitioning : Ok [5]
TIME : Erase time : 00:00:00
Write : Processing rm243_07.20_prd_core.fpsx
Total 404 [404/0/0] blocks to write, writing...
CMT : Writing Hash CERT [ADA]
CMT : Writing Hash CERT [KEYS]
CMT : Writing Hash CERT [PRIMAPP]
CMT : Writing Hash CERT [RAP3NAND]
CMT : Writing Hash CERT [PASUBTOC]
CMT : Writing Hash CERT [PAPUBKEYS]
CMT : Writing Hash CERT [SOS*UPDAPP]
CMT : Writing Hash CERT [SOS*DSP0]
CMT : Writing Hash CERT [SOS*ISASW]
CMT : Writing Hash CERT [SOS*CORE]
CMT : Writing Hash CERT [SOS+ROFS]
TIME : Write time : 00:00:55
MCU Write done
Erase : Processing rm243_07.20_prd_vB15_01_apac2.fpsx
Found 1 areas to erase
Erasing area 0x03300000 - 0x04DFFFFF, NAND, CMT
Result: 0000
Write : Processing rm243_07.20_prd_vB15_01_apac2.fpsx
Total 164 [164/0/0] blocks to write, writing...
CMT : Writing Hash CERT [SOS+ROFX]
TIME : Write time : 00:00:26
PPM Write done
Erase : Processing rm243_ENO_A_2009wk15v0.100.fpsx
Erasing area 0x00880000 - 0x00B7FFFF, NAND, CMT
Result: 0000
Write : Processing rm243_ENO_A_2009wk15v0.100.fpsx
Total 18 [18/0/0] blocks to write, writing...
CMT : Writing Hash CERT [SOS*ENO]
TIME : Write time : 00:00:01
CNT Write done
  ===Flashing [APE]===
Erase : Processing rm243_07.20_prd_UDA_Nokia_Noir.fpsx
Erasing area 0x04E00000 - 0x07B3FFFF, NAND, CMT
Result: 0000
Write : Processing rm243_07.20_prd_UDA_Nokia_Noir.fpsx
Total 1 [1/0/0] blocks to write, writing...
TIME : Write time : 00:00:00
APE Write done
ADL : End flashing
ADL : Finalize...
Flashing done!
Total flash time : 00:01:25
Reboot phone now...
Reading Phone Info....
Connected phone -  Nokia 6120
Software Info:    V 07.20 05-10-09 RM-243 (c) Nokia
IMEI:  355938045116078
Ape Version: 07.20
Product code:  0567074
Wait, when phone will be ready ...
Checking...
SimLock status : Can't get status
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Battery voltage is enough for start
Set phone to Normal mode...
AfterFlash operations done ;D
Done!
Elapsed: 00:02:23
Phone found!
read info...  - Ok
bright hlatini 02-28-2019 11:27
Nokia 105 ta-1010 reset code done
Phone found!
MTKx Nokia Phone detected
Read info... Ok
Software ver : 10.02.11 00-00-00 TA-1010
IMEI 1 : 3573XXXXXXXXXX
IMEI 2 : XXXXXXXXXXXXXX
XappVer : 000008F2
Ape Ver : NEMO G 4122fe8d/1 (00000000+0) T Thu Dec 29 01:31:09 2016 U d61db836
PPM : ID
CNT : N103.10.02.11.p1
Product SN : 8999706GU
Product code : 059Z1J1
Base Prd.code: 059X9N0
Module code : 0207196
Hardware info=======
HWID : 1200
LCDVer: TPO
Lock info ===========
IMEI : 35734XXXXXXXXXXX
IMEI spNet : 3A 75 43 02 68 77 34 66
Conf key : 800000000004000B
Provider key : 2440700000000000
Country : Finland
Operator : NOKIA (Open)
Lock info:
Block 1
L1:Open; L2:Open; L3:Open; L4:Open; L5:Open;
Block 2
Block 3
Block 4
Block 5
Block 6
Block 7
SimLock status : Ok
Security status : Ok
Done!
Software Info: 10.02.11 00-00-00 TA-1010
IMEI: 3573XXXXXXXXXX
PPM version : ID
Product code: 059Z1J1
Rebooting phone to FlashMode...
Wait for phone...
Phone found! [ 27 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0001
BB_CPU_SN : BF469EC9AEC81769D998B48151EAAF35
BROM Protocol Version : 05
BROM Status : 0000
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
MT626x : Reset User Code
All done! Remove USB cable
All Security Settings deactivated!
Code set to default : 12345
Done!
syed tuqeer 03-02-2019 10:47
Nokia 1 TA-1047 Format / Remove FRP Lock Done :)
Operation : Identify [ v1.09 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
 - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage!
PTFN : PreLoader USB VCOM Port (COM216)
MODE : PRELOADER PORT
PORT : 216
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
    CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000
    TYPE : LEGACY MTK
BROM : DSLevel  : DEV_KEY
BROM : PRELOADER PORT
AGENT : Found MT6735
AGENT : Nokia_All_InOne_DA_v02.2018.1809
    BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
    DA : AGENT started!
NAND : DEVICE NOT FOUND
eMMC : OK
eMMC : 90014A483847346132A536523D2549A1
DAInf: 4 : 2 : 155
    DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
        EMMC: 90014A483847346132A536523D25C4A1
        EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G4a2
        EMMC:
              BOOT1  : 0x00400000 [ 4.00 MB ]
              BOOT2  : 0x00400000 [ 4.00 MB ]
              RPMB  : 0x00400000 [ 4.00 MB ]
              USER  : 0x1D2000000 [ 7.28 GB ]
        SRAM: 0x00020000 [ 128.00 KB ]
        DRAM: 0x40000000 [ 1.00 GB ]
        CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : D5B161CCA01ECA82CF062AD24E2F497E
 STATUS : BLANK FLASH
 BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
--- SysInfoSub :
Patch Level    : O11019
Display ID    : 00WW_0_28M
Ver. CodeName  : REL
Ver. Release  : 8.1.0
Sec. Patch    : 2018-01-05
Build Time    : 1518071106
Product Model  : FRT
Product Brand  : alps
Product Name  : FRT_00WW_FIH
Product Device : FRT
Product Manfct : alps
Product Info  : FRT
Board Platform : mt6737m
--- SecuritySub :
IMEI[0] : 353413095006662
IMEI[1] : 353413098106667
NVRAM check : Passed!
Done!
Elapsed: 00:00:20
PORT : 216
BROM : Init BROM
BROM init passed!
    TYPE : LEGACY MTK
BROM : DA sent
    DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 155
    DA : DRAM ready!
        EMMC:
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:24
syed tuqeer 03-02-2019 11:22
Nokia 130 Write Firmware Done :)
1. Phone should be Off!
2. Battery must be charged and inserted! ( if not used external power )
 - > If phone can't switch to BL - use battery or flash from Local mode!
--- Insert USB cable now! ---
Wait for phone...
Phone found! [ 230 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0001
BB_CPU_SN : 98EB26D6918160E81243F6FC74D34312
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x8000
Project ID : CRYSTAL.10.01.11.p2
BROM/BL stage done
Configure RAMINIT Ok
Reading flash now ...
Done!
Control Block Validation (Security Test) :
CBR is Ok, match with BB SN. Phone Security is Alive :)
Mobile Info
IMEI  : 355129075410041
BBUID : 98EB26D6918160E81243F6FC74D34312
PCCode: 059W037
SimLock Info :
STATE : OPENED ( NOT LOCKED )
RPL Saved to : 355129075410041_MTKx.mtsec
Read Done!
Core : v2.29 , MTKx FlashEngine : v14.0
Verify files ...
MAUI : RM-1035_ROM_eMP_10.01.11
VIVA : RM-1035_VIVA_eMP_10.01.11
LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001
CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_AF_eMP_10.01.11_001
JMPT : RM-1035_JUMP_TABLE_IJ_MEA_AF_eMP_10.01.11_001
 - > MODE : FullFlash
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_eMP_Crystal.fg
DA_VERIFY : 00
DA_JUMP  : 00040000
DA_AUTH  : Passed!
DA_INFO  : 0xC0 , Ver : 3.2 , BBID : 0x8B
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV
[0] : FLASH_DIE : 00EF 0040 0016 0000
[0] : FLASH_LEN : 0x00400000
FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000
SecureDecrypt : RM-1035_ROM_eMP_10.01.11
SecureDecrypt : RM-1035_VIVA_eMP_10.01.11
SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001
SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_AF_eMP_10.01.11_001
SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_AF_eMP_10.01.11_001
OVRLP : 000069B900000001
PHPID : CRYSTAL.10.01.11.p2
OVRLP : 00004DF900000001
DA : FORMAT_BIN
Processing Flash Pre-format
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
WRITE_STYLE : DEF : 0x01 (SEQ)
Write : RM-1035_ROM_eMP_10.01.11
Write : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001
Write : RM-1035_CUSTPACK_ROM_IJ_MEA_AF_eMP_10.01.11_001
Write : RM-1035_JUMP_TABLE_IJ_MEA_AF_eMP_10.01.11_001
Write : RM-1035_VIVA_eMP_10.01.11
CODE_DNLOAD : Ok
[VERIFY] DONE : RM-1035_ROM_eMP_10.01.11
[VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001
[VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_AF_eMP_10.01.11_001
[VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_AF_eMP_10.01.11_001
[VERIFY] DONE : RM-1035_VIVA_eMP_10.01.11
CODE_VERIFY : Ok
Executing FFS FORMAT now...
DA_RET  : DA_IN_PROGRESS
DA_RET  : FORMAT_DONE
Rebooting phone now
Flashing done!
Total flash time : 00:01:10
Reboot phone Ok
 - > Hint : If phone shows Battery charge icon -  press and hold PowerOn button 10 seconds
Software Info:    10.01.11 00-00-00 RM-1035
IMEI:  355129075410041
Ape Version: NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul  1 02:50:44 2013 U 69b804d5
PPM version :  IJ
Product code:  059W037
Checking...
SimLock status : SimLock is Ok
Read Info Done!
Phone found!
Read info... Ok
Phone disconected!
mbiborna 03-02-2019 13:32
Open VPLfile : RM1035_059W2D4_10.01.11.vpl
Description  : RM-1035 NDT MEA IC RED ARABIC JO
DeviceType  : RM-1035
ProductCode  : 059W2D4
SoftwareVer  : 10.01.11
PPM LangPack :
[1] : Arabic (Saudi Arabia)
[2] : Portuguese (Portugal)
[3] : French (France)
[4] : English (United Kingdom)
Load Ok!
Operation : Write FirmWare [ v1.09 ]
Setting  : UserData erase : True
Setting  : LangPack Only : False
PORT : 7
BROM : Init BROM
BROM init passed!
BROM : MEID : 7A114526D0AF9472FE7ABD991E0A5083
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : CRYSTAL.10.01.11.p2
BOOT : SWR : 10.01.11
AGENT : CRYSTAL.10.01.11.p2
BOOT : DA sent
        NOR: 00EF : 0040 : 0016 : 0000
        NOR: [WINBOND] W25Q32BV
        NOR:
              STYPE  : 0x00000000
 STATUS : OK
Boot done!
VPL SoftwareVersion  : 10.01.11 [RM-1035]
DEV SoftwareVersion  : 10.01.11
SWInfo compare result : SAME
Load FlashSet :
MROM : RM-1035_ROM_eMP_10.01.11
LANG : RM-1035_LANG_PACK_ROM_IC_eMP_10.01.11_001
CUST : RM-1035_CUSTPACK_ROM_IC_MEA_JO_eMP_10.01.11_001
JUMP : RM-1035_JUMP_TABLE_IC_MEA_JO_eMP_10.01.11_001
Prepare FlashSet :
DCR : RM-1035_ROM_eMP_10.01.11
DCR : RM-1035_LANG_PACK_ROM_IC_eMP_10.01.11_001
DCR : RM-1035_CUSTPACK_ROM_IC_MEA_JO_eMP_10.01.11_001
DCR : RM-1035_JUMP_TABLE_IC_MEA_JO_eMP_10.01.11_001
DCR : RM-1035_VIVA_eMP_10.01.11
Prepare Target
SDS : OK : 0x003F4000 : 0x0000C000
FFS Format Ok!
CBR : 0x0000001A:0x00000001:0x00000000:0x00000000:0x00000010:0x00000002:0x00000000
Erase Target Flash
Erase done!
Write Target Flash
Write : RM-1035_LANG_PACK_ROM_IC_eMP_10.01.11_001
Write : RM-1035_CUSTPACK_ROM_IC_MEA_JO_eMP_10.01.11_001
Write : RM-1035_JUMP_TABLE_IC_MEA_JO_eMP_10.01.11_001
Write done, waiting target response ...
Write flash done!
Verify Target FlashContent
Verify : RM-1035_ROM_eMP_10.01.11
Verify : RM-1035_LANG_PACK_ROM_IC_eMP_10.01.11_001
Verify : RM-1035_CUSTPACK_ROM_IC_MEA_JO_eMP_10.01.11_001
Verify : RM-1035_JUMP_TABLE_IC_MEA_JO_eMP_10.01.11_001
Verify : RM-1035_VIVA_eMP_10.01.11
Done!
Elapsed: 00:01:33
umarnlw 03-02-2019 13:47
Nokia 216 Rm 1187 Contact Service Done With Infinity Nokia Best
Here are logs
File Link http://www.mediafire.com/file/2nehek...E_30.01.11.rar
https://i.postimg.cc/JzS3dptD/Nokia-...Nokia-Best.png
Youtube Link
https://www.youtube.com/watch?v=alnI...ture=*********
Akhtar Ali Jatt 03-03-2019 07:19
Nokia 225 FullFlash Done
Verify files ...
MAUI : RM-1011_ROM_eMP_30.06.11
VIVA : RM-1011_VIVA_eMP_30.06.11
LANG : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001
CUST : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001
JMPT : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001
Wait for phone...
Phone found! [ 20 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : 91D033420AC95CF7F328888201638692
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
Project ID : PEARL.10.01.11.p3
BROM/BL stage done
DA_eMP_Pearl.fg
DA_VERIFY : 00
DA_JUMP : 00040000
DA_AUTH : Passed!
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW
[0] : FLASH_DIE : 00EF 0060 0018 0000
[0] : FLASH_LEN : 0x01000000
FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000
SecureDecrypt : RM-1011_ROM_eMP_30.06.11
SecureDecrypt : RM-1011_VIVA_eMP_30.06.11
SecureDecrypt : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001
SecureDecrypt : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001
SecureDecrypt : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001
PHPID : PEARL.10.01.11.p3
DA : FORMAT_BIN
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
Write : RM-1011_ROM_eMP_30.06.11
Write : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001
Write : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001
Write : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001
Write : RM-1011_VIVA_eMP_30.06.11
CODE_DNLOAD : Ok
[VERIFY] DONE : RM-1011_ROM_eMP_30.06.11
[VERIFY] DONE : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001
[VERIFY] DONE : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001
[VERIFY] DONE : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001
[VERIFY] DONE : RM-1011_VIVA_eMP_30.06.11
CODE_VERIFY : Ok
Rebooting phone now
Flashing done!
Total flash time : 00:03:20
Reboot phone Ok
kothamamun 03-03-2019 09:56
Nokia ta-1030 password remove and read firmware done
PTFN : MTK USB Port (COM4)
PORT : 4
BROM : Init BROM
BROM init passed!
BROM : MEID : 8563453F28F4C3C80871C324A3981AF2
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : RETRO.11.02.11.p1
BOOT : SWR : 11.02.11
AGENT : RETRO.11.02.11.p1
BOOT : DA sent
        NOR:
              STYPE  : 0x00000000
 STATUS : OK
Boot done!
FFS Info exists in MAUI : 0x00CD0000  :  0x00324000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:38
Operation : Read FirmWare [ v1.09 ]
PORT : 4
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : BDDS : 30
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
SWVer : RETRO.11.02.11.p1
FLASH : 00EF : 0060 : 0018 : 0000
CODE  : 0x00CD0000
Reading Flash ...
TDSN : TA-1030
PRDC : 059Z0D6
PPM  : MS
LANG :
[1] : Hindi (India)
[2] : English (United Kingdom)
BUILD : TA-1030_ROM_eMP_11.02.11
BUILD : TA-1030_LANG_PACK_ROM_MS_eMP_11.02.11_001
BUILD : TA-1030_CUSTPACK_ROM_MS_eMP_11.02.11_001
BUILD : TA-1030_JUMP_TABLE_MS_eMP_11.02.11_001
BUILD : TA-1030_VIVA_eMP_11.02.11
Make VPL definition
Save Path : D:\Nokia Flash file\TA-1030\
Save Name : TA-1030_059Z0D6_11.02.11.vpl
Build Finished!
Done!
Elapsed: 00:06:22
muzammal mudass 03-03-2019 17:06
Nokia 130 2017 Code Reset Done By King Best Dongle
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.09
PTFN : Nokia USB Serial Port (COM69)
PORT : 69
BROM : Init BROM
BROM init passed!
BROM : MEID : 11558BC40EB0E31289CAD7377FEC1455
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : KESA61A.10.00.11.p2
BOOT : SWR : 10.00.11
AGENT : KESA61A.10.00.11.p2
BOOT : DA sent
        NOR: 00EF : 0060 : 0017 : 0000
        NOR: [WINBOND] W25Q64DW
        NOR:
              TSIZE  : 0x00800000 [ 8.00 MB ]
              PSIZE  : 0x00800000 [ 8.00 MB ]
              STYPE  : 0x00000000
 STATUS : OK
Boot done!
FFS Info exists in MAUI : 0x00580000  :  0x00278000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:01:06
https://imgur.com/zQ5BWP6.jpg
Muzammal Mudassar
muzammal mudass 03-03-2019 17:10
Nokia 105 2017 TA1034 Code Reset Done By King Best Dongle
PORT : 69
Error : Failed to open port!
Error : Fail to init protocol!
Remove battery, cable. Check cable and connection. Repeat operation!
PORT : 69
BROM : Init BROM
BROM init passed!
BROM : MEID : 99C053D944CADF66C6A875528DB7861F
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : N103.10.02.11.p1
BOOT : SWR : 10.02.11
AGENT : N103.10.02.11.p1
BOOT : DA sent
        NOR: 00C2 : 0020 : 0016 : 0000
        NOR: [MXIC] MX25L3291FWJI_09
        NOR:
              STYPE  : 0x00000000
 STATUS : OK
Boot done!
FFS Info exists in MAUI : 0x00370000  :  0x00088000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:26
https://imgur.com/aVraDQH.jpg
Muzammal Mudassar
VIJAY2U2 03-05-2019 08:38
Lumia 535 Flashing Done
Core : v2.29 , WP10x FlashEngine : v3.2
FFU : RM1090_02074.00000.15234.28006_RETAIL_prod_signed_1001_025CA7_000-IN.ffu
Checking FFU file, wait...
FFU Revision ID  : 2.0
FFU Model ID      : Nokia.MSM8212.P6214
FFU RootKeyHash  : 0000000000000000000000000000000000000000
FFU Languages    : Portuguese(Brazil) , Russian , Belorusian , fr-ca , Indonesian , Korean , Polish , Ukrainian , Uzbekistan(Latin) , Catalan , Swedish , Bulgarian , Japanese , Spanish , English (UK) , Czech , Latvian , Slovak , Chinese , sr-latn-rs , af-za , Hindi (India) , gl-es , Turkish , Thai , Italian , Danish (Denmark) , ha-latn-ng , Slovenian , Malay (Malaysia) , Lithuanian , Persian (Iran) , Kazakh , Romanian , English , eu-es , Estonian , Filipino (Philippines) , Greek , Norwegian (Bokmal , Norway) , Finnish , Vietnamese , Arabic , Croatian , Portuguese(Portugal) , Chinese(Taiwan) , Macedonian , Hungarian , Spanish(Mexico) , Azerbaijan(Latin) , German , Albanian , Dutch (Netherlands) , French , Hwbre (Israel) ,
FFU ChipSectors  : 15155200
FFU Header        : 0x000E0000
FFU Payload      : 0x6A520000
FFU FastVerify    : Ok
Waiting for phone...
Dead mode is selected , no phone in normal mode found
1. Press and hold "Volume Down"
2. Insert USB cable
3. Hold button until phone will be detected
Device catched in BOOT mode!
Boot Mode confirmed!
Setting Preloder
Collect Info...
Setting Application
Setting Secure
Collect Info...
=== Nokia Flash App info :
Protocol Version        : 2.34
Protocol Implementation : 2.59
=== Phone Initial info :
Phone RMxxx ID : RM-1090
Phone Model ID : Nokia.MSM8212.P6214.1.1
Phone Model PC : 059W6L6
Phone IMEI    : 359730068590941
=== eMMC info :
eMMC Vendor : Hynix
eMMC CID : 0090
eMMC Size : 7456 MiB
=== Security Initial info :
Security Status  : 010100000101
Secure Boot : Enabled
Secure eFUSE : Enabled
JTAG : Disabled
RDC Key : Not Present (Retail)
UEFI SBoot : Enabled
SecHW Key : Exists
Device RootKey    : BC2353ACA62C327ECCD582A281CA4A5672F35001
=== Other info :
SD present        : False
Full Check skipped , will be checked by ImageSignature
Battery Level : 65%
RPMB Provision Status Code : 0x0101
Device RAM size : 1024 MiB
Device not have ATRP
Backup to RAM Ok!
Flashing FFU
Sending FFU Header CertData
Header sent , accepted :)
Perform Data Partition Erase
Erase done
Sending FFU Payload Data...
Finishing flashing
Flashing done!
Green Light :)
Image Sent, processing PostFlash
FinalConfig : Ok , Status : Normal
Make Factory Set : Ok
Restore RAMBkp : Ok
Update NVI from Image
Ok , NVI will be updated on first boot!
PostFlash Finished
Total flash time : 00:07:39
Rebooting
Phone found!
WP10/WP8x Lumia Phone detected
Read info... Ok
Phone disconected!
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.29031 seconds with 6 queries
