GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   BB5 Easy Service Tool (BEST) Nokia Dongle (https://forum.gsmhosting.com/vbb/f641/)
-   -   Success Test Reports (https://forum.gsmhosting.com/vbb/f641/success-test-reports-2192308/)
A.G.Shahid 05-30-2021 05:01
Nokia 106 ta 1114 reset password done by best2
Card found : 30C22462 , v0122
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20
Operation : Identify [ v1.20 ]
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : Nokia USB Serial Port (COM30)
MODE : NOKIA USB SERIAL
PORT : 30
BROM : Init BROM
BROM init passed!
CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001
BROM : SECCFG : 0x00000005
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : 82AD57E6D986244D5FA957C26A078117
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : NEMO61D.10.00.11.p2
BOOT : SWR : 10.00.11
BOOT : BDDS : 30
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
SWVer : NEMO61D.10.00.11.p2
FLASH : 00C2 : 0025 : 0036 : 0000
PRDC : 059Z0X8
IMEI[1] : 357697108829427
IMEI[2] : 357711100109421
NCK : 20 digits
PROV : 24407000
Saved as : 357697108829427.mtsec
Saved to : C:\InfinityBox\BEST2\Backup\
Done!
Elapsed: 00:00:59
Reconnect Power/Cable!
Operation : Reset Settings [ v1.20 ]
PORT : 30
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
AGENT : Look for suitable BootChain in DA ...
AGENT : DEFAULT AUTO
AGENT : Found MT6261
AGENT : NEMO61D.10.00.11.p2
BOOT : Sending 1st DA ...
BOOT : DA sent
BOOT : Transfer control to DA ...
DA : Sync Passed!
DA : Authentification pass!
DA : Agent : v03.02 on BBID : 0x8E
NOR: 00EF : 0070 : 0016 : 0000
NOR: [Winbond] SF_W25Q32JV
NOR:
TSIZE : 0x00400000 [ 4.00 MB ]
PSIZE : 0x00400000 [ 4.00 MB ]
STYPE : 0x00000000
FLOTP : DA_NOR_OTP_EXIST
STATUS : OK
BSTYLE : SF_FLASH_BOOT
Boot done!
FFS Info exists in MAUI : 0x00370000 : 0x00088000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:26
Akhtar Ali Jatt 06-05-2021 11:26
Nokia 150 dual sim RM-1190
Operation : Write FirmWare [ v1.19 ]
Setting : UserData erase : False
Setting : LangPack Only : False
PTFN : Nokia USB Serial Port (COM7)
PORT : 7
BROM : Init BROM
BROM init passed!
BROM : SECCFG : 0x00000007
BROM : MEID : 484B3F8F77CCD030F77C3E825AB754A0
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : DUBAI61D.40.00.11.p1
BOOT : SWR : 40.00.11
AGENT : DUBAI61D.40.00.11.p1
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
VPL SoftwareVersion : 40.00.11 [RM-1190]
DEV SoftwareVersion : 40.00.11
SWInfo compare result : SAME
Load FlashSet :
MROM : RM-1190_ROM_eMP_40.00.11
LANG : RM-1190_LANG_PACK_ROM_IM_eMP_40.00.11_001
CUST : RM-1190_CUSTPACK_ROM_IM_eMP_40.00.11_001
JUMP : RM-1190_JUMP_TABLE_IM_eMP_40.00.11_001
VIVA : RM-1190_VIVA_eMP_40.00.11
Prepare FlashSet :
DCR : RM-1190_ROM_eMP_40.00.11
DCR : RM-1190_LANG_PACK_ROM_IM_eMP_40.00.11_001
DCR : RM-1190_CUSTPACK_ROM_IM_eMP_40.00.11_001
DCR : RM-1190_JUMP_TABLE_IM_eMP_40.00.11_001
DCR : RM-1190_VIVA_eMP_40.00.11
Prepare Target
SDS : OK : 0x003F8000 : 0x00008000
Erase Target Flash
Erase done!
Write Target Flash
Write : RM-1190_ROM_eMP_40.00.11
Write : RM-1190_LANG_PACK_ROM_IM_eMP_40.00.11_001
Write : RM-1190_CUSTPACK_ROM_IM_eMP_40.00.11_001
Write : RM-1190_JUMP_TABLE_IM_eMP_40.00.11_001
Write : RM-1190_VIVA_eMP_40.00.11
Write done, waiting target response ...
Write flash done!
Verify Target FlashContent
Verify : RM-1190_ROM_eMP_40.00.11
Verify : RM-1190_LANG_PACK_ROM_IM_eMP_40.00.11_001
Verify : RM-1190_CUSTPACK_ROM_IM_eMP_40.00.11_001
Verify : RM-1190_JUMP_TABLE_IM_eMP_40.00.11_001
Verify : RM-1190_VIVA_eMP_40.00.11
Done!
Elapsed: 00:01:08
Akhtar Ali Jatt 06-05-2021 11:28
Nokia 106 Format Done
Operation : Reset Settings [ v1.19 ]
PORT : 7
BROM : Init BROM
BROM init passed!
BROM : MEID : 5C6BE00C9C738CB462DD023BCCBBF559
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : N103.30.04.11.p1
BOOT : SWR : 30.04.11
AGENT : N103.30.04.11.p1
BOOT : DA sent
DA : Sync Passed!
NOR: 00C8 : 0060 : 0016 : 0000
NOR: [GigaDevice] GD25LQ32
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:50
Akhtar Ali Jatt 06-05-2021 11:29
Nokia Xl Flashing Done
Core : v2.29 , NXP FlashEngine : v6.0
Flash Mode : System Update (System , Boot) : Not Touch UserData
Check and select files according selected FlashMode
Ok, Set : RM1030_1.2.3.1_059V6Q7_IMEA_PK_variant.img
Ok, Set : RM1030_1.2.3.1_boot.img
Ok, Set : RM1030_1.2.3.1_cache.img
Ok, Set : RM1030_1.2.3.1_emmc_appsboot.mbn
Ok, Set : RM1030_1.2.3.1_emmc_appsboothd.mbn
Ok, Set : RM1030_1.2.3.1_fat.bin
Ok, Set : RM1030_1.2.3.1_oemsbl.mbn
Ok, Set : RM1030_1.2.3.1_oemsblhd.mbn
Ok, Set : RM1030_1.2.3.1_persist.img
Ok, Set : RM1030_1.2.3.1_preload.img
Ok, Set : RM1030_1.2.3.1_qcsbl.mbn
Ok, Set : RM1030_1.2.3.1_qcsblhd_cfgdata.mbn
Ok, Set : RM1030_1.2.3.1_recovery.img
Ok, Set : RM1030_1.2.3.1_system.img
Dead Mode is Selected
1. Phone should be Off!
2. Press and hold 'Volume Down' button
3. Insert USB cable and hold button, until phone will be detected
Connect Ok
Get Phone Initial Info
Product : MSM7627A
Version : 0.5
Serial : DDA7DA1F
HWDetails : 0x000B , 0x0FC5 , 0x0081 , 0x0770
HWDetails : eMMC : VEN 15 , OEM : 0X100 , NAME : J5XWMB
HWDetails : HW Revision V1
Processing : RM1030_1.2.3.1_qcsblhd_cfgdata.mbn
Init Ok, send data ...
Data sent, start flashing
Region Flash Done
Processing : RM1030_1.2.3.1_qcsbl.mbn
Region Flash Done
Processing : RM1030_1.2.3.1_oemsblhd.mbn
Region Flash Done
Processing : RM1030_1.2.3.1_oemsbl.mbn
[Info] : INFOhasHead == true!
Region Flash Done
Processing : RM1030_1.2.3.1_emmc_appsboothd.mbn
Region Flash Done
Processing : RM1030_1.2.3.1_emmc_appsboot.mbn
Region Flash Done
Processing : RM1030_1.2.3.1_boot.img
Region Flash Done
Processing : RM1030_1.2.3.1_recovery.img
Region Flash Done
Processing : RM1030_1.2.3.1_persist.img
Region Flash Done
Processing : RM1030_1.2.3.1_fat.bin
Region Flash Done
Processing : RM1030_1.2.3.1_system.img
Region Flash Done
Processing : RM1030_1.2.3.1_cache.img
Region Flash Done
Processing : RM1030_1.2.3.1_preload.img
Region Flash Done
Processing : RM1030_1.2.3.1_059V6Q7_IMEA_PK_variant.img
Region Flash Done
Rebooting phone now
Flashing done!
Total flash time : 00:03:34
Reboot phone Ok
Connect phone on selected interface...
malik zeshan 08-02-2021 17:20
nokia 105 TA-1034 password reset done
https://i.postimg.cc/rwMGgfYT/nokia-...reset-done.png
malik zeshan 08-02-2021 17:22
nokia 220 RM-969 hang on logo fix by flash
https://i.postimg.cc/133BsW0H/nokia-...-logo-done.png
malik zeshan 08-02-2021 17:23
mbiborna 08-17-2021 10:28
Nokia XL rm-1030 flash done
Flash Mode : Full Update (System, User, Boot)
Ok, Set : RM1030_V2_1.2.3.21_059W180_IMEA_AE_V2_variant.img
Ok, Set : RM1030_V2_1.2.3.21_boot.img
Ok, Set : RM1030_V2_1.2.3.21_cache.img
Ok, Set : RM1030_V2_1.2.3.21_emmc_appsboot.mbn
Ok, Set : RM1030_V2_1.2.3.21_emmc_appsboothd.mbn
Ok, Set : RM1030_V2_1.2.3.21_fat.bin
Ok, Set : RM1030_V2_1.2.3.21_oemsbl.mbn
Ok, Set : RM1030_V2_1.2.3.21_oemsblhd.mbn
Ok, Set : RM1030_V2_1.2.3.21_persist.img
Ok, Set : RM1030_V2_1.2.3.21_preload.img
Ok, Set : RM1030_V2_1.2.3.21_qcsbl.mbn
Ok, Set : RM1030_V2_1.2.3.21_qcsblhd_cfgdata.mbn
Ok, Set : RM1030_V2_1.2.3.21_recovery.img
Ok, Set : RM1030_V2_1.2.3.21_system.img
Ok, Set : RM1030_V2_1.2.3.21_udisk.bin
Ok, Set : RM1030_V2_1.2.3.21_userdata.img
Connect Ok
Product : MSM7627A
Version : 0.5
Serial  : E803CED5
HWDetails : 0x000B , 0x0FC5 , 0x0081 , 0x077C
HWDetails : HW Revision V2
Processing : RM1030_V2_1.2.3.21_qcsblhd_cfgdata.mbn
Region Flash Done
Processing : RM1030_V2_1.2.3.21_qcsbl.mbn
Region Flash Done
Processing : RM1030_V2_1.2.3.21_oemsblhd.mbn
Region Flash Done
Processing : RM1030_V2_1.2.3.21_oemsbl.mbn
Region Flash Done
Processing : RM1030_V2_1.2.3.21_emmc_appsboothd.mbn
Region Flash Done
Processing : RM1030_V2_1.2.3.21_emmc_appsboot.mbn
Region Flash Done
Processing : RM1030_V2_1.2.3.21_boot.img
Region Flash Done
Processing : RM1030_V2_1.2.3.21_recovery.img
Region Flash Done
Processing : RM1030_V2_1.2.3.21_persist.img
Region Flash Done
Processing : RM1030_V2_1.2.3.21_fat.bin
Region Flash Done
Processing : RM1030_V2_1.2.3.21_system.img
Region Flash Done
Processing : RM1030_V2_1.2.3.21_cache.img
Region Flash Done
Processing : RM1030_V2_1.2.3.21_userdata.img
Erase Partition : USERDATA
Partition Erase Done
Region Flash Done
Processing : RM1030_V2_1.2.3.21_udisk.bin
Region Flash Done
Processing : RM1030_V2_1.2.3.21_preload.img
Region Flash Done
Processing : RM1030_V2_1.2.3.21_059W180_IMEA_AE_V2_variant.img
Region Flash Done
Rebooting phone now
Flashing done!
Total flash time : 00:03:59
Reboot phone Ok
Phone found!
Nokia X Platform Phone detected (ADB)
Read info... Ok
Luckey1 09-04-2021 08:40
Nokia 206 fullflash done
Core : v2.29 , BB5XG FlashEngine : v10.5
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm872__04.52.mcusw
PPM : rm872__04.52.ppm_m2
CNT : rm872__04.52.image_m2_059Q4L5
Flashing phone now...
[Gen] Rules accepted for : XGOLD Generation
Check files done...
-> SWversion check skipped : Dead mode selected
Waiting for USB device...
-> If Windows say "Unrecognized device" / Operation not start
-> Or if Phone start charge - just reinsert battery
-> If flashing freeze - reinsert cable/battery and try again
--- Press phone's power button or insert usb cable! ---
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len : 0x0A
IF xCPUID : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data : 1FB300020303010100FF
Sending EBL Loader ...
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.53_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
Check keys...
Check done. Image can be flashed
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 356724055562206
IMEI 2 : 356724055562214
PCcode : 059Q4J7
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\356724055562206_2n d_XG213_CRT.rpl
Settings : EDM [0x8] , Block Mode , Fast CRC , Verify
===Flashing [MCU]===
File : rm872__04.52.mcusw
Image : rm872__04.52.mcusw_ebl_psi.fls
Sec-pack found, sending ...
Sec-pack sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:06
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01800000
Erasing, wait ...
Erase done, time : 00:02:23
Write , Start : 0x40280000 , Len : 0x01800000
Flashing , wait ...
Region flash done, time : 00:00:29
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
CRC check passed , 0xFA4D
===Flashing [PPM]===
File : rm872__04.52.ppm_m2
Image : package_m2.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41A80000 , Len : 0x00680000
Erasing, wait ...
Erase done, time : 00:00:22
Write , Start : 0x41A80000 , Len : 0x003C68F0
Flashing , wait ...
Region flash done, time : 00:00:04
CRC check passed , 0xC9E6
===Flashing [CNT]===
File : rm872__04.52.image_m2_059Q4L5
Image : package_m2_059Q4L5.image.fls
Sec-pack sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x42100000 , Len : 0x01D20000
Erasing, wait ...
Erase done, time : 00:02:04
Write , Start : 0x42100000 , Len : 0x01040000
Flashing , wait ...
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
Erase done, time : 00:00:08
No write data, skip
CRC check passed , 0x7399
Flashing done!
Total flash time : 00:06:12
Reboot phone now...
Reading Phone Info....
Connected phone - 206
Software Info: V 04.52 30-06-13 RM-872 (c) Nokia
IMEI: 356724055562206
PPM version : V 04.52 30-06-13 RM-872 (c) Nokia M2
Product code: 059Q4J7
Wait, when phone will be ready ...
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Check and Upload User Certificates ...
Total - 58 certs
Certificates found, skip upload ...
AfterFlash operations done ;D
Done!
Elapsed: 00:07:13
Phone found!
Series 40 Device detected!
read info... - Ok
Luckey1 09-10-2021 08:32
Nokia 150 full flash done
Operation : Write FirmWare [ v1.20 ]
Setting : UserData erase : True
PTFN : Nokia USB Serial Port (COM14)
PORT : 14
BROM : Init BROM
BROM init passed!
BROM : MEID : F0D9DD56C7DB297F9327207F391FF984
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : DUBAI61D.30.00.11.p1
BOOT : SWR : 30.00.11
AGENT : DUBAI61D.30.00.11.p1
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
VPL SoftwareVersion : 30.00.11 [RM-1190]
DEV SoftwareVersion : 30.00.11
Load FlashSet :
MROM : RM-1190_DUBAI_ROM_eMP_30.00.11
LANG : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_30.00.11
CUST : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_30.00.11
JUMP : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_30.00.11
VIVA : RM-1190_DUBAI_VIVA_eMP_30.00.11
Prepare FlashSet :
DCR : RM-1190_DUBAI_ROM_eMP_30.00.11
DCR : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_30.00.11
DCR : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_30.00.11
DCR : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_30.00.11
DCR : RM-1190_DUBAI_VIVA_eMP_30.00.11
Prepare Target
FFS Format Ok!
Erase Target Flash
Erase done!
Write Target Flash
Write : RM-1190_DUBAI_ROM_eMP_30.00.11
Write : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_30.00.11
Write : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_30.00.11
Write : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_30.00.11
Write : RM-1190_DUBAI_VIVA_eMP_30.00.11
Write flash done!
Verify : RM-1190_DUBAI_ROM_eMP_30.00.11
Verify : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_30.00.11
Verify : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_30.00.11
Verify : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_30.00.11
Verify : RM-1190_DUBAI_VIVA_eMP_30.00.11
Done!
Elapsed: 00:01:12
A.G.Shahid 09-12-2021 13:37
Nokia 106 ta 1114 hang on logo done by best
PTFN : Nokia USB Serial Port (COM10)
PORT : 10
BROM : Init BROM
BROM init passed!
BROM : MEID : 909727D06427CA108B48AB9E7F01477E
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : BDDS : 30
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
PRDC : 059Z0X8
IMEI[1] : 35768010
IMEI[2] : 35768010
NCK : 20 digits
PROV : 24407000
Saved as : 35768010.mtsec
Done!
Elapsed: 00:00:59
Open VPLfile : TA-1114_059Z0X8_10.00.11.vpl
Description : TA-1114 IM
DeviceType : TA-1114
ProductCode : 059Z0X8
SoftwareVer : 10.00.11
PPM LangPack :
[1] : Hindi (India)
[2] : Urdu (Islamic Republic of Pakistan)
[3] : Arabic (Saudi Arabia)
[4] : English (United Kingdom)
Load Ok!
PORT : 10
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
VPL SoftwareVersion : 10.00.11 [TA-1114]
DEV SoftwareVersion : 10.00.11
Load FlashSet :
MROM : TA-1114_ROM_eMP_10.00.11
LANG : TA-1114_LANG_PACK_ROM_IM_eMP_10.00.11_001
CUST : TA-1114_CUSTPACK_ROM_IM_eMP_10.00.11_001
JUMP : TA-1114_JUMP_TABLE_IM_eMP_10.00.11_001
VIVA : TA-1114_VIVA_eMP_10.00.11
Prepare FlashSet :
DCR : TA-1114_ROM_eMP_10.00.11
DCR : TA-1114_LANG_PACK_ROM_IM_eMP_10.00.11_001
DCR : TA-1114_CUSTPACK_ROM_IM_eMP_10.00.11_001
DCR : TA-1114_JUMP_TABLE_IM_eMP_10.00.11_001
DCR : TA-1114_VIVA_eMP_10.00.11
Prepare Target
FFS Format Ok!
Erase Target Flash
Erase done!
Write Target Flash
Write : TA-1114_ROM_eMP_10.00.11
Write : TA-1114_LANG_PACK_ROM_IM_eMP_10.00.11_001
Write : TA-1114_CUSTPACK_ROM_IM_eMP_10.00.11_001
Write : TA-1114_JUMP_TABLE_IM_eMP_10.00.11_001
Write : TA-1114_VIVA_eMP_10.00.11
Write flash done!
Verify : TA-1114_ROM_eMP_10.00.11
Verify : TA-1114_LANG_PACK_ROM_IM_eMP_10.00.11_001
Verify : TA-1114_CUSTPACK_ROM_IM_eMP_10.00.11_001
Verify : TA-1114_JUMP_TABLE_IM_eMP_10.00.11_001
Verify : TA-1114_VIVA_eMP_10.00.11
Done!
Elapsed: 00:01:11
Luckey1 09-14-2021 13:52
Nokia 106 format done
PTFN : Nokia USB Serial Port (COM29)
PORT : 29
BROM : Init BROM
BROM init passed!
BROM : MEID : 54C65CC61B7CAB3E791712149B156AAF
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:21
Akhtar Ali Jatt 09-22-2021 09:58
PORT : 29
BROM : Init BROM
BROM init passed!
BROM : MEID : FD564B8B66684389285A4D3DF9BD00BB
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : DUBAI61D.11.00.11.p1
BOOT : SWR : 11.00.11
AGENT : DUBAI61D.11.00.11.p1
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
VPL SoftwareVersion : 11.00.11 [RM-1190]
DEV SoftwareVersion : 11.00.11
Load FlashSet :
MROM : RM-1190_DUBAI_ROM_eMP_11.00.11
LANG : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11
CUST : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11
JUMP : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11
VIVA : RM-1190_DUBAI_VIVA_eMP_11.00.11
Prepare FlashSet :
DCR : RM-1190_DUBAI_ROM_eMP_11.00.11
DCR : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11
DCR : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11
DCR : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11
DCR : RM-1190_DUBAI_VIVA_eMP_11.00.11
Prepare Target
FFS Format Ok!
Erase Target Flash
Erase done!
Write Target Flash
Write : RM-1190_DUBAI_ROM_eMP_11.00.11
Write : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11
Write : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11
Write : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11
Write : RM-1190_DUBAI_VIVA_eMP_11.00.11
Write flash done!
Verify : RM-1190_DUBAI_ROM_eMP_11.00.11
Verify : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11
Verify : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11
Verify : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11
Verify : RM-1190_DUBAI_VIVA_eMP_11.00.11
Done!
Elapsed: 00:01:18
Akhtar Ali Jatt 11-04-2021 14:34
Open VPLfile : TA-1034_059Z107_30.04.11.vpl
Description : TA-1034 IJ
DeviceType : TA-1034
ProductCode : 059Z107
SoftwareVer : 30.04.11
PPM LangPack :
[1] : Urdu (Islamic Republic of Pakistan)
[2] : English (United Kingdom)
Load Ok!
Setting : LangPack Only : True
PORT : 29
BROM : Init BROM
BROM init passed!
BROM : MEID : 835345BFA7484B7CB1286B4D8F8BE5DC
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
VPL SoftwareVersion : 30.04.11 [TA-1034]
DEV SoftwareVersion : 30.04.11
Load FlashSet :
LANG : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001
CUST : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001
JUMP : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001
Prepare FlashSet :
DCR : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001
DCR : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001
DCR : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001
Prepare Target
Erase Target Flash
Erase done!
Write Target Flash
Write : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001
Write : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001
Write : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001
Write flash done!
Verify : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001
Verify : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001
Verify : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001
Done!
Elapsed: 00:00:40
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.29341 seconds with 6 queries
