Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 07-27-2017, 11:16   #181 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,027
Nokia 105 Write FIrmware DOne :)
UFS S/N 103896 boot - Ok
Connect phone on selected interface...
Phone found!
Series 40 Device detected!
read info...  - Ok
Core : v2.29 , BB5XG FlashEngine : v10.5
Selected FlashSettings : Manual
Files Set for Flashing :
MCU : rm908_003.400
PPM : rm908_003.40ij
CNT : rm9080_nai03.40ij
Infineon flashing...
-> Infineon XG110 : IMEI Backup Created
Booting phone now....
Sync Ok , A2
CPU ID : XGOLD , A200341100
PBL : Dynamic
Boot Ok , 01AB
SBL : Dynamic
Algo Ok , 01
SBL mode Ok
SBL : Default_RAM_Bootloader
EPP CFG [Bering]...
FLASH VEN : 0000002C
FLASH DIE  : 0000CB17
FLASH ID : SPI , 25W064A
Boot Done!
   ===Flashing [MCU]===
File : rm908_003.400
Image : hw_f31_rm908_62_mcusw_03.40_Best.fls
Cert block found, sending....
Cert sent
Found 3 region(s)
Processing Region 1/3
Erase , Start : 0x00800000 , Len : 0x00210000
Erasing, wait ...
Erase done
Write , Start : 0x00800000 , Len : 0x00210000
Flashing , wait ...
Region flash done
Processing Region 2/3
Erase , Start : 0x00C60000 , Len : 0x00250000
Erasing, wait ...
Erase done
Write , Start : 0x00C60000 , Len : 0x00221240
Flashing , wait ...
Region flash done
Processing Region 3/3
Erase , Start : 0x00FFC000 , Len : 0x00004000
Erasing, wait ...
Erase done
Write , Start : 0x00FFC000 , Len : 0x00000040
Flashing , wait ...
Region flash done
Check : 5960
   ===Flashing [PPM]===
File : rm908_003.40ij
Image : hw_f31_rm908_62_ppm_03.40ij_Best.fls
Cert sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x00210000 , Len : 0x00250000
Erasing, wait ...
Erase done
Write , Start : 0x00210000 , Len : 0x0018A340
Flashing , wait ...
Region flash done
Check : 3ED1
   ===Flashing [CNT]===
File : rm9080_nai03.40ij
Image : hw_f31_rm908_62_image_03.40ij_Best.fls
Cert sent
Found 1 region(s)
Erase , Start : 0x00EB0000 , Len : 0x000D0000
Erasing, wait ...
Erase done
Write , Start : 0x00EB0000 , Len : 0x000661C0
Flashing , wait ...
Region flash done
Check : 919A
Flashing done, rebooting...
-> Infineon info : Do FullFactory Sets after flashing
Flashing Done!
Init Service mode... Wait...
Afterflash settings...
SW ver : V 03.40
08-08-13
RM-908
(c) Nokia
IMEI   : 357252050161757
PCode  : 059R447
Settings After Flash Defaults...
FullFactorySet...OK!
ProductTuneSet...OK!
SwUpgradeSet...OK!
All done!
Phone found!
read info...  - Ok
Reading Phone Info....
SW ver  : V 03.40 08-08-13 RM-908 (c) Nokia
PPM     :      V 03.40
08-08-13
RM-908
(c) Nokia
IJ
PCode   :      059R447
BPCode  :      059Q858
HWID    :      2000
LCDVer  :      TIANMA:BEIHAIv83
ST7735R2
Sl Conf  : 001-01-00000000000
Sl Prof  : 000000000004000-2
Sl Aux   : 000B0000
Hw Sig   : 876443597A6B5AD4
Country      : Test SIM (Open)
Operator     : NOKIA (Open)
Lock info:
Block 1
L1:Open;  L2:Open;  L3:Open;  L4:Open;  L5:Open;
Block 2
Block 3
Block 4
Block 5
Block 6
Block 7
Done!
The Following 2 Users Say Thank You to syed tuqeer For This Useful Post:
Old 07-27-2017, 13:45   #182 (permalink)
Member: 654997
Thanks Meter: 4,027
Nokia 515 write firmware Done :)
Check FlashFiles, Please, wait...
MCU : rm952__10.34.mcusw
PPM : rm952__10.34.ppm_m2
CNT : rm952__10.34.image_m2_059T0H8
Flashing phone now...
[Gen] Rules accepted for : XGOLD Generation
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" / Operation not start
-> Or if Phone start charge - just reinsert battery
-> If flashing freeze - reinsert cable/battery and try again
--- Press phone's power button or insert usb cable! ---
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len  : 0x16
IF xCPUID    : XGOLD 618 [XMM6180 QUARK]
IF uCHIPID    :  50A9070100030101E0401012000C4B64583073B4FFFF
IF Resp Data  :  50A9070100030101
Wait for user action : Insert battery
Sending EBL Loader ...
EBL Loader Ok
EBL Loader ready
Sending EBL ...
EBL sent Ok
EBL : QUARK_1337.500_M1S1
QUARK EEP config Ok
FLASHID : EC004000 , [ MuxOneNAND ]
Boot conf set, Target Ready
Boot done!
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 359602055439426
IMEI 2 : 359602055439434
Phone Product Code : 059T0H8
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : F:\1+Flashing Software\1+Infinity Box\BEST\Backup\Cert\359602055439426_2nd_XG618_CRT.rpl
Processing file : rm952__10.34.mcusw
Region count : 8
00 : [ PSI ]   : psi_flash_unsigned.fls
01 : [ BCore ] : slb_signed.fls
02 : [ Code ]  : main_toc_signed.fls
03 : [ Code ]  : rm952__10.34.mcusw_signed_mcusw.fls
04 : [ Code ]  : swap_signed.fls
05 : [ Cust ]  : dynsw.fls
06 : [ Code ]  : aeneas_signed.fls
07 : [ Code ]  : fota_signed.fls
Parse done , flashing now
Flash : 00 : psi_flash_unsigned.fls
Sending Sec-Pack
SecInfo Area : 0x0000 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x00090000 , Len : 0x00020000
Erase now...
Erase done
Region Start : 0x00090000 , Data Len : 0x00010FB0
Region Load done
Write done
psi_flash_unsigned.fls image flash done
Flash : 01 : slb_signed.fls
Sending Sec-Pack
SecInfo Area : 0x0001 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x60000000 , Len : 0x00040000
Erase now...
Erase done
Region Start : 0x60000000 , Data Len : 0x00040000
Region Load done
Write done
slb_signed.fls image flash done
Flash : 02 : main_toc_signed.fls
Sending Sec-Pack
SecInfo Area : 0x0002 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x60040000 , Len : 0x00000400
Erase now...
Erase done
Region Start : 0x60040000 , Data Len : 0x00000400
Region Load done
Write done
main_toc_signed.fls image flash done
Flash : 03 : rm952__10.34.mcusw_signed_mcusw.fls
Sending Sec-Pack
SecInfo Area : 0x0003 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x62E00000 , Len : 0x01100000
Erase now...
Erase done
Erase area 0x01 , Start 0xFFF00000 , Len : 0x00080000
Erase now...
Erase done
Region Start : 0x62E00000 , Data Len : 0x00F29698
Region Load done
Write done
rm952__10.34.mcusw_signed_mcusw.fls image flash done
Flash : 04 : swap_signed.fls
Sending Sec-Pack
SecInfo Area : 0x0004 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x80000000 , Len : 0x00F00000
Erase now...
Erase done
Region Start : 0x80000000 , Data Len : 0x00C2D070
Region Load done
Write done
swap_signed.fls image flash done
Flash : 05 : dynsw.fls
Sending Sec-Pack
SecInfo Area : 0x0005 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x62080000 , Len : 0x00100000
Erase now...
Erase done
Region Start : 0x62080000 , Data Len : 0x00044000
Region Load done
Write done
dynsw.fls image flash done
Flash : 06 : aeneas_signed.fls
Sending Sec-Pack
SecInfo Area : 0x0006 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x63F79C00 , Len : 0x00080000
Erase now...
Erase done
Region Start : 0x63F79C00 , Data Len : 0x00046870
Region Load done
Write done
aeneas_signed.fls image flash done
Flash : 07 : fota_signed.fls
Sending Sec-Pack
SecInfo Area : 0x0007 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x61F00004 , Len : 0x0017FFFC
Erase now...
Erase done
Region Start : 0x61F00004 , Data Len : 0x001498A4
Region Load done
Write done
fota_signed.fls image flash done
Processing file : rm952__10.34.ppm_m2
Region count : 1
00 : [ Cust ]  : package_m2.ppm_ebl_psi.fls
Flash : 00 : package_m2.ppm_ebl_psi.fls
Sending Sec-Pack
Erase area 0x00 , Start 0x80F00000 , Len : 0x00B00000
Erase now...
Erase done
Region Start : 0x80F00000 , Data Len : 0x00521534
Region Load done
Write done
package_m2.ppm_ebl_psi.fls image flash done
Processing file : rm952__10.34.image_m2_059T0H8
Region count : 1
00 : [ Cust ]  : package_m2_059T0H8.image.fls
Flash : 00 : package_m2_059T0H8.image.fls
Sending Sec-Pack
Erase area 0x00 , Start 0xA1000000 , Len : 0x0C580000
Erase now...
Erase done
Erase area 0x01 , Start 0xAE000000 , Len : 0x00300000
Erase now...
Erase done
Region Start : 0xA1000000 , Data Len : 0x02379A00
Region Load done
Write done
package_m2_059T0H8.image.fls image flash done
Flashing done!
Total flash time : 00:00:16
Reboot phone now...
Connected phone -   Nokia 515
Software Info:     V 10.34 13-03-14 RM-952 (c) Nokia
IMEI:  359602055439426
PPM version :   V 10.34 13-03-14 RM-952 (c) Nokia             M2
Product code:  059T0H8
Wait, when phone will be ready ...
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
SwUpgradeSet...OK!
Check and Upload User Certificates ...
Total - 58 certs
Certificates found, skip upload ...
Battery voltage is enough for start
Set phone to Normal mode...
AfterFlash operations done ;D
Done!
Elapsed: 00:00:54
Phone found!
read info...  - Ok
The Following User Says Thank You to syed tuqeer For This Useful Post:
Old 07-27-2017, 15:16   #183 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,244
Smile Nokia 225
Core : v2.29 , MTKx FlashEngine : v14.0
Verify files ...
MAUI : RM-1011_ROM_eMP_30.06.11
VIVA : RM-1011_VIVA_eMP_30.06.11
LANG : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001
CUST : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001
JMPT : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001
 - > MODE : FullFlash
1. Phone should be Off!
2. Battery must be charged and inserted! ( if not used external power )
 - > If phone can't switch to BL - use battery or flash from Local mode!
--- Insert USB cable now! ---
Wait for phone...
Phone found! [ 145 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0001
BB_CPU_SN : 5F68885C941D13789D2AECCEBEE96B5E
BROM Protocol Version : 05
BROM Status : 0000
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x8000
Project ID : PEARL.20.10.11.p1
BROM/BL stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_eMP_Pearl.fg
DA_VERIFY : 00
DA_JUMP   : 00040000
DA_AUTH   : Passed!
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8B
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW
[0] : FLASH_DIE : 00EF 0060 0018 0000
[0] : FLASH_LEN : 0x01000000
FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000
SecureDecrypt : RM-1011_ROM_eMP_30.06.11
SecureDecrypt : RM-1011_VIVA_eMP_30.06.11
SecureDecrypt : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001
SecureDecrypt : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001
SecureDecrypt : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001
OVRLP : 000069B900000001
PHPID : PEARL.20.10.11.p1
OVRLP : 00004DF900000001
DA : FORMAT_BIN
Processing Flash Pre-format
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
WRITE_STYLE : DEF : 0x01 (SEQ)
Write : RM-1011_ROM_eMP_30.06.11
Write : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001
Write : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001
Write : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001
Write : RM-1011_VIVA_eMP_30.06.11
CODE_DNLOAD : Ok
[VERIFY] DONE : RM-1011_ROM_eMP_30.06.11
[VERIFY] DONE : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001
[VERIFY] DONE : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001
[VERIFY] DONE : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001
[VERIFY] DONE : RM-1011_VIVA_eMP_30.06.11
CODE_VERIFY : Ok
Executing FFS FORMAT now...
DA_RET   : DA_IN_PROGRESS
DA_RET   : FORMAT_DONE
Rebooting phone now
Flashing done!
Total flash time : 00:03:26
The Following 3 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 07-28-2017, 07:09   #184 (permalink)
Member: 654997
Thanks Meter: 4,027
Memory Card Format /Unlock Done :)
Check phone mode...
Phone in Normal mode
Seting Local mode... wait...
Local mode set
Format ...
Format Done
All done
Old 07-28-2017, 19:54   #185 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 2,693
NOKIA ASHA 210 RM-925 HANG AFTER POWER ON DONE BY INFINITY BEST
Card found: S/N : A6936825 , v0136
Registered to: Yuslam Unique
Selected FlashSettings : FullFlash
MCU : rm925__06.09.mcusw
PPM : rm925__06.09.ppm_mec
CNT : rm925__06.09.image_mec_059R844
Check files done...
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
IF xCPUID    : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data  :  1FB300020303010100FF
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.56_M1S1
Speed accepted, use 6.500.000
FLASHID : EC001230
FLIC conf set, RST set
Boot done!
Check keys...
Check done. Image can be flashed
Reading CCC
Reading HWC
Reading NPC
IMEI : 355513052091124
PCcode : 059R9T6
RPL saved : C:\InfinityBox\BEST\Backup\Cert\355513052091124_XG213_CRT.rpl
Settings : EDM [0x8] , Block Mode , Fast CRC , Verify
File : rm925__06.09.mcusw
Image : rm925__06.09.mcusw_ebl_psi.fls
Sec-pack found, sending ...
Sec-pack sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:02
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01A40000
Erasing, wait ...
Erase done, time : 00:00:58
Write , Start : 0x40280000 , Len : 0x01A40000
Flashing , wait ...
Region flash done, time : 00:00:35
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
CRC check passed , 0xA045
File : rm925__06.09.ppm_mec
Image : package_mec.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Erase , Start : 0x41CC0000 , Len : 0x00640000
Erasing, wait ...
Erase done, time : 00:00:09
Write , Start : 0x41CC0000 , Len : 0x0056371C
Flashing , wait ...
Region flash done, time : 00:00:06
CRC check passed , 0x7C2E
File : rm925__06.09.image_mec_059R844
Image : package_mec_059R844.image.fls
Sec-pack sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x42300000 , Len : 0x01B20000
Erasing, wait ...
Erase done, time : 00:01:15
Write , Start : 0x42300000 , Len : 0x00C20000
Flashing , wait ...
Region flash done, time : 00:00:15
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
No write data, skip
CRC check passed , 0x79D9
Flashing done!
Total flash time : 00:03:29
Reboot phone now...
 - > AfterFlash Failed! :( Reason : Downgrade try or HW Error
     Anyway - try reinsert battery and PowerUp phone manualy
Done!
Elapsed: 00:06:01
Phone found!
read info...  - Ok
Phone disconected!
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 07-29-2017, 08:30   #186 (permalink)
Member: 654997
Thanks Meter: 4,027
Nokia 108 Write FIrmware Done :)
Phone found!
MTKx Nokia Phone detected
Read info... Ok
Software ver : 11.01.11 00-00-00 RM-944
IMEI 1  :      357270055617706
IMEI 2  :      357270055617714
XappVer :      000008F2
Ape Ver :      NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul  1 02:50:44 2013 U 69b804d5
PPM     :      IJ
CNT     :      Bree.11.01.11.p1
Product SN   :     3658422BH
Product code :     059S7R0
Base Prd.code:     059S0R7
Module code  :     0205624
Hardware info=======
HWID  : 1001
LCDVer: TPO
Lock info ===========
IMEI       : 357270055617706
IMEI spNet : 3A 75 72 00 55 16 77 60
Conf key     : 800000000004000B
Provider key : 0010100000000000
Lock info:
Block 1
Block 2
Block 3
Block 4
Block 5
Block 6
Block 7
SimLock status : Ok
Security status : Ok
Done!
Verify files ...
MAUI : RM-944_ROM_eMP_22.00.11
VIVA : RM-944_VIVA_eMP_22.00.11
LANG : RM-944_LANG_PACK_ROM_IC_eMP_22.00.11
CUST : RM-944_CUSTPACK_ROM_IC_MEA_DZ_eMP_22.00.11
JMPT : RM-944_JUMP_TABLE_IC_MEA_DZ_eMP_22.00.11
Software Info:     11.01.11 00-00-00 RM-944
IMEI:  357270055617706
PPM version :   IJ
Product code:  059S7R0
Rebooting phone to FlashMode...
Wait for phone...
Phone found! [ 174 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0001
BB_CPU_SN : F80ACD3ECAD41300F1579774689BBFC0
BROM Status : 1012
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
Project ID : Bree.11.01.11.p1
BROM/BL stage done
DA_eMP_Bree.fg
DA_VERIFY : 00
DA_JUMP   : 00040000
DA_AUTH   : Passed!
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x88
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E
[0] : FLASH_DIE : 00C2 0025 0036 0000
[0] : FLASH_LEN : 0x00400000
FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000
SecureDecrypt : RM-944_ROM_eMP_22.00.11
SecureDecrypt : RM-944_VIVA_eMP_22.00.11
SecureDecrypt : RM-944_LANG_PACK_ROM_IC_eMP_22.00.11
SecureDecrypt : RM-944_CUSTPACK_ROM_IC_MEA_DZ_eMP_22.00.11
SecureDecrypt : RM-944_JUMP_TABLE_IC_MEA_DZ_eMP_22.00.11
PHPID : Bree.11.01.11.p1
DA : FORMAT_BIN
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
Write : RM-944_ROM_eMP_22.00.11
Write : RM-944_LANG_PACK_ROM_IC_eMP_22.00.11
Write : RM-944_CUSTPACK_ROM_IC_MEA_DZ_eMP_22.00.11
Write : RM-944_JUMP_TABLE_IC_MEA_DZ_eMP_22.00.11
Write : RM-944_VIVA_eMP_22.00.11
CODE_DNLOAD : Ok
[VERIFY] DONE : RM-944_ROM_eMP_22.00.11
[VERIFY] DONE : RM-944_LANG_PACK_ROM_IC_eMP_22.00.11
[VERIFY] DONE : RM-944_CUSTPACK_ROM_IC_MEA_DZ_eMP_22.00.11
[VERIFY] DONE : RM-944_JUMP_TABLE_IC_MEA_DZ_eMP_22.00.11
[VERIFY] DONE : RM-944_VIVA_eMP_22.00.11
CODE_VERIFY : Ok
Rebooting phone now
Flashing done!
Total flash time : 00:00:59
Reboot phone Ok
 - > Hint : If phone shows Battery charge icon -  press and hold PowerOn button 10 seconds
Software Info:     22.00.11 00-00-00 RM-944
Ape Version: NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul  1 02:50:44 2013 U 69b804d5
PPM version :   IC
Checking...
Read Info Done!
Phone found!
Read info... Ok
Phone disconected!
Old 07-29-2017, 09:38   #187 (permalink)
Member: 654997
Thanks Meter: 4,027
Nokia 110 Read User Code Done :)
Backup Certificates now...
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
EBL Loader : Custom
EBL Loader Ok, 01
Sending EBL ...
EBL : Custom
EBL sent Ok
Boot done!
Read CRT block...
Read EEPROM block...
SL3 Simlock found (XGOLD) ...
WMDRM Key found ...
CMLA Key found ...
 ===== USER CODE =====
Executing Code extraction...
 - > Phone Lock Code : 55555
 ===== MMC PASSWORD =====
We have next Pass: agmdm
We have next Pass: ddddd
SimLock Data saved...
SimLock Key saved...
WMDRM_PD Data saved...
CMLA_KEY Data saved...
RPL saved : F:\1+Flashing Software\1+Infinity Box\BEST\Backup\Cert\354631055469625_XG213.rpl
Old 07-29-2017, 15:44   #188 (permalink)
Member: 654997
Thanks Meter: 4,027
Nokia 107 Factory Reset Done :)
Phone found!
read info...  - Ok
Phone found!
read info...  - Ok
SW ver  : V 02.60 01-08-13 RM-961 (c) Nokia
IMEI    :      352359061428763
PPM     :      V 02.60
01-08-13
RM-961
(c) Nokia
IJ
PCode   :      059T243
BPCode  :      059S7H7
HWID    :      1000
LCDVer  :      WIN:BOHAIv93
NT39121
Sl Aux   : 000B0000
Hw Sig   : FB90A31E630CE343
Lock info:
Block 1
Block 2
Block 3
Block 4
Block 5
Block 6
Block 7
Done!
Resetting selected items...
Check phone mode...
Phone in Local mode
Seting Test mode... wait...
Test mode set
Settings Full Factory Defaults...
Set OK!
Settings Software Upgrade Defaults...
Set OK!
Settings Service Centre Defaults...
Set OK!
Settings Production Tune Defaults...
Set OK!
Settings User Data Defaults...
Set OK!
Settings Leave Factory defaults...
Set OK!
Elapsed: 00:00:11
Old 07-29-2017, 15:56   #189 (permalink)
SkyMobile05's Avatar
Member: 508860
Sonork: 1613186
Thanks Meter: 221
Please add ufst comme interface
Envoyé de mon TA-1032 en utilisant Tapatalk
The Following 2 Users Say Thank You to SkyMobile05 For This Useful Post:
Old 07-30-2017, 14:51   #190 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Nokia 301 Dual SIM
MCU : rm839__09.04.mcusw
PPM : rm839__09.04.ppm_m2
CNT : rm839__09.04.image_m2_059Q9B5
Check files done...
->  Check SW version...
FlashFile version : 09.04
Phone version : 02.33 17-05-13 RM-839 (c) Nokia
->  Check SW version : Upgrade
Backup CRT308 data...
CRT308 Backup Created
Check communication with phone....
ADL req restart
Communication verify done... Preparing...
SL3 Simlock read (XGOLD) ... Ok
WMDRM Key read ... Ok
CMLA Key read ... Ok
Reboot....
-> If Phone start charge - just reinsert battery fast
IF Boot Init : 0xF0
IF Resp Len  : 0x16
IF uCHIPID    :  50A9070100030101E030241220084450593AE8B5FFFF
EBL Loader Ok
EBL Loader ready
Sending EBL ...
EBL sent Ok
QUARK EEP config Ok
Boot done!
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 352356062414008
IMEI 2 : 352356062414016
Phone Product Code : 059Q9B5
RPL saved : C:\InfinityBox\BEST\Backup\Cert\352356062414008_XG618.rpl
Processing file : rm839__09.04.mcusw
Region count : 8
03 : [ Code ]  : rm839__09.04.mcusw_signed_mcusw.fls
Sending Sec-Pack
Erase now...
Erase done
Region Load done
Write done
Sending Sec-Pack
Erase now...
Erase done
Region Load done
Write done
Sending Sec-Pack
Erase now...
Erase done
Region Load done
Write done
Flash : 03 : rm839__09.04.mcusw_signed_mcusw.fls
Sending Sec-Pack
Erase now...
Erase done
Erase now...
Erase done
Region Start : 0x62E00000 , Data Len : 0x00F0D4CC
Region Load done
Write done
rm839__09.04.mcusw_signed_mcusw.fls image flash done
Sending Sec-Pack
Erase now...
Erase done
Region Start : 0x80000000 , Data Len : 0x00C2BCD0
Region Load done
Write done
Sending Sec-Pack
Erase now...
Erase done
Region Load done
Write done
Sending Sec-Pack
Erase now...
Erase done
Region Load done
Write done
Sending Sec-Pack
Erase now...
Erase done
Region Start : 0x61F00004 , Data Len : 0x00149890
Region Load done
Write done
Processing file : rm839__09.04.ppm_m2
Region count : 1
Sending Sec-Pack
Erase now...
Erase done
Region Start : 0x80F00000 , Data Len : 0x0052A288
Region Load done
Write done
Processing file : rm839__09.04.image_m2_059Q9B5
Region count : 1
00 : [ Cust ]  : package_m2_059Q9B5.image.fls
Flash : 00 : package_m2_059Q9B5.image.fls
Sending Sec-Pack
Erase now...
Erase done
Erase now...
Erase done
Region Start : 0xA1000000 , Data Len : 0x01C35200
Region Load done
Write done
package_m2_059Q9B5.image.fls image flash done
Flashing done!
Total flash time : 00:00:14
Reboot phone now...
Connected phone -   Nokia 301 Dual SIM
Software Info:     V 09.04 03-12-13 RM-839 (c) Nokia
IMEI:  352356062414008
PPM version :   V 09.04 03-12-13 RM-839 (c) Nokia             M2
Product code:  059Q9B5
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 58 certs
Done!
Elapsed: 00:00:49
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 07-31-2017, 06:52   #191 (permalink)
Member: 1740980
Sonork: st72
Thanks Meter: 13
ErroInfo : Unknown response received from SRV
plese help any body to slove nevifirm download error
thanks.
Old 07-31-2017, 07:49   #192 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Nokia 200
MCU : rm761__11.95.mcusw
PPM : rm761__11.95.ppm_ma3
CNT : rm761__11.95.image_ma3_059J4L0
Check files done...
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
EBL Loader Ok, 01
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.46_M1S1
FLASHID : 89008289
Boot done!
Check keys...
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 352414057142801
IMEI 2 : 352414057142819
PCcode : 059J4L0
RPL saved : C:\InfinityBox\BEST\Backup\Cert\352414057142801_XG213_CRT.rpl
File : rm761__11.95.mcusw
Image : rm761__11.95.mcusw_ebl_psi.fls
Sec-pack sent
Found 5 region(s)
Erasing, wait ...
Erase done, time : 00:00:01
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:00:07
Flashing , wait ...
Erase , Start : 0x40280000 , Len : 0x01800000
Erasing, wait ...
Erase done, time : 00:02:56
Write , Start : 0x40280000 , Len : 0x01800000
Flashing , wait ...
Region flash done, time : 00:00:44
Erasing, wait ...
No write data, skip
CRC check passed , 0x495E
File : rm761__11.95.ppm_ma3
Image : package_ma3.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Erase , Start : 0x41A80000 , Len : 0x00740000
Erasing, wait ...
Erase done, time : 00:00:27
Write , Start : 0x41A80000 , Len : 0x0051BF5C
Flashing , wait ...
CRC check passed , 0xE957
File : rm761__11.95.image_ma3_059J4L0
Image : package_ma3_059J4L0.image.fls
Sec-pack sent
Found 2 region(s)
Erase , Start : 0x421C0000 , Len : 0x01C60000
Erasing, wait ...
Erase done, time : 00:02:49
Write , Start : 0x421C0000 , Len : 0x00FA0000
Flashing , wait ...
Region flash done, time : 00:00:20
Erasing, wait ...
No write data, skip
CRC check passed , 0x9814
Flashing done!
Total flash time : 00:07:43
Old 07-31-2017, 09:59   #193 (permalink)
Member: 654997
Thanks Meter: 4,027
Nokia 220 Write Full firmware Done :)
Verify files ...
MAUI : RM-969_ROM_eMP_31.01.11
VIVA : RM-969_VIVA_eMP_31.01.11
LANG : RM-969_LANG_PACK_ROM_IC_eMP_31.01.11_001
CUST : RM-969_CUSTPACK_ROM_IC_MEA_JO_eMP_31.01.11_001
JMPT : RM-969_JUMP_TABLE_IC_MEA_JO_eMP_31.01.11_001
Wait for phone...
Phone found! [ 215 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : 94A920ECCF5559084252AC9126CD9617
BROM Status : 1012
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
Project ID : Rivendell.10.03.11.p1
BROM/BL stage done
DA_eMP_Rivendell.fg
DA_VERIFY : 00
DA_JUMP   : 00040000
DA_AUTH   : Passed!
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000
SecureDecrypt : RM-969_ROM_eMP_31.01.11
SecureDecrypt : RM-969_VIVA_eMP_31.01.11
SecureDecrypt : RM-969_LANG_PACK_ROM_IC_eMP_31.01.11_001
SecureDecrypt : RM-969_CUSTPACK_ROM_IC_MEA_JO_eMP_31.01.11_001
SecureDecrypt : RM-969_JUMP_TABLE_IC_MEA_JO_eMP_31.01.11_001
PHPID : Rivendell.10.03.11.p1
DA : FORMAT_BIN
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
Write : RM-969_ROM_eMP_31.01.11
Write : RM-969_LANG_PACK_ROM_IC_eMP_31.01.11_001
Write : RM-969_CUSTPACK_ROM_IC_MEA_JO_eMP_31.01.11_001
Write : RM-969_JUMP_TABLE_IC_MEA_JO_eMP_31.01.11_001
Write : RM-969_VIVA_eMP_31.01.11
CODE_DNLOAD : Ok
[VERIFY] DONE : RM-969_ROM_eMP_31.01.11
[VERIFY] DONE : RM-969_LANG_PACK_ROM_IC_eMP_31.01.11_001
[VERIFY] DONE : RM-969_CUSTPACK_ROM_IC_MEA_JO_eMP_31.01.11_001
[VERIFY] DONE : RM-969_JUMP_TABLE_IC_MEA_JO_eMP_31.01.11_001
[VERIFY] DONE : RM-969_VIVA_eMP_31.01.11
CODE_VERIFY : Ok
Will Upload FAT Image now
Write : RM-969_FATIMAGE_IC_31.01.11
FAT Image Flash done!
FAT Verify Ok
Rebooting phone now
Flashing done!
Total flash time : 00:04:21
Reboot phone Ok
Software Info:     31.01.11 00-00-00 RM-969
IMEI:  353050068787462
PPM version :   IC
Product code:  059V2H4
Checking...
Read Info Done!
Phone found!
Read info... Ok
Phone disconected!
Old 07-31-2017, 10:39   #194 (permalink)
Member: 654997
Thanks Meter: 4,027
Nokia 130 Reset User Code Done :)
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : 65465C1E4F08C50A8C1C3BF17C6EBA1D
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
MT626x : Reset User Code
All done! Remove USB cable
All Security Settings deactivated!
Code set to default : 12345
Done!
Old 08-01-2017, 07:20   #195 (permalink)
Member: 654997
Thanks Meter: 4,027
Nokia 215 Reset User Code DOne :)
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : E7891D463684BCAF7F3EE9C15EE72195
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
Done!
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.35033 seconds with 8 queries
