Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 08-01-2017, 07:20   #196 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,072
Nokia 215 Reset User Code DOne :)
Connect phone on selected interface...
Dead Mode is Selected
Waiting for USB device...
1. Phone should be Off!
2. Battery must be charged and inserted! ( if not used external power )
 - > If phone can't switch to BL - use battery or flash from Local mode!
--- Insert USB cable now! ---
Wait for phone...
Phone found! [ 215 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0001
BB_CPU_SN : E7891D463684BCAF7F3EE9C15EE72195
BROM Protocol Version : 05
BROM Status : 0000
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
MT626x : Reset User Code
All done! Remove USB cable
All Security Settings deactivated!
Code set to default : 12345
Done!
The Following User Says Thank You to syed tuqeer For This Useful Post:
Old 08-02-2017, 09:47   #197 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,437
Smile Nokia C1-01
Core : v2.29 , BB5XG FlashEngine : v10.5
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm607__04.40.mcusw
PPM : rm607__04.40.ppm_m_c
CNT : rm607__04.40.image_m_c_0595609
Flashing phone now...
[Gen] Rules accepted for : XGOLD Generation
Check files done...
-> SWversion check skipped : Dead mode selected
-> If Windows say "Unrecognized device" / Operation not start
-> Or if Phone start charge - just reinsert battery
-> If flashing freeze - reinsert cable/battery and try again
--- Press phone's power button or insert usb cable! ---
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
IF xCPUID    : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data  :  1FB300020303010100FF
Sending EBL Loader ...
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_2.3_M1S1
Speed accepted, use 6.500.000
FLASHID : EC001230
FLIC conf set, RST set
Boot done!
Check keys...
Check done. Image can be flashed
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI : 352842054380216
PCcode : 0596380
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\352842054380216_XG213_CRT.rpl
Settings : EDM [0x8] , Block Mode , Fast CRC , Verify
   ===Flashing [MCU]===
File : rm607__04.40.mcusw
Image : rm607__04.40.mcusw_ebl_psi.fls
Sec-pack found, sending ...
Sec-pack sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00040000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00040000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40080000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40080000 , Len : 0x00020000
Flashing , wait ...
Processing Region 4/5
Erase , Start : 0x400A0000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:02
Write , Start : 0x400A0000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 5/5
Erase , Start : 0x40400000 , Len : 0x01800000
Erasing, wait ...
Erase done, time : 00:00:47
Write , Start : 0x40400000 , Len : 0x01780000
Flashing , wait ...
Region flash done, time : 00:00:34
CRC check passed , 0xD471
   ===Flashing [PPM]===
File : rm607__04.40.ppm_m_c
Image : package_m_c.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41C00000 , Len : 0x00600000
Erasing, wait ...
Erase done, time : 00:00:06
Write , Start : 0x41C00000 , Len : 0x0031A50C
Flashing , wait ...
Region flash done, time : 00:00:03
CRC check passed , 0x4A12
   ===Flashing [CNT]===
File : rm607__04.40.image_m_c_0595609
Image : package_m_c_0595609.image.fls
Sec-pack sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x42200000 , Len : 0x01C60000
Erasing, wait ...
Erase done, time : 00:01:04
Write , Start : 0x42200000 , Len : 0x00B60000
Flashing , wait ...
Region flash done, time : 00:00:15
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
No write data, skip
CRC check passed , 0x17AA
Flashing done!
Total flash time : 00:03:00
Reboot phone now...
Reading Phone Info....
Connected phone -   C1-01
Software Info:     V 04.40 23-02-11 RM-607 (c) Nokia
IMEI:  352842054380216
PPM version :   V 04.40 23-02-11 RM-607 (c) Nokia             M_C
Product code:  0596380
Wait, when phone will be ready ...
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Check and Upload User Certificates ...
Total - 39 certs
Certificates found, skip upload ...
Battery voltage is enough for start
AfterFlash operations done ;D
Done!
Elapsed: 00:03:44
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post:
Old 08-03-2017, 08:25   #198 (permalink)
Member: 654997
Thanks Meter: 4,072
Nokia 1650 factory reset done :)
UFS S/N 103896 boot - Ok
Phone found!
Series 40 Device detected! [DCT4+]
read info...  - Ok
Resetting selected items...
Check phone mode...
Phone in Normal mode
Seting Test mode... wait...
Test mode set
Settings Full Factory Defaults...
Error When resetting Full factory :( ...
Settings Software Upgrade Defaults...
Set OK!
Settings Service Centre Defaults...
Set OK!
Settings Production Tune Defaults...
Set OK!
Settings User Data Defaults...
Set OK!
Settings Leave Factory defaults...
Set OK!
Elapsed: 00:00:12
Check phone mode...
Phone already in Test mode, skip change...
Set OK!
Set OK!
Set OK!
Set OK!
Set OK!
Set OK!
Elapsed: 00:00:04
SW ver  :
IMEI    :      V 5.32
18-05-08
RM-305
(c) NMP
PPM     :      P06w45.v50
CNT     :      V 5.32
18-05-08
RM-305
(c) NMP
IJ
DSP Ver :      47576 8
PCode   :      355744021570126
BPCode  :
HWID    :      0203271
LCDVer  :      2501
IMEI    :      V 5.32
18-05-08
RM-305
(c) NMP
Sl Conf  : 475-54-94E7638360A
Sl Prof  : 533642333344310-0
Sl Aux   : 00000000
Hw Sig   :
Country      : Unknown
Operator     : Unknown
Lock info:
Done!
old is gold
Old 08-03-2017, 10:32   #199 (permalink)
Member: 654997
Thanks Meter: 4,072
Nokia 112 Write Full Flash Done :)
MCU : rm837__03.51.mcusw
PPM : rm837__03.51.ppm_m2
CNT : rm837__03.51.image_m2_059P790
Check files done...
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
EBL Loader Ok, 01
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.50_M1S1
FLASHID : EC001230
Boot done!
Check keys...
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 359984055189882
IMEI 2 : 359984055189890
PCcode : 059P790
RPL saved : F:\1+Flashing Software\1+Infinity Box\BEST\Backup\Cert\359984055189882_XG213_CRT.rpl
File : rm837__03.51.mcusw
Image : rm837__03.51.mcusw_ebl_psi.fls
Sec-pack sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Erase , Start : 0x40280000 , Len : 0x01940000
Erasing, wait ...
Erase done, time : 00:00:52
Write , Start : 0x40280000 , Len : 0x018C0000
Flashing , wait ...
Region flash done, time : 00:00:38
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
CRC check passed , 0x87F4
File : rm837__03.51.ppm_m2
Image : package_m2.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Erase , Start : 0x41BC0000 , Len : 0x00600000
Erasing, wait ...
Erase done, time : 00:00:07
Write , Start : 0x41BC0000 , Len : 0x0030F7C0
Flashing , wait ...
CRC check passed , 0x46E6
File : rm837__03.51.image_m2_059P790
Image : package_m2_059P790.image.fls
Sec-pack sent
Found 2 region(s)
Erase , Start : 0x421C0000 , Len : 0x01C60000
Erasing, wait ...
Erase done, time : 00:01:25
Write , Start : 0x421C0000 , Len : 0x00EE0000
Flashing , wait ...
Region flash done, time : 00:00:21
Erasing, wait ...
No write data, skip
CRC check passed , 0x9EEB
Flashing done!
Total flash time : 00:03:36
Reboot phone now...
Connected phone -   Nokia 112
Software Info:     V 03.51 06-08-13 RM-837 (c) Nokia
IMEI:  359984055189882
PPM version :   V 03.51 06-08-13 RM-837 (c) Nokia             M2
Product code:  059P790
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 58 certs
Done!
Elapsed: 00:05:34
Phone found!
read info...  - Ok
Old 08-05-2017, 17:08   #200 (permalink)
Member: 1677653
Thanks Meter: 2,775
NOKIA ASHA 210 RM-824 FLASH DONE
Card found: S/N : A6936825 , v0136
Registered to: Yuslam Unique
Selected FlashSettings : FullFlash
MCU : 1FBBABE4_rm924__06.09.mcusw
PPM : F8DA1D82_rm924__06.09.ppm_mel
CNT : 6A12511D_rm924__06.09.image_mel_059R786
Check files done...
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
EBL Loader Ok, 01
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.56_M1S1
FLASHID : EC001230
Boot done!
Check keys...
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 357897054392780
IMEI 2 : 357897054392798
PCcode : 059R9P6
RPL saved : C:\InfinityBox\BEST\Backup\Cert\357897054392780_2nd_XG213_CRT.rpl
File : 1FBBABE4_rm924__06.09.mcusw
Image : rm924__06.09.mcusw_ebl_psi.fls
Sec-pack sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erase , Start : 0x40280000 , Len : 0x01A40000
Erasing, wait ...
Erase done, time : 00:00:54
Write , Start : 0x40280000 , Len : 0x01A40000
Flashing , wait ...
Region flash done, time : 00:00:37
Erasing, wait ...
No write data, skip
[Minor Error] : CRC returned by phone is wrong!
[CHK] : 0100E361
File : F8DA1D82_rm924__06.09.ppm_mel
Image : package_mel.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Erase , Start : 0x41CC0000 , Len : 0x00640000
Erasing, wait ...
Write , Start : 0x41CC0000 , Len : 0x00394B10
Flashing , wait ...
Region flash done, time : 00:00:04
CRC check passed , 0xCA7D
File : 6A12511D_rm924__06.09.image_mel_059R786
Image : package_mel_059R786.image.fls
Sec-pack sent
Found 2 region(s)
Erase , Start : 0x42300000 , Len : 0x01B20000
Erasing, wait ...
Erase done, time : 00:01:15
Write , Start : 0x42300000 , Len : 0x00C60000
Flashing , wait ...
Region flash done, time : 00:00:17
Erasing, wait ...
No write data, skip
CRC check passed , 0x35BE
Flashing done!
Total flash time : 00:03:25
Reboot phone now...
Connected phone -   Nokia 210
Software Info:     V 06.09 14-10-13 RM-924 (c) Nokia
IMEI:  357897054392780
PPM version :   V 06.09 14-10-13 RM-924 (c) Nokia             MEL
Product code:  059R9P6
Checking...
Read Info Done!
SwUpgradeSet...OK!
Resetting LifeTimer
Reset Done!
Set phone to Normal mode...
Done!
Elapsed: 00:04:22
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 08-06-2017, 11:00   #201 (permalink)
Member: 654997
Thanks Meter: 4,072
Nokia 225 write firmware Done :)
Core : v2.29 , MTKx FlashEngine : v14.0
Verify files ...
MAUI : RM-1011_ROM_eMP_30.06.11
VIVA : RM-1011_VIVA_eMP_30.06.11
LANG : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001
CUST : RM-1011_CUSTPACK_ROM_IJ_MEA_IR_eMP_30.06.11_001
JMPT : RM-1011_JUMP_TABLE_IJ_MEA_IR_eMP_30.06.11_001
 - > MODE : FullFlash
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : 9EDB7110C9822A525FA5C0587DA7ECA9
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x8000
Project ID : PEARL.20.10.11.p1
BROM/BL stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_eMP_Pearl.fg
DA_VERIFY : 00
DA_JUMP   : 00040000
DA_AUTH   : Passed!
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8B
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW
[0] : FLASH_DIE : 00EF 0060 0018 0000
[0] : FLASH_LEN : 0x01000000
FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000
SecureDecrypt : RM-1011_ROM_eMP_30.06.11
SecureDecrypt : RM-1011_VIVA_eMP_30.06.11
SecureDecrypt : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001
SecureDecrypt : RM-1011_CUSTPACK_ROM_IJ_MEA_IR_eMP_30.06.11_001
SecureDecrypt : RM-1011_JUMP_TABLE_IJ_MEA_IR_eMP_30.06.11_001
OVRLP : 000069B900000001
PHPID : PEARL.20.10.11.p1
OVRLP : 00004DF900000001
DA : FORMAT_BIN
Processing Flash Pre-format
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
WRITE_STYLE : DEF : 0x01 (SEQ)
Write : RM-1011_ROM_eMP_30.06.11
Write : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001
Write : RM-1011_CUSTPACK_ROM_IJ_MEA_IR_eMP_30.06.11_001
Write : RM-1011_JUMP_TABLE_IJ_MEA_IR_eMP_30.06.11_001
Write : RM-1011_VIVA_eMP_30.06.11
CODE_DNLOAD : Ok
[VERIFY] DONE : RM-1011_ROM_eMP_30.06.11
[VERIFY] DONE : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001
[VERIFY] DONE : RM-1011_CUSTPACK_ROM_IJ_MEA_IR_eMP_30.06.11_001
[VERIFY] DONE : RM-1011_JUMP_TABLE_IJ_MEA_IR_eMP_30.06.11_001
[VERIFY] DONE : RM-1011_VIVA_eMP_30.06.11
CODE_VERIFY : Ok
Executing FFS FORMAT now...
DA_RET   : DA_IN_PROGRESS
DA_RET   : FORMAT_DONE
Rebooting phone now
Flashing done!
Total flash time : 00:03:20
Reboot phone Ok
 - > Hint : If phone shows Battery charge icon -  press and hold PowerOn button 10 seconds
Software Info:     30.06.11 00-00-00 RM-1011
IMEI:  351854074621009
Ape Version: NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul  1 02:50:44 2013 U 69b804d5
PPM version :   IJ
Product code:  059V5V2
Checking...
Read Info Done!
Phone found!
MTKx Nokia Phone detected
Read info... Ok
Phone disconected!
Old 08-07-2017, 07:59   #202 (permalink)
Member: 654997
Thanks Meter: 4,072
Nokia 215 write full factory firmware Done :)
Verify files ...
MAUI : RM-1110_ROM_eMP_12.03.11
VIVA : RM-1110_VIVA_eMP_12.03.11
LANG : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001
CUST : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001
JMPT : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : 4A6A9A5727D1AB2559A84BBF02AC5A26
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
Project ID : JET.12.03.11.p1
BROM/BL stage done
DA_eMP_Jet.fg
DA_VERIFY : 00
DA_JUMP   : 00040000
DA_AUTH   : Passed!
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G
[0] : FLASH_DIE : 00C2 0025 0038 0000
FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000
SecureDecrypt : RM-1110_ROM_eMP_12.03.11
SecureDecrypt : RM-1110_VIVA_eMP_12.03.11
SecureDecrypt : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001
SecureDecrypt : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001
SecureDecrypt : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001
PHPID : JET.12.03.11.p1
DA : FORMAT_BIN
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
Write : RM-1110_ROM_eMP_12.03.11
Write : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001
Write : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001
Write : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001
Write : RM-1110_VIVA_eMP_12.03.11
CODE_DNLOAD : Ok
[VERIFY] DONE : RM-1110_ROM_eMP_12.03.11
[VERIFY] DONE : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001
[VERIFY] DONE : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001
[VERIFY] DONE : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001
[VERIFY] DONE : RM-1110_VIVA_eMP_12.03.11
CODE_VERIFY : Ok
Rebooting phone now
Flashing done!
Total flash time : 00:02:41
Reboot phone Ok
Software Info:     12.03.11 00-00-00 RM-1110
IMEI:  358596065600020
PPM version :   IJ
Product code:  059W6H5
Checking...
Read Info Done!
Phone found!
Read info... Ok
Phone disconected!
Old 08-07-2017, 09:33   #203 (permalink)
Member: 654997
Thanks Meter: 4,072
Nokia 108 Format / Repair Done :)
Phone found!
Read info... Ok
Software Info:     20.06.11 00-00-00 RM-944
IMEI:  359973056929206
PPM version :   IJ
Product code:  059S7R0
Rebooting phone to FlashMode...
Wait for phone...
Phone found! [ 174 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0001
BB_CPU_SN : F6384834E871E3E1D23A8BA511FEA43B
BROM Status : 1012
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
Project ID : Bree.20.06.11.p4
BROM/BL stage done
DA_eMP_Bree.fg
DA_VERIFY : 00
DA_JUMP   : 00040000
DA_AUTH   : Passed!
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x88
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV
[0] : FLASH_DIE : 00EF 0040 0016 0000
[0] : FLASH_LEN : 0x00400000
FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000
Elapsed: 00:00:26
Phone found!
Read info... Ok
Software ver : 20.06.11 00-00-00 RM-944
IMEI 1  :      359973056929206
IMEI 2  :      359973056929214
XappVer :      000008F2
Ape Ver :      NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul  1 02:50:44 2013 U 69b804d5
PPM     :      IJ
CNT     :      Bree.20.06.11.p4
Product SN   :     6BF04BEBH
Product code :     059S7R0
Base Prd.code:     059S0R7
Module code  :     0205624
Hardware info=======
HWID  : 1003
LCDVer: TPO
Lock info ===========
IMEI       : 359973056929206
IMEI spNet : 3A 95 79 03 65 29 29 60
Conf key     : 800000000004000B
Provider key : 0010100000000000
Country      : Test SIM (Open)
Operator     : NOKIA (Open)
Lock info:
Block 1
L1:Open;  L2:Open;  L3:Open;  L4:Open;  L5:Open;
Block 2
Block 3
Block 4
Block 5
Block 6
Block 7
SimLock status : Ok
Security status : Ok
Done!
Phone disconected!
Old 08-09-2017, 08:33   #204 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Nokia 301 Dual SIM
MCU : rm839__09.04.mcusw
PPM : rm839__09.04.ppm_m2
CNT : rm839__09.04.image_m2_059Q9B5
Check files done...
IF Boot Init : 0xF0
IF Resp Len  : 0x16
IF xCPUID    : XGOLD 618 [XMM6180 QUARK]
IF uCHIPID    :  50A9070100030101E0301812000408A1583498B4FFFF
IF Resp Data  :  50A9070100030101
Wait for user action : Insert battery
EBL Loader Ok
EBL Loader ready
Sending EBL ...
EBL sent Ok
EBL : QUARK_1337.500_M1S1
QUARK EEP config Ok
FLASHID : EC004000 , [ MuxOneNAND ]
Boot conf set, Target Ready
Boot done!
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 359212057750505
IMEI 2 : 359212057750513
Phone Product Code : 059Q9B9
RPL saved : C:\InfinityBox\BEST\Backup\Cert\359212057750505_XG618_CRT.rpl
Processing file : rm839__09.04.mcusw
Region count : 8
00 : [ PSI ]   : psi_flash_unsigned.fls
01 : [ BCore ] : slb_signed.fls
02 : [ Code ]  : main_toc_signed.fls
03 : [ Code ]  : rm839__09.04.mcusw_signed_mcusw.fls
04 : [ Code ]  : swap_signed.fls
05 : [ Cust ]  : dynsw.fls
06 : [ Code ]  : aeneas_signed.fls
07 : [ Code ]  : fota_signed.fls
Parse done , flashing now
Flash : 00 : psi_flash_unsigned.fls
Sending Sec-Pack
SecInfo Area : 0x0000 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x00090000 , Len : 0x00020000
Erase now...
Erase done
Region Start : 0x00090000 , Data Len : 0x00010FB0
Region Load done
Write done
psi_flash_unsigned.fls image flash done
Flash : 01 : slb_signed.fls
Sending Sec-Pack
SecInfo Area : 0x0001 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x60000000 , Len : 0x00040000
Erase now...
Erase done
Region Start : 0x60000000 , Data Len : 0x00040000
Region Load done
Write done
slb_signed.fls image flash done
Flash : 02 : main_toc_signed.fls
Sending Sec-Pack
SecInfo Area : 0x0002 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x60040000 , Len : 0x00000400
Erase now...
Erase done
Region Start : 0x60040000 , Data Len : 0x00000400
Region Load done
Write done
main_toc_signed.fls image flash done
Flash : 03 : rm839__09.04.mcusw_signed_mcusw.fls
Sending Sec-Pack
SecInfo Area : 0x0003 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x62E00000 , Len : 0x01100000
Erase now...
Erase done
Erase area 0x01 , Start 0xFFF00000 , Len : 0x00080000
Erase now...
Erase done
Region Start : 0x62E00000 , Data Len : 0x00F0D4CC
Region Load done
Write done
rm839__09.04.mcusw_signed_mcusw.fls image flash done
Flash : 04 : swap_signed.fls
Sending Sec-Pack
SecInfo Area : 0x0004 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x80000000 , Len : 0x00F00000
Erase now...
Erase done
Region Start : 0x80000000 , Data Len : 0x00C2BCD0
Region Load done
Write done
swap_signed.fls image flash done
Flash : 05 : dynsw.fls
Sending Sec-Pack
SecInfo Area : 0x0005 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x62080000 , Len : 0x00100000
Erase now...
Erase done
Region Start : 0x62080000 , Data Len : 0x00044000
Region Load done
Write done
dynsw.fls image flash done
Flash : 06 : aeneas_signed.fls
Sending Sec-Pack
SecInfo Area : 0x0006 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x63F79C00 , Len : 0x00080000
Erase now...
Erase done
Region Start : 0x63F79C00 , Data Len : 0x00046870
Region Load done
Write done
aeneas_signed.fls image flash done
Flash : 07 : fota_signed.fls
Sending Sec-Pack
SecInfo Area : 0x0007 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x61F00004 , Len : 0x0017FFFC
Erase now...
Erase done
Region Start : 0x61F00004 , Data Len : 0x00149890
Region Load done
Write done
fota_signed.fls image flash done
Processing file : rm839__09.04.ppm_m2
Region count : 1
00 : [ Cust ]  : package_m2.ppm_ebl_psi.fls
Flash : 00 : package_m2.ppm_ebl_psi.fls
Sending Sec-Pack
Erase area 0x00 , Start 0x80F00000 , Len : 0x00B00000
Erase now...
Erase done
Region Start : 0x80F00000 , Data Len : 0x0052A288
Region Load done
Write done
package_m2.ppm_ebl_psi.fls image flash done
Processing file : rm839__09.04.image_m2_059Q9B5
Region count : 1
00 : [ Cust ]  : package_m2_059Q9B5.image.fls
Flash : 00 : package_m2_059Q9B5.image.fls
Sending Sec-Pack
Erase area 0x00 , Start 0xA1000000 , Len : 0x0C580000
Erase now...
Erase done
Erase area 0x01 , Start 0xAE000000 , Len : 0x00300000
Erase now...
Erase done
Region Start : 0xA1000000 , Data Len : 0x01C35200
Region Load done
Write done
package_m2_059Q9B5.image.fls image flash done
Flashing done!
Total flash time : 00:00:14
Reboot phone now...
Connected phone -   Nokia 301 Dual SIM
Software Info:     V 09.04 03-12-13 RM-839 (c) Nokia
IMEI:  359212057750505
PPM version :   V 09.04 03-12-13 RM-839 (c) Nokia             M2
Product code:  059Q9B9
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 58 certs
Done!
Elapsed: 00:00:51
Phone found!
read info...  - Ok
Old 08-09-2017, 10:14   #205 (permalink)
Member: 654997
Thanks Meter: 4,072
Memory card format/unlock done :)
Phone found!
read info...  - Ok
Check phone mode...
Seting Local mode... wait...
Local mode set
Format ...
Format Done
All done
Old 08-10-2017, 08:51   #206 (permalink)
Member: 654997
Thanks Meter: 4,072
Nokia 6600 Slide write firmware done :)
MCU : rm414__06.55.mcusw
PPM : rm414__06.55.ppm_d
CNT : rm414__06.55_ISM_025.image_d_cz_black
[Gen] Rules accepted for : RAP3x Generation
Check files done...
Getting product info...
--- Press phone's power button or insert cable & charger! ---
Waiting for communication response.
ASIC ID:       000000010000022600010006030C192101023000
CPU ID :       RAP3Gv3 , Features : No any extended features
RAP_PUB:   1ED000016A607D56B34FAA469C8238D66D147941
CMT_ROOT:  9DDBFCFE6E73CED7D8C6268C8EB85723
PatchRAWLoader: Patched OK
Processing RAWLOADER...
Processing UPDAPP...
Processing PASUBTOC...
TIME : Boot time : 00:00:06
Reopening the connection...
Waiting for response: 30
Waiting for response: 29
Waiting for response: 28
Waiting for response: 27
ADL -> [2nd] changing...
ADL Server confirm flashmode!
ADL : Check data
ADL : Data accepted
Erase : Processing rm414__06.55.mcusw
Found 5 areas to erase
Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT
Result: 0000
Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT
Result: 0000
Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT
Result: 0000
Erasing area 0x01780000 - 0x0197FFFF, NOR, CMT
Result: 0000
Erasing area 0x00140000 - 0x0177FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:01:05
Write : Processing rm414__06.55.mcusw
Total 116 [116/0/0] blocks to write, writing...
CMT : Writing Hash CERT [NOLO]
CMT : Writing Hash CERT [KEYS]
CMT : Writing Hash CERT [PRIMAPP]
CMT : Writing Hash CERT [PASUBTOC]
CMT : Writing Hash CERT [PAPUBKEYS]
CMT : Writing Hash CERT [UPDAPP]
CMT : Writing Hash CERT [DSP0]
CMT : Writing Hash CERT [MCUSW]
TIME : Write time : 00:02:23
MCU Write done
Erase : Processing rm414__06.55.ppm_d
Found 1 areas to erase
Erasing area 0x01980000 - 0x021BFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:00:48
Write : Processing rm414__06.55.ppm_d
Total 30 [30/0/0] blocks to write, writing...
TIME : Write time : 00:00:49
PPM Write done
Erase : Processing rm414__06.55_ISM_025.image_d_cz_black
Found 2 areas to erase
Erasing area 0x02620000 - 0x03F9FFFF, NOR, CMT
Result: 0000
Erasing area 0x021C0000 - 0x0261FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:03:29
Checking content info...
Check Image : Content size is 128k, use direct write mode
Write : Processing rm414__06.55_ISM_025.image_d_cz_black
Total 38 [38/0/0] blocks to write, writing...
TIME : Write time : 00:01:00
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:09:37
Reboot phone now...
Connected phone -   Nokia 6600 slide
Software Info:     V 06.55 26-10-09 RM-414 (c) Nokia
IMEI:  351954032294434
PPM version :   V 06.55 26-10-09 RM-414 (c) Nokia             D
Product code:  0572228
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 0 certs
Uploading User Certificates...
Uploaded 26 certs!
Done!
Elapsed: 00:10:41
Old 08-10-2017, 12:20   #207 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Nokia 308
SSChannel : Create SC
SSChannel : SC Created!
ProductID HWCode : RM-838
Selected Variant : RM-838 MEA_MAA_BLACK_NULL_PK
Firmware Version : 08.13
Platform Version : Series 40
SSChannel : DC Ok with code 0x04
Switch to IDM now ...
IDM initializing, wait...
Checking access to Products folder...
Folder for RM-838 not exist. Attempt to create
Prepare done, collect info
[Query] : rm838__08.13.image_maa_059N7V9 , 51.88 MiB
[Query] : rm838__08.13.mcusw , 28.10 MiB
[Query] : rm838__08.13.ppm_maa , 6.27 MiB
[Query] : RM838_059N7V9_08.13_032.vpl , 3.61 KiB
Total size to download : 86.26 MiB
Downloading now, please, wait...
[Download] : rm838__08.13.image_maa_059N7V9
[Download] : rm838__08.13.mcusw
[Download] : rm838__08.13.ppm_maa
[Download] : RM838_059N7V9_08.13_032.vpl
Verify files now ...
[Verify Ok] : rm838__08.13.mcusw
[Verify Ok] : rm838__08.13.ppm_maa
[Verify Ok] : rm838__08.13.image_maa_059N7V9
All done, all files were downloaded!
File [Ok] : rm838__08.13.mcusw
File [Ok] : rm838__08.13.ppm_maa
File [Ok] : rm838__08.13.image_maa_059N7V9
If PC not detect phone - Insert Cable first, then Insert battery
If stuck on boot  - remove MicroSD card from phone!
1st Boot Done, processing booting now
ASIC ID_F     : 00000C201610004049B22409A2C18D6418F1D100
ASIC ID_E     : 00000C2016100040
PUBLIC ID     : 76FEAAB1983D2DE949B22409A2C18D6418F1D100
XGCHIP ID     : 76FEAAB1983D2DE9
ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579
ROM ID        : 535882252F54C676
Prepare and send 2nd loader...
2nd boot Ok
Prepare and send Algo loader...
Algo boot Ok
RPL saved : C:\InfinityBox\BEST\Backup\Cert\_XG223_SIM.rpl
PAPUBkeys : blank (Erased or HW failure)
 === SW Version Check ===
- > Can not collect initial info, continue flashing...
- > Hope, this version will be ok
  === Flashing MCU ===
Processing file : rm838__08.13.mcusw
Erasing...
Writing...
Total blocks : 90
Writing RKH CRT [ISSW]
Writing RKH CRT [MEMSET]
Writing RKH CRT [PRIMAPP]
Writing RKH CRT [LOADER]
Writing RKH CRT [PASUBTOC]
Writing RKH CRT [PAPUBKEYS] [PAKeys : FAF910DA218D8536CEFBDCE369A8C034160C6A5F]
Writing RKH CRT [UPDAPP]
Writing RKH CRT [MCUSW]
File processed Ok, 89 blocks were writen
  === Flashing PPM ===
Processing file : rm838__08.13.ppm_maa
Erasing...
Writing...
Total blocks : 13
File processed Ok, 13 blocks were writen
  === Flashing CNT ===
Processing file : rm838__08.13.image_maa_059N7V9
Erasing...
Writing...
Total blocks : 104
File processed Ok, 104 blocks were writen
Flashing done , total time : 00:00:37
Old 08-14-2017, 15:45   #208 (permalink)
Member: 654997
Thanks Meter: 4,072
Nokia 206 write CNT flash file Done :)
Phone found!
read info...  - Ok
Connected phone -    206
Software ver : V 04.52 30-06-13 RM-872 (c) Nokia
IMEI 1  :      356724052107922
IMEI 2  :      356724052107930
XappVer :      000008F2
PPM     :      V 04.52 30-06-13 RM-872 (c) Nokia             M2
CNT     :      Content: m2_059Q4J7 V 04.52 17-04-14 RM-872 (c) Nokia
Product SN   :     FECDD6FAH
Product code :     059Q4J7
Base Prd.code:     059P6H2
Module code  :     0205283
Long Prod.SN :     0
HWID  : 1600
Battery: 5007 mV
CMT BT: 19b5-22012
LCDVer: TPO
IMEI       : 356724052107922
IMEI spNet : 3A 65 27 04 25 01 97 02
IMEI svNet : 33 65 27 04 25 01 97 12 F1
Sl Conf  : 001-01-00000000000
Sl Prof  : 800000000004000-B
Sl Aux   : 000B0000
Hw Sig   : 40430A0ADCC6F4C8
Lock info:
Block 1
Block 2
Block 3
Block 4
Block 5
Block 6
Block 7
Error collect lock info, try again
CRT308 Backup Created
CMLA Key status : Ok
SimLock status : Ok
PA_SimLock Version :
PA_SL30 (20 digit) phone detected...
User Code : 12345
MMC pwd  : no any record found
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
CNT : rm872__04.52.image_m2_059V0F5
Check files done...
-> SWversion check skipped : Custom mode selected
Backup CRT308 data...
Check communication with phone....
ADL req restart
Communication verify done... Preparing...
SL3 Simlock read (XGOLD) ... Ok
WMDRM Key read ... Ok
CMLA Key read ... Ok
Reboot....
-> If Phone start charge - just reinsert battery fast
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
EBL Loader Ok, 01
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.53_M1S1
FLASHID : 89008289
Boot done!
Check keys...
Reading CCC
Reading HWC
Reading NPC
PCcode : 059Q4J7
SimLock Data saved...
SimLock Key saved...
WMDRM_PD Data saved...
CMLA_KEY Data saved...
RPL saved : F:\1+Flashing Software\1+Infinity Box\BEST\Backup\Cert\356724052107922_XG213.rpl
File : rm872__04.52.image_m2_059V0F5
Image : package_m2_059V0F5.image.fls
Sec-pack sent
Found 2 region(s)
Erase , Start : 0x42100000 , Len : 0x01D20000
Erasing, wait ...
Erase done, time : 00:03:37
Write , Start : 0x42100000 , Len : 0x01040000
Flashing , wait ...
Region flash done, time : 00:00:22
Erasing, wait ...
No write data, skip
CRC check passed , 0xA340
Flashing done!
Total flash time : 00:04:06
Reboot phone now...
Software Info:     V 04.52 30-06-13 RM-872 (c) Nokia
IMEI:  356724052107922
PPM version :   V 04.52 30-06-13 RM-872 (c) Nokia             M2
Product code:  059Q4J7
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 58 certs
Done!
Elapsed: 00:04:59
Phone found!
read info...  - Ok
Phone disconected!
Old 08-15-2017, 18:32   #209 (permalink)
Member: 1677653
Thanks Meter: 2,775
NOKIA X6 RM-551 FULL FACTORY DONE BY BEST
Phone found!
Series 60 Device detected!
read info...  - Ok
Connected phone -    Nokia X6-00
Software ver : V ICPR72_11w16.1 28-07-11 RM-551 (c) Nokia
IMEI    :      356945030695114
XappVer :      000008F2
Ape Ver :      V 40.2.002
APE Var :      V 40.2.002V 40.2.002 V 40.2.002
APE ADSP:      256
DSP Ver :      11w13
APE Test:      eno_version
PPM     :
CNT     :      v 001_000 09-12-10 vanilla RM551r  RM551_001_000_M027
Product SN   :     CVD896079
Product code :     0592811
Base Prd.code:     0575853
Long Prod.SN :     0
HWID  : 1152
Retu  : 16
Tahvo : 22
Battery: 3990 mV
APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.
APE HW: 256
IMEI spNet : 3A 65 49 05 03 96 15 01
IMEI svNet : 33 65 49 05 03 96 15 21 F3
Conf key     : 0000000000000000
Provider key : 2440700000000000
Country      : Finland
Counters     : Key 0  [3] , Fbus 0  [10]
Blocks       : 7
LOCK STATUS :
BLK : 1
 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS :  All Open
SDD key status : Ok
SimLock status : Ok
PA_SL3 phone ,  SP_CODE_LEN : 15
User code : Crypted
UserDataExLevel : Low [Gallery] , FullFlash method
Done!
FULL FACTORY RESET
Check phone mode...
Phone in RfInactive mode
Test mode set
Set OK!
Elapsed: 00:01:10
Old 08-16-2017, 11:04   #210 (permalink)
Member: 1677653
Thanks Meter: 2,775
NOKIA X2-01 RM-709 FLASH DONE BY INFINITY BEST
MCU : rm709__08.75.mcusw
PPM : rm709__08.75.ppm_ms
CNT : rm709__08.75.image_ms_059C3D9
[Gen] Rules accepted for : RAPUxx Generation
Check files done...
--- Insert cable and charger or press phone's power button! ---
Waiting for communication response...
[BootRom] : 1st boot Ok!
ASIC ID:       000000000000000022000509200C0000
CPU ID :       BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB
EM0 ID:        00005361
PUBLIC ID:     00000000007B05F7EB5A21A29EE077A97EA7A770
ASIC MODE ID:  00
ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
ROM ID:        DE56D582BDDE7A3A
Use BCM21351_usb2nd.fg  ,  Rev : 2.1  Ver : 12.8.0
FLIC : 00300020
Req : XSR 1.6
Use BCM21351_XSR16_usbalg.fg  ,  Rev : 2.1  Ver : 12.8.0
Processing PASUBTOC ...
Processing ALG ...
Boot Done! :)
TIME : Boot time : 00:00:01
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : 37955B6FC432998EF0DB240E332228384D19ED09
ADL: phone is in flash mode
Backup enabled, will read all certificates...
Reading NPC certificate...
IMEI : 357410049998321
Reading CCC certificate...
Reading HWC certificate...
Reading R&D certificate...
Reading VARIANT certificate...
Reading PARTNERC certificate...
Reading MDM_KEYS certificate...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\357410049998321_CRT.rpl
- > REFLASHING
Erase : Processing rm709__08.75.mcusw
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:00
Write : Processing rm709__08.75.mcusw
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [ADA]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [RAP3NAND]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [UPDAPP]
CMT: Writing Hash CERT [MCUSW]
CMT: Writing Hash CERT [MCUSW1]
CMT: Writing Hash CERT [GENIO_INIT]
CMT: Writing Hash CERT [ISA+DYNSW]
Total writen 504 blocks
TIME : Write time : 00:00:06
MCU Write done
ADL: Request programm status
NAND status : 00000000 / 00000000 / 00000000
Erase : Processing rm709__08.75.ppm_ms
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
Write : Processing rm709__08.75.ppm_ms
Total writen 112 blocks
TIME : Write time : 00:00:01
PPM Write done
Erase : Processing rm709__08.75.image_ms_059C3D9
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:01
Write : Processing rm709__08.75.image_ms_059C3D9
Total writen 531 blocks
CNT Write done
ADL: Close_Session
Content: 000300000000000000000000000000
ADL: Reboot
Flashing done!
Total flash time : 00:00:15
Reboot phone now...
Connected phone -   X2-01
Software Info:     V 08.75 11-01-12 RM-709 (c) Nokia
IMEI:  357410049998321
PPM version :   V 08.75 11-01-12 RM-709 (c) Nokia             MS
Product code:  059G326
Checking...
Read Info Done!
SwUpgradeSet...OK!
Resetting LifeTimer
Reset Done!
Done!
Elapsed: 00:01:54
Phone found!
read info...  - Ok
Phone disconected!
Page generated in 0.37480 seconds with 9 queries
