12-30-2017, 20:58 | #346 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Card found: S/N : A6XXXXX5 , v0136 Registered to: yuslamunique Connect phone on selected interface... Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : FEBD2E18_rm872__04.52.mcusw PPM : CC7A91E4_rm872__04.52.ppm_mh1 CNT : 3099529F_rm872__04.52.image_mh1_059Q317 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 358362057867063 IMEI 2 : 358362057867071 PCcode : 059R7V6 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358362057867063_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : FEBD2E18_rm872__04.52.mcusw Image : rm872__04.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:02:22 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:28 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xFA4D ===Flashing [PPM]=== File : CC7A91E4_rm872__04.52.ppm_mh1 Image : package_mh1.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:27 Write , Start : 0x41A80000 , Len : 0x004DF5A8 Flashing , wait ... Region flash done, time : 00:00:05 CRC check passed , 0x4FC8 ===Flashing [CNT]=== File : 3099529F_rm872__04.52.image_mh1_059Q317 Image : package_mh1_059Q317.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:04:56 Write , Start : 0x42100000 , Len : 0x01140000 Flashing , wait ... Region flash done, time : 00:00:28 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:09 No write data, skip CRC check passed , 0xA6FD Flashing done! Total flash time : 00:09:07 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 04.52 30-06-13 RM-872 (c) Nokia IMEI: 358362057867063 PPM version : V 04.52 30-06-13 RM-872 (c) Nokia MH1 Product code: 059R7V6 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Resetting LifeTimer Reset Done! Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:10:31 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
12-31-2017, 10:04 | #347 (permalink) |
Freak Poster Join Date: Aug 2015 Location: Choubara(Layyah Pakistan..)
Member: 2451856 Status: Offline Thanks Meter: 247 | Nokia 230 Rm1172 write flash done by infinty best... Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1172_ROM_eMP_10.01.11 VIVA : RM-1172_VIVA_eMP_10.01.11 LANG : RM-1172_LANG_PACK_ROM_IJ_eMP_10.01.11_001 CUST : RM-1172_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 JMPT : RM-1172_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 24 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : EDA87DBA48D950876D0BF4D3DF48FE01 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DOHA.10.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Doha.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 SecureDecrypt : RM-1172_ROM_eMP_10.01.11 SecureDecrypt : RM-1172_VIVA_eMP_10.01.11 SecureDecrypt : RM-1172_LANG_PACK_ROM_IJ_eMP_10.01.11_001 SecureDecrypt : RM-1172_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 SecureDecrypt : RM-1172_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 OVRLP : 000069B900000001 PHPID : DOHA.10.01.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1172_ROM_eMP_10.01.11 Write : RM-1172_LANG_PACK_ROM_IJ_eMP_10.01.11_001 Write : RM-1172_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1172_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1172_VIVA_eMP_10.01.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1172_ROM_eMP_10.01.11 [VERIFY] DONE : RM-1172_LANG_PACK_ROM_IJ_eMP_10.01.11_001 [VERIFY] DONE : RM-1172_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1172_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1172_VIVA_eMP_10.01.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:03:07 Reboot phone Ok Connect phone on selected interface... |
The Following User Says Thank You to sanwal malik For This Useful Post: |
01-01-2018, 07:17 | #348 (permalink) |
No Life Poster Join Date: Oct 2012 Location: Pakistan ,Sahiwal ,Bwn Age: 30
Member: 1819120 Status: Offline Sonork: 100.1648344 Thanks Meter: 1,448 | Nokia 130 Urdu Language Done By BB5 Dongle Nokia 130 Urdu Language Done By BB5 Dongle Code: Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_11.00.11 VIVA : RM-1035_VIVA_eMP_11.00.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 73 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 65A6DF474DC6B0E035764FFE151B9D2C BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.02.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_11.00.11 SecureDecrypt : RM-1035_VIVA_eMP_11.00.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.02.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_11.00.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_VIVA_eMP_11.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_11.00.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_VIVA_eMP_11.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:11 Reboot phone Ok Connect phone on selected interface... Br Muzammal Mudasser |
The Following User Says Thank You to muzammal mudass For This Useful Post: |
01-03-2018, 12:55 | #349 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | f1st nokia 2 flash done 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 0EC3103D ID_BLOCK_I : 009600E1 ID_BLOCK_L : 737F9AACB834129F1ECB8C840A290C06 ID_BLOCK_L : C5EF981C00F53F7EAC2FFF16B349A887 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Flash Chain : 49 Flashing now Flashing : gpt_main0.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : sysinfo.cfg Flashing : splash.img Flashing : ftm.img Flashing : hidden.img Flashing : cda.img Flashing : label.img Flashing : recovery.img Flashing : sec.dat Flashing : boot.img Flashing : NON-HLOS.bin Flashing : system.img Flashing : misc.img Flashing : cache.img Flashing : persist.img Flashing : cmnlib.mbn Flashing : cmnlib.mbn Flashing : keymaster.mbn Flashing : keymaster.mbn Flashing : userdata.img Flashing : gpt_backup0.bin Wipe data ... BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:03:52 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to iftikhar_246 For This Useful Post: |
01-04-2018, 12:46 | #350 (permalink) |
Member: 2451856 Status: Offline Thanks Meter: 247 | Nokia 230 rm1172 sec code remove done by format with infinty best... Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 24 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : DED4F2B25C9F8C7BFC43E73CCFD3EEDA BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DOHA.13.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Doha.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 Executing FFS FORMAT now... FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:29 Connect phone on selected interface... |
01-07-2018, 10:29 | #351 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,419 | Nokia 108 Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-944_ROM_eMP_22.00.11 VIVA : RM-944_VIVA_eMP_22.00.11 LANG : RM-944_LANG_PACK_ROM_IC_eMP_22.00.11 CUST : RM-944_CUSTPACK_ROM_IC_MEA_DZ_eMP_22.00.11 JMPT : RM-944_JUMP_TABLE_IC_MEA_DZ_eMP_22.00.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 31 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : B4CFBD0381D2955569A4139F38F0C299 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Bree.20.06.11.p4 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_22.00.11 SecureDecrypt : RM-944_VIVA_eMP_22.00.11 SecureDecrypt : RM-944_LANG_PACK_ROM_IC_eMP_22.00.11 SecureDecrypt : RM-944_CUSTPACK_ROM_IC_MEA_DZ_eMP_22.00.11 SecureDecrypt : RM-944_JUMP_TABLE_IC_MEA_DZ_eMP_22.00.11 OVRLP : 000069B900000001 PHPID : Bree.20.06.11.p4 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-944_ROM_eMP_22.00.11 Write : RM-944_LANG_PACK_ROM_IC_eMP_22.00.11 Write : RM-944_CUSTPACK_ROM_IC_MEA_DZ_eMP_22.00.11 Write : RM-944_JUMP_TABLE_IC_MEA_DZ_eMP_22.00.11 Write : RM-944_VIVA_eMP_22.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-944_ROM_eMP_22.00.11 [VERIFY] DONE : RM-944_LANG_PACK_ROM_IC_eMP_22.00.11 [VERIFY] DONE : RM-944_CUSTPACK_ROM_IC_MEA_DZ_eMP_22.00.11 [VERIFY] DONE : RM-944_JUMP_TABLE_IC_MEA_DZ_eMP_22.00.11 [VERIFY] DONE : RM-944_VIVA_eMP_22.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:12 Reboot phone Ok Connect phone on selected interface... |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
01-09-2018, 12:05 | #352 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 44
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,419 | NOKIA E7-00 FLASH DONE Code: Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : RM-626_111.040.1511_987.01_default_79u.2012.20.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 0F8000075AD5034410E09EE042478CE201CC3FCE ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00680020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 8EABFDA6B8A757034233978C16A93B892CE2D4FA ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 3XXXXXXXXXXXX Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\354864043961136_2nd.rpl === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [CNT]=== Erase : Processing RM-626_111.040.1511_987.01_default_79u.2012.20.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:06 Write : Processing RM-626_111.040.1511_987.01_default_79u.2012.20.uda.fpsx Total writen 851 blocks TIME : Write time : 00:00:28 CNT Write done ADL: Request programm status NAND status : 00000016 / 00000016 / 00000000 ADL: Close_Session Content: 000300000000160000001600000000 ADL: Reboot Flashing done! Total flash time : 00:00:35 Reboot phone now... Reading Phone Info.... Connected phone - Nokia E7-00 Software Info: V 79_sr1_12w18.5 27-07-12 RM-626 (c) Nokia IMEI: 354864043961136 Ape Version: 111.040.1511 Product code: 059G8H1 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Phone disconected! |
The Following User Says Thank You to Kirumira For This Useful Post: |
01-09-2018, 12:12 | #353 (permalink) |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,419 | NOKIA 2690 RM-635 FLASHING Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm635__10.65.mcusw PPM : rm635__10.65.ppm_mr CNT : rm635__10.65.image_mr_pink Flashing phone now... [Gen] Rules accepted for : RAP3x Generation Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1AF000100BB404560EF22583871A5A05DF52B314 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ===Flashing [MCU]=== Erase : Processing rm635__10.65.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:49 Write : Processing rm635__10.65.mcusw Total 1165 [1165/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:56 MCU Write done ===Flashing [PPM]=== Erase : Processing rm635__10.65.ppm_mr Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:12 Write : Processing rm635__10.65.ppm_mr Total 205 [205/0/0] blocks to write, writing... TIME : Write time : 00:00:12 PPM Write done ===Flashing [CNT]=== Erase : Processing rm635__10.65.image_mr_pink Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:07:22 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm635__10.65.image_mr_pink Total 488 [488/0/0] blocks to write, writing... TIME : Write time : 00:00:28 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:13:03 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 2690 Software Info: V 10.65 09-12-10 RM-635 (c) Nokia IMEI: 355954040369414 PPM version : V 10.65 09-12-10 RM-635 (c) Nokia MR Product code: 0592084 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 0 certs Uploading User Certificates... Uploaded 26 certs! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! |
01-09-2018, 12:22 | #354 (permalink) |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,419 | NOKIA 130 FLASHING DONE Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_10.02.11 VIVA : RM-1035_VIVA_eMP_10.02.11 LANG : RM-1035_LANG_PACK_ROM_AZ_eMP_10.02.11_001 CUST : RM-1035_CUSTPACK_ROM_AZ_EURO_AZ_eMP_10.02.11_001 JMPT : RM-1035_JUMP_TABLE_AZ_EURO_AZ_eMP_10.02.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 73 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 4E6926D23A90C4501A6A04610351311D BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_10.02.11 SecureDecrypt : RM-1035_VIVA_eMP_10.02.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_AZ_eMP_10.02.11_001 SecureDecrypt : RM-1035_CUSTPACK_ROM_AZ_EURO_AZ_eMP_10.02.11_001 SecureDecrypt : RM-1035_JUMP_TABLE_AZ_EURO_AZ_eMP_10.02.11_001 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_10.02.11 Write : RM-1035_LANG_PACK_ROM_AZ_eMP_10.02.11_001 Write : RM-1035_CUSTPACK_ROM_AZ_EURO_AZ_eMP_10.02.11_001 Write : RM-1035_JUMP_TABLE_AZ_EURO_AZ_eMP_10.02.11_001 Write : RM-1035_VIVA_eMP_10.02.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_10.02.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_AZ_eMP_10.02.11_001 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_AZ_EURO_AZ_eMP_10.02.11_001 [VERIFY] DONE : RM-1035_JUMP_TABLE_AZ_EURO_AZ_eMP_10.02.11_001 [VERIFY] DONE : RM-1035_VIVA_eMP_10.02.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:00:51 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds Wait, when phone will be ready ... Reading Phone Info.... Software Info: 10.02.11 00-00-00 RM-1035 IMEI: 35XXXXXXXXXXXX Ape Version: NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM version : AZ Product code: 059W041 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Code: Connect phone on selected interface... [MTK] : Extract PhoneBook from file : 356873073661100_MTKx.bin [PROCESS] : Sorting Data [1/3] [PROCESS] : Extract Data [2/3] [PROCESS] : Decrypt Data [3/3] [EXTRACT] : Ok, 75 records found! [INFO] PhoneBook Memory : 500 , Used : 75 CSV Saved to : C:\Users\HJH\Desktop\driver\35XXXXXXXX_MTKx.csv MBAK Saved to : C:\Users\HJH\Desktop\driver\35XXXXXXXX_MTKx.csv [INFO] : MBAK Info : Create folder "Backup" on SDcard. Put this file in SDcard to folder /Backup/ Inserd card in phone, make "Restore backup" from Settings->Backup Done |
01-11-2018, 07:24 | #355 (permalink) |
Member: 2451856 Status: Offline Thanks Meter: 247 | Nokia 230 read&reset user code done by infinty best... Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 24 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 9619481CD8F76A98C3843EDC0C7CEEC4 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
01-16-2018, 08:29 | #356 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 3310 reset user Code Done :) Code: Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 11.02.11 00-00-00 TA-1030 IMEI 1 : 357314082113584 IMEI 2 : 357314082113592 XappVer : 000008F2 Ape Ver : NEMO G 4122fe8d/1 (00000000+0) T Thu Dec 29 01:31:09 2016 U d61db836 PPM : IJ CNT : RETRO.11.02.11.p1 Product SN : 14F3037BU Product code : 059Z014 Base Prd.code: 059Z380 Module code : 0207297 Hardware info======= HWID : 1000 LCDVer: TPO Lock info =========== IMEI : 357314082113584 IMEI spNet : 3A 75 13 04 28 11 53 48 Conf key : 800000000004000B Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; SimLock status : Ok Security status : Ok Done! Software Info: 11.02.11 00-00-00 TA-1030 IMEI: 357314082113584 PPM version : IJ Product code: 059Z014 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 113 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 49D561A6AF933760681580C1E123ADDA BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
01-16-2018, 10:30 | #357 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,419 | Nokia 112 Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm837__03.51.mcusw PPM : rm837__03.51.ppm_m2 CNT : rm837__03.51.image_m2_059P7B2 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.50_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 358367055432182 IMEI 2 : 358367055432190 PCcode : 059S8H2 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358367055432182_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm837__03.51.mcusw Image : rm837__03.51.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:00:50 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:33 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x87F4 ===Flashing [PPM]=== File : rm837__03.51.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:06 Write , Start : 0x41BC0000 , Len : 0x0030F7C0 Flashing , wait ... Region flash done, time : 00:00:03 CRC check passed , 0x46E6 ===Flashing [CNT]=== File : rm837__03.51.image_m2_059P7B2 Image : package_m2_059P7B2.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:01:04 Write , Start : 0x421C0000 , Len : 0x00EE0000 Flashing , wait ... Region flash done, time : 00:00:19 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x2E64 Flashing done! Total flash time : 00:03:06 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 112 Software Info: V 03.51 06-08-13 RM-837 (c) Nokia IMEI: 358367055432182 PPM version : V 03.51 06-08-13 RM-837 (c) Nokia M2 Product code: 059S8H2 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:03:55 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
01-18-2018, 10:09 | #358 (permalink) |
Member: 2451856 Status: Offline Thanks Meter: 247 | Nokia 230 rm1172 facebook&internet apps not working done byflashing with infinty best Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1172_ROM_eMP_10.01.11 VIVA : RM-1172_VIVA_eMP_10.01.11 LANG : RM-1172_LANG_PACK_ROM_IJ_eMP_10.01.11_001 CUST : RM-1172_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 JMPT : RM-1172_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 90 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : BA0576E9E19579AF0E0BEBDE4C4FFF26 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DOHA.13.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Doha.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 SecureDecrypt : RM-1172_ROM_eMP_10.01.11 SecureDecrypt : RM-1172_VIVA_eMP_10.01.11 SecureDecrypt : RM-1172_LANG_PACK_ROM_IJ_eMP_10.01.11_001 SecureDecrypt : RM-1172_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 SecureDecrypt : RM-1172_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 OVRLP : 000069B900000001 PHPID : DOHA.13.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1172_ROM_eMP_10.01.11 Write : RM-1172_LANG_PACK_ROM_IJ_eMP_10.01.11_001 Write : RM-1172_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1172_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1172_VIVA_eMP_10.01.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1172_ROM_eMP_10.01.11 [VERIFY] DONE : RM-1172_LANG_PACK_ROM_IJ_eMP_10.01.11_001 [VERIFY] DONE : RM-1172_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1172_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1172_VIVA_eMP_10.01.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:03:12 Reboot phone Ok Connect phone on selected interface... |
01-20-2018, 18:17 | #359 (permalink) |
Member: 2451856 Status: Offline Thanks Meter: 247 | Nokia 206 rm872 hang on logo done by flashing with infinty best.. Connect phone on selected interface... Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm872__04.52.mcusw PPM : rm872__04.52.ppm_m2 CNT : rm872__04.52.image_m2_059Q4J7 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 3563*********** IMEI 2 : 3563*********** PCcode : 059Q4J7 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\356324052239609_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm872__04.52.mcusw Image : rm872__04.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:02:15 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:28 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xFA4D ===Flashing [PPM]=== File : rm872__04.52.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:21 Write , Start : 0x41A80000 , Len : 0x003C68F0 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xC9E6 ===Flashing [CNT]=== File : rm872__04.52.image_m2_059Q4J7 Image : package_m2_059Q4J7.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:04:22 Write , Start : 0x42100000 , Len : 0x01040000 Flashing , wait ... Region flash done, time : 00:00:23 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip CRC check passed , 0x719B Flashing done! Total flash time : 00:08:13 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 04.52 30-06-13 RM-872 (c) Nokia IMEI: 3563*********** PPM version : V 04.52 30-06-13 RM-872 (c) Nokia M2 Product code: 059Q4J7 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:09:29 Connect phone on selected interface... |
01-20-2018, 18:22 | #360 (permalink) |
Member: 2451856 Status: Offline Thanks Meter: 247 | Nokia 215 rm1110 hang on logo done by flashing with infinty best... Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1110_ROM_eMP_12.03.11 VIVA : RM-1110_VIVA_eMP_12.03.11 LANG : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001 CUST : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001 JMPT : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 90 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 3F547AA730ACDAF556E0278EA1A21D82 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : JET.10.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Jet.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 SecureDecrypt : RM-1110_ROM_eMP_12.03.11 SecureDecrypt : RM-1110_VIVA_eMP_12.03.11 SecureDecrypt : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001 SecureDecrypt : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001 SecureDecrypt : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001 OVRLP : 000069B900000001 PHPID : JET.10.01.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1110_ROM_eMP_12.03.11 Write : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001 Write : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001 Write : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001 Write : RM-1110_VIVA_eMP_12.03.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1110_ROM_eMP_12.03.11 [VERIFY] DONE : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001 [VERIFY] DONE : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001 [VERIFY] DONE : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001 [VERIFY] DONE : RM-1110_VIVA_eMP_12.03.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:02:49 Reboot phone Ok Connect phone on selected interface... |
