03-04-2018, 11:55 | #406 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 215 format done Wait for phone... Phone found! [ 97 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 8C015A020DEFF52C285D9EE56F7E418D BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : JET.12.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Jet.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 Executing FFS FORMAT now... FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:30 |
The Following User Says Thank You to Luckey1 For This Useful Post: |
03-05-2018, 09:25 | #407 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia X2-05 Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm772__08.60.mcusw PPM : rm772__08.60.ppm_m_a CNT : rm772__08.60.image_m_a_059H126 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> Check SW version... FlashFile version : 08.60 Phone version : 08.30 14-10-11 RM-772 (c) Nokia -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... Batery voltage : 3576 mV -> Batery voltage less, than 3,7V (3576mV). Continue at user risk SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok Reboot.... -> If Phone start charge - just reinsert battery fast Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 357406041396787 PCcode : 059H126 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357406041396787_XG213.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm772__08.60.mcusw Image : rm772__08.60.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x018C0000 Erasing, wait ... Erase done, time : 00:00:49 Write , Start : 0x40280000 , Len : 0x01840000 Flashing , wait ... Region flash done, time : 00:00:33 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x0746 ===Flashing [PPM]=== File : rm772__08.60.ppm_m_a Image : package_m_a.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41B40000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:09 Write , Start : 0x41B40000 , Len : 0x0046A330 Flashing , wait ... Region flash done, time : 00:00:05 CRC check passed , 0xA701 ===Flashing [CNT]=== File : rm772__08.60.image_m_a_059H126 Image : package_m_a_059H126.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42240000 , Len : 0x01BE0000 Erasing, wait ... Erase done, time : 00:01:06 Write , Start : 0x42240000 , Len : 0x00D00000 Flashing , wait ... Region flash done, time : 00:00:18 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x23F4 Flashing done! Total flash time : 00:03:10 Reboot phone now... Reading Phone Info.... Connected phone - X2-05 Software Info: V 08.60 21-12-11 RM-772 (c) Nokia IMEI: 357406041396787 PPM version : V 08.60 21-12-11 RM-772 (c) Nokia M_A Product code: 059H126 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 42 certs Certificates found, skip upload ... ===== WARNING ===== Battery voltage is NOT enough for start ===== WARNING ===== AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:00 Last edited by Luckey1; 03-05-2018 at 09:32. |
03-08-2018, 09:40 | #408 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 225 format done Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 97 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 5A4553646283DE748E35BC8C38A47844 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.20.10.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 Executing FFS FORMAT now... FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:01:16 |
03-11-2018, 15:55 | #409 (permalink) | |
No Life Poster Join Date: Aug 2015 Location: Bangladesh Age: 30
Member: 2443283 Status: Offline Thanks Meter: 518 | Nokia 5 no service successfully done Nokia 5 no service done Quote:
The Following 2 Users Say Thank You to nahidroman For This Useful Post: |
03-12-2018, 14:09 | #410 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia X2-00 write firmware Done :) Code: Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 00000000002BCC21F27BC9D5E57D5143CD4DEA47 ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 00300020 Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:23 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : E9700989029D9E899915F781B1582048E042A738 ADL: Reading certificates... Reading NPC certificate... IMEI : 352699046971142 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... ADL: Reading certificates done! :) ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Wait, reconneting... SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok CMLA Key read ... Ok WMDRM read ... Ok CRT308 Backup Created NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : F:\1+Flashing Software\1+Infinity Box\BEST\Backup\Cert\352699046971142.rpl All done, Disconnecting Elapsed: 00:00:49 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Initializing Tests... IMEI : 352699046971142 , Phone : RM-618 Nokia X2-00 Get keys... PASSED | ST_SIM_LOCK_TEST PASSED | ST_SECURITY_TEST PASSED | ST_PWR_KEY_TEST PASSED | ST_LCD_TEST PASSED | ST_LPRF_AUDIO_LINES_TEST PASSED | ST_LPRF_IF_TEST PASSED | ST_KEYBOARD_STUCK_TEST PASSED | ST_CAMERA_IF_TEST PASSED | ST_RADIO_TEST PASSED | ST_BT_WAKEUP_TEST PASSED | ST_LED_FLASH_TEST PASSED | ST_LED_FLASH_IF_TEST PASSED | ST_CHIPSET_API_PMU_TEST PASSED | ST_CHIPSET_API_RFPA_TEST PASSED | ST_SLEEP_CLOCK_FREQ_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_PWB_TEMP_TEST PASSED | ST_BTEMP_TEST PASSED | ST_INTERNAL_ANTENNA_TEST PASSED | ST_BACKUP_BATT_TEST SelfTests end Done! Elapsed: 00:00:13 Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm618__08.35.mcusw PPM : rm618__08.35.ppm_meaa CNT : rm618__08.35.image_meaa_0595146 Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 00000000002BCC21F27BC9D5E57D5143CD4DEA47 ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 00300020 Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:11 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : E9700989029D9E899915F781B1582048E042A738 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 352699046971142 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : F:\1+Flashing Software\1+Infinity Box\BEST\Backup\Cert\352699046971142_2nd.rpl === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm618__08.35.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm618__08.35.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [UPDAPP] Total writen 511 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing rm618__08.35.ppm_meaa Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm618__08.35.ppm_meaa Total writen 101 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing rm618__08.35.image_meaa_0595146 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm618__08.35.image_meaa_0595146 Total writen 342 blocks TIME : Write time : 00:00:04 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:00:12 Reboot phone now... Reading Phone Info.... Connected phone - Nokia X2-00 Software Info: V 08.35 09-01-12 RM-618 (c) Nokia IMEI: 352699046971142 PPM version : V 08.35 09-01-12 RM-618 (c) Nokia MEA Product code: 0595307 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 39 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Phone disconected! Connect phone on selected interface... Elapsed: 00:00:59 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
03-19-2018, 15:29 | #411 (permalink) | |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,804 | clone j200 MT6577 format done [AP] : Initial info read Ok! Brand : alps ProdName : ga1502 ProdModel : 1502 Device : ga1502 AndroidVer: 4.4.2 MTKxCPU : MT6577 MTKxPRJ : ALPS.JB.MP.V2.60 SECURITY : IMEI_SW [1] : F90ACF834925240 IMEI_SW [2] : 68E6B048366811B BTMAC Addr : 894508E97C38 WiFi MAC : 7C3800009090 Quote:
The Following User Says Thank You to profkefah For This Useful Post: |
03-20-2018, 16:28 | #412 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | NOkia X2-00 write firmware Done :) Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm618__08.35.mcusw PPM : rm618__08.35.ppm_meaa CNT : rm618__08.35.image_meaa_0595146 Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 0000000000A5D3FA88399539738728746D3CF8B6 ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 00300020 Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:22 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : E9700989029D9E899915F781B1582048E042A738 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 351657058982226 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : F:\1+Flashing Software\1+Infinity Box\BEST\Backup\Cert\351657058982226_CRT.rpl === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm618__08.35.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm618__08.35.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [UPDAPP] Total writen 511 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000007 / 00000006 / 00000000 ===Flashing [PPM]=== Erase : Processing rm618__08.35.ppm_meaa Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm618__08.35.ppm_meaa Total writen 101 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000007 / 00000006 / 00000000 ===Flashing [CNT]=== Erase : Processing rm618__08.35.image_meaa_0595146 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm618__08.35.image_meaa_0595146 Total writen 342 blocks TIME : Write time : 00:00:03 CNT Write done ADL: Request programm status NAND status : 00000007 / 00000006 / 00000000 ADL: Close_Session Content: 000300000000070000000600000000 ADL: Reboot Flashing done! Total flash time : 00:00:12 Reboot phone now... Reading Phone Info.... Connected phone - Nokia X2-00 Software Info: V 08.35 09-01-12 RM-618 (c) Nokia IMEI: 351657058982226 PPM version : V 08.35 09-01-12 RM-618 (c) Nokia MEA Product code: 0595304 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 39 certs Certificates found, skip upload ... ===== WARNING ===== Battery voltage is NOT enough for start ===== WARNING ===== Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:13 Connect phone on selected interface... |
03-22-2018, 12:01 | #413 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Ukraine
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Nokia E52 Flash Done with Infinity BEST Nokia E52 Flash Done with Infinity BEST Read Info Code: Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia E52-1 Software ver : V ICPR82_11w16.3 19-05-11 RM-469 (c) Nokia IMEI : 353785042796358 XappVer : 000008F2 Ape Ver : 071.004 APE Var : 071.004071.004.03.01071.004.221.02 APE ADSP: 256 DSP Ver : ICPR82_11w16 APE Test: 0.073 PPM : CNT : Product SN : MHJ734893 Product code : 0587587 Base Prd.code: 0565921 Long Prod.SN : 0 Hardware info======= HWID : 8000 Retu : 40 Tahvo : 00 Battery: 3944 mV APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652. APE HW: 256 Lock info =========== IMEI : 353785042796358 IMEI spNet : 3A 35 87 05 24 97 36 05 IMEI svNet : 33 35 87 05 24 97 36 55 F4 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= Error collect lock info, try again CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm469_091.003_prd.core.fpsx PPM : rm469_091.003_05.01_Russian_prd.rofs2.fpsx PPM2 : rm469_091.003_C00.01_DEFAULT_prd.rofs3.fpsx CNT : rm469_091.003_U009.000_prd.uda.fpsx APE : RM469_APE_ONLY_ENO_09wk23v0.091.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> Check SW version... FlashFile version : 091.003 Phone version : 071.004 -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 21000103B685034417E8B0DC3D9C2987A0065244 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 85F252E351E225CAFC4DFBC8041EABD2823E3500 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 353785042796358 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\353785042796358.rpl === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm469_091.003_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm469_091.003_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 440 blocks TIME : Write time : 00:00:27 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing rm469_091.003_05.01_Russian_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm469_091.003_05.01_Russian_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 168 blocks TIME : Write time : 00:00:11 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM2]=== Erase : Processing rm469_091.003_C00.01_DEFAULT_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm469_091.003_C00.01_DEFAULT_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 35 blocks TIME : Write time : 00:00:02 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing rm469_091.003_U009.000_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm469_091.003_U009.000_prd.uda.fpsx Total writen 51 blocks TIME : Write time : 00:00:03 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [APE]=== Erase : Processing RM469_APE_ONLY_ENO_09wk23v0.091.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM469_APE_ONLY_ENO_09wk23v0.091.fpsx CMT: Writing Hash CERT [SOS*ENO] Total writen 12 blocks TIME : Write time : 00:00:00 APE Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:00:47 Reboot phone now... Reading Phone Info.... Connected phone - Nokia E52-1 Software Info: V ICPR82_11w16.3.11 29-03-12 RM-469 (c) Nokia IMEI: 353785042796358 Ape Version: 091.003 Product code: 0587587 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Resetting LifeTimer Reset Done! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! |
The Following User Says Thank You to localizator For This Useful Post: |
03-22-2018, 12:09 | #414 (permalink) |
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Nokia C2 Flash Done with Infinity BEST Nokia C2 Flash Done with Infinity BEST Read Info Code: Reading Phone Info.... Connected phone - Nokia C2-01 Software ver : V 11.00 17-03-11 RM-721 (c) Nokia IMEI : 352445053005329 XappVer : 000008F2 DSP Ver : SPR91_09w09_11w02 PPM : V 11.00 17-03-11 RM-721 (c) Nokia A CNT : Content: telenor DK V 11.00 17-03-11 RM-721 (c) Nokia Product SN : M4I648882 Product code : 059H8R0 Base Prd.code: 059C872 Module code : 0204769 Long Prod.SN : 0 Hardware info======= HWID : 4001 Retu : 51 Tahvo : 00 Battery: 3717 mV CMT BT: 1673-46038 LCDVer: SEIKO Lock info =========== IMEI : 352445053005329 IMEI spNet : 3A 25 44 05 35 00 35 02 IMEI svNet : 33 25 44 05 35 00 35 62 F9 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= Error collect lock info, try again CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm721__11.40.mcusw PPM : rm721__11.40.ppm_i CNT : rm721__11.40.image_i_059D5K0 Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> Check SW version... FlashFile version : 11.40 Phone version : 11.00 17-03-11 RM-721 (c) Nokia -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000010000022600000001020C192102044100 CPU ID : RAP3Gv4 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 3660010E638811496CE14B7D29C79E9D072C8483 ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 Use RAP3Gv40_2nd.fg , Rev : 3.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAP3Gv40_XSR17_alg.fg , Rev : 3.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 8443ECD57D2EDADDAADBAD248F1B3B559E14D184 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 352445053005329 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\352445053005329.rpl === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm721__11.40.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm721__11.40.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 134 blocks TIME : Write time : 00:00:39 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing rm721__11.40.ppm_i Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm721__11.40.ppm_i Total writen 26 blocks TIME : Write time : 00:00:08 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing rm721__11.40.image_i_059D5K0 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm721__11.40.image_i_059D5K0 Total writen 72 blocks TIME : Write time : 00:00:23 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:01:13 Reboot phone now... Reading Phone Info.... Connected phone - Nokia C2-01 Software Info: V 11.40 24-10-12 RM-721 (c) Nokia IMEI: 352445053005329 PPM version : V 11.40 24-10-12 RM-721 (c) Nokia I Product code: 059H8R0 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Resetting LifeTimer Reset Done! Check and Upload User Certificates ... Total - 34 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! |
03-22-2018, 14:18 | #415 (permalink) |
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Nokia 1800 Flash Done with Infinity BEST+UFS3 HWK Nokia 1800 Flash Done with Infinity BEST+UFS3 HWK Read Info Code: Reading Phone Info.... SW ver : V 06.51 13-05-11 RM-653 (c) Nokia IMEI : 358646043183027 PPM : V 06.51 13-05-11 RM-653 (c) Nokia AA PCode : 0594365 BPCode : 059J7J5 HWID : 2010 LCDVer : INNO:BOHAIv93 NT39121 IMEI : 358646043183027 Sl Conf : 001-01-00000000000 Sl Prof : 000000000003000-2 Sl Aux : 000B0000 Hw Sig : F8649F1A5E84BDE5 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Done! Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm653_004.100 PPM : rm653_004.10ej CNT : rm6530_nai04.10ej Infineon flashing... -> Infineon XG110 : IMEI Backup Created Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 PBL : Dynamic Boot Ok , 01A3 PBL : SE0_091125 F11 SBL : Dynamic Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH VEN : 000000EC FLASH DIE : 0000227A FLASH ID : UNKNOW [Not In Base] Boot Done! ===Flashing [MCU]=== File : rm653_004.100 Image : hw_b2_rm653_r04.100.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00800000 , Len : 0x00210000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x00210000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00C60000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00C60000 , Len : 0x00204900 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00FFC000 , Len : 0x00004000 Erasing, wait ... Erase done Write , Start : 0x00FFC000 , Len : 0x00000040 Flashing , wait ... Region flash done Check : 48F7 ===Flashing [PPM]=== File : rm653_004.10ej Image : hw_b2_rm653_004.10ej.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00210000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00210000 , Len : 0x001F6D80 Flashing , wait ... Region flash done Check : C6A1 ===Flashing [CNT]=== File : rm6530_nai04.10ej Image : hw_b2_rm6530_nai04.10ej.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00EB0000 , Len : 0x000D0000 Erasing, wait ... Erase done Write , Start : 0x00EB0000 , Len : 0x0005AD40 Flashing , wait ... Region flash done Check : 4E70 Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Afterflash settings... SW ver : V 04.10 24-04-10 RM-653 (c) Nokia IMEI : 358646043183027 PCode : 0594365 Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! All done! |
03-22-2018, 14:31 | #416 (permalink) |
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Nokia 2600 Flash Done with Infinity BEST+UFS3 HWK Nokia 2600 Flash Done with Infinity BEST+UFS3 HWK Code: Phone found! Series 40 Device detected! [DCT4+] read info... - Ok Reading Phone Info.... SW ver : V 5.24 26-08-05 RH-59 (c) NMP 2600 IMEI : 357620009302609 PPM : V 5.24 26-08-05 RH-59 (c) NMP 2600 AA DSP Ver : 2.14-@ PCode : 0518467 BPCode : 0516191 HWID : 0672 LCDVer : s6b33a0 IMEI : 357620009302609 Sl Conf : 001-01-00000000000 Sl Prof : 000000000000000-2 Sl Aux : 00026233 Hw Sig : 39F19032541F0DD0 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Done! Code: MCU File: rh59_06.420 1st Boot: Ok, DCT4, UPP: 1201 [Rh-59] [2.3.0.3] 2nd Boot: u_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00208828,St M58MR032 Algorithm: u_st_i.fia, Ver: 4.79.0 Algorithm Ok, MSID: 84B5476D389B224153A8B02A0D Decoded MSID: 3E4EBAE9-0016C753-A8000000 Encoded FAID: D3672CA7-924E14DC-F1056194 IMAGE: rh59_06.420 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013AFFFF Erased, Time: 00:33 Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:02 Area4: 0x017B0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FB0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:10 CNT File: rh590_nai6.42ej_3 IMAGE: rh590_nai6.42ej_3 Area1: 0x01370000-0x013AFFFF Erased, Time: 00:02 CNT Flashing Completed, Time: 00:01 Running: Server fake reply for CUI phone. Contents Package Extracting Ok, Time: 00:06 PPM File: rh59_06.42ej 1st Boot: Ok, DCT4, UPP: 1201 [Rh-59] [2.3.0.3] 2nd Boot: u_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00208828,St M58MR032 Algorithm: u_st_i.fia, Ver: 4.79.0 Algorithm Ok, MSID: 8485BD90C4205DDB1932B91F86 Decoded MSID: 3E4EBAE9-0016C753-A9000000 Encoded FAID: B6B82098-5E1D0A56-9CF138D4 IMAGE: rh59_06.42ej Area1: 0x011B0000-0x011BFFFF Erased, Time: 00:00 Area2: 0x011C0000-0x0136FFFF Erased, Time: 00:17 PPM Flashing Completed, Time: 00:07 Flashing Completed, Rebooting Mobile UI Defaults Ok, Time: 00:05 Set UI Factory Defaults Ok, Time: 00:00 Set Full Factory Defaults Ok, Time: 00:01 Set Software Upgrade Defaults Ok, Time: 00:00 Set Security Ok, Time: 00:00 |
03-22-2018, 14:45 | #417 (permalink) |
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Nokia 1208 Flash Done with Infinity BEST+UFS3 HWK Nokia 1208 Flash Done with Infinity BEST+UFS3 HWK Read Info Code: Phone found! Series 40 Device detected! [DCT4+] read info... - Ok Reading Phone Info.... SW ver : V 5.91 27-03-09 RH-105 (c) NMP IMEI : 356045033337853 PPM : V 5.91 27-03-09 RH-105 (c) NMP AA DSP Ver : PR62_08w31_UPP PCode : 0550337 BPCode : 0582127 HWID : 1610 LCDVer : WINTEK:NAXv84 ST7628 IMEI : 356045033337853 Sl Conf : 001-01-00000000000 Sl Prof : 000000000001000-2 Sl Aux : 000B0000 Hw Sig : 279F6108C4E61CEB Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Done! Code: 1st Boot: Ok, DCT4, UPP: 2292 [Rh-105] [2.3.0.3] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00012A7E,Amd 29BDS320 Algorithm: u3_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 849771B3891557063C64FC8841 Decoded MSID: 3E4EBAE9-0046D051-A8000000 Encoded FAID: D5E56779-887840AC-41E879E5 IMAGE: rh105_06.000 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013AFFFF Erased, Time: 00:26 Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:02 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:14 IMAGE: rh1050_nai6.00ej Area1: 0x01380000-0x013AFFFF Erased, Time: 00:01 CNT Flashing Completed, Time: 00:00 Running: Server fake reply for CUI phone. Contents Package Extracting Ok, Time: 00:06 1st Boot: Ok, DCT4, UPP: 2292 [Rh-105] [2.3.0.3] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00012A7E,Amd 29BDS320 Algorithm: u3_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 84F29764609B12857839ED9D7F Decoded MSID: 3E4EBAE9-0046D051-AA000000 Encoded FAID: 465D52EF-22405B2C-A7A12E24 IMAGE: rh105_06.00ej Area1: 0x01240000-0x0124FFFF Erased, Time: 00:00 Area2: 0x01250000-0x0137FFFF Erased, Time: 00:08 PPM Flashing Completed, Time: 00:07 Flashing Completed, Rebooting Mobile UI Defaults Ok, Time: 00:05 Set UI Factory Defaults Ok, Time: 00:00 Set Full Factory Defaults Ok, Time: 00:00 Set Software Upgrade Defaults Ok, Time: 00:00 |
03-23-2018, 12:10 | #418 (permalink) |
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Nokia X6 Flash Done with Infinity BEST Nokia X6 Flash Done with Infinity BEST Read Info Code: Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia X6-00 Software ver : V ICPR72_10w29.2.3 27-10-10 RM-559 (c) Nokia IMEI : 355964041128248 XappVer : 000008F2 Ape Ver : V 30.0.003 APE Var : V 30.0.003V 30.0.003 V 30.0.003 APE ADSP: 256 DSP Ver : ICPR72_10w26p2 APE Test: rm559_ENO_A_09wk28v0.470 PPM : CNT : v 001_000 03-09-10 vanilla RM559r RM559_002_001_M003 Product SN : MIM072847 Product code : 059B1J6 Base Prd.code: 0599944 Module code : 0204645 Long Prod.SN : 0 Hardware info======= HWID : 1285 Retu : 16 Tahvo : 22 Battery: 3794 mV APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708. APE HW: 256 Lock info =========== IMEI : 355964041128248 IMEI spNet : 3A 55 69 04 14 21 28 04 IMEI svNet : 33 55 69 04 14 21 28 24 F0 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= Error collect lock info, try again CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-559_40.0.002_prd.core.C00 PPM : RM-559_40.0.002_prd.rofs2.V05 PPM2 : RM-559_40.0.002_C03_prd.rofs3.fpsx CNT : RM-559_32.0.002_001_000_U001.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPIDO Generation Check files done... -> Check SW version... FlashFile version : 40.0.002 Phone version : V 30.0.003 -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355964041128248_SIM.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Batery valtage : 3794 mV -> Batery voltage less, than 3,8V (3794mV). Continue at user risk Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 20000101C4A900524DEE1216776181C24B804822 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! :) TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! RHASH : 479C6DDE3942E12C429C1D6ADED80371 RPAKeys : E00DA77BF32983F864BC7671FE7709A29D8E2C08 Pr.Code : 059B1J6 IMEI : 355964041128248 ADL : Auth done... === SW Version Check === - > REFLASHING or UPGRADE === SW Version Check === ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-559_40.0.002_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x0B71FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:01 Write : Processing RM-559_40.0.002_prd.core.C00 Total 508 [508/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:35 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-559_40.0.002_prd.rofs2.V05 Found 1 areas to erase Erasing area 0x07920000 - 0x0A2FFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-559_40.0.002_prd.rofs2.V05 Total 116 [116/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:08 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-559_40.0.002_C03_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x0A300000 - 0x0B71FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-559_40.0.002_C03_prd.rofs3.fpsx Total 27 [27/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:01 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-559_32.0.002_001_000_U001.uda.fpsx Found 1 areas to erase Erasing area 0x0B720000 - 0x1EF7FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-559_32.0.002_001_000_U001.uda.fpsx Total 32 [32/0/0] blocks to write, writing... TIME : Write time : 00:00:02 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:50 Reboot phone now... Reading Phone Info.... Connected phone - Nokia X6-00 Software Info: V ICPR72_11w16.1 28-07-11 RM-559 (c) Nokia IMEI: 355964041128248 Ape Version: V 40.0.002 Product code: 059B1J6 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Resetting LifeTimer Reset Done! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! |
03-24-2018, 12:59 | #419 (permalink) |
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Nokia 6030 (RM-74) Unlock SIM Done with Infinity BEST+UFS3+JAF Nokia 6030 (RM-74) Unlock SIM Done with Infinity BEST+UFS3+JAF Read Info Code: Phone found! Series 40 Device detected! [DCT4+] read info... - Ok Reading Phone Info.... SW ver : V y4.10 29-12-05 RM-74 (c) Nokia. IMEI : 358828001951138 PPM : V y4.10 29-12-05 RM74 (c) Nokia. B DSP Ver : 5w19.v20 PCode : 0529573 BPCode : 0519975 HWID : 0605 LCDVer : ELBE IMEI : 358828001951138 Sl Conf : 260-03-00000000000 Sl Prof : 800000000000000-2 Sl Aux : 00025555 Hw Sig : F8222EC8CC67C0BF Country : Poland Operator : Orange PL Lock info: Block 1 L1:Close; Done! Code: JAF version 1.98.62 Detected PKEY: 90007BF6 Card life counter: 99.99% P-key nokia module version 01.02 Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B1, Driver version: 0, Library version: 0 JAF DCT4/BB5 LOADERS DIR: C:\Program Files (x86)\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files (x86)\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files (x86)\ODEON\JAF\Flash3\ USB Cable Driver version: 7.1.182.0 Powering the phone... Unlocking... IMEI: 358828001951138 ASIC: 2 SW version: y4.10 Checking locks... Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Done! DCT4 unlock counter: 1 |
03-26-2018, 13:20 | #420 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 130 user code reset done --- Insert USB cable now! --- Wait for phone... Phone found! [ 35 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 3A3E6CF53AFA8DDAF3C40180F8169975 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! |
