Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 08-08-2020, 08:39   #1156 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 140
Nokia C2 TA-1204 successfully reset by CM2 Best 2
Sent from my SM-N960F using Tapatalk
The Following User Says Thank You to killme12 For This Useful Post:
Old 08-08-2020, 13:01   #1157 (permalink)
GSM AR's Avatar
Member: 2608490
Thanks Meter: 914
Nokia 106 2019 TA-1114 Full Flash Done
Operation : Write FirmWare [ v1.20 ]
Setting : UserData erase : False
Setting : LangPack Only : False
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : Nokia USB Serial Port (COM15)
MODE : NOKIA USB SERIAL
PORT : 15
BROM : Init BROM
BROM init passed!
CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001
BROM : SECCFG : 0x00000005
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : 1D735E1F0DB5EE1FE1C5E84A0EC637A9
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : NEMO61D.10.00.11.p2
BOOT : SWR : 10.00.11
AGENT : Look for suitable BootChain in DA ...
AGENT : DEFAULT AUTO
AGENT : Found MT6261
AGENT : NEMO61D.10.00.11.p2
BOOT : Sending 1st DA ...
BOOT : DA sent
BOOT : Transfer control to DA ...
DA : Sync Passed!
DA : Authentification pass!
DA : Agent : v03.02 on BBID : 0x8E
NOR: 00C8 : 0060 : 0016 : 0000
NOR: [GigaDevice] GD25LQ32
NOR:
TSIZE : 0x00400000 [ 4.00 MB ]
PSIZE : 0x00400000 [ 4.00 MB ]
STYPE : 0x00000000
FLOTP : DA_NOR_OTP_EXIST
STATUS : OK
BSTYLE : SF_FLASH_BOOT
Boot done!
VPL SoftwareVersion : 10.00.11 [TA-1114]
DEV SoftwareVersion : 10.00.11
SWInfo compare result : SAME
Load FlashSet :
MROM : TA-1114_ROM_eMP_10.00.11
LANG : TA-1114_LANG_PACK_ROM_IJ_eMP_10.00.11_001
CUST : TA-1114_CUSTPACK_ROM_IJ_eMP_10.00.11_001
JUMP : TA-1114_JUMP_TABLE_IJ_eMP_10.00.11_001
VIVA : TA-1114_VIVA_eMP_10.00.11
Prepare FlashSet :
DCR : TA-1114_ROM_eMP_10.00.11
DCR : TA-1114_LANG_PACK_ROM_IJ_eMP_10.00.11_001
DCR : TA-1114_CUSTPACK_ROM_IJ_eMP_10.00.11_001
DCR : TA-1114_JUMP_TABLE_IJ_eMP_10.00.11_001
DCR : TA-1114_VIVA_eMP_10.00.11
Prepare Target
SDS : OK : 0x003F8000 : 0x00008000
Erase Target Flash
Erase done!
Write Target Flash
Write : TA-1114_ROM_eMP_10.00.11
Write : TA-1114_LANG_PACK_ROM_IJ_eMP_10.00.11_001
Write : TA-1114_CUSTPACK_ROM_IJ_eMP_10.00.11_001
Write : TA-1114_JUMP_TABLE_IJ_eMP_10.00.11_001
Write : TA-1114_VIVA_eMP_10.00.11
Write done, waiting target response ...
Write flash done!
Verify Target FlashContent
Verify : TA-1114_ROM_eMP_10.00.11
Verify : TA-1114_LANG_PACK_ROM_IJ_eMP_10.00.11_001
Verify : TA-1114_CUSTPACK_ROM_IJ_eMP_10.00.11_001
Verify : TA-1114_JUMP_TABLE_IJ_eMP_10.00.11_001
Verify : TA-1114_VIVA_eMP_10.00.11
Done!
Elapsed: 00:00:55
Reconnect Power/Cable!
The Following 2 Users Say Thank You to GSM AR For This Useful Post:
Old 08-19-2020, 07:02   #1158 (permalink)
ajaystarin's Avatar
Member: 173081
Thanks Meter: 350
Nokia 5.1 (TA-1088) Pattern & Frp done with Best NK2 V1.20
Operation : Reset Settings [ v1.20 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
- > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage!
PTFN : MediaTek USB Port (COM11)
MODE : BOOTROM
PORT : 11
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : DSLevel : DEV_KEY
BROM : BOOTROM
AGENT : Found MT6755
AGENT : BEST_Nokia_DA_v19_1711_06
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0x80000000 [ 2.00 GB ]
EMMC: 150100514536334D420302599B7A45A3
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x3A3E00000 [ 14.56 GB ]
CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 2CF899A7A64E6F586C63EDE91015AE9
DA : USB : FULL-SPEED
DA : USB : Change Port Speed
PTFN : MediaTek DA USB VCOM (Android) (COM5)
MODE : PRELOADER PORT
PORT : 5
Boot done!
Format Ok : USERDATA
Format Ok : RESET PROTECTION
Format Ok : PRIVACY
Done!
Elapsed: 00:02:26
Regards
Ajay Gupta
The Following 2 Users Say Thank You to ajaystarin For This Useful Post:
Old 08-19-2020, 07:20   #1159 (permalink)
ajaystarin's Avatar
Member: 173081
Thanks Meter: 350
Nokia 2.2 (TA-1183) Frp done with Best NK2 V1.20
-> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable
-> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear
Wait for phone...
Connect Ok!
Device Found!
Initialize ...
Initialize Ok!
Device : Wasp ( Wasp )
BLType : WT2
SecVer : 02
Device authentification ...
Processing server operation ...
Connecting to server...
Connected
Authenticating...
Authenticated
Checking Client version...
Client version is valid
Process...
Finished
Disconnected
Finished
Challenge : Process
Challenge : Passed!
FRP reset Ok!
UserData Size : 0x00000000
UserData reset failed!
Done!
Elapsed: 00:00:11
Regards
Ajay Gupta
The Following 3 Users Say Thank You to ajaystarin For This Useful Post:
Old 08-21-2020, 06:49   #1160 (permalink)
ajaystarin's Avatar
Member: 173081
Thanks Meter: 350
Nokia 5.1 Plus (TA-1102) your device is corrupt. done by Infinity Best NK2 v1.20
Nokia 5.1 Plus (TA-1102) your device is corrupt. It can't be trusted and will not boot. error successfully recovered by flashing with great Infinity Best NK2 v1.20 tool.
Operation : Write FW [ v1.20 ]
Setting : UserData preserve : False
Setting : Flash Pre-Erase : True
Setting : Bootloader update : True
PTFN : MediaTek USB Port (COM14)
MODE : BOOTROM
PORT : 14
BROM : Init BROM
BROM init passed!
CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
BROM : DSLevel : DEV_KEY+DEV_ARB
BROM : BOOTROM
BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001]
BROM : SOCID : 160BF54CAC52BCBF61581B41AEDF85E1648A1313A4FAC7116F 1B5355EA51E75E
AGENT : Found MT6771
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DRAM: 0xC0000000 [ 3.00 GB ]
EMMC: 90014A68423861503E014ABA3429B55D
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP>
EMMC:
RPMB : 0x01000000 [ 16.00 MB ]
USER : 0x747C00000 [ 29.12 GB ]
CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : A6196849BFA9E4B923D8B52AC01F9D66
DA : USB : HIGH-SPEED
Boot done!
DL_INFO : PMT present
SEC_DL : False (RAPHAEL)
SEC_ID : 0x494E46494E495459424F584245535432
[FL] : HW verification passed!
Erase : 0x0000000000000000 : 0x0000000000108000
Erase : 0x0000000000188000 : 0x0000000001500000
Erase : 0x0000000003688000 : 0x0000000006000000
Erase : 0x000000000E800000 : 0x0000000000800000
Erase : 0x0000000012580000 : 0x0000000000800000
Erase : 0x0000000013DA0000 : 0x0000000001800000
Erase : 0x00000000156A0000 : 0x0000000002000000
Erase : 0x0000000018000000 : 0x00000000CE800000
Erase : 0x00000000E6900000 : 0x0000000002000000
Erase : 0x00000000E9800000 : 0x000000018E000000
PMT Update : OK
Flashing now ...
PROCESS : PRELOADER
Unpack : PDA-0-220G-0001-preloader_fih_mt6771_64.bin
Flash : PDA-0-220G-0001-preloader_fih_mt6771_64.bin
Update bootloader backup copy ...
Update bootloader backup copy Ok!
PROCESS : LOGO_A
Unpack : PDA-0-220G-00WW-logo.bin
Flash : PDA-0-220G-00WW-logo.bin
PROCESS : MD1IMG_A
Unpack : PDA-0-220G-md1img.img
Flash : PDA-0-220G-md1img.img
PROCESS : SPMFW_A
Unpack : PDA-0-220G-spmfw.img
Flash : PDA-0-220G-spmfw.img
PROCESS : SCP_A
Unpack : PDA-0-220G-scp.img
Flash : PDA-0-220G-scp.img
PROCESS : SSPM_A
Unpack : PDA-0-220G-sspm.img
Flash : PDA-0-220G-sspm.img
PROCESS : CAM_VPU1_A
Unpack : PDA-0-220G-cam_vpu1.img
Flash : PDA-0-220G-cam_vpu1.img
PROCESS : CAM_VPU2_A
Unpack : PDA-0-220G-cam_vpu2.img
Flash : PDA-0-220G-cam_vpu2.img
PROCESS : CAM_VPU3_A
Unpack : PDA-0-220G-cam_vpu3.img
Flash : PDA-0-220G-cam_vpu3.img
PROCESS : LK_A
Unpack : PDA-0-220G-0001-lk_service.img
Flash : PDA-0-220G-0001-lk_service.img
PROCESS : BOOT_A
Unpack : PDA-0-220G-00WW-boot.img
Flash : PDA-0-220G-00WW-boot.img
PROCESS : ODMDTBO_A
Unpack : PDA-0-220G-odmdtbo.img
Flash : PDA-0-220G-odmdtbo.img
PROCESS : TEE_A
Unpack : PDA-0-220G-tee.img
Flash : PDA-0-220G-tee.img
PROCESS : VENDOR_A
Unpack : PDA-0-220G-00WW-vendor.img
Flash : PDA-0-220G-00WW-vendor.img
PROCESS : SYSTEM_A
Unpack : PDA-0-220G-00WW-system.img
Flash : PDA-0-220G-00WW-system.img
PROCESS : USERDATA
Unpack : PDA-0-220G-0001-userdata.img
Flash : PDA-0-220G-0001-userdata.img
PMT Update : OK
Flashing finished!
Done!
Elapsed: 00:03:36
Regards
Ajay Gupta
Old 08-21-2020, 16:38   #1161 (permalink)
Member: 2643730
Thanks Meter: 1,104
NOKIA 3.1 PLUS(TA-1118) your device is corrupted , cannot be trusted FIX BY KING NK2
PTFN : MediaTek USB Port_V1632 (COM51)
MODE : BOOTROM
PORT : 51
BROM : Init BROM
BROM init passed!
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
BROM : BOOTROM
BROM : SOCID : 083B7679644D493E5EF24C2F9DB2448BA6763D4356E8D7CB28 E58C8B6C5BCEDE
AGENT : Found MT6765
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMMC: 90014A68423861503E014AA06C4BB5B1
EMMC:
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 9F932A3ACCE39FD92EFC5906F694C62A
Boot done!
Erase : 0x0000000000000000 : 0x0000000001688000
Erase : 0x0000000012584000 : 0x0000000000800000
Erase : 0x0000000013DA4000 : 0x0000000001800000
Erase : 0x00000000156A4000 : 0x0000000002000000
Erase : 0x0000000018000000 : 0x00000000DE000000
Erase : 0x00000000F6100000 : 0x0000000002000000
Erase : 0x00000000F9000000 : 0x000000019D800000
PMT Update : OK
Flashing now ...
PROCESS : PRELOADER
Unpack : ROO-0-124H-preloader_ROO.bin
Flash : ROO-0-124H-preloader_ROO.bin
PROCESS : LOGO_A
Unpack : ROO-0-124H-00WW-logo.bin
Flash : ROO-0-124H-00WW-logo.bin
PROCESS : MD1IMG_A
Unpack : ROO-0-124H-md1img.img
Flash : ROO-0-124H-md1img.img
PROCESS : SPMFW_A
Unpack : ROO-0-124H-spmfw.img
Flash : ROO-0-124H-spmfw.img
PROCESS : SCP_A
Unpack : ROO-0-124H-scp.img
Flash : ROO-0-124H-scp.img
PROCESS : SSPM_A
Unpack : ROO-0-124H-sspm.img
Flash : ROO-0-124H-sspm.img
PROCESS : LK_A
Unpack : ROO-0-124H-00WW-lk.img
Flash : ROO-0-124H-00WW-lk.img
PROCESS : BOOT_A
Unpack : ROO-0-124H-00WW-boot.img
Flash : ROO-0-124H-00WW-boot.img
PROCESS : ODMDTBO_A
Unpack : ROO-0-124H-odmdtbo.img
Flash : ROO-0-124H-odmdtbo.img
PROCESS : TEE_A
Unpack : ROO-0-124H-tee.img
Flash : ROO-0-124H-tee.img
PROCESS : VENDOR_A
Unpack : ROO-0-124H-00WW-vendor.img
Flash : ROO-0-124H-00WW-vendor.img
PROCESS : SYSTEM_A
Unpack : ROO-0-124H-00WW-system.img
Flash : ROO-0-124H-00WW-system.img
PROCESS : VBMETA_A
Unpack : ROO-0-124H-00WW-vbmeta.img
Flash : ROO-0-124H-00WW-vbmeta.img
PROCESS : USERDATA
Unpack : ROO-0-124H-00WW-userdata.img
Flash : ROO-0-124H-00WW-userdata.img
PMT Update : OK
Flashing finished!
Done!
Elapsed: 00:04:59
The Following 2 Users Say Thank You to djj007 For This Useful Post:
Old 08-23-2020, 11:00   #1162 (permalink)
Malik Shani G's Avatar
Member: 2963610
Thanks Meter: 507
Nokia 130 RM-1172 Phone Lock Reset Done
Card found : 27F73DA1 , v0122
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20
PTFN : MediaTek PreLoader USB VCOM Port (COM8)
PORT : 8
BROM : Init BROM
BROM init passed!
CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000
BROM : SECCFG : 0x00000007
BROM : MEID : D1A68CFA1EEFA15E58D029F7DAAC0C6C
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : DOHA.10.01.11.p1
BOOT : SWR : 10.01.11
AGENT : Found MT6260
AGENT : DOHA.10.01.11.p1
BOOT : DA sent
DA : Sync Passed!
DA : Agent : v03.02 on BBID : 0x8B
NOR: 00EF : 0060 : 0018 : 0000
NOR: [WINBOND] W25Q128FW
NOR:
TSIZE : 0x01000000 [ 16.00 MB ]
PSIZE : 0x01000000 [ 16.00 MB ]
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Info exists in MAUI : 0x00DC0000 : 0x00234000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:01:00
The Following 4 Users Say Thank You to Malik Shani G For This Useful Post:
Old 08-23-2020, 11:01   #1163 (permalink)
zeeshan ali 786's Avatar
Member: 2711874
Sonork: 100.650600
Thanks Meter: 460
nice.........................................
The Following User Says Thank You to zeeshan ali 786 For This Useful Post:
Old 08-23-2020, 11:03   #1164 (permalink)
Member: 2963610
Thanks Meter: 507
PORT : 8
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:01:00
Old 08-24-2020, 10:11   #1165 (permalink)
Member: 1555233
Thanks Meter: 2,192
Nokia 110 rm-827 full flash done
Card found: S/N : A9EC786B , v0144
Registered to: amjadnona
Connect phone on selected interface...
Core : v2.29 , BB5XG FlashEngine : v10.5
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm827__03.04.mcusw
PPM : rm827__03.04.ppm_m4
CNT : rm827__03.04.image_m4_059N407
Flashing phone now...
[Gen] Rules accepted for : XGOLD Generation
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" / Operation not start
-> Or if Phone start charge - just reinsert battery
-> If flashing freeze - reinsert cable/battery and try again
--- Press phone's power button or insert usb cable! ---
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len : 0x0A
IF xCPUID : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data : 1FB300020303010100FF
Sending EBL Loader ...
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.49_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
Check keys...
Check done. Image can be flashed
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 354138052161429
IMEI 2 : 354138052161437
PCcode : 059N2R0
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\354138052161429_XG 213_CRT.rpl
Settings : EDM [0x8] , Block Mode , Fast CRC , Verify
===Flashing [MCU]===
File : rm827__03.04.mcusw
Image : rm827__03.04.mcusw_ebl_psi.fls
Sec-pack found, sending ...
Sec-pack sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:01
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:05
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01940000
Erasing, wait ...
Erase done, time : 00:02:16
Write , Start : 0x40280000 , Len : 0x018C0000
Flashing , wait ...
Region flash done, time : 00:00:40
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
CRC check passed , 0x74A0
===Flashing [PPM]===
File : rm827__03.04.ppm_m4
Image : package_m4.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41BC0000 , Len : 0x00600000
Erasing, wait ...
Erase done, time : 00:00:17
Write , Start : 0x41BC0000 , Len : 0x00380998
Flashing , wait ...
Region flash done, time : 00:00:04
CRC check passed , 0xA432
===Flashing [CNT]===
File : rm827__03.04.image_m4_059N407
Image : package_m4_059N407.image.fls
Sec-pack sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x421C0000 , Len : 0x01C60000
Erasing, wait ...
Erase done, time : 00:04:06
Write , Start : 0x421C0000 , Len : 0x00DE0000
Flashing , wait ...
Region flash done, time : 00:00:22
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
Erase done, time : 00:00:07
No write data, skip
CRC check passed , 0xED62
Flashing done!
Total flash time : 00:08:06
Reboot phone now...
Reading Phone Info....
Connected phone - Nokia 110
Software Info: V 03.04 20-04-12 RM-827 (c) Nokia
IMEI: 354138052161429
PPM version : V 03.04 20-04-12 RM-827 (c) Nokia M4
Product code: 059N2R0
Wait, when phone will be ready ...
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Check and Upload User Certificates ...
Total - 42 certs
Certificates found, skip upload ...
AfterFlash operations done ;D
Done!
Elapsed: 00:08:49
Phone found!
Series 40 Device detected!
read info... - Ok
Read and Check phone data...
RAP_BOOT: 0000000000000000
RAP_PUB: 0000000000000000000000000000000000000000
CMT_ROOT: 00000000000000000000000000000000
RAP_PAPUB: 0000000000000000000000000000000000000000
Live Test Ok!
CNT sector : 128 kb
CMLA Key status : CMLA key is Ok
PA_SimLock Version :
PA_SL30 (20 digit) phone detected...
Phone disconected!
The Following 5 Users Say Thank You to amjadnona For This Useful Post:
Old 08-24-2020, 10:13   #1166 (permalink)
Member: 1555233
Thanks Meter: 2,192
Nokia 130 Phone Lock Reset Done
Card found : A9EC786B , v0122
PTFN : Nokia USB Serial Port (COM18)
PORT : 18
BROM : Init BROM
BROM init passed!
BROM : MEID : 4F10CFBFE00B8F50868C67B6CF6E5772
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : KESA61A.10.00.11.p2
AGENT : KESA61A.10.00.11.p2
BOOT : DA sent
DA : Sync Passed!
NOR: 00EF : 0060 : 0017 : 0000
NOR: [WINBOND] W25Q64DW
NOR:
TSIZE : 0x00800000 [ 8.00 MB ]
PSIZE : 0x00800000 [ 8.00 MB ]
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Info exists in MAUI : 0x00580000 : 0x00278000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:35
Old 08-24-2020, 10:15   #1167 (permalink)
Member: 1555233
Thanks Meter: 2,192
Nokia 105 ta-1034 full flash done
Open VPLfile : TA-1034_059Z107_30.04.11.vpl
Description : TA-1034 IJ
DeviceType : TA-1034
ProductCode : 059Z107
SoftwareVer : 30.04.11
PPM LangPack :
[1] : Urdu (Islamic Republic of Pakistan)
[2] : English (United Kingdom)
Load Ok!
Setting : UserData erase : True
PORT : 18
BROM : Init BROM
BROM init passed!
BROM : MEID : 6CE7B669CE2A5EE8C83CEEA5FD973F00
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : N103.30.04.11.p1
BOOT : SWR : 30.04.11
AGENT : N103.30.04.11.p1
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
VPL SoftwareVersion : 30.04.11 [TA-1034]
DEV SoftwareVersion : 30.04.11
Load FlashSet :
MROM : TA-1034_ROM_eMP_30.04.11
LANG : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001
CUST : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001
JUMP : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001
VIVA : TA-1034_VIVA_eMP_30.04.11
Prepare FlashSet :
DCR : TA-1034_ROM_eMP_30.04.11
DCR : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001
DCR : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001
DCR : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001
DCR : TA-1034_VIVA_eMP_30.04.11
Prepare Target
FFS Format Ok!
Erase Target Flash
Erase done!
Write Target Flash
Write : TA-1034_ROM_eMP_30.04.11
Write : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001
Write : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001
Write : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001
Write : TA-1034_VIVA_eMP_30.04.11
Write flash done!
Verify : TA-1034_ROM_eMP_30.04.11
Verify : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001
Verify : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001
Verify : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001
Verify : TA-1034_VIVA_eMP_30.04.11
Done!
Elapsed: 00:01:12
Old 08-24-2020, 10:21   #1168 (permalink)
Member: 1555233
Thanks Meter: 2,192
Nokia c2 rm-704 full flash done
MCU : rm704__03.99.mcusw
PPM : rm704__03.99.ppm_m_a
CNT : rm704__03.99.image_m_a_dgray_059K7P5
Check files done...
IF Boot Init : 0xF0
IF Resp Len : 0x0A
EBL Loader Ok, 01
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.44_M1S1
FLASHID : 89008289
Boot done!
Check keys...
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 352835051360066
IMEI 2 : 352835051360074
PCcode : 059C8J8
RPL saved : C:\InfinityBox\BEST\Backup\Cert\352835051360066_XG 213_CRT.rpl
File : rm704__03.99.mcusw
Image : rm704__03.99.mcusw_ebl_psi.fls
Sec-pack sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:02:13
Flashing , wait ...
Region flash done, time : 00:00:38
Erasing, wait ...
No write data, skip
CRC check passed , 0x6C69
File : rm704__03.99.ppm_m_a
Image : package_m_a.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Erasing, wait ...
Write , Start : 0x41BC0000 , Len : 0x0034C73C
Flashing , wait ...
CRC check passed , 0x6D09
File : rm704__03.99.image_m_a_dgray_059K7P5
Image : package_m_a_dgray_059K7P5.image.fls
Sec-pack sent
Found 2 region(s)
Erasing, wait ...
Erase done, time : 00:04:15
Write , Start : 0x421C0000 , Len : 0x00A00000
Flashing , wait ...
Region flash done, time : 00:00:16
Erasing, wait ...
No write data, skip
CRC check passed , 0xC239
Flashing done!
Total flash time : 00:08:02
Reboot phone now...
Connected phone - C2-00
Software Info: V 03.99 03-04-12 RM-704 (c) Nokia
IMEI: 352835051360066
PPM version : V 03.99 03-04-12 RM-704 (c) Nokia M_A
Product code: 059C8J8
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 42 certs
Battery voltage is enough for start
Done!
Elapsed: 00:09:12
Phone found!
read info... - Ok
Live Test Ok!
CNT sector : 128 kb
CMLA Key status : CMLA key Not exist
PA_SL3 phone , SP_CODE_LEN : 15
Phone disconected!
Old 08-24-2020, 10:26   #1169 (permalink)
Member: 1555233
Thanks Meter: 2,192
NOKIA 230 Phone Lock Reset Done
PORT : 18
BROM : Init BROM
BROM init passed!
BROM : MEID : C8E2B9C058AB631F9EB2183E4BA5D3D5
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : DOHA.13.00.11.p1
BOOT : SWR : 13.00.11
AGENT : DOHA.13.00.11.p1
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:01:53
Old 08-24-2020, 10:29   #1170 (permalink)
Member: 1555233
Thanks Meter: 2,192
Nokia 106 TA-1114 FULL FLASH DONE
Open VPLfile : TA-1114_059Z0X8_10.00.11.vpl
Description : TA-1114 IJ
DeviceType : TA-1114
ProductCode : 059Z0X8
SoftwareVer : 10.00.11
PPM LangPack :
Load Ok!
PORT : 18
BROM : Init BROM
BROM init passed!
BROM : MEID : BE51C55D39554C692E4CC09B9373938D
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
Load FlashSet :
Prepare FlashSet :
Prepare Target
Erase Target Flash
Erase done!
Write Target Flash
Write flash done!
Done!
Elapsed: 00:01:14
Page generated in 0.35079 seconds with 9 queries
