Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1171 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2011
Member: 1555233 Status: Offline Thanks Meter: 2,192 | NOKIA 216 RM-1187 Phone Lock Reset Done Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM18) MODE : NOKIA USB SERIAL PORT : 18 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : FB6C32E2ACE0886BC2846C7B0BBF2322 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : SUEZ.60.02.11.p1 BOOT : SWR : 60.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : SUEZ.60.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00CE0000 : 0x00314000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:42 Reconnect Power/Cable! |
The Following 5 Users Say Thank You to amjadnona For This Useful Post: |
![]() | #1172 (permalink) |
Junior Member ![]() ![]() Join Date: Aug 2020 Location: pakistan Age: 42
Member: 2964528 Status: Offline Thanks Meter: 105 | nokia 222 Phone Lock Reset Done Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM18) MODE : NOKIA USB SERIAL PORT : 18 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 1574CA1E2B2DCA5A639603E06A96D610 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : ROME.10.00.11.p2 BOOT : SWR : 10.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : ROME.10.00.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00E00000 : 0x001F4000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:44 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to NAJAABnajaa For This Useful Post: |
![]() | #1173 (permalink) |
Member: 2964528 Status: Offline Thanks Meter: 105 | Nokia 106 TA-1114 Phone Lock Reset Done Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM18) MODE : NOKIA USB SERIAL PORT : 18 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : BE51C55D39554C692E4CC09B9373938D BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.10.00.11.p2 BOOT : SWR : 10.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : NEMO61D.10.00.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00370000 : 0x00088000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:37 Reconnect Power/Cable! |
![]() | #1174 (permalink) |
Member: 2964528 Status: Offline Thanks Meter: 105 | nokia 105 ta 1034 Phone Lock Reset Done Card found : A9EC786B , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM18) MODE : NOKIA USB SERIAL PORT : 18 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM18) MODE : NOKIA USB SERIAL PORT : 18 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 855C5A60995A1C0803794FEF52BF4AD4 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.11.02.11.p1 BOOT : SWR : 11.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : RETRO.11.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00CD0000 : 0x00324000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:01:15 Reconnect Power/Cable! |
![]() | #1175 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2015 Location: Islam Age: 34
Member: 2371500 Status: Offline Thanks Meter: 5,469 | Nokia 106 (2018) TA-1114 remove lock code done Card found : Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Identify [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM191) MODE : NOKIA USB SERIAL PORT : 191 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 7C12B0C062C18BBFE43B00721B64D246 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.10.00.11.p2 BOOT : SWR : 10.00.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : NEMO61D.10.00.11.p2 FLASH : 00C2 : 0025 : 0036 : 0000 PRDC : 059Z0X8 NCK : 20 digits PROV : 24407000 Saved as : .mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:00:40 Reconnect Power/Cable! Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM191) MODE : NOKIA USB SERIAL PORT : 191 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 7C12B0C062C18BBFE43B00721B64D246 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.10.00.11.p2 BOOT : SWR : 10.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : NEMO61D.10.00.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00370000 : 0x00088000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! Last edited by profkefah; 08-27-2020 at 14:30. |
The Following 3 Users Say Thank You to profkefah For This Useful Post: |
![]() | #1176 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 676 | Nokia 105 format done Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM342) MODE : NOKIA USB SERIAL PORT : 342 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 15A4BC689134026EDBC230C37E2DB48F BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : LAGOS61D.10.01.11.p2 BOOT : SWR : 10.01.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : LAGOS61D.10.01.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00368000 : 0x00090000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:01:00 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Luckey1 For This Useful Post: |
![]() | #1177 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 676 | Nokia 150 format done Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM306) MODE : NOKIA USB SERIAL PORT : 306 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : A05B11C13ACD1FDEEC65B7314833FFED BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DUBAI61D.11.00.11.p1 BOOT : SWR : 11.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : DUBAI61D.11.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x003A0000 : 0x00058000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:03:46 Reconnect Power/Cable! |
![]() | #1178 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,722 | Nokia ta-1165 format done Card found : A6936825 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Identify [ v1.20 ] 1. Power off device, remove battery 2. Not hold any key on device! 3. Insert battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! PR_CODE : PROD_SN : A00000K150010501 BASE_SN : CODE_HW : IMEI[1] : XXXXXXXXXXXXXXX IMEI[2] : XXXXXXXXXXXXXXX Backup security data ... Security saved : NKSPDv2_XXXXXXXXXXXXXXX.scnv Done! Elapsed: 00:00:44 Reconnect Power/Cable! Operation : Reset Settings ( Format FS ) [ v1.20 ] Extra : FTM mode 1. Power off device, remove battery 2. Not hold any key on device! 3. Insert battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Erase BLK #0 Format Ok! Done! Elapsed: 00:00:50 Reconnect Power/Cable! |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
![]() | #1179 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2013 Location: gsmhosting Age: 28
Member: 1876736 Status: Offline Thanks Meter: 734 | nokia 5.1 plus imei repair done with best 2 Code: Operation : Repair Security [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM148) MODE : BOOTROM PORT : 148 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6755 AGENT : BEST_Nokia_DA_v19_1711_06 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100475836424D42032B76D24F253B EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GX6BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B3EDC358B0C4612B46E2455C71A7558 DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM296) MODE : PRELOADER PORT PORT : 296 Boot done! DEV SEC : IMEI[0] : yyyyyyyyyyyy IMEI[1] : yyyyyyyyyy NEW SEC : IMEI[0] : 35yyyyyyyyyy IMEI[1] : 35yyyyyyyyyyyy SECBLOCK: updated! Update SECURITY data ... Update SECURITY dependencies ... Update SECURITY dependencies ... Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to sky73 For This Useful Post: |
![]() | #1180 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2009
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 378 | nokia 3310 3G ta-1036 done. Card found : A7DA8130 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Identify [ v1.20 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! SW_VERS : 15.0.0.17.00 PC_EXTR : MX 059Z3V9 IMEI[1] : 357306083953091 IMEI[2] : 352751019523267 BT_ADDR : B9695465A390 Security saved : NKSPDv2_357306083953091.scnv Done! Elapsed: 00:00:36 Reconnect Power/Cable! Operation : Read UserCode [ v1.20 ] 1. Power off device, remove battery 2. Not hold any key on device! 3. Insert battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... Error : Boot Failed! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Reset Settings ( Format FS ) [ v1.20 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! Erase BLK #0 Erase BLK #1 Erase BLK #2 Erase BLK #3 Format Ok! Done! Elapsed: 00:00:47 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to wsmobile For This Useful Post: |
![]() | #1181 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: Sindh Pakistan
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,373 | ![]() Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM254) MODE : NOKIA USB SERIAL PORT : 254 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : F8EE82B2AA95F85873664BFEB50C5EDE BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : SUEZ.40.00.11.p1 BOOT : SWR : 40.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : SUEZ.40.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00CE0000 : 0x00314000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:52 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
![]() | #1182 (permalink) |
Member: 1555233 Status: Offline Thanks Meter: 2,192 | Nokia 150 rm-1190 full flash done Open VPLfile : RM-1190_059X975_11.00.11.vpl Description : RM-1190 059X975 IJ 11.00.11 DeviceType : RM-1190 ProductCode : 059X975 SoftwareVer : 11.00.11 PPM LangPack : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : False Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM62) MODE : NOKIA USB SERIAL PORT : 62 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 03B3E9DBB171855B9EF538CEC31B6945 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DUBAI61D.11.00.11.p1 BOOT : SWR : 11.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : DUBAI61D.11.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 11.00.11 [RM-1190] DEV SoftwareVersion : 11.00.11 SWInfo compare result : SAME Load FlashSet : MROM : RM-1190_DUBAI_ROM_eMP_11.00.11 LANG : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11 CUST : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11 JUMP : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11 VIVA : RM-1190_DUBAI_VIVA_eMP_11.00.11 Prepare FlashSet : DCR : RM-1190_DUBAI_ROM_eMP_11.00.11 DCR : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11 DCR : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11 DCR : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11 DCR : RM-1190_DUBAI_VIVA_eMP_11.00.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 Erase Target Flash Erase done! Write Target Flash Write : RM-1190_DUBAI_ROM_eMP_11.00.11 Write : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11 Write : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11 Write : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11 Write : RM-1190_DUBAI_VIVA_eMP_11.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1190_DUBAI_ROM_eMP_11.00.11 Verify : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11 Verify : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11 Verify : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11 Verify : RM-1190_DUBAI_VIVA_eMP_11.00.11 Done! Elapsed: 00:01:14 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to amjadnona For This Useful Post: |
![]() | #1183 (permalink) |
Member: 1555233 Status: Offline Thanks Meter: 2,192 | NOKIA 105 TA-1035 Phone Lock Reset Done Card found : A9EC786B , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM62) MODE : NOKIA USB SERIAL PORT : 62 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 3362CD72B30709FCA686DC0819DA20EC BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : CRYSTAL.10.01.11.p2 BOOT : SWR : 10.01.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : CRYSTAL.10.01.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0040 : 0016 : 0000 NOR: [WINBOND] W25Q32BV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x003A4000 : 0x00050000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:45 Reconnect Power/Cable! |
![]() | #1184 (permalink) |
Member: 1555233 Status: Offline Thanks Meter: 2,192 | NOKIA 215 Phone Lock Reset Done Card found : A9EC786B , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM62) MODE : NOKIA USB SERIAL PORT : 62 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : E8F94B68F6BBC633989E24F2279F1627 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : JET.12.03.11.p1 BOOT : SWR : 12.03.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : JET.12.03.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00C2 : 0025 : 0038 : 0000 NOR: [MXIC] MX25U12835FZNI_10G NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00E80000 : 0x00174000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
![]() | #1185 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2020 Location: pakistan daska Age: 28
Member: 2963610 Status: Offline Thanks Meter: 507 | nokia 105 RM- 1133 secreen lock reset done by infinity BEST nokia 105 RM- 1133 secreen lock reset done by infinity BEST ![]() |
The Following 2 Users Say Thank You to Malik Shani G For This Useful Post: |
