Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1232 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2015 Location: ISLAMIC WORLD Age: 32
Member: 2371500 Status: Offline Thanks Meter: 3,753 | Nokia 106 (2018) TA-1114 lock code reset done Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Identify [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM99) MODE : NOKIA USB SERIAL PORT : 99 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 163A7C00374214C4C8E1B72AA3AC3C52 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.10.00.11.p2 BOOT : SWR : 10.00.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : FLASH : 0000 : 0000 : 0000 : 0000 BBSN [RPL] : BBSN [DEV] : 163A7C00374214C4C8E1B72AA3AC3C52 -> Info : Device security area damaged! -> Info : Write RPL backup, if it exists! Done! Elapsed: 00:00:49 Reconnect Power/Cable! Operation : Identify [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM99) MODE : NOKIA USB SERIAL PORT : 99 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 163A7C00374214C4C8E1B72AA3AC3C52 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.10.00.11.p2 BOOT : SWR : 10.00.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : NEMO61D.10.00.11.p2 FLASH : 00C2 : 0025 : 0036 : 0000 PRDC : 059Z0X8 NCK : 20 digits PROV : 24407000 Saved as : 35.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:01:01 Reconnect Power/Cable! Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM99) MODE : NOKIA USB SERIAL PORT : 99 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 163A7C00374214C4C8E1B72AA3AC3C52 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.10.00.11.p2 BOOT : SWR : 10.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : NEMO61D.10.00.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00370000 : 0x00088000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to profkefah For This Useful Post: |
![]() | #1233 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2017 Location: Quelimane Mz Age: 22
Member: 2680008 Status: Offline Thanks Meter: 774 ![]() | ![]() Code: Card found : , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Load : C:\Users\HTCENTER95\Downloads\Compressed\ANT-0750-0-00WW-B03\ANT-0750-0-00WW-B03.nb0 Load Ok! Operation : Write FW [ v1.20 ] Setting : UserData preserve : False Setting : Flash Pre-Erase : True Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM15) MODE : PRELOADER PORT PORT : 15 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY BROM : PRELOADER PORT BROM : SOCID : 1E61EC6FCDF15C995CBBD6091824B3E8AC1EACDC065CED4BA3ECC03809BC1AFD AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6739 AGENT : BEST_Nokia_DA_v19_1711_06 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 150100464E36324D420348636A8B5669 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 55C354D56FF223DCBD0017877EEA7BBB DA : USB : HIGH-SPEED Boot done! DL_INFO : PMT present SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : HW verification passed! Erase : 0x0000000000000000 : 0x0000000002000000 Erase : 0x0000000002800000 : 0x0000000004000000 Erase : 0x0000000007800000 : 0x0000000000800000 Erase : 0x000000000B300000 : 0x0000000000800000 Erase : 0x000000000C440000 : 0x00000000003C0000 Erase : 0x000000000CA80000 : 0x0000000005200000 Erase : 0x0000000012180000 : 0x0000000000200000 Erase : 0x00000000123A0000 : 0x00000000B5C60000 PMT Update : OK Flashing now ... PROCESS : PRELOADER Unpack : ANT-0-0750-00WW-1-1-preloader_ANT.bin Flash : ANT-0-0750-00WW-1-1-preloader_ANT.bin Update bootloader backup copy ... Update bootloader backup copy Ok! PROCESS : RECOVERY Unpack : ANT-0-0750-00WW-1-1-recovery.img Flash : ANT-0-0750-00WW-1-1-recovery.img PROCESS : MD1IMG Unpack : ANT-0-0750-00WW-1-1-md1img.img Flash : ANT-0-0750-00WW-1-1-md1img.img PROCESS : MD1DSP Unpack : ANT-0-0750-00WW-1-1-md1dsp.img Flash : ANT-0-0750-00WW-1-1-md1dsp.img PROCESS : SPMFW Unpack : ANT-0-0750-00WW-1-1-spmfw.img Flash : ANT-0-0750-00WW-1-1-spmfw.img PROCESS : MCUPMFW Unpack : ANT-0-0750-00WW-1-1-mcupmfw.img Flash : ANT-0-0750-00WW-1-1-mcupmfw.img PROCESS : LK Unpack : ANT-0-0750-00WW-1-1-lk.img Flash : ANT-0-0750-00WW-1-1-lk.img PROCESS : LK2 Unpack : ANT-0-0750-00WW-1-1-lk.img Flash : ANT-0-0750-00WW-1-1-lk.img PROCESS : LOADER_EXT1 Unpack : ANT-0-0750-00WW-1-1-loader_ext.img Flash : ANT-0-0750-00WW-1-1-loader_ext.img PROCESS : LOADER_EXT2 Unpack : ANT-0-0750-00WW-1-1-loader_ext.img Flash : ANT-0-0750-00WW-1-1-loader_ext.img PROCESS : BOOT Unpack : ANT-0-0750-00WW-1-1-boot.img Flash : ANT-0-0750-00WW-1-1-boot.img PROCESS : LOGO Unpack : ANT-0-0750-00WW-1-1-logo.bin Flash : ANT-0-0750-00WW-1-1-logo.bin PROCESS : DTBO Unpack : ANT-0-0750-00WW-1-1-dtbo.img Flash : ANT-0-0750-00WW-1-1-dtbo.img PROCESS : TEE1 Unpack : ANT-0-0750-00WW-1-1-tee.img Flash : ANT-0-0750-00WW-1-1-tee.img PROCESS : TEE2 Unpack : ANT-0-0750-00WW-1-1-tee.img Flash : ANT-0-0750-00WW-1-1-tee.img PROCESS : VENDOR Unpack : ANT-0-0750-00WW-1-1-vendor.img Flash : ANT-0-0750-00WW-1-1-vendor.img PROCESS : SYSTEM Unpack : ANT-0-0750-00WW-1-1-system.img Flash : ANT-0-0750-00WW-1-1-system.img PROCESS : CACHE Unpack : ANT-0-0750-00WW-1-1-cache.img Flash : ANT-0-0750-00WW-1-1-cache.img PROCESS : USERDATA Unpack : ANT-0-0750-00WW-1-1-userdata.img Flash : ANT-0-0750-00WW-1-1-userdata.img PMT Update : OK SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 Flashing finished! Done! Elapsed: 00:04:30 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to yuranc8 For This Useful Post: |
