01-31-2021, 09:21 | #1246 (permalink) |
No Life Poster Join Date: Jul 2020 Location: pakistan daska Age: 29
Member: 2963610 Status: Offline Thanks Meter: 560 | nokia 205 hang on logo done by flashing infinity BEST |
The Following 2 Users Say Thank You to Malik Shani G For This Useful Post: |
01-31-2021, 09:21 | #1247 (permalink) |
Member: 2963610 Status: Offline Thanks Meter: 560 | nokia 205 hang on logo done by flashing infinity BEST nokia 205 hang on logo done by flashing infinity BEST |
02-02-2021, 11:50 | #1249 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 216 user code reset done Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM12) MODE : NOKIA USB SERIAL PORT : 12 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : AFBB744C29164A5DDE7ED667ACDECEE1 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DUBAI61D.40.00.11.p1 BOOT : SWR : 40.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : DUBAI61D.40.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x003A0000 : 0x00058000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Luckey1 For This Useful Post: |
02-10-2021, 16:14 | #1250 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Great India
Member: 1615596 Status: Offline Sonork: 100.160704? Thanks Meter: 760 | OPPO A15 [CPH2185] Format dONE... HW Report.. Code: Operation : HW Report [ v2.21 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM382) MODE : BOOTROM PORT : 382 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : CF97CE63120EF92257EDDE73797F9F6C BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : 26505C3C390560389240C6981B9E000D3AEE7AA1827617D1DF7A5D74CCA87883 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0005 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 90014A68423861503E030012367DA733 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 805515CA1402F77352FCE22CD67DAB0 DA : USB : HIGH-SPEED Boot done! Memory Info : CID : 90014A68423861503E030012367DA733 MEM : VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> DAT : Size: 29820 MB, Max.Speed: 52000 kHz, blklen(512), nblks(61071360), ro(0) EXT_CSD Info : EXT_CSD rev. : v1.8 ( MMC v5.1 ) CSD struct rev. : v1.2 Supported command sets : 1h HPI features : 1h BG operations support : 1h BG operations status : 0h Correct prg. sectors : 0h 1st init time after part. : 1000 ms Min. write perf.(DDR,52MH,8b): 0h Min. read perf. (DDR,52MH,8b): 0h TRIM timeout: 0 ms Secure feature support: 55h Secure erase timeout : 150000 ms Secure trim timeout : 150000 ms Access size : 3584 bytes HC erase unit size : 512 kbytes HC erase timeout : 600 ms HC write prot grp size: 8192 kbytes HC erase grp def. : 0h Reliable write sect count: 1h Sleep current (VCC) : 8h Sleep current (VCCQ): 9h Sleep/awake timeout : 419430400 ns Sector count : 3a3e000h Min. WR Perf. (52MH,8b): 78h Min. Read Perf.(52MH,8b): 8ch Min. WR Perf. (26MH,8b,52MH,4b): 46h Min. Read Perf.(26MH,8b,52MH,4b): 46h Min. WR Perf. (26MH,4b): 1eh Min. Read Perf.(26MH,4b): 1eh Power class: 0 Power class(DDR,52MH,3.6V): 0h Power class(DDR,52MH,1.9V): 0h Power class(26MH,3.6V) : 0h Power class(52MH,3.6V) : 0h Power class(26MH,1.9V) : 0h Power class(52MH,1.9V) : 0h Part. switch timing : 1h Out-of-INTR busy timing: ah Card type : 57h Command set : 0h Command set rev.: 0h HS timing : 0h Bus width : 0h Erase memory content : 0h Partition config : 48h Boot partition size : 4096 kbytes Boot information : 7h Boot config protection: 0h Boot bus width : 2h Boot area write prot : 0h User area write prot : 0h FW configuration : 0h RPMB size : 16384 kbytes Write rel. setting : 1fh Write rel. parameter: 15h Start background ops : 0h Enable background ops: 2h H/W reset function : 1h HPI management : 0h Max. enhanced area size : 747h (15261696 kbytes) Part. support : 7h Part. attribute: 0h Part. setting : 0h General purpose 1 size : 0h (0 kbytes) General purpose 2 size : 0h (0 kbytes) General purpose 3 size : 0h (0 kbytes) General purpose 4 size : 0h (0 kbytes) Enh. user area size : 0h (0 kbytes) Enh. user area start: 0h Bad block mgmt mode: 0h Overall status : MLC status : 0% - 10% used SLC status : Not defined EOL status : Normal ( Less than 80% reserved blocks used ) RPMB : RPMB KEY EXISTS! [State : NOT CLEAN : UNUSABLE] Done! Elapsed: 00:00:20 Code: Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM382) MODE : BOOTROM PORT : 382 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : CF97CE63120EF92257EDDE73797F9F6C BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : 26505C3C390560389240C6981B9E000D3AEE7AA1827617D1DF7A5D74CCA87883 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0005 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 90014A68423861503E030012367DA733 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 805515CA1402F77352FCE22CD67DAB0 DA : USB : HIGH-SPEED Boot done! Done! Elapsed: 00:00:23 Reconnect Power/Cable! SMART RESET... Code: Operation : Reset Settings/Format FS [ v2.21 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM382) MODE : BOOTROM PORT : 382 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : CF97CE63120EF92257EDDE73797F9F6C BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : 26505C3C390560389240C6981B9E000D3AEE7AA1827617D1DF7A5D74CCA87883 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0005 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 90014A68423861503E030012367DA733 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 805515CA1402F77352FCE22CD67DAB0 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825757 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:44 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to .::Gsm-Play::. For This Useful Post: |
02-12-2021, 13:56 | #1251 (permalink) |
Member: 2963610 Status: Offline Thanks Meter: 560 | nokia 130 rm-1035 hang on logo done by flashing infinity best |
02-23-2021, 08:11 | #1253 (permalink) |
No Life Poster Join Date: Jul 2006 Location: uk
Member: 306676 Status: Offline Thanks Meter: 148 | Nokia 3 [ TA-1032 ] firmware update successfully Nokia 3 [ TA-1032 ] firmware update successfully Code: Load :\N-3-Essential_NE1-5220-0-00WW-B02\NE1-5220-0-00WW-B02.nb0 Load Ok! Operation : Write FW [ v1.20 ] Setting : UserData preserve : False Setting : Flash Pre-Erase : True Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : BEST_Nokia_DA_v19_1711_06 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 13014E51324A39365210088417DEF70B DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 13014E51324A39365210088417DEC40B EMMC: VEN : MICRON | OEM : 4E01 | DEV : Q2J96R EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B14571B8199B47ABF68F5E1EB9792DFB STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! DL_INFO : PMT EMPTY! Update required! SEC_DL : False () SEC_ID : 0x00000000000000000000000000000000 [FL] : HW verification passed! Erase : 0x0000000001C80000 : 0x0000000005680000 Erase : 0x0000000009B20000 : 0x000000017D4E0000 PMT Update : Skip Flashing now ... PROCESS : PRELOADER Unpack : NE1-0-5220-00WW-preloader_NE1.bin Flash : NE1-0-5220-00WW-preloader_NE1.bin Update bootloader code ... Update bootloader Ok! PROCESS : LK Unpack : NE1-0-5220-00WW-lk.img Flash : NE1-0-5220-00WW-lk.img PROCESS : BOOT Unpack : NE1-0-5220-00WW-boot.img Flash : NE1-0-5220-00WW-boot.img PROCESS : RECOVERY Unpack : NE1-0-5220-00WW-recovery.img Flash : NE1-0-5220-00WW-recovery.img PROCESS : LOGO Unpack : NE1-0-5220-logo.bin Flash : NE1-0-5220-logo.bin PROCESS : SECRO Unpack : NE1-0-5220-secro.img Flash : NE1-0-5220-secro.img PROCESS : TEE1 Unpack : NE1-0-5220-tee.img Flash : NE1-0-5220-tee.img PROCESS : TEE2 Unpack : NE1-0-5220-tee.img Flash : NE1-0-5220-tee.img PROCESS : SYS_INFO Unpack : fver Flash : fver PROCESS : SUTINFO Unpack : NE1-00WW-001-sutinfo.img Flash : NE1-00WW-001-sutinfo.img PROCESS : SYSTEM Unpack : NE1-0-5220-00WW-system.img Flash : NE1-0-5220-00WW-system.img PROCESS : CACHE Unpack : NE1-0-5220-00WW-cache.img Flash : NE1-0-5220-00WW-cache.img PROCESS : USERDATA Unpack : NE1-0-5220-00WW-userdata.img Flash : NE1-0-5220-00WW-userdata.img PMT Update : Skip SEC_DL : False (CUST) SEC_ID : 0x03041013EE0E00F800F21212EF110DFC Flashing finished! Done! Elapsed: 00:06:50 Reconnect Power/Cable! |
The Following User Says Thank You to services_mobile For This Useful Post: |
02-24-2021, 09:04 | #1254 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | NOKIA TA-1203 READ CODE Done Code: Card found : 5C203D37 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Read UserCode [ v1.20 ] 1. Power off device, remove battery 2. Not hold any key on device! 3. Insert battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SW_VER : 20.00.17.03 LP_VER : ID 23KIG03ZA00 UserCode : 891002 Done! Elapsed: 00:01:15 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to yuranc8 For This Useful Post: |
03-11-2021, 06:33 | #1255 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 150 Operation : Write FirmWare [ v1.19 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM23) MODE : NOKIA USB SERIAL PORT : 23 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 41152EDEC373E1754E4C6D2D8F009220 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DUBAI61D.40.00.11.p1 BOOT : SWR : 40.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : DUBAI61D.40.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 40.00.11 [RM-1190] DEV SoftwareVersion : 40.00.11 SWInfo compare result : SAME Load FlashSet : MROM : RM-1190_ROM_eMP_40.00.11 LANG : RM-1190_LANG_PACK_ROM_IM_eMP_40.00.11_001 CUST : RM-1190_CUSTPACK_ROM_IM_eMP_40.00.11_001 JUMP : RM-1190_JUMP_TABLE_IM_eMP_40.00.11_001 VIVA : RM-1190_VIVA_eMP_40.00.11 Prepare FlashSet : DCR : RM-1190_ROM_eMP_40.00.11 DCR : RM-1190_LANG_PACK_ROM_IM_eMP_40.00.11_001 DCR : RM-1190_CUSTPACK_ROM_IM_eMP_40.00.11_001 DCR : RM-1190_JUMP_TABLE_IM_eMP_40.00.11_001 DCR : RM-1190_VIVA_eMP_40.00.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : RM-1190_ROM_eMP_40.00.11 Write : RM-1190_LANG_PACK_ROM_IM_eMP_40.00.11_001 Write : RM-1190_CUSTPACK_ROM_IM_eMP_40.00.11_001 Write : RM-1190_JUMP_TABLE_IM_eMP_40.00.11_001 Write : RM-1190_VIVA_eMP_40.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1190_ROM_eMP_40.00.11 Verify : RM-1190_LANG_PACK_ROM_IM_eMP_40.00.11_001 Verify : RM-1190_CUSTPACK_ROM_IM_eMP_40.00.11_001 Verify : RM-1190_JUMP_TABLE_IM_eMP_40.00.11_001 Verify : RM-1190_VIVA_eMP_40.00.11 Done! Elapsed: 00:01:25 Reconnect Power/Cable! |
03-18-2021, 04:15 | #1256 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | Reading Phone Info.... SW ver : V 03.60 11-12-13 RM-908 (c) Nokia IMEI : 355158069898804 PPM : V 03.60 11-12-13 RM-908 (c) Nokia MB PCode : 059R4D5 BPCode : 059V9B8 HWID : 1001 LCDVer : BYD:BEIHAIv83 ST7735R2 IMEI : 355158069898804 Sl Conf : 001-01-00000000000 Sl Prof : 000000000004000-2 Sl Aux : 000B0000 Hw Sig : 7CB361CEAD955ED4 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Done! Resetting selected items... Operating mode is OK, no need change... Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:03 |
The Following User Says Thank You to malka4u For This Useful Post: |
03-18-2021, 06:35 | #1257 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 106 Fullflash Done Open VPLfile : TA-1114_059Z0X8_10.00.11.vpl Description : TA-1114 IJ DeviceType : TA-1114 ProductCode : 059Z0X8 SoftwareVer : 10.00.11 PPM LangPack : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.19 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM23) MODE : NOKIA USB SERIAL PORT : 23 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 1A7C4C34BBF5398F6A1FD0607255A50C BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.10.00.11.p2 BOOT : SWR : 10.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : NEMO61D.10.00.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 10.00.11 [TA-1114] DEV SoftwareVersion : 10.00.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1114_ROM_eMP_10.00.11 LANG : TA-1114_LANG_PACK_ROM_IJ_eMP_10.00.11_001 CUST : TA-1114_CUSTPACK_ROM_IJ_eMP_10.00.11_001 JUMP : TA-1114_JUMP_TABLE_IJ_eMP_10.00.11_001 VIVA : TA-1114_VIVA_eMP_10.00.11 Prepare FlashSet : DCR : TA-1114_ROM_eMP_10.00.11 DCR : TA-1114_LANG_PACK_ROM_IJ_eMP_10.00.11_001 DCR : TA-1114_CUSTPACK_ROM_IJ_eMP_10.00.11_001 DCR : TA-1114_JUMP_TABLE_IJ_eMP_10.00.11_001 DCR : TA-1114_VIVA_eMP_10.00.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1114_ROM_eMP_10.00.11 Write : TA-1114_LANG_PACK_ROM_IJ_eMP_10.00.11_001 Write : TA-1114_CUSTPACK_ROM_IJ_eMP_10.00.11_001 Write : TA-1114_JUMP_TABLE_IJ_eMP_10.00.11_001 Write : TA-1114_VIVA_eMP_10.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1114_ROM_eMP_10.00.11 Verify : TA-1114_LANG_PACK_ROM_IJ_eMP_10.00.11_001 Verify : TA-1114_CUSTPACK_ROM_IJ_eMP_10.00.11_001 Verify : TA-1114_JUMP_TABLE_IJ_eMP_10.00.11_001 Verify : TA-1114_VIVA_eMP_10.00.11 Done! Elapsed: 00:01:09 Reconnect Power/Cable! |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
03-24-2021, 09:05 | #1258 (permalink) |
No Life Poster Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | Nokia TA-1203 Read User Code Done Operation : Identify [ v1.20 ] 1. Power off device, remove battery 2. Not hold any key on device! 3. Insert battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SW_VER : 20.00.17.03 LP_VER : MH PR_CODE : 23KIG03IN00 PROD_SN : 0786958PE BASE_SN : 31KIGM4000A CODE_HW : 1000 IMEI[1] : 35774XXXXXXXXX IMEI[2] : 35275XXXXXXXXX Backup security data ... Security saved : NKSPDv2_35774910XXXXXX.scnv Done! Elapsed: 00:00:33 Reconnect Power/Cable! Operation : Read UserCode [ v1.20 ] 1. Power off device, remove battery 2. Not hold any key on device! 3. Insert battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SW_VER : 20.00.17.03 LP_VER : MH UserCode : 44441 Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to 4G Telecom For This Useful Post: |
03-24-2021, 15:21 | #1259 (permalink) |
Junior Member Join Date: Sep 2015 Location: Nigeria
Member: 2457420 Status: Offline Thanks Meter: 2 | Nokia ta-1212 (5310-2020) reset done by BB5 Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 8 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 8D9220B0ECA91678D4CF9A0E4E6E3201 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
The Following 2 Users Say Thank You to oremejisolns For This Useful Post: |
04-03-2021, 16:30 | #1260 (permalink) |
Member: 1626780 Status: Offline Thanks Meter: 1,275 | nokia 1 dead recover done nokia 1 dead recovered done by change emmc and flash by best2 Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 79 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A0190613447383537A53247A38D36 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4G8 [eMMC] : FLASH_CID : 90014A483847346132A53735368D3547 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xA82DB6488D052003AA63220ACA3F8933 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read error! Erased or damaged FlashIC?! Force eMMC test by user request [Processing] FlashMemory Read-Write test [eMMC] : [HYNIX] , 2a4G8 , 0x1D2000000 , 7456 MiB [eMMC] : CID : 90014A483847346132A53735368D3547 [eMMC] : MODE : SQ-WR [FAILED : READONLY] : eMMC state seems as READ-ONLY !!!! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 76 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32364EC9C30342E9B1C6F2 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM26N [eMMC] : FLASH_CID : 150100464E36324D4203C3C9F2C675E9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xA82DB6488D052003AA63220ACA3F8933 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Processing] FlashMemory Read-Write test [eMMC] : [SAMSUNG] , BM26N , 0x1D2000000 , 7456 MiB [eMMC] : CID : 150100464E36324D4203C3C9F2C675E9 [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! All Done! Done! Elapsed: 00:00:40 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to malka4u For This Useful Post: |
