Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1261 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2016
Member: 2608490 Status: Offline Thanks Meter: 914 | ![]() Selected FlashSettings : FullFlash -> File : rm872__04.52.mcusw not found! Check it! -> File : rm872__04.52.ppm_mh1 not found! Check it! -> File : rm872__04.52.image_mh1_059Q317 not found! Check it! Check FlashFiles, Please, wait... Files Set for Flashing : Flashing phone now... [Gen] Rules accepted for : RAP3x Generation Check files done... -> SWversion check skipped : Dead mode selected -> [MCU] file NOT selected!!! You can Select: MCU, PPM, CNT, MCU+PPM, MCU+CNT, MCU+PPM+CNT... Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : FEBD2E18_rm872__04.52.mcusw PPM : CC7A91E4_rm872__04.52.ppm_mh1 CNT : 3099529F_rm872__04.52.image_mh1_059Q317 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 356456XXXXXXXX IMEI 2 : 356456XXXXXXXX PCcode : 059Q4M1 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\356456XXXXXXXXXXXX X_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : FEBD2E18_rm872__04.52.mcusw Image : rm872__04.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:00:50 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:30 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xFA4D ===Flashing [PPM]=== File : CC7A91E4_rm872__04.52.ppm_mh1 Image : package_mh1.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:11 Write , Start : 0x41A80000 , Len : 0x004DF5A8 Flashing , wait ... Region flash done, time : 00:00:05 CRC check passed , 0x4FC8 ===Flashing [CNT]=== File : 3099529F_rm872__04.52.image_mh1_059Q317 Image : package_mh1_059Q317.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:01:00 Write , Start : 0x42100000 , Len : 0x01140000 Flashing , wait ... Region flash done, time : 00:00:21 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0xA6FD Flashing done! Total flash time : 00:03:08 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 04.52 30-06-13 RM-872 (c) Nokia IMEI: 356456XXXXXXXXXX PPM version : V 04.52 30-06-13 RM-872 (c) Nokia MH1 Product code: 059Q4M1 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:16 |
The Following 2 Users Say Thank You to GSM AR For This Useful Post: |
![]() | #1262 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 678 | ![]() Operation : Write FirmWare [ v1.19 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM12) MODE : NOKIA USB SERIAL PORT : 12 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : E72573593B28E9412A400FAFFC7EB4B4 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DUBAI61D.40.00.11.p1 BOOT : SWR : 40.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : DUBAI61D.40.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 40.00.11 [RM-1190] DEV SoftwareVersion : 40.00.11 SWInfo compare result : SAME Load FlashSet : MROM : RM-1190_ROM_eMP_40.00.11 LANG : RM-1190_LANG_PACK_ROM_IM_eMP_40.00.11_001 CUST : RM-1190_CUSTPACK_ROM_IM_eMP_40.00.11_001 JUMP : RM-1190_JUMP_TABLE_IM_eMP_40.00.11_001 VIVA : RM-1190_VIVA_eMP_40.00.11 Prepare FlashSet : DCR : RM-1190_ROM_eMP_40.00.11 DCR : RM-1190_LANG_PACK_ROM_IM_eMP_40.00.11_001 DCR : RM-1190_CUSTPACK_ROM_IM_eMP_40.00.11_001 DCR : RM-1190_JUMP_TABLE_IM_eMP_40.00.11_001 DCR : RM-1190_VIVA_eMP_40.00.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : RM-1190_ROM_eMP_40.00.11 Write : RM-1190_LANG_PACK_ROM_IM_eMP_40.00.11_001 Write : RM-1190_CUSTPACK_ROM_IM_eMP_40.00.11_001 Write : RM-1190_JUMP_TABLE_IM_eMP_40.00.11_001 Write : RM-1190_VIVA_eMP_40.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1190_ROM_eMP_40.00.11 Verify : RM-1190_LANG_PACK_ROM_IM_eMP_40.00.11_001 Verify : RM-1190_CUSTPACK_ROM_IM_eMP_40.00.11_001 Verify : RM-1190_JUMP_TABLE_IM_eMP_40.00.11_001 Verify : RM-1190_VIVA_eMP_40.00.11 Done! Elapsed: 00:01:06 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Luckey1 For This Useful Post: |
![]() | #1263 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: Sindh Pakistan
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,384 | ![]() Operation : Reset Settings [ v1.19 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM23) MODE : NOKIA USB SERIAL PORT : 23 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 6B99ACBBFDF569B886507DFD38371BFA BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : OUTRUN.10.01.11.p1 BOOT : SWR : 10.01.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : OUTRUN.10.01.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00C8 : 0060 : 0018 : 0000 NOR: [GigaDevice] GD25LQ128 NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_NOT_SUPPORT STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00C40000 : 0x003B4000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:01:52 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
![]() | #1264 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,384 | ![]() Operation : Reset Settings [ v1.19 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM23) MODE : NOKIA USB SERIAL PORT : 23 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : BE6F73A60D2EFE58C228E045D9178C25 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.10.00.11.p2 BOOT : SWR : 10.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : NEMO61D.10.00.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00370000 : 0x00088000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
![]() | #1265 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,759 | Nokia 106 ta 1114 reset password done by best2 Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Identify [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM30) MODE : NOKIA USB SERIAL PORT : 30 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 82AD57E6D986244D5FA957C26A078117 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.10.00.11.p2 BOOT : SWR : 10.00.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : NEMO61D.10.00.11.p2 FLASH : 00C2 : 0025 : 0036 : 0000 PRDC : 059Z0X8 IMEI[1] : 357697108829427 IMEI[2] : 357711100109421 NCK : 20 digits PROV : 24407000 Saved as : 357697108829427.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:00:59 Reconnect Power/Cable! Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM30) MODE : NOKIA USB SERIAL PORT : 30 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 82AD57E6D986244D5FA957C26A078117 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.10.00.11.p2 BOOT : SWR : 10.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : NEMO61D.10.00.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00370000 : 0x00088000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to A.G.Shahid For This Useful Post: |
![]() | #1266 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,384 | ![]() Operation : Write FirmWare [ v1.19 ] Setting : UserData erase : False Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM7) MODE : NOKIA USB SERIAL PORT : 7 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 484B3F8F77CCD030F77C3E825AB754A0 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DUBAI61D.40.00.11.p1 BOOT : SWR : 40.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : DUBAI61D.40.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 40.00.11 [RM-1190] DEV SoftwareVersion : 40.00.11 SWInfo compare result : SAME Load FlashSet : MROM : RM-1190_ROM_eMP_40.00.11 LANG : RM-1190_LANG_PACK_ROM_IM_eMP_40.00.11_001 CUST : RM-1190_CUSTPACK_ROM_IM_eMP_40.00.11_001 JUMP : RM-1190_JUMP_TABLE_IM_eMP_40.00.11_001 VIVA : RM-1190_VIVA_eMP_40.00.11 Prepare FlashSet : DCR : RM-1190_ROM_eMP_40.00.11 DCR : RM-1190_LANG_PACK_ROM_IM_eMP_40.00.11_001 DCR : RM-1190_CUSTPACK_ROM_IM_eMP_40.00.11_001 DCR : RM-1190_JUMP_TABLE_IM_eMP_40.00.11_001 DCR : RM-1190_VIVA_eMP_40.00.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 Erase Target Flash Erase done! Write Target Flash Write : RM-1190_ROM_eMP_40.00.11 Write : RM-1190_LANG_PACK_ROM_IM_eMP_40.00.11_001 Write : RM-1190_CUSTPACK_ROM_IM_eMP_40.00.11_001 Write : RM-1190_JUMP_TABLE_IM_eMP_40.00.11_001 Write : RM-1190_VIVA_eMP_40.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1190_ROM_eMP_40.00.11 Verify : RM-1190_LANG_PACK_ROM_IM_eMP_40.00.11_001 Verify : RM-1190_CUSTPACK_ROM_IM_eMP_40.00.11_001 Verify : RM-1190_JUMP_TABLE_IM_eMP_40.00.11_001 Verify : RM-1190_VIVA_eMP_40.00.11 Done! Elapsed: 00:01:08 Reconnect Power/Cable! |
![]() | #1267 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,384 | ![]() Operation : Reset Settings [ v1.19 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM7) MODE : NOKIA USB SERIAL PORT : 7 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 5C6BE00C9C738CB462DD023BCCBBF559 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.30.04.11.p1 BOOT : SWR : 30.04.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.30.04.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00370000 : 0x00088000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:50 Reconnect Power/Cable! |
![]() | #1268 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,384 | ![]() Core : v2.29 , NXP FlashEngine : v6.0 Flash Mode : System Update (System , Boot) : Not Touch UserData Check and select files according selected FlashMode Ok, Set : RM1030_1.2.3.1_059V6Q7_IMEA_PK_variant.img Ok, Set : RM1030_1.2.3.1_boot.img Ok, Set : RM1030_1.2.3.1_cache.img Ok, Set : RM1030_1.2.3.1_emmc_appsboot.mbn Ok, Set : RM1030_1.2.3.1_emmc_appsboothd.mbn Ok, Set : RM1030_1.2.3.1_fat.bin Ok, Set : RM1030_1.2.3.1_oemsbl.mbn Ok, Set : RM1030_1.2.3.1_oemsblhd.mbn Ok, Set : RM1030_1.2.3.1_persist.img Ok, Set : RM1030_1.2.3.1_preload.img Ok, Set : RM1030_1.2.3.1_qcsbl.mbn Ok, Set : RM1030_1.2.3.1_qcsblhd_cfgdata.mbn Ok, Set : RM1030_1.2.3.1_recovery.img Ok, Set : RM1030_1.2.3.1_system.img Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : DDA7DA1F HWDetails : 0x000B , 0x0FC5 , 0x0081 , 0x0770 HWDetails : eMMC : VEN 15 , OEM : 0X100 , NAME : J5XWMB HWDetails : HW Revision V1 Processing : RM1030_1.2.3.1_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_qcsbl.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_oemsblhd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_oemsbl.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_1.2.3.1_emmc_appsboothd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_emmc_appsboot.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_1.2.3.1_boot.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_recovery.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_persist.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_fat.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_system.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_cache.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_preload.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_059V6Q7_IMEA_PK_variant.img Init Ok, send data ... Data sent, start flashing Region Flash Done Rebooting phone now Flashing done! Total flash time : 00:03:34 Reboot phone Ok Connect phone on selected interface... |
![]() | #1269 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2021 Location: daska Age: 29
Member: 2992853 Status: Offline Sonork: 100.650600 Thanks Meter: 60 | nokia 105 TA-1034 password reset done nokia 105 TA-1034 password reset done ![]() |
The Following 2 Users Say Thank You to malik zeshan For This Useful Post: |
![]() | #1271 (permalink) |
Member: 2992853 Status: Offline Sonork: 100.650600 Thanks Meter: 60 | nokia 220 RM-969 hang on logo fix by flash nokia 220 RM-969 hang on logo fix by flash ![]() |
![]() | #1273 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,203 | Nokia XL rm-1030 flash done Code: Core : v2.29 , NXP FlashEngine : v6.0 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM1030_V2_1.2.3.21_059W180_IMEA_AE_V2_variant.img Ok, Set : RM1030_V2_1.2.3.21_boot.img Ok, Set : RM1030_V2_1.2.3.21_cache.img Ok, Set : RM1030_V2_1.2.3.21_emmc_appsboot.mbn Ok, Set : RM1030_V2_1.2.3.21_emmc_appsboothd.mbn Ok, Set : RM1030_V2_1.2.3.21_fat.bin Ok, Set : RM1030_V2_1.2.3.21_oemsbl.mbn Ok, Set : RM1030_V2_1.2.3.21_oemsblhd.mbn Ok, Set : RM1030_V2_1.2.3.21_persist.img Ok, Set : RM1030_V2_1.2.3.21_preload.img Ok, Set : RM1030_V2_1.2.3.21_qcsbl.mbn Ok, Set : RM1030_V2_1.2.3.21_qcsblhd_cfgdata.mbn Ok, Set : RM1030_V2_1.2.3.21_recovery.img Ok, Set : RM1030_V2_1.2.3.21_system.img Ok, Set : RM1030_V2_1.2.3.21_udisk.bin Ok, Set : RM1030_V2_1.2.3.21_userdata.img Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : E803CED5 HWDetails : 0x000B , 0x0FC5 , 0x0081 , 0x077C HWDetails : eMMC : VEN 15 , OEM : 0X100 , NAME : J5XWMB HWDetails : HW Revision V2 Processing : RM1030_V2_1.2.3.21_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_qcsbl.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_oemsblhd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_oemsbl.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_V2_1.2.3.21_emmc_appsboothd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_emmc_appsboot.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_V2_1.2.3.21_boot.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_recovery.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_persist.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_fat.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_system.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_cache.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_userdata.img Erase Partition : USERDATA Partition Erase Done Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_udisk.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_preload.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_059W180_IMEA_AE_V2_variant.img Init Ok, send data ... Data sent, start flashing Region Flash Done Rebooting phone now Flashing done! Total flash time : 00:03:59 Reboot phone Ok Connect phone on selected interface... Phone found! Nokia X Platform Phone detected (ADB) Read info... Ok |
The Following 2 Users Say Thank You to mbiborna For This Useful Post: |
![]() | #1274 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 678 | Nokia 206 fullflash done Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm872__04.52.mcusw PPM : rm872__04.52.ppm_m2 CNT : rm872__04.52.image_m2_059Q4L5 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 356724055562206 IMEI 2 : 356724055562214 PCcode : 059Q4J7 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\356724055562206_2n d_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm872__04.52.mcusw Image : rm872__04.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:06 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:02:23 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:29 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xFA4D ===Flashing [PPM]=== File : rm872__04.52.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:22 Write , Start : 0x41A80000 , Len : 0x003C68F0 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xC9E6 ===Flashing [CNT]=== File : rm872__04.52.image_m2_059Q4L5 Image : package_m2_059Q4L5.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:02:04 Write , Start : 0x42100000 , Len : 0x01040000 Flashing , wait ... Region flash done, time : 00:00:29 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip CRC check passed , 0x7399 Flashing done! Total flash time : 00:06:12 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 04.52 30-06-13 RM-872 (c) Nokia IMEI: 356724055562206 PPM version : V 04.52 30-06-13 RM-872 (c) Nokia M2 Product code: 059Q4J7 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:07:13 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following User Says Thank You to Luckey1 For This Useful Post: |
![]() | #1275 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 678 | Nokia 150 full flash done Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM14) MODE : NOKIA USB SERIAL PORT : 14 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : F0D9DD56C7DB297F9327207F391FF984 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DUBAI61D.30.00.11.p1 BOOT : SWR : 30.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : DUBAI61D.30.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 30.00.11 [RM-1190] DEV SoftwareVersion : 30.00.11 SWInfo compare result : SAME Load FlashSet : MROM : RM-1190_DUBAI_ROM_eMP_30.00.11 LANG : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_30.00.11 CUST : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_30.00.11 JUMP : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_30.00.11 VIVA : RM-1190_DUBAI_VIVA_eMP_30.00.11 Prepare FlashSet : DCR : RM-1190_DUBAI_ROM_eMP_30.00.11 DCR : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_30.00.11 DCR : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_30.00.11 DCR : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_30.00.11 DCR : RM-1190_DUBAI_VIVA_eMP_30.00.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : RM-1190_DUBAI_ROM_eMP_30.00.11 Write : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_30.00.11 Write : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_30.00.11 Write : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_30.00.11 Write : RM-1190_DUBAI_VIVA_eMP_30.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1190_DUBAI_ROM_eMP_30.00.11 Verify : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_30.00.11 Verify : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_30.00.11 Verify : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_30.00.11 Verify : RM-1190_DUBAI_VIVA_eMP_30.00.11 Done! Elapsed: 00:01:12 Reconnect Power/Cable! |
