Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 05-26-2022, 08:31   #1306 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,746
Nokia 105 TA 1034 Reset Password Done By Best2
Card found : 30C22462 , v0122
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20
Operation : Reset Settings [ v1.20 ]
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : Nokia USB Serial Port (COM12)
MODE : NOKIA USB SERIAL
PORT : 12
BROM : Init BROM
BROM init passed!
CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001
BROM : SECCFG : 0x00000007
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : 7C3EEBE4C30E45EE0978EC6565B62BD0
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : N103.10.02.11.p1
BOOT : SWR : 10.02.11
AGENT : Look for suitable BootChain in DA ...
AGENT : DEFAULT AUTO
AGENT : Found MT6261
AGENT : N103.10.02.11.p1
BOOT : Sending 1st DA ...
BOOT : DA sent
BOOT : Transfer control to DA ...
DA : Sync Passed!
DA : Authentification pass!
DA : Agent : v03.02 on BBID : 0x8E
NOR: 00C2 : 0020 : 0016 : 0000
NOR: [MXIC] MX25L3291FWJI_09
NOR:
TSIZE : 0x00400000 [ 4.00 MB ]
PSIZE : 0x00400000 [ 4.00 MB ]
STYPE : 0x00000000
FLOTP : DA_NOR_OTP_EXIST
STATUS : OK
BSTYLE : SF_FLASH_BOOT
Boot done!
FFS Info exists in MAUI : 0x00370000 : 0x00088000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:20
Reconnect Power/Cable!
The Following User Says Thank You to A.G.Shahid For This Useful Post:
Old 05-29-2022, 12:18   #1307 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 676
Rm-1190
Operation : Write FirmWare [ v1.20 ]
Setting : UserData erase : True
Setting : LangPack Only : False
PTFN : Nokia USB Serial Port (COM19)
PORT : 19
BROM : Init BROM
BROM init passed!
BROM : SECCFG : 0x00000005
BROM : MEID : FB0C9937E9CFAA96BAE9F02E38E8BB7E
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : DUBAI61D.50.00.11.p1
BOOT : SWR : 50.00.11
AGENT : DUBAI61D.50.00.11.p1
BOOT : DA sent
DA : Sync Passed!
NOR: 00EF : 0070 : 0016 : 0000
NOR: [Winbond] SF_W25Q32JV
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
VPL SoftwareVersion : 50.00.11 [RM-1190]
DEV SoftwareVersion : 50.00.11
SWInfo compare result : SAME
Load FlashSet :
MROM : RM-1190_ROM_eMP_50.00.11
LANG : RM-1190_LANG_PACK_ROM_IC_eMP_50.00.11_001
CUST : RM-1190_CUSTPACK_ROM_IC_eMP_50.00.11_001
JUMP : RM-1190_JUMP_TABLE_IC_eMP_50.00.11_001
VIVA : RM-1190_VIVA_eMP_50.00.11
Prepare FlashSet :
DCR : RM-1190_ROM_eMP_50.00.11
DCR : RM-1190_LANG_PACK_ROM_IC_eMP_50.00.11_001
DCR : RM-1190_CUSTPACK_ROM_IC_eMP_50.00.11_001
DCR : RM-1190_JUMP_TABLE_IC_eMP_50.00.11_001
DCR : RM-1190_VIVA_eMP_50.00.11
Prepare Target
SDS : OK : 0x003F8000 : 0x00008000
FFS Format Ok!
Erase Target Flash
Erase done!
Write Target Flash
Write : RM-1190_ROM_eMP_50.00.11
Write : RM-1190_LANG_PACK_ROM_IC_eMP_50.00.11_001
Write : RM-1190_CUSTPACK_ROM_IC_eMP_50.00.11_001
Write : RM-1190_JUMP_TABLE_IC_eMP_50.00.11_001
Write : RM-1190_VIVA_eMP_50.00.11
Write done, waiting target response ...
Write flash done!
Verify Target FlashContent
Verify : RM-1190_ROM_eMP_50.00.11
Verify : RM-1190_LANG_PACK_ROM_IC_eMP_50.00.11_001
Verify : RM-1190_CUSTPACK_ROM_IC_eMP_50.00.11_001
Verify : RM-1190_JUMP_TABLE_IC_eMP_50.00.11_001
Verify : RM-1190_VIVA_eMP_50.00.11
Done!
Elapsed: 00:01:07
The Following User Says Thank You to Luckey1 For This Useful Post:
Old 06-03-2022, 17:23   #1308 (permalink)
yuslamunique's Avatar
Member: 2993572
Thanks Meter: 155
Old is gold! Nokia 5310 [ta-1212] security code done by infinity best
Card found: S/N : A6936825 , v0153
Registered to: yuslamuique
Connect phone on selected interface...
Dead Mode is Selected
Waiting for USB device...
1. Phone should be Off!
2. Battery must be charged and inserted! ( if not used external power )
- > If phone can't switch to BL - use battery or flash from Local mode!
--- Insert USB cable now! ---
Wait for phone...
Phone found! [ 75 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0001
BB_CPU_SN : D29ECC66CE02A5A658BB922E982686D0
BROM Protocol Version : 05
BROM Status : 0000
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
MT626x : Reset User Code
All done! Remove USB cable
All Security Settings deactivated!
Code set to default : 12345
Done!
The Following 2 Users Say Thank You to yuslamunique For This Useful Post:
Old 06-05-2022, 17:19   #1309 (permalink)
raza400's Avatar
Member: 1661953
Sonork: 100.1666694
Thanks Meter: 1,373
nokia 6500c unlock done by one & only great best dongle
Phone found!
Series 40 Device detected!
read info...  - Ok
Unlock procedure started...
Phone Imei: 353099027959233
Checking locks...
Conf key     : 8000000000000000
Provider key : 2382000000000000
Country      : Denmark
Operator     : TELIA DK
Counters     : Key 0  [3] , Fbus 0  [10]
Blocks       : 12
LOCK STATUS :
BLK : 1
 Lock1:Close
BLK : 2
 Lock1:Close
BLK : 3
 Lock1:Close
BLK : 4
 Lock1:Close
BLK : 5
 Lock1:Close
BLK : 6
 Lock1:Close
BLK : 7
 Lock1:Close
BLK : 8
 Lock1:Close
BLK : 9
 Lock1:Close
BLK : 10
 Lock1:Close
BLK : 11
 Lock1:Close
BLK : 12
 Lock1:Close
LOCKS :  Closed
PA_SL2 phone detected...
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT ASICID   : 000000010000022600010006010C192101003000
CMT EM0 ID  : 00000295
CMT EM1 ID  : 00000B22
CMT PUB ID  : 171002125B750254F5767B9444B0FD2E68CAF6FC
CMT MODE ID : 00
CMT R_HASH  : BAF3A9C3DBFA8454937DB77F2B8852B1
CMT ROM ID  : 273F6D55DFAAF68F
CMT : Sending 2nd loader...
CMT Loader sent, Boot Ok
rap= 171002125B750254F5767B9444B0FD2E68CAF6FC
hash= BAF3A9C3DBFA8454937DB77F2B8852B1
key= C1F345263576404B20E0268534D681C536F2DA1F
Init Service mode... Wait...
Key file updated...
Using F-bus count...
Sending code 766092008306072 Level : 7 to SimLock Server...
Simlock Server Answer: Unlock code Accepted! :)
Unlock Done!
Phone disconected!
br Raza400
The Following User Says Thank You to raza400 For This Useful Post:
Old 06-14-2022, 10:09   #1310 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,373
Smile Nokia 108 RM-944 FullFlash Done
Open VPLfile : RM944_059S7R0_20.06.11_013.vpl
Description : MEA IJ URDU PK
DeviceType : RM-944
ProductCode : 059S7R0
SoftwareVer : 20.06.11
Load Ok!
PTFN : MediaTek PreLoader USB VCOM Port (COM15)
PORT : 15
BROM : Init BROM
BROM init passed!
CHIP : MT625A , SBID : 0xCA01 , HWVR : 0x8000 , SWVR : 0x0001
BROM : MEID : BBF7E6A4B5EF26FBD7788B0DEF69751C
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : Bree.20.06.11.p4
BOOT : SWR : 20.06.11
AGENT : Found MT625A
AGENT : Bree.20.06.11.p4
BOOT : DA sent
DA : Sync Passed!
DA : Agent : v03.02 on BBID : 0x88
NOR: 00EF : 0040 : 0016 : 0000
NOR: [WINBOND] W25Q32BV
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
VPL SoftwareVersion : 20.06.11 [RM-944]
DEV SoftwareVersion : 20.06.11
Load FlashSet :
MROM : RM-944_ROM_eMP_20.06.11
LANG : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11
CUST : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11
JUMP : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11
VIVA : RM-944_VIVA_eMP_20.06.11
Prepare FlashSet :
DCR : RM-944_ROM_eMP_20.06.11
DCR : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11
DCR : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11
DCR : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11
DCR : RM-944_VIVA_eMP_20.06.11
Prepare Target
SDS : OK : 0x003F4000 : 0x0000C000
FFS Format Ok!
CBR : 0x00000019:0x00000001:0x00000000:0x00000000:0x0000 0010:0x00000002:0x00000000
Erase Target Flash
Erase done!
Write Target Flash
Write : RM-944_ROM_eMP_20.06.11
Write : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11
Write : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11
Write : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11
Write : RM-944_VIVA_eMP_20.06.11
Write flash done!
Verify : RM-944_ROM_eMP_20.06.11
Verify : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11
Verify : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11
Verify : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11
Verify : RM-944_VIVA_eMP_20.06.11
Done!
Elapsed: 00:03:41
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 06-30-2022, 10:48   #1311 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,746
Nokia 150 Full Flash Done By BEST2
Operation : Identify [ v1.20 ]
PTFN : Nokia USB Serial Port (COM21)
PORT : 21
BROM : Init BROM
BROM init passed!
BROM : MEID : 4188F59BCAF47190EC073E647DB4AA5B
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : BDDS : 30
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
SWVer : DUBAI61D.50.00.11.p1
FLASH : 00C2 : 0025 : 0036 : 0000
PRDC : 059Z0X8
IMEI[1] :
IMEI[2] :
NCK : 20 digits
PROV : 24407000
Saved as : 3576931xxxxxxxx.mtsec
Saved to : C:\InfinityBox\BEST2\Backup\
Done!
Elapsed: 00:00:59
Open VPLfile : RM-1190_059Z0X8_50.00.11.vpl
Description : RM-1190 IC
DeviceType : RM-1190
ProductCode : 059Z0X8
SoftwareVer : 50.00.11
PPM LangPack :
[1] : Arabic (Saudi Arabia)
[2] : French (France)
[3] : English (United Kingdom)
Load Ok!
PORT : 21
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
Load FlashSet :
Prepare FlashSet :
Prepare Target
FFS Format Ok!
Erase Target Flash
Erase done!
Write Target Flash
Write flash done!
Done!
Elapsed: 00:01:11
Old 07-04-2022, 07:10   #1312 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Nokia 206 FullFlash Done
Core : v2.29 , BB5XG FlashEngine : v10.5
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm872__04.52.mcusw
PPM : rm872__04.52.ppm_m2
CNT : rm872__04.52.image_m2_059Q4L5
Flashing phone now...
[Gen] Rules accepted for : XGOLD Generation
Check files done...
-> SWversion check skipped : Dead mode selected
-> If Windows say "Unrecognized device" / Operation not start
-> Or if Phone start charge - just reinsert battery
-> If flashing freeze - reinsert cable/battery and try again
--- Press phone's power button or insert usb cable! ---
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len : 0x0A
IF xCPUID : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data : 1FB300020303010100FF
Sending EBL Loader ...
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.53_M1S1
Speed accepted, use 6.500.000
FLASHID : EC001230
FLIC conf set, RST set
Boot done!
Check keys...
Check done. Image can be flashed
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 355153068672144
IMEI 2 : 355153068672151
PCcode : 059R6D9
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\355153068672144_XG 213_CRT.rpl
Settings : EDM [0x8] , Block Mode , Fast CRC , Verify
===Flashing [MCU]===
File : rm872__04.52.mcusw
Image : rm872__04.52.mcusw_ebl_psi.fls
Sec-pack found, sending ...
Sec-pack sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:02
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01800000
Erasing, wait ...
Erase done, time : 00:00:47
Write , Start : 0x40280000 , Len : 0x01800000
Flashing , wait ...
Region flash done, time : 00:00:34
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
CRC check passed , 0xFA4D
===Flashing [PPM]===
File : rm872__04.52.ppm_m2
Image : package_m2.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41A80000 , Len : 0x00680000
Erasing, wait ...
Erase done, time : 00:00:08
Write , Start : 0x41A80000 , Len : 0x003C68F0
Flashing , wait ...
Region flash done, time : 00:00:05
CRC check passed , 0xC9E6
===Flashing [CNT]===
File : rm872__04.52.image_m2_059Q4L5
Image : package_m2_059Q4L5.image.fls
Sec-pack sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x42100000 , Len : 0x01D20000
Erasing, wait ...
Erase done, time : 00:01:03
Write , Start : 0x42100000 , Len : 0x01040000
Flashing , wait ...
Region flash done, time : 00:00:23
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
No write data, skip
CRC check passed , 0x7399
Flashing done!
Total flash time : 00:03:10
Reboot phone now...
Reading Phone Info....
Connected phone - 206
Software Info: V 04.52 30-06-13 RM-872 (c) Nokia
IMEI: 355153068672144
PPM version : V 04.52 30-06-13 RM-872 (c) Nokia M2
Product code: 059R6D9
Wait, when phone will be ready ...
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Check and Upload User Certificates ...
Total - 58 certs
Certificates found, skip upload ...
AfterFlash operations done ;D
Done!
Elapsed: 00:03:56
Phone found!
read info... - Ok
Phone disconected!
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post:
Old 07-08-2022, 07:14   #1313 (permalink)
Member: 953334
Sonork: 100.1614005
DeviceType : RM-944
Load Ok!
PORT : 15
BROM : Init BROM
BROM init passed!
BROM : MEID : 2184E8E4D223F2BAD359566A8B4F75BD
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : Bree.11.01.11.p1
BOOT : SWR : 11.01.11
AGENT : Bree.11.01.11.p1
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
DEV SoftwareVersion : 11.01.11
SWInfo compare result : DEVICE SW ( Major version ) is LOWER, than in VPL!
Load FlashSet :
Prepare FlashSet :
Prepare Target
FFS Format Ok!
Erase Target Flash
Erase done!
Write Target Flash
Write flash done!
Done!
Elapsed: 00:01:30
Old 09-13-2022, 08:20   #1314 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Nokia 105
Operation : Reset Settings ( Format FS ) [ v1.20 ]
Extra : FTM mode
1. Power off device, remove battery
2. Not hold any key on device!
3. Insert battery in device!
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
SVC : DiagChannel opened!
Boot Done!
Erase BLK #0
Format Ok!
Done!
Elapsed: 00:00:09
Old 09-27-2022, 07:32   #1315 (permalink)
Member: 953334
Sonork: 100.1614005
Check files done...
IF Boot Init : 0xF0
IF Resp Len : 0x0A
EBL Loader Ok, 01
Sending EBL ...
EBL sent Ok
FLASHID : 89008289
Boot done!
Check keys...
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 357298050805505
IMEI 2 : 357298050805513
PCcode : 059S8K5
RPL saved : C:\InfinityBox\BEST\Backup\Cert\357298050805505_XG 213_CRT.rpl
Sec-pack sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:00:05
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:02:09
Flashing , wait ...
Erasing, wait ...
No write data, skip
Sec-pack sent
Found 1 region(s)
Erasing, wait ...
Erase done, time : 00:00:21
Flashing , wait ...
Sec-pack sent
Found 2 region(s)
Erasing, wait ...
Erase done, time : 00:04:06
Flashing , wait ...
Region flash done, time : 00:00:25
Erasing, wait ...
Erase done, time : 00:00:07
No write data, skip
Flashing done!
Total flash time : 00:08:00
Reboot phone now...
IMEI: 357298050805505
Product code: 059S8K5
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 58 certs
Done!
Elapsed: 00:09:20
Old 10-11-2022, 09:47   #1316 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Ta-1114
Open VPLfile : TA-1114_059Z0X8_10.00.11.vpl
Description : TA-1114 IC
DeviceType : TA-1114
SoftwareVer : 10.00.11
PPM LangPack :
[2] : Portuguese (Portugal)
[3] : French (France)
[4] : English (United Kingdom)
Load Ok!
PTFN : Nokia USB Serial Port (COM13)
PORT : 13
BROM : Init BROM
BROM init passed!
BROM : MEID : 3175AADB04AC54F600BBBF734FC285EB
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : NEMO61D.10.00.11.p2
BOOT : SWR : 10.00.11
AGENT : NEMO61D.10.00.11.p2
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
VPL SoftwareVersion : 10.00.11 [TA-1114]
DEV SoftwareVersion : 10.00.11
Load FlashSet :
MROM : TA-1114_ROM_eMP_10.00.11
LANG : TA-1114_LANG_PACK_ROM_IC_eMP_10.00.11_001
CUST : TA-1114_CUSTPACK_ROM_IC_eMP_10.00.11_001
JUMP : TA-1114_JUMP_TABLE_IC_eMP_10.00.11_001
VIVA : TA-1114_VIVA_eMP_10.00.11
Prepare FlashSet :
DCR : TA-1114_ROM_eMP_10.00.11
DCR : TA-1114_LANG_PACK_ROM_IC_eMP_10.00.11_001
DCR : TA-1114_CUSTPACK_ROM_IC_eMP_10.00.11_001
DCR : TA-1114_JUMP_TABLE_IC_eMP_10.00.11_001
DCR : TA-1114_VIVA_eMP_10.00.11
Prepare Target
FFS Format Ok!
Erase Target Flash
Erase done!
Write Target Flash
Write : TA-1114_ROM_eMP_10.00.11
Write : TA-1114_LANG_PACK_ROM_IC_eMP_10.00.11_001
Write : TA-1114_CUSTPACK_ROM_IC_eMP_10.00.11_001
Write : TA-1114_JUMP_TABLE_IC_eMP_10.00.11_001
Write : TA-1114_VIVA_eMP_10.00.11
Write flash done!
Verify : TA-1114_ROM_eMP_10.00.11
Verify : TA-1114_LANG_PACK_ROM_IC_eMP_10.00.11_001
Verify : TA-1114_CUSTPACK_ROM_IC_eMP_10.00.11_001
Verify : TA-1114_JUMP_TABLE_IC_eMP_10.00.11_001
Verify : TA-1114_VIVA_eMP_10.00.11
Done!
Elapsed: 00:01:00
Old 10-30-2022, 14:02   #1317 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Nokia 216
PTFN : Nokia USB Serial Port (COM18)
PORT : 18
BROM : Init BROM
BROM init passed!
BROM : MEID : ACBFF153BB6A546E4FFB16AAD06982C2
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Info exists in MAUI : 0x003A0000 : 0x00058000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:19
Old 01-08-2023, 12:00   #1318 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 676
Nokia 105 spd reset done
Extra : FTM mode
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
Boot Done!
Erase BLK #0
Format Ok!
Done!
Elapsed: 00:00:21
Old 01-08-2023, 13:19   #1319 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 676
Nokia 210 reset done
PORT : 18
BROM : Init BROM
BROM init passed!
CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000
BROM : MEID : 1939801212C1A8B4E898703144954DB1
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : OUTRUN.10.01.11.p1
BOOT : SWR : 10.01.11
AGENT : Found MT6260
AGENT : OUTRUN.10.01.11.p1
BOOT : DA sent
DA : Sync Passed!
DA : Agent : v03.02 on BBID : 0x8B
NOR: 00C8 : 0060 : 0018 : 0000
NOR: [GigaDevice] GD25LQ128
NOR:
TSIZE : 0x01000000 [ 16.00 MB ]
PSIZE : 0x01000000 [ 16.00 MB ]
STYPE : 0x00000000
FLOTP : DA_NOR_OTP_NOT_SUPPORT
STATUS : OK
Boot done!
FFS Info exists in MAUI : 0x00C40000 : 0x003B4000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:30
Old 01-21-2023, 12:24   #1320 (permalink)
Member: 1524022
Sonork: 100.1608738
Thanks Meter: 51
Operation : Read UserCode [ v1.20 ]
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
Boot Done!
SW_VER : 11.00.17.02
LP_VER : IJ 23QEN79PK00
UserCode : 25815
UserCode : 4488
Done!
Elapsed: 00:00:36
Page generated in 0.37184 seconds with 9 queries
